Need firmware for Danfoss FC302
привода и частотники
Xenonci
Post by Xenonci » Sat Jan 06, 2018 2:03 pm
Hi Guys,
I need to roll back firmware into Danfoss FC302 inverter. Now it is 40.05. I need version 4.38 or earlier.
Where I can find firmware images (files *.ose or *.osx) firmware in Danfoss FC302 using software MCT ?
mohdabshr
Re: Need firmware for Danfoss FC302
Post by mohdabshr » Sun Jan 07, 2018 3:39 am
In MCT use converter to change firmware and download to FC302.
Xenonci
Post by Xenonci » Sun Jan 07, 2018 10:45 am
What is the menu item in the mct 10 for this?
How to download the firmware from the danfoss drive for convert???
mohdabshr
Post by mohdabshr » Sun Jan 07, 2018 1:18 pm
Hi after you opened your project with MCT right click mouse on the project you will see in the menu convert drive.
Xenonci
Post by Xenonci » Tue Jan 09, 2018 10:21 am
Hi
When I try to write to the drive the project from an early version 4.38 it fails with the following message. Version 5.84 does not overwrite. :( :(
mohdabshr
Post by mohdabshr » Tue Jan 09, 2018 11:02 am
Hi in your project you didn't change the voltage to be 380-500 volt and you didn't choose the option A this is reason.
Xenonci
Post by Xenonci » Tue Jan 09, 2018 1:12 pm
I have adjusted the tension and removed the option. Version 4.38 is not rewritten 5.84. Project loaded good, but in paragraph 15.43 are still version software 05.84.
mohdabshr
Post by mohdabshr » Tue Jan 09, 2018 6:05 pm
Hi what is the reason you want to change the firmware of the drive to 4.38.
Xenonci
Post by Xenonci » Wed Jan 10, 2018 3:50 pm
Hi
Because the controller omron CJ1-M not familiar with the danfoss 4.38 above. Error "no connection". Program the controller to change there is no possibility
mohdabshr
Post by mohdabshr » Thu Jan 11, 2018 5:34 pm
Hi my friend I think the firmware not effect the communication between fc302 and plc you must check setting and wiring , what is the communication between fc302 and plc .
Xenonci
Post by Xenonci » Sat Jan 13, 2018 7:35 am
Hi.
When I put outside instead of the frequency Converter Converter firmware 4.38 it works in that place. When I put any other Converter with firmware older than 4.38 - it doesn't work. Meanwhile, they all meet in the fc Protocol when communicating with the laptop.Now I am trying to connect the old inverter VLT5000 FC302 instead.
