Fatek Protected File
[?]: How crack or unlock FATEK PLC password
hi all friends
FATEK plc file is password protection.
How is it crack or look ?
help me please...
best regards
help me please...
best regards
Re: [?]: How crack or unlock FATEK PLC password
i sent u link program of PLC Fatek, which have pass in sub-program. pls help me unlock them.
http://www.mediafire.com/?qi44gk096zd407c
I thank you so much. it's very good.
and Can u description how to do crack?
hi.
plz EXPLAIN how we can do it.
thanks.
thanks.
http://ifolder.ru/20318038
- Forum Community
- Location: We are anonymous users. We do not read your private messages :( Ask questions in the forum !
Hi is it possible to crack password in the main program PLC Model FBE-40MU
Hello, kaga and/or link!
Can You please unlock this Fatek program?
[dead] :/432919315/H ... 101124.rar
Best regards and thanks in advance,
Homeroid
Homeroid
- Forum Community
- Forum Community
To Link and kaga
first at all thank's for the nice proladder version it is perfect, but my problem is a little bigger! Is there any way to export the password and if is possible, if it is encrypted to be exporeted decrypted. That is because I cant go online to the PLC althought after I "skip" the password with your version of the WinProladder
Thanks in advance!
Thanks in advance!
hi Link or kaga and ALL
1, I can go online to the PLC with your version of the WinProladder
http://www.rapidshare.com/files/4370660 ... ENU_CR.rar
2, he want the password. I skip" the password but I cant go online to the PLC
and cant the PLC Program Upload .he Message = (Illegal Password or PLC ID)
3, How is it possible to crack password in the main program PLC Model FBs-20 mct
can anyone please help us to register the plc_password_crack software to reveal the password.
plz EXPLAIN how we can do it the PLC Program Upload .
thnx in advance,
from
Anwer Shahzad
thnx in advance,
from
Anwer Shahzad
To anwer shahzad. Describe in detail the steps as you did and lay out the screenshots.
To anwer shahzad.
Here video as you remove the password from the project, write to the controller and go online. I have no controller and I can `t check.
http://www.rapidshare.com/files/4456234 ... unlock.rar
Make this the same video with your problem.
Good luck!
Good luck!
hi vlad2006gr & ALL
your video is good bat,
1, I can go online to the PLC with version of the WinProladder
plz Explain how we can do it the PLC Program Upload .
thnx in advance,
from
Anwer Shahzad
thnx in advance,
from
Anwer Shahzad
hi guys
can you please help me to my problem i cannot go online to my fatek plc the massege appear on the screen is access reject
thanks
thanks
To Mikel_010201 and anwer shahzad.
I have no FATEK PLC. Record how you connect with FATEK PLC and any error is WinProladder. And give a link to the PM. Then try to help. Example in post viewtopic.php?f=3&t=5035%20#%20p42023. I used Camtasia Studio 6.0.1
Good luck!
Good luck!
https://rapidshare.com/files/461167321/TFT602.pdw
Homeroid
The projecte have been unlocked.tks!
Homeroid
why I can't download the https://www.rapidshare.com/files/773948 ... unlock.rar
?would you upload a copy for me?
Thank you very much .
yours leaf
yours leaf
I have this problem too. the cracked version of winprodladder program can open files with passwords. but when you try to connect to plc and when it asks you the password , here program cannot open it and does not allow to connect to plc. Can any one help me ?vlad2006gr wrote:To anwer shahzad. Describe in detail the steps as you did and lay out the screenshots.
hi all.
i m having same problem with FBs-20MC..
when i attempt to get online the winproladder gives a message,enter password or ID...
I want to modify the existing code but i don't know the passward...please help me..
thanks advance..
thanks advance..
Plz i need this crack could u upload it on an auther server, rapidshare is not working
Hello ,
i downloaded the modded version of the ladder , i can enter in password protected files fine
but i want to know how can i change the project password?
i can easily change the programm id but when trying to do the same with the password says
"ola password not matching"
any help ?
thanks for your time and your great work
any help ?
Hi, all
I have faced with this problem also. I read all comments above.
That seem if I use a modify WinProLadder CR2 program which vlad2006gr post, the program will skip the password authentication.
Do I understand correct?
Last time I link my computer with the FBs-40MC with the original WinProLadder. The password screen always appear when I try to access.
Therefore, I tried the modify WinProLadder CR2 version. But it display the same: no password skipped.
I am a little bit confuse ???
Anyway, my work on this fatek plc is only backup a plc program from old plc to a new one.
Is there anyway to backup the plc program without knowing password protected.
Thank you
Thank you
Hi all,
Please help me unlock this program.I tried with the modified Winprolad but it can not remove the password.
Thanks all.
Thanks all.
Hi vlad2006gr,
Thanks for your help.Can you hint me the way to remove or find the password?I tried to find with 010 Editor but seem to be very hard.
Thanks and regards,
Thanks and regards,
How to break Fatek PLC Password? Is there any software? Plz help me.
Open the project with a password or download from password protected PLC?
If from password protected PLC, only brute force.
Good luck!
Good luck!
Any Body has Fatek plc Key read.............???????????
https://dl.dropboxusercontent.com/u/117 ... esajes.pdw
Cicatral
Cicatral
Thank you very much for the work, already being used.
one more question if you dont mind could you tell me how to do to find the key ?, or tell me what was the key file?
http://www.4shared.com/file/lD0WXGH-ce/123.html
Can you re-upload "WPlad300-12308-ENU_CR.rar"
Can you please unlock the program on thr following link?
http://www.4shared.com/file/O9c8PiK8ba/MBR.html
THANKS in Advance
THANKS in Advance
Thank you very much
If Possible can you upload "WPlad300-12308-ENU_CR.rar"
Thank you very much kaga and/or link!
hello to all
any body can upload "WPlad300-12308-ENU_CR.rar"
I programmed my fatek fbs 32mc plc last year, but I lost the programm because my hard drive failed.
Now I want to download the programm from the plc, but I don't remember the password.
Any idea how to brute force the plc? (so I don't have to write the programm again).
Thank you...
Thank you...
Hi people,
I'm having a problem with Fatek PLC and its program. One part of it is protected by the password. I was checking all the links to download cracked version of WinProLadder but none of them works. Can anyone help me with taking the password from the program out?
Link to the program:
https://www.sendspace.com/file/ggm5tl
best regards
best regards
Password is KONKAC13
http://www.4shared.com/rar/XIVIx_IHba/W ... NU_CR.htmlMorteza Panahi wrote:hello to all
Dear ziconltai: Please share Fatek Unlock software for we..
