Hello everyone!
Well , i have 2 PLC CPU 315 2DP and ET 200M and two station PC all is in net using Profibus , the Problem that i can't see the input output from CPU 315 to other CPU 315 , i can't using a global variable as we can't use the MPI connection
![Exclamation :!:](./images/smilies/icon_exclaim.gif)
how i can to do to see direct Data exchange between Separare DP Systems Via DP communication? i see that all write that it's easy and possible but i can't see one example of that? please Maybe you know documentation about that , thank you
![Smile :)](./images/smilies/icon_smile.gif)
