Vijeo Designer top urgent
omar zedan
Post by omar zedan »
Dear All
I use Vijeo Designer 6.2 to program HMISTU855 touch screen from Schneider but I need the driver of this screen.
I did not find driver in Vijeo Designer 6.2 DVD
Can any one upload the driver of this screen please??
Thanks in advance
apilife
Re: Vijeo Designer top urgent
Post by apilife »
I don't understand which driver you need!
Is it the driver of the USB cable PC<->HMI ? This driver is provided on the DVD! And maybe you already installed it with Vijeo Designer.
But if you try to connect the HMI on your PC with a standard USB cable, this will not work!
You can also download your project by Ethernet or with a USB stick, thus not requiring a driver.
apilife
Post by apilife »
Sorry, I was mistaken about the USB cable, the HMISTU855 document say:
2 USB ports (for downloading the configuration either by a standard USB printer cable or USB memory stick)
But documents mention also a USB data cable named BMX XCA USB H018...
As I don't have this HMI model, I can't try... Maybe someone else will help you now.
omar zedan
Dear apilife
the hmi in windows device manager is unknown (with yellow mark) and also I can not download the project to the hmi screen.
this is what I call it I need device driver of hmi screen.
thanks in advance
