Hello.
I have problem with my EPLAN Fluid 2.2.
I had previously installed EPLAN P8 Electric 1.9 (it's work without any problems), yesterday I installed EPLAN Fluid 2.2.
The program works fine, license is ok, but unfortunately symbol library is empty.
 Can anyone give me a hint where to find a solution?
I downloaded  installation files from this forum.
Other question.
Is it possible to install a library pneumatics and hydraulics to EPLAN P8 Electric end use it on P8?
Thank's for any help.
						[?]: EPLAN Fluid 2.2 - symbol library is empty.
				Bartasek
				dsekulic
Re: [?]: EPLAN Fluid 2.2 - symbol library is empty.
You should define libraries which You want to use in each project. Open project You want to edit. Go on Option->Settings...->Projects->"Project name"->Managemet->Symbol libraries. You can specify desired libraries there by pressing Symbol libraries filed.
regards
regards
