[EXAMPLES] Pump station
примеры программ
gogycro
Post by gogycro » Fri Feb 15, 2013 3:41 pm
Hello everyone,
next month I will write a PLC program for one sewage pump station, does anyone have any examples ?
Best regards,
Goran
Re: [EXAMPLES] Pump station
Post by Dfcz » Mon Feb 18, 2013 2:18 pm
Pumps are different: liquid and gaseous (untranslatable Russian humour).
What is pump about?
gogycro
Post by gogycro » Tue Feb 19, 2013 9:09 am
Pump station has one liquid pump, power 3 kW
Post by Dfcz » Fri Feb 22, 2013 6:19 am
Вот пример:
////////start-stop pomp
A DB15.DBX 15.2 //Bit_ON_pompa (from panel)
AN I 3.0 //Sel_aut_A
O Q 8.7 //OUT_pompa_olio
AN DB15.DBX 15.3 //Bit_OFF_pompa (from panel)
A(
AN I 0.2 //FC_extra_corsa_pistone
O M 244.3 //AUX 4 pompa salEXTRAcors
AN I 5.2 //Termico_pompa
A I 0.5 //Emergenza
= Q 8.7 //OUT_pompa_olio
//emergence stop pomp
A M 245.1 //Bit_disc_pistone_A
AN I 2.6 //Barriere_A
R Q 8.7 //OUT_pompa_olio
//reset emergence stop pomp
A I 0.2 //FC_extra_corsa_pistone
S M 244.3 //AUX 4 pompa salEXTRAcors
A M 244.3 //AUX 4 pompa salEXTRAcors
FR T 62 //T_rit_da_FCexta_pist
L S5T#3S
SD T 62 //T_rit_da_FCexta_pist
R M 244.3 //AUX 4 pompa salEXTRAcors
могу оставить комменты еще по русски
