Request: DPL Toolkit from control techniques
lewis
hello guys
my company has an old machine which use unidrive with UD73 card,and there's program in UD73 Card,
I want to update the driver to unidrive sp series,
and i search on internet that i have to upload the UD73 card program
Could anyone help me?
thanks a lot
thanks a lot
venix
Re: Request: DPL Toolkit from control techniques
You must use SyPT Pro to do that.
I think the best way is to contact the local representive of Control Techniques to buy the software wich comes with the programming cable for SP.
To connect to UD73 I succed with a RS232 cable (not all the time) or with a RS232-RS485 converter.
Best regards,
Venix
Best regards,
Venix
lewis
Venix ,Thanks for your answer,I have upload the program use SyPT Pro with RS232 cable,but there's some warnings in the program.
w1naenator
which protocol need to use?
demicv
I desperately need for a dpl toolkit software to program a ud70 module for uni1401 series inverters. thanks all
vdat_bg
I need DPL Toolkit v3.3.
Can Anybody send to me, please.
I checked on control techniques site, but I didn't find it.
Best regards,
Vasil Atanasov
Best regards,
Vasil Atanasov
Mx_man
I'm new to this forum. I'm currently working on a windmill project. I bought this windmill without the electronics which consist of a telemecanique PLC with 2 Control techniques unidrives.
The software files of the PLC and the Unidrives where included.
I'm now busy building the electronics according to the supplied electrical diagram which was included in the sale.
The only problem or challenge I have now is that in both unidrives an UD70 module must be fitted. finding those modules will be a challenge and programming even more so.
The software that I need is DPL Toolkit as described above. Is some one able to share that with me? It will help me a lot!
I thought all was included in the sale but the software that was included was the installed version on a pc so I'm missing some files so my dpl Toolkit isn't working.
All the help will be much appreciated!
Mx_man
Thanks a lot A12sdd!
JodPLC
I'm in the same situation as the guys above, I need the DPL Toolkit app. Any hint of where it could be found would be very appreciated. Thanks.
Best regards,
Jod
Best regards,
Jod
aerol1nepro
Hi, , I need the DPL Toolkit app. Can you help me? Thanks. Best regards
promupac
I need DPL Toolkit.
It is very difficult to find this program today.
I need DPL Toolkit.
mohdabshr
Olson
Hello
Please, I need DPL TOOLKIT. Can you please reupload the files ?
Thank you in advance.
HadiR1396396
Greetings and Regards
Please guide me
I set up a technique control drive(uni2403) and used the PROFIBUS method to communicate with the S7 300 PLC.
I also used PROMESS software to measure the pressure. Unfortunately, we have to program ud70 and I need the .DPL file.
Is it possible to send the UD70 program file to me?
Please guide me
acer
I need to connect MD29 card. For it Could you send again DPL toolkit software ?
Kindly for your support.
MMMzzz
Hi guys,
I'm desperate, I urgently need the DPL toolkit too.
Can anyone help me?
I would be infinitely grateful
Can anyone help me?
silviudima
Finally I've found this program but I can't connect to the VFD. Inside of the program there are not too many settings. Is there someone who knows what settings must be done in the VFD in order to realize the connection ?
I have a Unidrive SP drive with two cards, I/O and SM-Application, the connection cable is the one recommended by the producer. Using SyptLite and CT-soft the connection between was made immediately.
idadkumara
mohdabshr wrote: Sat Feb 04, 2023 8:10 am Hi
download it from below link it will delete after 7 days:
https://we.tl/t-PEC5S4BRWm
Please send a link again to download this
Thank You
