float keys 09 2005
Micikino
float keys 09 2005
Post by Micikino » Mon Mar 13, 2006 7:38 pm
Hello friends,
I have downloaded zip file named: S7_LongFloatKeySet_09_2005_02
in which there are folder AX NF ZZ with ekb files. There are also folders:
Rental and N Hour and files: FastCopy float keys 09 2005 02.txt and FloatKeys 09 2005 02.IMA. Now in the txt file there is note that is only needed to copy ekb files in C:\AX NF ZZ. When I do that Licence manager don't see that fioles as valid licence keys. I need keys for Step7 v5.3 and PLCSim 5.3
What I need to do?
YDist
Post by YDist » Fri Mar 24, 2006 11:09 am
Install any short key by Siemens.exe.
Siemens.exe create C:\AX NF ZZ with Hidden System attributes.
After this - copy S7PROF0503.EKB (for Step7 5.3 Pro) to this folder by WindowsCommander.
Need use >=ALM 2.0
Rental and Hour keys in this KeySet is for probe only!
Need delete Trial folders **AFMIS from Windows and Windows\System directory
