[Link]: Allen Bradely PLC simulator LogixPro
jinn
Post by jinn » Fri Feb 17, 2006 5:56 am
Dear All,
I hope you will be fine and enjoying learning from this forum, it would be really appreciatable if some one can help me regarding how to simulate Allen Bradely PLCs by writing its software in RS Logix 500, 5000 etc.
I have found one link i.e. LogixPro for PLC5 its demo can be found from www.thelearningpit.com but still not been able to register it coz i have version 1.74 while its crack is for ver 1.6XX.
Kindly expedite.
Regards,
JINN
niila
Post by niila » Sat Oct 07, 2006 5:30 pm
hi friends..
İ find a plc simulator for ab(logixpro 1.61),ready of keygen.. there is directory..but i didn't work.. please help
directory:
Just run install.
As for registering it's a pain.
Do not change the name that is originally there.
open a cmd window
cd\
C:\>cd program file\
C:\Program Files>cd thelearningpit\
C:\Program Files\TheLearningPit\>cd logixpro\
C:\Program Files\TheLearningPit\Logixpro
Make sure you are in the logixpro directory
run "logixpro.exe register"
put the "enh" id from the registartion popup into the keygen
Generate a number and try it.
Link to logixpro1.61:
Link_is_Dead :(/files/25588157/lpro.zip
utuh_garubuk
Post by utuh_garubuk » Sun Oct 08, 2006 4:32 am
Reupload to uploading.com please... :)
niila
Post by niila » Sun Oct 08, 2006 8:34 am
hi utuh_garubuk..
I connecting single directional with satellite to net..so not upload only download ..sorry.. :oops: also, this link is working..
thanx..
best regards...
james_dias
LogixPro Simulation
Post by james_dias » Thu Oct 19, 2006 1:44 pm
I try to uso de Keygen but in all the tentative the software sed me same message:
[code]invalid key or user name[/code]
Do you have anoder option for I use ?
plcfever
Post by plcfever » Thu Oct 19, 2006 2:13 pm
I think you used a different name than the one on the keygen.
Don't change that.
Just enter the "enh" code and generate the key.
niila
Post by niila » Fri Oct 20, 2006 8:44 am
hi plcfever..
I tryed all of ıt.. but ıt wasn't crack..
best regards...
james_dias
LogixPro
Post by james_dias » Wed Oct 25, 2006 11:17 pm
In the Keygen do you have this spaces for insert information: user name ( this space came me whit name "dt2004") and hwid .
Where i need insert this code "enh"?
Thank's for help me .
I'm if have erros in the mensage, because my english is not to good.
niila
Post by niila » Sun Nov 19, 2006 9:51 am
hi friends..
I cracked fınally to logixpro..statement is spanish but no problem
http://www.oxedion.de/index.php/downloa ... b64c43a78a
