[?]: Unprotect Schneider PL7-Pro DFBs
другие контроллеры
SE_support
Re: [?]: Unprotect Schneider PL7-Pro DFBs
Post by SE_support » Thu Mar 08, 2018 8:30 am
Привет Vlad,
с помощью какого пароля я смогу сменить пароль на секции в данном проекте?
https://www.file-upload.net/download-13 ... pt.7z.html
Спасибо.
franzferdinand
Post by franzferdinand » Wed Mar 14, 2018 12:08 pm
привет, Влад!
вижу, как ты активно помогаешь коллегам, за что тебе огромный респект и благодарность.
но хотелось бы самому уметь убирать пароли с проектов. внимательно изучил первую страницу темы, даже что-то пробую сделать, но никак :(
вероятно если обновить "потухшие" скриншоты с первой страницы, то дело стронется с мертвой точки..
sunshine
Post by sunshine » Tue Apr 10, 2018 1:54 pm
hello Vlad,
please can you found the password of this projects, many thanks
https://mon-partage.fr/f/vCInUa1V/
https://mon-partage.fr/f/WRtbgLWX/
https://mon-partage.fr/f/TVRAq5Ed/
nene
Post by nene » Tue Apr 10, 2018 5:50 pm
Hello Vlad i hope you doing great!!
please i need your help to find a password for DFBs
https://drive.google.com/file/d/1546-Ka ... sp=sharing
SE_support
Post by SE_support » Wed Apr 11, 2018 3:00 pm
nene wrote:Hello Vlad i hope you doing great!!
Hi nene, the DFB pass and app pass are the same: !M@rch?
Good luck!
SE_support
Post by SE_support » Wed Apr 11, 2018 3:26 pm
sunshine wrote:hello Vlad,
Hello sunshine, please check following info.
app pass: aeg2-kiabi
dfb pass: aeg2-kia
Best regards
simbamike
Post by simbamike » Tue May 29, 2018 11:27 am
Hello All
Please help unprotect DFBs!
Exported project .ZEF from Unity Pro 11.0
Many thanks!
https://drive.google.com/drive/folders/ ... sp=sharing
vlad2006gr
Post by vlad2006gr » Wed May 30, 2018 5:21 am
simbamike wrote:Please help unprotect DFBs!
See PM
geyikgokhan
Post by geyikgokhan » Mon Jun 11, 2018 1:38 pm
This program routines are locked. Please help me for it.
https://drive.google.com/open?id=15w8iF ... xRAFPMrLhZ
vlad2006gr
Post by vlad2006gr » Tue Jun 12, 2018 7:48 am
geyikgokhan wrote:This program routines are locked.
see PM
geyikgokhan
Post by geyikgokhan » Tue Jun 12, 2018 10:21 pm
Hello Vlad,
Thanks for Support
cyberb
Post by cyberb » Wed Jun 27, 2018 6:39 pm
Hello Vlad
Would be grateful if you could unlock or provide the passwords for the locked DFBs in https://we.tl/xYBZaeijAZ
Thanks in advance.
vlad2006gr
Post by vlad2006gr » Sun Jul 01, 2018 5:55 am
cyberb wrote:Would be grateful if you could unlock or provide the passwords for the locked DFBs
See PM
StudAsu
Post by StudAsu » Mon Jul 30, 2018 5:10 am
Здравствуйте уважаемые эксперты!!!
Проблема у меня, помогите решить, достались проекты на юните, а с ней я не так много работал как хотелось бы, а еще они и запаролены
https://drive.google.com/open?id=1QhTUi ... fcwCmrbwAj
ссылка на проект. И если я правильно понял то в свойствах проекта если очистить пароль то проект станет мне доступным?
vlad2006gr
Post by vlad2006gr » Tue Jul 31, 2018 5:52 am
StudAsu wrote:Здравствуйте уважаемые эксперты!!!
Смотрите ПМ
sd-electro
Post by sd-electro » Thu Aug 02, 2018 11:39 am
Hi Vlad,
Can you look for the password of this project?
Edit: http://www.dumo-technics.be/proj/projcpi.stu
StudAsu
Post by StudAsu » Thu Aug 02, 2018 1:10 pm
Смотрите ПМ
Я прошу прощение за глупый вопрос но раздел Derived FB Type остался закрытым, можно ли как то и его открыть?
http://prntscr.com/kdtprm
vlad2006gr
Post by vlad2006gr » Thu Aug 02, 2018 8:12 pm
StudAsu wrote:Я прошу прощение за глупый вопрос но раздел Derived FB Type остался закрытым
Щелкаете по DFB, открывается Data Editor. В нем ставите стрелку на DFB и правой клавишей мышки выбираете Data Properties. У вас появляется отдельное окно для этого блока Data Properties., в нем выбираете Protecnion. В выпадающем списке ставите None и вводите пароль. Пароль на проект и на блоки один и тот-же.
vlad2006gr
Post by vlad2006gr » Thu Aug 02, 2018 8:25 pm
sd-electro wrote:Can you look for the password of this project?
See PM.
sd-electro
Post by sd-electro » Sat Aug 04, 2018 5:00 am
Thank you!
xcyong89
Post by xcyong89 » Sat Sep 22, 2018 4:42 pm
Hi, appreciate that if somebody can help to unlock password for all DFB from the project below:
https://drive.google.com/file/d/1HwjVKF ... sp=sharing
vlad2006gr
Post by vlad2006gr » Sun Sep 23, 2018 6:58 pm
xcyong89 wrote:Hi, appreciate that if somebody can help to unlock password for all DFB from the project below:
the project is needed in the format of sta, zif. Or it must be compiled.
xcyong89
Post by xcyong89 » Sun Sep 23, 2018 10:32 pm
Noted. Please find the .sta file from the link below:
https://drive.google.com/file/d/1iCU1TG ... sp=sharing
vlad2006gr
Post by vlad2006gr » Mon Sep 24, 2018 8:50 am
xcyong89 wrote:Noted. Please find the .sta file from the link below:
see PM
xcyong89
Post by xcyong89 » Mon Sep 24, 2018 1:08 pm
Hi, vlad2006gr, the password are worked. Thanks for your great effort
rqcimperium
Post by rqcimperium » Thu Nov 01, 2018 6:24 pm
Hi vlad2006gr
Can you help me with this? https://drive.google.com/open?id=1o5thF ... XdxfTjVL26
rosco87
Post by rosco87 » Sat Nov 03, 2018 1:13 pm
rqcimperium wrote:Hi vlad2006gr
password : melgar1962
rqcimperium
Post by rqcimperium » Sat Nov 03, 2018 5:47 pm
Thanks !!! Works fine
theo26220
Post by theo26220 » Tue Dec 04, 2018 7:36 am
Hi vlad2006gr
Can you help me with this? https://drive.google.com/open?id=1Mi4cp ... SwCIGeUjf5
thanks you much
SE_support
Post by SE_support » Wed Dec 05, 2018 8:55 am
theo26220 wrote:Hi vlad2006gr
thanks you much
Hi theo26200,
see PM
theo26220
Post by theo26220 » Wed Dec 05, 2018 3:18 pm
Thanks you !!
Other question, possible unlock somachine project ??
Thank’s
vlad2006gr
Post by vlad2006gr » Wed Dec 05, 2018 6:54 pm
theo26220 wrote:Other question, possible unlock somachine project ??
Upload project. Then we'll see.
theo26220
Post by theo26220 » Fri Dec 07, 2018 5:30 pm
hi,
link for somachine project : https://drive.google.com/open?id=1Ckdmc ... EvKk8pdpF3
thank's much
theo26220
Post by theo26220 » Mon Dec 17, 2018 10:54 am
Hi vlad2006gr,
Did you find a solution?
Thank you
xcyong89
Post by xcyong89 » Wed Jan 09, 2019 1:27 am
hi vlad2006gr,
Appreciate that if you can help to unlock the unity pro file below:
https://drive.google.com/file/d/1g2LmQW ... sp=sharing
omega1024
Post by omega1024 » Fri Jan 11, 2019 11:00 am
theo26220 wrote:hi vlad2006gr,
Hello
Password is MU3344
Best regards
xcyong89
Post by xcyong89 » Sun Jan 13, 2019 1:51 am
Hello
Password is MU3344
Best regards
it is worked. Thank alot for ur help
vlad2006gr
Post by vlad2006gr » Sun Jan 13, 2019 3:52 pm
theo26220 wrote:link for somachine project
Unfortunately, at this time it is difficult for you to help. The work algorithm is clear, but it is not yet possible to decrypt it.
Sorry.
theo26220
Post by theo26220 » Mon Jan 14, 2019 9:09 pm
Hi Vlad
Thank you very much for your help
In any case thank you for trying to keep me Informed
If you got there ..
Thank
Unimaks
Post by Unimaks » Wed Apr 10, 2019 3:28 pm
Добрый день Vlad,
помоги пожалуйста подобрать пароль на секции в данном проекте:
https://yadi.sk/d/FXt0UP6NgNZPBA
Заранее спасибо!
vlad2006gr
Post by vlad2006gr » Wed Apr 10, 2019 7:17 pm
Добрый день
Смотри ПМ
Sebator_79
Post by Sebator_79 » Thu Apr 18, 2019 2:57 pm
Please help me with this.
https://drive.google.com/open?id=1EG2Jn ... 2A-KRPPpEi
Best Regards
vlad2006gr
Post by vlad2006gr » Fri Apr 19, 2019 6:20 am
See PM
Sebator_79
Post by Sebator_79 » Fri Apr 19, 2019 6:30 am
Thank You Vlad
You are The Best :)
celikkadir
Post by celikkadir » Sun May 19, 2019 12:46 pm
Hi Vlad we need your help, the project is attached. Derived FB Types are locked, please help.
https://wetransfer.com/downloads/479b9b ... 114/62ac1c
Thanks. (tyou)
vlad2006gr
Post by vlad2006gr » Tue May 21, 2019 6:55 am
see PM
Alessandraadkl
Post by Alessandraadkl » Thu May 23, 2019 7:55 pm
https://wetransfer.com/downloads/53b5a2 ... ient_email
vlad2006gr
Post by vlad2006gr » Fri May 24, 2019 7:04 am
see PM
alfred88
Post by alfred88 » Fri May 31, 2019 1:41 pm
Hello Vlad,
I need some help, I have an old project in Concept that its password secure.
https://drive.google.com/open?id=1a8lRv ... diOuI3cYMC
Thanks in advance.
(tyou)
Imanu
Post by Imanu » Mon Jun 17, 2019 11:46 am
Hello vlad2006gr,
Can you help me unlock DFB's and all the stuff on this unity pro proyect?
Thanks in advance!!!!!!!!
