It is currently Thu Jan 24, 2019 4:03 pm
Post new topic Reply to topic  [ 239 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Thu Mar 08, 2018 11:30 am
Привет Vlad,
с помощью какого пароля я смогу сменить пароль на секции в данном проекте?
https://www.file-upload.net/download-13 ... pt.7z.html
Спасибо.
PostPosted: Wed Mar 14, 2018 3:08 pm
привет, Влад!
вижу, как ты активно помогаешь коллегам, за что тебе огромный респект и благодарность.
но хотелось бы самому уметь убирать пароли с проектов. внимательно изучил первую страницу темы, даже что-то пробую сделать, но никак :(
вероятно если обновить "потухшие" скриншоты с первой страницы, то дело стронется с мертвой точки..
PostPosted: Tue Apr 10, 2018 4:54 pm
hello Vlad,
please can you found the password of this projects, many thanks
https://mon-partage.fr/f/vCInUa1V/
https://mon-partage.fr/f/WRtbgLWX/
https://mon-partage.fr/f/TVRAq5Ed/
PostPosted: Tue Apr 10, 2018 8:50 pm
Hello Vlad i hope you doing great!!
please i need your help to find a password for DFBs
https://drive.google.com/file/d/1546-Ka ... sp=sharing
PostPosted: Wed Apr 11, 2018 6:00 pm
Hi nene, the DFB pass and app pass are the same: !M@rch?
Good luck!
PostPosted: Wed Apr 11, 2018 6:26 pm
sunshine wrote:
hello Vlad,
Hello sunshine, please check following info.
app pass: aeg2-kiabi
dfb pass: aeg2-kia
Best regards
PostPosted: Tue May 29, 2018 2:27 pm
Hello All
Please help unprotect DFBs!
Exported project .ZEF from Unity Pro 11.0
Many thanks!
PostPosted: Wed May 30, 2018 8:21 am
See PM
PostPosted: Mon Jun 11, 2018 4:38 pm
This program routines are locked. Please help me for it.
https://drive.google.com/open?id=15w8iF ... xRAFPMrLhZ
PostPosted: Tue Jun 12, 2018 10:48 am
see PM
PostPosted: Wed Jun 13, 2018 1:21 am
Hello Vlad,
Thanks for Support
PostPosted: Wed Jun 27, 2018 9:39 pm
Hello Vlad
Would be grateful if you could unlock or provide the passwords for the locked DFBs in https://we.tl/xYBZaeijAZ
Thanks in advance.
PostPosted: Sun Jul 01, 2018 8:55 am
See PM
PostPosted: Mon Jul 30, 2018 8:10 am
Здравствуйте уважаемые эксперты!!!
Проблема у меня, помогите решить, достались проекты на юните, а с ней я не так много работал как хотелось бы, а еще они и запаролены
https://drive.google.com/open?id=1QhTUi ... fcwCmrbwAj
ссылка на проект. И если я правильно понял то в свойствах проекта если очистить пароль то проект станет мне доступным?
PostPosted: Tue Jul 31, 2018 8:52 am
Смотрите ПМ
PostPosted: Thu Aug 02, 2018 2:39 pm
Hi Vlad,
Can you look for the password of this project?
Edit: http://www.dumo-technics.be/proj/projcpi.stu
PostPosted: Thu Aug 02, 2018 4:10 pm
vlad2006gr wrote:
Смотрите ПМ
Я прошу прощение за глупый вопрос но раздел Derived FB Type остался закрытым, можно ли как то и его открыть?
http://prntscr.com/kdtprm
PostPosted: Thu Aug 02, 2018 11:12 pm
Щелкаете по DFB, открывается Data Editor. В нем ставите стрелку на DFB и правой клавишей мышки выбираете Data Properties. У вас появляется отдельное окно для этого блока Data Properties., в нем выбираете Protecnion. В выпадающем списке ставите None и вводите пароль. Пароль на проект и на блоки один и тот-же.
PostPosted: Thu Aug 02, 2018 11:25 pm
See PM.
PostPosted: Sat Aug 04, 2018 8:00 am
Thank you!
PostPosted: Sat Sep 22, 2018 7:42 pm
Hi, appreciate that if somebody can help to unlock password for all DFB from the project below:
https://drive.google.com/file/d/1HwjVKF ... sp=sharing
PostPosted: Sun Sep 23, 2018 9:58 pm
the project is needed in the format of sta, zif. Or it must be compiled.
PostPosted: Mon Sep 24, 2018 1:32 am
Noted. Please find the .sta file from the link below:
https://drive.google.com/file/d/1iCU1TG ... sp=sharing
PostPosted: Mon Sep 24, 2018 11:50 am
see PM
PostPosted: Mon Sep 24, 2018 4:08 pm
Hi, vlad2006gr, the password are worked. Thanks for your great effort
PostPosted: Thu Nov 01, 2018 9:24 pm
Hi vlad2006gr
Can you help me with this? https://drive.google.com/open?id=1o5thF ... XdxfTjVL26
PostPosted: Sat Nov 03, 2018 4:13 pm
rqcimperium wrote:
Hi vlad2006gr
password : melgar1962
PostPosted: Sat Nov 03, 2018 8:47 pm
Thanks !!! Works fine
PostPosted: Tue Dec 04, 2018 10:36 am
Hi vlad2006gr
Can you help me with this? https://drive.google.com/open?id=1Mi4cp ... SwCIGeUjf5
thanks you much
PostPosted: Wed Dec 05, 2018 11:55 am
theo26220 wrote:
Hi vlad2006gr
thanks you much
Hi theo26200,
see PM
PostPosted: Wed Dec 05, 2018 6:18 pm
Thanks you !!
Other question, possible unlock somachine project ??
Thank’s
PostPosted: Wed Dec 05, 2018 9:54 pm
Upload project. Then we'll see.
PostPosted: Fri Dec 07, 2018 8:30 pm
hi,
link for somachine project : https://drive.google.com/open?id=1Ckdmc ... EvKk8pdpF3
thank's much
PostPosted: Mon Dec 17, 2018 1:54 pm
Hi vlad2006gr,
Did you find a solution?
PostPosted: Wed Jan 09, 2019 4:27 am
hi vlad2006gr,
Appreciate that if you can help to unlock the unity pro file below:
https://drive.google.com/file/d/1g2LmQW ... sp=sharing
PostPosted: Fri Jan 11, 2019 2:00 pm
theo26220 wrote:
hi vlad2006gr,
Hello
Password is MU3344
Best regards
PostPosted: Sun Jan 13, 2019 4:51 am
omega1024 wrote:
theo26220 wrote:
hi vlad2006gr,
Hello
Password is MU3344
Best regards
it is worked. Thank alot for ur help
PostPosted: Sun Jan 13, 2019 6:52 pm
Unfortunately, at this time it is difficult for you to help. The work algorithm is clear, but it is not yet possible to decrypt it.
Sorry.
PostPosted: Tue Jan 15, 2019 12:09 am
Hi Vlad
Thank you very much for your help
In any case thank you for trying to keep me Informed
If you got there ..
Thank
Users browsing this forum: Google [Bot] and 7 guests
