[?+]: emulator for Spac2009
Тools, Elcad, Eplan, ...
Link
Forum Community
Forum Community
Post by Link »
I have the dump and sys file of working key for spac 2009
Who Help Me to create emulator?
Tank You
DMP and SYS
[dead] :/217239044/Spa.rar
SPAC 2009
http://www.sdproget.it/software/SPAC_Au ... 2009_8.zip
PLEASE HELP ME
Link
Forum Community
Forum Community
Re: [?]: Who Help Me to create emulator for Spac2009?
Post by Link »
Your dump is encrypted.
Use eu_pbl.exe tool and post correct dump
I have created new dump with eu_pbl.exe.
[dead] :/321107692/FGZaaaa.rar
Tank You
guy426
Re: [?+]: emulator for Spac2009
Post by guy426 »
I cannot try, but i think it works:
key_spac.rar
[dead] :/321530408/key_spac.rar
or
http://narod.ru/disk/16626485000/key_spac.rar.html
most
Post by most »
guy426 wrote:I cannot try, but i think it works:
installation full does not function because it needs one serial number...
trial installation also does not function because in the end it asks for the activação code
the cr@ck that you made seems to function well but the codes do not work (?)
can you help ?
(perhaps the maverik53 has the serial number)
this is the report of the generated license:
Unique identifier: 6097A573
Key type: PR - Port: LPT (1) - Memory: 64 byte
Serial no: 5139168134
Automazione product versions authorized by the key
version platform
2009 Autodesk OEM Engine
2008 Autodesk OEM Engine
No expiry
Modules included in product Automazione
module version
Traduttore 2008 (1 licenze)
Traduttore 2009 (1 licenze)
Spac FULL 2008 (1 licenze)
Spac FULL 2009 (1 licenze)
______________________________________________________________
thanks
best regards
most
parappapa
Post by parappapa »
emulator works great with internal program test32.exe but when i install the program with full installation required a serial number
i try my original serial number but is different and give me an error :(
can you post a working serial number for spac 2009 ? :mrgreen:
thx
most
Post by most »
GuJack20 wrote:Guys. Happy new year to you all
...have any solution
the installation of spac originates a code in each computer.
the necessary serial number is dependent of this generated code.
the emulator functions well but only in the computer of where dump was taken off
is necessary one keygen, perhaps somebody make it :?: :?
guy426
Post by guy426 »
GuJack20 wrote:thanks guys
i can confirm that the emulator works fine even with the SPAC2008, but the serial number is still required :(
Here is working code generator.....
spac2009_keygen.exe
[dead] :/331700979/spac2009_keygen.exe
or http://narod.ru/disk/16665391000/spac2009_keygen.exe.html
GuJack20
Post by GuJack20 »
Thanks guy426 for the keygen.
The keygen does not contain a virus. Its a false alarm..
I only have spac2008, so i will need to download the 2009 version to try the keygen.
GuJack20
Post by GuJack20 »
xblu wrote:can u tell me how keygen work? where can i pick the number to insert in register code? thanks for answer
xblu, when you try to install the full version of Spac, look at the window that pops up after the hardware driver install, in the last sentence you have a code, that code must be insterted in the keygen for it to calculate the correct serial..
most
Post by most »
djto wrote: my laptop not has the parallel port
I do not have experience in this case :oops:
perhaps with a emulator LPT, if to exist... or card PCMCIA :?:
guy426
Post by guy426 »
Second msgbox is wrong:
Demo code is CAD code....
GuJack20
Post by GuJack20 »
Guy426... thanks for everything man.
Everything works fine
Nice job.
What if the computer doesn't have a LPT port?? Can't we crate a virtual one??
djcatalyst
Post by djcatalyst »
HELP PLEASE!
Oh, ive tried to install . something wrong happens :cry:
1. start install shield wizard the spac 2009 : I chose full installation
2. next window : i chose local LPT hardwere key (par elel port) , i presset next then i had a window with message: to complete he hardkare key configuration insert the LPT key now then press ok.
Where i can find that key? , how to create ? where to insert ? what means "paralel port"?
how to use the dump file?
so i stand in position that i cant even get to code to insert to keygen that posted here .
3. Then i tried "MiniSPAC" option because i heve installed Autocad electrical , so then the miniSPAC installed with no problems . But when ive started the program there came small window wth requeat code
to active the program. the request code was : "9u0i3k a3xme2 0m2j0a" . so ive thinking may be i will to insert this code to the posted keygen to get activation code but when ive tried i get message: "the number must be muximum 12 digits"
what can i do to active it
can some one write the currect way of actions to install this program?
thanks alot.
GuJack20
Post by GuJack20 »
djcatalyst wrote:HELP PLEASE!
thanks alot.
i don't want to be rude, but djcatalyst, are you sure you don't know what a paralel port is??
It's the LPT port, printer port of your computer. Normally Spac 2009 needs a dongle: http://en.wikipedia.org/wiki/Dongle.
To make Spac think that you inserted the dongle the guys here made the emulator posted in the previous posts. Just open and execute it.
xblu
Post by xblu »
thank gujack20 and guy24 too,
but i need one more little help,
have i to install the complete version or 30 days trial?
thanks very much
xblu
GuJack20
Post by GuJack20 »
The complete version.
1. With the emulator, fake the dongle
2. With the keygenerator, generate dhe registration code from the install code
3. Enjoy the full version
Greetings go to guy426
xblu
Post by xblu »
Thank you GuJack20
another problem, my pc haven't parallel door, function same?
GuJack20
Post by GuJack20 »
That is to be seen. I don't know if the setup of SPAC lets you continue without a real LPT port. The emulator instead should function as it does just that, an emulation.
I don't have a Mobo without LPT handly so it's your turn to test and let us know, this way i can inform my many italian friends that asked this same question :)
xblu
Post by xblu »
Hi GuJack20, While I am installing spac 2009, all of a sudden it tells me to insert the key in hands her parallel, I make ok but it doesn't find her/it to me, I repeat you my pc it is not endowed with parallel door, only of doors USB from the resolve us the probema.....
are ah also me Italian, you of where you are???
Hi and thanks for the disponibilitò
GuJack20
Post by GuJack20 »
xblu wrote:Hi GuJack20, While I am installing spac 2009, all of a sudden it tells me to insert the key in hands her parallel, I make ok but it doesn't find her/it to me, I repeat you my pc it is not endowed with parallel door, only of doors USB from the resolve us the probema.....
Albanese. :)
I don't think if it is permitted to write in italian here...if yes i will be more than glad to try to help you, writing in your native language :) sara un piacere.
Anyway, did you install the emulator?? In the archive of the emulator there is also a leggimi.txt, that's in italian, did you follow the instructions there??
Let me know..
xblu
Post by xblu »
Ciao GuJack20
Provo a scriverti in italiano,
Ti stavo dicendo che mentre stò installando spac 2009, dopo avere intallato l'emulatore, si apre una finestra che dice di inserire la chiave hardware nelle porta parallela digito ok per almeno 3 o 4 volte ma niente non la trova, che posso fare? ti prego aiutami ciao e grazie... ti leggerò domani, ciao e buona notte :roll:
GuJack20
Post by GuJack20 »
Capisco
Hai installato l'emulatore?
Lo puoi scaricare da:
or
djcatalyst
GuJack20 ; thanx alot for explanation about paralel port , but i still dont get how i make "dongle emulator" ? to emulate the paralel port or to emulate the key on paralel port?
if i have this port or USB , how i use thoes files : eutron.dmp, eutron.sys ?
THANKS AGAIN
GuJack20
Post by GuJack20 »
Djcatalyst...inside the archive of the emulator you have install.bat, just execute it..
The emulator is used to emulate the key on the parallel port, as i have written before, i think it should work in a system without physical parallel port, but i don't have such system here to test.
Post here the information from the install.bat window if you still can't install SPAC.
djcatalyst
thanks alot GuJack20.
i made that , it works ... but this program more difficult then autocad electrical :(
xblu
Post by xblu »
Ciao GuJack20,
Ma non esiste in rete qualche software che emula una porta LPT Virtuale?
Grazie sei un amico
GuJack20
Post by GuJack20 »
Ciao xblu.
In windowsXP puoi aggiungere manualmente una porta ECP: Pannello Di controlo -> Aggiungi Nuovo Hardware
Prova se risolve il problema
xblu
Post by xblu »
Ok GuJack20 ti farò sapere, ora sto reinstallando il sistema operativo.
Ciao e grazie di tutto
GuJack20
Post by GuJack20 »
Thanks djto for this useful post.
Please can you try to install a ECP port in your laptop through Control Panel -> Add new hardware ??
I really don't think that a REAL parallel port is required...at least i hope that.
Many thanks
GuJack20
Post by GuJack20 »
GREAT!!! I knew it :):):)
Sincerely, i didn't knew it, i just hoped it would work :) :)
Thanks djto
xblu
Post by xblu »
Ciao GuJaCK20 e djto
OK works for me,
Thank you all for the 'aid
OK funziona anche a me,
Grazie a tutti per l' aiuto
bkrk
Post by bkrk »
i have try so hard to install on my notebook that haven't parallel port, until i have decide to buy a usb to parallel adapter. But it don't work because it don't create a parallel port into windows peripherials until you attach phisically a printer. So, i have an idea, naturally the most simply.... :evil: :
1. add a new parallel ecp trought add new hardware(panel control link)
in the windows related peripherial i see the yellows bang, the same problem that i have all time that i try this method..., The ecp port don't start because doesn't phisically exist, so:
2. go to the ecp port, in windows peripherial, select properties->resource and set manually i/o irq dma with the default value that you see in the form.
3. restart
4. install full spac, it install eutron driver
5.launch install.bat( you can find in to key.rar)
6. select ltp hardare key from spac installer
7. use keygen with the number that spac tell you for kay generation
8.complete installation
By bye
Italian wrote:Non comprate un adattatore usb parallelo come ho provato a fare io.....
Se non avete la parallela aggiungetela da nuovo hardware e se andando in gestione periferiche ha il punto esclamativo giallo come è successo a me, andate nelle propietà scegliete risorse e impostate manualmente le risorse che vi propone windows per ogni voce.
Riavvio installa spac full quando ha finito di installare i driver lanciate install.bat date avanti a spac usate il keygen per creare il codice di attivazione usando quello che spac vi dà come codice di richiesta.
Ciao
emmeci85
Post by emmeci85 »
Thank you!
everything worked perfectly!
do you work with the version 2010 ?
Italian wrote:Grazie!
funziona tutto perfettamente!
secondo voi funziona con la versione 2010?
Ciao
M.C.
Link
Forum Community
Forum Community
Post by Link »
You can download it from here:
_w++.sdproget.it/software/SPAC_Automazione/Download_File/DVD_SPAC_Automazione_2009_10.zip_
Ciao
Mesner74
Post by Mesner74 »
on this page you can download Spac 2010
http://www.sdproget.it/Download/IsoImag ... one%202010
Can someone kindly create dump files for the new version?
thanks (tyou)
xblu
Post by xblu »
please maverik create dump file for spac2010
Please guy426 create emulator for spac2010
Thank you
maluedo
Post by maluedo »
Hi all,
some1 can share Spac Impianti, with Caneco?
Cheers
Wolf81
Post by Wolf81 »
Does someone know if this emulator work even on Windows 7 and, if yes, how to get it working?
I have tried but still have some problems, while everything goes fine with XP, but unfortunally I have W7 in the machine when I need SPAC :(
xblu
Post by xblu »
Ehi! Most help me tank you
mauronicola
Post by mauronicola »
trial and minispac installation also does not function because in the first run asks for the activation code.
I load keygen program but the required number is max 12 digit, my request code is 18 plus 2 space.
The keygen end whit error.
Can help me if possible. and sorry for my bad english.
Mauro
mauronicola
djto wrote:keygen for spac 2009 is not compatible with minispac
djto
All ok
Many thaks
Mauro
xblu
Post by xblu »
Hello to everybody,
I need an information, whi some progams for electrical diagram (eplan), every release are unprotected while spac automazione isn't ?
maybe because have a special protection?
Thanks to everybody
zagor
Post by zagor »
hi to everybody, is there anyone that tried to do the Spac installation on a vmware virtual machine (Xp os)? When i try to install Spac appears a message like "operative system not recognized, only wxp, vista... are admitted"....
Massimilian
Post by Massimilian »
hello,
keygen to generate serial of spac automazione cad 2009?
