Please upload SIMATIC MicroComputing
Thanks !!
[reLINK]: SIMATIC MicroComputing
This is from Computing documentation:
To access an S7 system on an MPI or PROFIBUS network, use the formula
wcS7=xx,a,b
where xx is the node (MPI or DP) address
a is the rack number
b is the slot number
(The longer legacy string S7DosIntfMPI=x,a,b is also supported.)
Note that:
- The node address is always decimal.
- The rack number is 0 to 7 decimal.
- The slot number is 0 to 31 decimal.
Regards...
wcS7=xx,a,b
Note that:
Regards...
Computing V3.0 SP2 Link
Hi Mate,
Download it from siemens website.
http://support.automation.siemens.com/W ... n/12666256
SIMATIC Computing V3.0 incl. SP2
https://support.automation.siemens.com/ ... 30_SP2.exe
( 60614 KB )
This version 3.0 SP2 can talk to all PLCs (200/300/ and 400) and it is easy to integrate in VS6.0 and VS2005/08 and also Labview.
connect as zxcslo described.
Regards
( 60614 KB )
Regards
