[?]: WINCC key A9WTG60602?
Hi friends i install all keys about wincc with EKB_Install
but i can not find A9WTG60602 licence ???
how can i find it????
Re: [?]: WINCC key A9WTG60602?
Short keyname use only 8 chars.knetknet wrote:Hi friends i install all keys about wincc with EKB_Install
A9WTG60602 have 9 chars
You are spy
Specify all the details when asking questions.knetknet wrote:it is a mismatching???yeah i am spy:D
It compels us to apply the methods that apply to unleash the tongue of the spy
Russian wrote:Указывайте все подробности, когда задаёте вопросы.
Не заставляйте нас применять методы, которые применяют для развязывания языка у шпиона
Notknetknet wrote:SIFLA9WTG60602 is the licence key is it ok??
try Find key button with A9WTG
Show me screen copykorceguitar wrote:i have the same problem like knetknet's problem...
i try all of way but i couldn't find the key
If i start wincc v7.0, the screen give me as follows:
License Name: A9WTG60602
License Description: WinCC Option Archive
Used By: Runtime+Miscellaneous
i am waiting for your help...
You read the EKB_Install help ?
English > Problems > Problems with WinCC Archive v6.2
Simple example with 513 archives tags - fot testing Runtime.korceguitar wrote:i try your way but it didn't accept again.
i attached 2 pictures of problem.
if i press runtime button, first picture opens.
Then i press details button, second picture opens.
http://plcforum.uz.ua//T ... 512Atg.rar
Blank screen but with big tag table.
without SIFCYWTG* show
or
with SIFCYWTG06* work without problems (WinCC v6.2 and v7.0)
C:\Program Files\Siemens\WinCC\Diagnose\License.Log
03/25/2009 00:00:26 InitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WRC40700 | Text of License = WinCC RC (65536) | Relevant Limit = 0000065536 |
03/25/2009 00:00:26 InitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | NameForMessageBox = | Name of License = SIFLA9WRC40700 | Text of License = WinCC RC (65536) | Relevant Limit = 0000065536 |
03/25/2009 00:00:35 InitLicense ED | AppName = AppEd:TlgCS | CycleCheck = own | NameForMessageBox = | Name of License = SIFLA9WRC40700 | Text of License = WinCC RC (65536) | Relevant Limit = 0000065536 |
03/25/2009 00:00:36 InitLicense CS | AppName = AppCS:TlgEd | CycleCheck = yes | NameForMessageBox = | Name of License = SIFCY9WTGX06021 | Text of License = WINCC Arch (1500) | Relevant Limit = 0000001500 |
03/25/2009 00:01:00 ExitLicense ED | AppName = AppEd:TlgCS | CycleCheck = own | Name of License = SIFLA9WRC40700 | Text of License = WinCC RC (65536) |
03/25/2009 00:01:00 ExitLicense CS | AppName = AppCS:TlgEd | CycleCheck = yes | Name of License = SIFCY9WTGX06021 | Text of License = WINCC Arch (1500) |
03/25/2009 00:01:07 InitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WRC40700 | Text of License = WinCC RC (65536) | Relevant Limit = 0000065536 |
03/25/2009 00:01:07 InitLicense RT | AppName = AppRT:Mcp_Server | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WSEC0700 | Text of License = WinCC Server |
03/25/2009 00:01:08 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = SIFCY9WTGX06021 | Text of License = WINCC Arch (1500) | Relevant Limit = 0000001500 |
03/25/2009 00:02:42 ExitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | Name of License = SIFLA9WRC40700 | Text of License = WinCC RC (65536) |
03/25/2009 00:02:42 ExitLicense RT | AppName = AppRT:Mcp_Server | CycleCheck = yes | Name of License = SIFLA9WSEC0700 | Text of License = WinCC Server |
03/25/2009 00:02:42 ExitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | Name of License = SIFCY9WTGX06021 | Text of License = WINCC Arch (1500) |
03/25/2009 00:02:46 ExitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | Name of License = SIFLA9WRC40700 | Text of License = WinCC RC (65536) |
03/25/2009 00:02:46 ExitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | Name of License = SIFLA9WRC40700 | Text of License = WinCC RC (65536) |
1. your example (with more 512 archives tags) - Rapidshare link or e-mail
2. Authoinformation.inf
3. ScreenCopy of ALM with installed keys
Russian wrote:Простой пример с 513 архивными тэгами.
Чистый проект с набитой таблицей тэгов.
Без ключа SIFCY9WTGX* вылазит сообщение о превышении 512 тэгов.
Сообщения именно такие.
Поэтому мне непонятно приведённое некоторыми интуристами сообщение об A9WTG.
С установленным SIFCY9WTGX* ничего не вылазит.
Естественно первым делом надо поменять имя компьютера в проекте на имя своего компьютера.
EKB install> Help > English > Problems > Problems with WinCC Archive v6.2kidbebong911 wrote:i also had a problem with license A9WTG60602
I tried to find it in "EKB install.exe" but i couldn't .you can help me ? much!
For archive licenses, the new license type "Count-Relevant" is being introduced starting with WinCC V6.2.
SIFCY9WTGX06026
I have the same problem like you (see http://www.plcforum.uz.ua/viewtopic.php?t=11415 )korceguitar wrote:hi comod.
Cause: Too much license for the product
Remedy:
- Delete all files in the license folder AX NF ZZ
- Run EKB_Install_2009_08_26
- Select all Required keys
- Press Install Long
- Install Short keys remain checked
- Enjoy!
Hi, friends.
About license for additional tags for TagLogging.
Do You solved this problem?
I have similar problem.
I use PCS7 ver.7.1 (include WinCC v7.0)
For WinCC v7.0 used SIFLA9WCP80700 WinCC RC PO (20000) with 512 Atg
When archiving tags for TagLogging has more than 512 (in my project 805)
during start WinCC I get message, that I must install A9WTG69999 WinCC Option Archive.
I don't find this license.
I install extention for archive tags:
WinCC Arch(1500) SIFCY9WTGX07001
After that, during start WinCC I get messag,
that license
don't install and WinCC run in demo mode.
But in License Manager this license is OK
After deleting license WinCC Arch(1500) SIFCY9WTGX07001
WinCC continues start in demo mode
Do someone can help me?
The previous advice in this thread don't help me.
that license
i installed wincc v7.0. but i dont crack.
i have Simatic_EKB_Install_2009_08_26. but i have still demo license.
which number of ekb can crack?
what can i do?
please help...
what can i do?
please help...
Hi guys !
I have similiar problem. PCS7 v.7.1 and Archive Licence...
I've tryed already to install "all reccomended licence" from EKB 09.05.2010
But regardles of what I've install I have still problems with Archive licence.
First of all - I don't know why I have "Unlimited" number of Archive Tags - see pict:
This is a message which I see when I try to start Runtime:
And whan I open Aditional Information (which is simply Authorinformation.inf) I can see this:
I'm trying to use as well SIFLA9WARC0700 and/or SIFCY9WTGX07001 but they seems to be "not used" by ALM
The question is: what more can I do to solve problem ?
When I've installed all "reccomended" Licence from EKB I have now
"Missing licence keys" in ALM totally clean
ans still message "Missing licence" during runtime
Re:
It works thxCoMod wrote:with SIFCYWTG06* work without problems (WinCC v6.2 and v7.0)
WinCC7.0SP2HF4 with more than 512 Archive Tags works with following keys:
WinCC-V7 RC 256kTg 512ATg - SIFLA9WRC70700
WinCC-V6 Arch 120000ATg - SIFCY9WTGX06027
(EKB_Install_2011_05_22)
need PC-restart !
WinCC-V7 Arch xxxATg dont works at my configuration...
thx,
blackducati
Install SIFLA9WRC70700 only it's work.
Hi, guys!
I use PCS7 of SP4 version 7.1 (including WinCC v7.0).
At start of RunTime I get message demanding the installation of the following keys:
A9WRP?0700
A9WTG69999
A9WCP?0700
But License Manager says that everything is OK.
I can't find these licenses. I looked for in several EKB including in the last at the moment Sim_EKB_Install_2014_07_28.
Has anyone encountered this problem? Please, advise how to solve it.
A9WRP?0700
A9WTG69999
A9WCP?0700
