[?]: COM 525 under MS Windows XP?
venix
Post by venix » Thu Mar 12, 2009 10:40 am
Hello!
Does anybody have succes using COM525 under MS Windows XP?
Best regards!
Venix
Umencho
Post by Umencho » Thu Mar 12, 2009 1:02 pm
Hello
I can't confirm 100%. I haven't necessary cable. But COM525 is starting by Step5. Step5 version 7.23 is compatible with Windows XP SP2. In my notebook I can start this com program, can create program. Let's say I can go around menus inside. But I never go online with hardware CP525/CP524. (I have this type CP, which is working at the moment). I believe that this will works, but this is Step5... :roll: . By the way, I was connected with PG (windows 2000) with CP524. :lol:
regards
venix
Post by venix » Thu Mar 12, 2009 2:56 pm
Hello Umencho!
And thanks again for your help!
I use for connection on S5 the IBH software S5/S7 for Windows or PG2000 od S7 Doctor.With Step 5 I did not try to connect.
I played a little in COM 525(offline) but after a while it crashed.
I have a COM 524 and I don't know what cable to use
Best regards!
Venix
PLC_ITA
Post by PLC_ITA » Fri Mar 13, 2009 11:16 am
I use CP524 / 525. Thre are more difference beetwen card.
for CP524 the program must be into a eprom, and you need a PROMMER
CP525 can be programmed also in ram through a interface 2 . To do this you need a special cable rs232 -- TTY . Is the same for cpu but the connector is 25 pin male
I'm sorry but i don't know the connect pin, and is't impossible to open the shell connector
You need S5 V7.0 or greather to work under Wxp sp2 , and COM525 add on package
venix
Post by venix » Fri Mar 13, 2009 6:53 pm
Thanks a lot for your support! :D
Now I must find a PROMMER :(
Best regards!
Venix
Umencho
Post by Umencho » Sun Mar 15, 2009 6:19 am
Hello
About pins descriptions, you can find in manual CP525. Here you can find link to this manual.
regards
Contact:
Re: [?]: COM 525 under MS Windows XP?
Post by sania » Tue Mar 14, 2023 8:04 am
hey,
need com525 one of later version : 4, 4.1, 4.2 or 4.3
if any one have it, please upload
