[?]: Quality codes Domino A series non-impact printers
другие контроллеры
aloksh25
Re: [?]: Quality codes Domino A series non-impact printers
Post by aloksh25 »
thank you everyone for sharing the code , really appreciated, how company expires code after 600 hrs of use even you. have ink anyway , below is the code I got it in April but can't use it anymore , but it can abe used use on other machine
Code for IR-270BKA - 279-549-0323 expires end: 04/2020
zarakshahzarak
Post by zarakshahzarak »
hi guys please share 292bk quality code
thanks in advanced
ua3vui
Post by ua3vui »
DOMINO A-200 IR-261 850-421-3076 до 04.2017
In the near future I will post a few more codes for this type of ink. Please share the code for IR-261. Those that are posted here on the forum - I have already used. Thank you in advance. Alexander.
ali9999
Post by ali9999 »
(gpost)
ua3vui
Post by ua3vui »
As promised earlier, quality codes IR-261
703-327-7168 02/17
530-862-1663 07/17
409-992-5703 07/14
506-385-2290 11/11
881-206-6005 04/17
036-316-6032 07/17
Please give me quality codes for IR -261 Thank you in advance - Alexander
Jlicea
Post by Jlicea »
Need code for 236blk ASAP please thank you in advance
BiMSHA
Post by BiMSHA »
(sbutton) Hi i need code for IR—291BK printing INK expired 2020 or 2021 , Thanks !!
Julian+
Post by Julian+ »
I am new to this forum. Can somebody write me to make sure my messages are seen and I am on the right track. My message early today was the one below:
Hello Everybody
I am looking for the quality codes for MC-2BK and IC-2BK series including the following:
MC-2BK009
MC-2BK024
IC-2BK009
IC-2BK024
Please help.
ChetalInkjet
Post by ChetalInkjet »
2BK009 MAKEUP CODE IS OF DOMINO I-TECH SERIES INKJET PRINTER.
NOW ONE MORE PRINTER COME WHICH NAMES AX SERIES THATS COMPATIBLE MAKEUP IS NOT AVAILABLE IN LOCAL MARKET
jamesss
Post by jamesss »
We are looking for Domino 2WT854 ink - make Up - ink cube code.
We have got alternative Domino cube system and 2BK009 codes ( ink -make Up - ink cube code ).
If somebodies need to cube system ( filter system ), change to codes, please write me
and use my private mail address.
Regards,
Jamesss
Julian+
Post by Julian+ »
ChetalInkjet wrote: Tue Nov 26, 2019 1:29 pm 2BK009 MAKEUP CODE IS OF DOMINO I-TECH SERIES INKJET PRINTER.
Hello thank you for the info. Pls advise how we may help instead
Julian+
Post by Julian+ »
jamesss wrote: Wed Nov 27, 2019 10:42 am We are looking for Domino 2WT854 ink - make Up - ink cube code.
Jamesss
Hello and thank you.
Unfortunately we do not have 2WT codes. Please advise what else we can help you with whatsoever.
Thank you
Best regards,
Julian Viand
jamesss
Post by jamesss »
Do you have 2BK009 and 2BK024 codes ?
Regards,
James
Julian+
Post by Julian+ »
Hello James’s
Yes and I will send them to you. May I have your number on WhatsApp? Thanks
Julian+
Post by Julian+ »
We need i-Tech Module Data Code for 2BK009. I mean the Data Code on i-Tech Module of 2BK009. Can you help?
jamesss
Post by jamesss »
Hello Julian,
I send you 2BK009 I - tech module code.
We have got new I-tech module.
Regards,
James
Julian+
Post by Julian+ »
Thank you James
Your i-Tech module is original or after market? If you have both pls quote for the two.
Also I read one of your messages about changing a cube system to code system. Would you pls explain
Thank you
Simodell
Post by Simodell »
Domino itech module CODE
CD60D5BFD
DD001DBDA
6DDB0EDAC
2DED0BCD6
ic 2BK009
5DE7-1F8B-EAF9 exp : 01/2019
MC 2BK009
CC80-56535 exp : 12/2017
145C-C0C31 exp : 12/2017
0534-0082A exp : 11/2017
ic 2BK006
A112-E5AB-8886 exp : 03/2018
36E4-8185-A218 exp : 03/2018
6A52-10E8-8859 exp : 03/2018
B861-8655-9B2E exp : 01/2016
Mc 2BK006
FFFD-E4FC7 exp : 10/2018
7FE6-7CF4E exp : 10/2018
8F7E-E7FC4 exp : 10/2018
Simodell
Post by Simodell »
ir-295bk quality code :
672-459-5590 exp : 02/2020
Julian+
Post by Julian+ »
Thank you Simodell
What can we do for you in return?
We also do need i-tech module itself(the cube)
Simodell
Post by Simodell »
https://www.facebook.com/akira.shi.121
I Saw itech module on Akira shi profil, chinese seller.
your welcome !!
jamesss
Post by jamesss »
We need 2BK0024 Domino Ax series INK and make Up quality code.
Best Regards,
James
dermo_renegade
Post by dermo_renegade »
for IR-270BK
774-927-3302 exp 10/2020
Charliedominoa
Post by Charliedominoa »
Hi there,
I need a quality code for a domino a series plus if that is possible?
Who sells ink and make up online do we have a link?
Thanks Charlie
Julian+
Post by Julian+ »
Hello code for which ink type Charlie & where do you need the ink ?
Charliedominoa
IR-446RD Printing ink
Do you sell this ink?
Charliedominoa
My supplier is very expensive. I’ve a lot of ink here which I don’t think there is a problem with but the codes kept running out after 600 hours. I found some codes on YouTube but they don’t work now. Thanks
Julian+
Post by Julian+ »
I’m afraid we cannot help you with 446RD
ua3vui
Post by ua3vui »
Очень и очень -- нужен код качества для чернил IR 261
Поделитесь пожалуйста.
azad
Post by azad »
ethio wrote: Sat Jul 21, 2018 12:43 pm Any body who can share a code for DOMINO a320i qube, ink and make up code
Thanks,
Hi
I need me to
Manuel78
Post by Manuel78 »
Hello there
Here's two QC for 299 BK ink:
900 668 7958 06/2020
008 809 7576 06/2020
Cheers!
Usama Jawed
Post by Usama Jawed »
Hello there, i hv one query for all of you, actually the question is can we update the service hours in Domino A series plus (A300+) without dongle key? is there any solution?
Nourelhakc
Post by Nourelhakc »
Please can you send me a valid code for DOMINO seria A100 IR-292BK
IgorKopil
Post by IgorKopil »
Good afternoon. Maybe someone can share the codes for ink (IC-2BK019) and solvents (MC-2BK019) on a Domino 320i printer? In turn, I can share the codes for 270BK ink, if anyone is interested, write in private messages.
Julian+
Post by Julian+ »
Hello to all colleagues
Has any of you heard of ink type 226BK . We desperately need some quality codes for this type of ink.
g8mail1216
Post by g8mail1216 »
how do I get the Q-code generator? I would like to pay for it. e-mail me : g8mail1216@gmail.com , thanks.
Valiants
Post by Valiants »
... If you need ANY IR Code for A series Printers just let me know. I can write them BY HAND on the spot. 8) 8) 8)
Valiants
Post by Valiants »
Someone ask for 292BK Codes ?? Here they comes :
Fluid Type :292BK
Expiry Date :May / 2020
Assigned Batch :Assign Batch No.
Customer Name :Enter Customer Name
Number of Generated Code(s) : 4
The Following Code(s) Apply ...
928-927-0713
779-765-3091
260-097-3179
919-927-0713
............. Enjoy It !!
ua3vui
Post by ua3vui »
Valiants
Добрый день из России. Не оставьте пожалуйста без внимания. Мне очень необходим код качества Domino А200+ Чернила IR-261YL
Если кому необходимо, - то выше я выкладывал свои коды качества для этих чернил.
ServTech1
Post by ServTech1 »
Hi Valiants,
Can you share 899BK quality codes?
Thank you
Amit1390
Post by Amit1390 »
HI
I have a domino touchpad.and its touch not working.we replace the touch screen but still its not working.and also mouse is also not working when mouse connected in it.CAN anyone help me?
AMIT SAINI
ServTech1
Post by ServTech1 »
Hi all,
Anyone using Domino G20I thermal Inkjet printers?
The cartridges are extremely expensive. Is there any way to bypass the volume reader?
Please WhatsApp me at +60133928943
Thank you
Simodell
Post by Simodell »
Good morning
Can someone send domino quality code for ic 191bk
Thks
AiOGajo
Post by AiOGajo »
sneg wrote: Sat Feb 01, 2014 4:34 pm IR-295BK printing ink, Expires end 7/2015:
153-896-7094
864-356-0969
324-905-5693
539-369-6045
269-153-0495
Worked for me, thanks.
The codes that I have for the same IR-295BK are the following:
353-565-2025 - expires: 06/2015
765-581-0192 - expires: 01/2017
594-925-2509 - expires: 5/2014
372-099-9755 - expires: 3/2018
410-558-6739 - expires: 02/2015
ua3vui
Post by ua3vui »
Код качества IR-261BK
5027050803 09/20
Есть у кого либо коды качества для этих чернил ? Поделитесь пожалуйста. Очень нужно.
Александр.
MEX_2380
Post by MEX_2380 »
Simodell wrote: Thu Jun 18, 2020 10:09 am Good morning
Thks
QUALITY CODE IR-191BK
9929058538 03/2020
5526839372 01/2020
4785523293 01/2020
niceguy
Post by niceguy »
Hello Everyone,
I hope you are all well. I'm looking for new Domino codes for IR-270BK.
Thank you very much for sharing!
NG (tyou)
MEX_2380
Post by MEX_2380 »
IR-270BKA
709 723 0204 EXP 07/2020
ali9999
Post by ali9999 »
Domino A Classic Series
Software 3L5HS -60
I have Domino software of all Classic Series but i need this 1 ?
Can anyone suggest about this how can i got this ????
Jamer
Post by Jamer »
Hello, I have a domino AX350-I printer, I have expired ink and make up cartridges,does any one have codes I can use? Also how do I input the codes I new to the domino printers and rather paying 600 dollars for a a new cartridge I would like to use the box we have.
thanks
