Address of simotion d params
Utilites for Simatic Automation
Garrido95
Post by Garrido95 »
On some forum, I have seen that the address of tag in this devices look like ANY(10.05.00.01.00.03.84.00.02.10). How can I see this addres in Simotion Scout or simatic manager? For example, I need to read P250 param on Simotion D425 (I use snap7 to do this or WinCC), using STARTER (similar to simotion scout) i can see all the param but without the addres that i mencioned before. Anyone can help me??
Draco Malfoy
Re: Address of simotion d params
Post by Draco Malfoy »
Dear Sir,
you are completely wrong. The adresses in the format you desribed above, are belonging to the SIMOTION-Tags, witch you declare as "public" and export for example like a Watch-Tab or for using inside of an HMI (TIA or WinCC Flexible). Tags, witch are declared as "private" or "system" you cannot display on HMI or put into a Watch-Tab.
Futhemore, you definitely need the full functionally SCOUT to work with a SIMOTION. Inside of STARTER you can only define the Data Interface to the Drive (i.e. TLG111 + TLG30 or somewhat like that) and make the comissioning of the drive. No more no less.
