Check your PMrkhamdamov wrote: Sat Dec 04, 2021 6:01 am Hi all!
I have exob file from weintex mt8071ie locked, can you help me to ulock?
Exob file: https://drive.google.com/file/d/1ywLmpO ... sp=sharing
Thanks in advance.
Rustam
Thanks in advance.
Rustam
Check your PMmrdona2098 wrote: Thu Apr 14, 2022 5:28 pm Hello,
can you decompile my XOB file???
Thanks,
https://www.mediafire.com/file/q8h6w1se ... i.xob/file
I assume your HMI is MT8071IE and you took a project copy using a usb flash drive, right? There's something strange about this series. Could you take another copy of your HMI on the flash drive and send me all those contents (not just the exob)? It's still going to take a while to figure it out but the more information I have, the better.legzylart wrote: Tue Apr 19, 2022 6:47 pm Hello,
Please help me to decompile this file
https://drive.google.com/file/d/18L1Faf ... sp=sharing
necrohamcer wrote: Wed Apr 20, 2022 6:57 amI assume your HMI is MT8071IE and you took a project copy using a usb flash drive, right? There's something strange about this series. Could you take another copy of your HMI on the flash drive and send me all those contents (not just the exob)? It's still going to take a while to figure it out but the more information I have, the better.legzylart wrote: Tue Apr 19, 2022 6:47 pm Hello,
Check your PMyacinio87 wrote: Wed Apr 20, 2022 11:07 am HI i have weintek kt6070 i want unlock xob file if you helpe me my mail yacinio87@gmail.com this is the link of the file https://files.fm/u/fr28jcrh3
Check your PM.milly wrote: Thu May 12, 2022 8:55 pm Hello,
Can someone please help me to decompile this file:
https://drive.google.com/file/d/1O0Txfv ... sp=sharing
Thanks!
Check your PMgycu wrote: Sat May 14, 2022 9:44 am Hi guys,
Can you help me decompile this?
https://drive.google.com/file/d/1hoGx-- ... 5LFFcK2xa0
Thanks a bunch!
Cheers!
TK6070iP is the chinese series of the HMI. You need to install EB8000 in chinese language and set your computer system locale to chinese also.milly wrote: Mon May 16, 2022 2:53 pm After the password was reset, when I try to load file (with no other modification) on the HMI, I get the error that the incompatible project settings. Any ideas? I am using Easybuilder8000. My screen is TK6070IP, but I only see MT6070IP in the System Parameters menu option.
Check your PMideed354 wrote: Sat Jun 11, 2022 4:59 am Please help me to open lock... many thanks before
link file : https://drive.google.com/drive/folders/ ... sp=sharing
Check your PMbakiro2005 wrote: Mon Jun 20, 2022 5:56 pm PLEASE WOULD YOU HELP ME TO CONVERT THE WEINVIEW TH6070IP HMI XOB TO MTP OR UNLOCK THE XOB FILE THAT WOULD BE SO HELPFULL
THANK YOU IN ADVANCE FILE BELLOW LINK
https://www.4shared.com/file/euXZ595Iea ... 070IP.html?
i have HMI weintek Mt6071ip.vlad2006gr wrote: Thu May 08, 2014 6:44 am Send me a project *. Xob format, I decompiled the project and send you.
Check your PMOlson wrote: Fri Jun 24, 2022 9:36 am Hello, sir.
Need your help, please.
Can you help me to decompile ? Link below.
https://we.tl/t-wuqcOVucN1
HMI Model : MT6071iP
Thank you in advance.
Olson.
necrohamcer wrote: Fri Jun 24, 2022 4:28 pmCheck your PMOlson wrote: Fri Jun 24, 2022 9:36 am Hello, sir.
Olson.
You haven't shared the file with everyone, I can't download it.Kevin83 wrote: Fri Jul 01, 2022 9:23 am Could anyone help me please.
I need to decompile my XOB file to change the HMI program.
Pls find the file in the link below:
https://drive.google.com/file/d/1_nQPXR ... sp=sharing
Really appreciate your kind support.![]()
acdwkr wrote: Sat Jul 02, 2022 9:32 am Hello,
I need to change the HMI type for this project, could you please help me and unlock this file.
Thanks you in advance
https://drive.google.com/file/d/1dztMr4 ... sp=sharing
I answered your other post in the russian thead, the password is in your PM.mukovic wrote: Wed Jul 06, 2022 3:18 pm Hi
The program was made a long time ago, but the password was forgotten. Can you help me to edit it please.
https://drive.google.com/file/d/1KCH2Jz ... sp=sharing
You could upload the exob here, just saying.ghulamshoaib wrote: Tue Jul 19, 2022 8:04 am Hello Everyone
I have exob file abd I want to decompile it
It showing message that file is protected and cannot be decompile
Any solution
Waiting
Just decompile this file in ebpro 6.06.02 with password 111111.corndog wrote: Tue Aug 02, 2022 10:01 am hello, i need help to decompile a file for the mt8071ip please help
https://www.mediafire.com/file/98wu8m9e ... .exob/file
Your file expired, can you send it again?fairooz313 wrote: Sun Jul 24, 2022 1:54 am dear vlad
can you decompile it
https://we.tl/t-9wnwyZdXsv
Can you take a another backup of the project from the HMI using a usb flash drive? Send me the contents of the drive after that.muhammadali7712 wrote: Tue Jul 26, 2022 5:47 am Hello dear I have a xob file of weintek hmi when I am trying to decompile the xob file then got the message is the XOB must be newer tool.
Hmi model is MT 6071ie
Using software is easy builder pro v 6.07.02.
File link is
https://www.mediafire.com/file/hv1dyvfl ... .exob/file
Can you decompile the file in edit able file I am thankful to you.
Check your PM.KreatorBuki wrote: Thu Aug 25, 2022 12:34 pm Can you help me to unlock pasword for this project :
https://drive.google.com/file/d/1ncyxpM ... sp=sharing
It is Weintek MT6070iH 2WK
Check your PM.farhhan wrote: Mon Aug 29, 2022 12:10 pm dear sir,
please unlock xob
https://www.mediafire.com/file/fw75owq2 ... w.xob/file
thanks and regard
Check your PM.yeronix wrote: Wed Aug 31, 2022 1:40 pm Hello,
I need to decompile this file:
https://drive.google.com/file/d/1-f8Ekd ... sp=sharing
i hope you can,
Thanks in advance
Check your PM.Hozefa wrote: Sat Sep 10, 2022 7:04 pm please help me
https://drive.google.com/file/d/1uHJaSt ... sp=sharing
open this file
Ho.ze.fa@hotmail.com
