[?]: PC Software CPU 1505s/1507s
Longhunter
Re: [?]: PC Software CPU 1505s/1507s
Post by Longhunter »
Well, the plan "B" would be getting a hardware report from the IPC with the AIDA64
http://uploaded.net/file/boanvrfy <= AIDA64 Extreme Portable
With the programa open, you'll need to generate the file in "Report -> Report Wizard -> Custom Selection -> deselect Benchmark -> HTML -> Finish"
Avoid the "All pages" or "Benchmark pages" options because it will have a heavy impact on Windows performance that would be troublesome if the IPC is in production.
Save the file (is around 1 MB) and upload it, please. Choose the best method that suits your situation.
den1049
Post by den1049 »
Maybe the problem is that 150xS requires a specific network card that the hypervisor can capture and use in the CPU configuration.
By analogy with RTX, it could only capture an E1000E network card when used with VMWare.
Accordingly, when loading any configuration into the CPU, it cannot start with the error "does not match hardware".
I tried different settings of the vmx file. I tried different BIOS files. In the best case, the processor was in the STOP state and was waiting for the configuration. After loading any configuration, it cannot start with the error "does not match hardware".
P.S. Sorry for my english.
Longhunter
I think the software looks for its hardware in a specific slots. While I was trying a way to start the kernel, the fact it asked me the SATA device has the pciSlotNumber "17" gave a hint why sometimes fresh Windows installations in a Siemens IPC doesn't work, as I have seen in other forums, and the only way they recover the PLC is with a HDD image. The PCI data changed, so the kernel doesn't know where to look.
In my research I found you can reencode the Bus:Dev.Func: you would encounter in Windows' Device Manager in a value you can use in the VMX file. I don't know the limit of this, so I hope someone else can give a better idea. We could reconstruct the Ethernet port with the VMWare E1000E device and at least get, if not the RT protocol, basic S7 comm without patching the kernel. I checked some IPCs with 1507S support have the 82574L ethernet chipset. Good enough for a minimal chance to get it working.
amarillo
Post by amarillo »
Here is what I got so far:
- Screen shot from a running VM with CPU1507s in STOP mode:
https://mega.nz/file/GpZ11QqI#OCZ5nUBEw ... d3VAAE7h3s
How I got here:
- Modified vmware config file *.vmx so sata0.pciSlotNumber = "17" etc see the vmx file below:
https://mega.nz/file/HoQlGSrK#Tk2MLm_p5 ... FOWlhvARFg
- Install Windows and CPU1507s.
- Modify VMM_1ST_STAGE.ELF and VMM_2ND_STAGE.ELF otherwise only a select list of PCs are allowed to run:
https://mega.nz/file/r8IHRSIL#eBur6YTJc ... XPOpI1MLFI
Items to figure out:
- Why SIMATIC RT-VMM Network Adapter driver fails to start
- Make a GUI program and use the existing API (VMM_BinConfigFileApi.dll) to generate cfg file for each VM guest that SIMATIC Hypervisor RT-VMM will start.
- Create a TIA HW catalog package installer with VMware VM as a PC Station like but capable to add CPU1507s.
Longhunter
In my case the SIMATIC RT-VMM Network Adapter works, but I can't see any ethernet module available in the "Devices" section to do an upload from TIA Portal and sometimes I couldn't power on the PLC.
I think that's happening because I'm using the PLC 1508S v20.8 when the VM BIOS tell the PLC that is a IPC227E and Siemens document says that hardware isn't supported. ^-^u Instead I'll try the 1507S and check your solution.
Example pic:
https://mega.nz/file/UWZAzAiB#aXRmLRdxZ ... 7KxJFLfCwM
Demen
Post by Demen »
I have the same result with 1507s. No ethernet device in cpu.
I read manual. Real ethernet adapter connected to CPU ethernet throw simens hypervisor.
Need to undestand why simens hypervisor don't see Ethernet card. see page 73.
Link to cloud with manual and 1507s virtual machine
https://cloud.mail.ru/public/41FS/4omCCetzi
amarillo
Post by amarillo »
Longhunter,
Can you please look under resources what RAM, I/O and IRQ is SIMATIC RT-VMM Network Adapter using?
Ilya
Post by Ilya »
Demen wrote: Tue Sep 08, 2020 8:39 am I have the same result with 1507s. No ethernet device in cpu.
Works but no license.
notebook HP.
desktop computer - asus (no)
p.s.Where to find :wink: ?
Demen
Post by Demen »
And next.
Use TIA 16 to make a PC station file and try to import in 1507s.
Result. CPU in Error. See screenshots
Screenshots and "PC system configuration.psc" i upload to cloud.
I install a new Embedded machine and now i can see from TIA portal. BUT can't download. f...
https://cloud.mail.ru/public/R4s6/2VxFZW1m4
If some one need new 1507s machine. I can upload it.
And i don't know where to get a license for software cpu 1500 v2.0
Demen
Post by Demen »
I think problem with Ethernet adapter X2.
See:
in cloud
Ramomkosta
Post by Ramomkosta »
I have a old Image GHO of IPC277D OS = WinPE 7 x86 V 6.1.7601 . After change to VHD image, can i see de .Reg file.
This is the link below, I hope it helps...
https://ulozto.net/tamhle/kaowCLyiOdEq# ... SJpwp5At==
racer77rus
Post by racer77rus »
I think the problem is that TIA portal doesn't recognize the VM Network adapter as "Siemens Network adapter". that's why TIA portal show a message that incompatible device was found during downloading to device attempt.
Contact:
about PC Software CPU 1505s/1507s from Russian Support
видео от российской техподдержки
"Программные контроллеры Simatic (softlogic). Вводная часть"
https://youtu.be/0LZAAMPlyrA?t=975
about keys
hanjinxing
Post by hanjinxing »
Expect 1507 or 1508 to run on the VM
flyingengine
Post by flyingengine »
Does anyone know how to fix it? I can't use the working VMs from here as I have there no option to create a shared drive (to import data from my host PC). I tried to fix it by adapting the vmx based on the vmx from the posted VMs here but no lock so far:
Demen
Post by Demen »
Ему скорее всего нужен правильный БИОС.
He most likely needs the correct BIOS.
erre
Post by erre »
Anyone got it running as it should in a virtual machine or on real hw PC (not siemens IPC)?
I tried i vmware workstation 15.5, but I didn't get passed BSOD or even to open vmx-file after adding all suggested lines to vmx. And rom-file.
I tried HW compability 11.x and 15.x.
UEFI and BIOS.
antibalda
Post by antibalda »
Hello all,
Is possible install software controller on non-IPC computer with Windows 10 and "normal" (no CP1616 or other) ethernet card ?
I read only install on WM - why install to the virtual machine ?
Thank you.
Wang
Post by Wang »
Is it possible install 1507s in IPC127E? From official manual i saw it support IPC 227E, 127E doesn't include. (usearch)
Wang
Post by Wang »
(h) (nuser) I bought A secondhand IPC127E,tried whole weekend,here is the result,since UEFI only,1507 can be only tested with latest version,failed with IPC type unknown,with type ID 0x0d01,is anyone have a Bios editor.so that I can let it pretends as like IPC227E.thanks
Nael
Post by Nael »
A few notes for the UEFI version (not working yet, but making progress):
* Requires a modification to the UEFI bios (either via a UEFI shell app or a custom firmware image) that changes the SMBIOS machine model and adds an entry with type "129" and contents
unsigned char Data[] = {
  0xff,
  9,
  5, 2, 2,
  LOBYTE(type), HIBYTE(type), 0, 0
where type can be extracted from VMM_2nd_stage.elf. An example would be model="SIMATIC IPC847E" and type=0x0C04. You can find the data around 0x2003A7A60 in 21.9 Upd4.
I have a tool for doing this on any platform, but I'm not ready to release it yet.
* AMD does not work. It requires Intel VT-d specifically. Otherwise it just silently resets. I also encountered an error during timer init in 21.9 Upd4 but I'm not sure if it's due to Intel or AMD -- I just bypassed that reset.
* Some startup debug output can be enabled by NOP-ing the LEA instruction in 0x200008D5F0
* The checksum for the .cfg files is weird. It's calculated over the file except for the last 24 bytes and is stored in bytes 12-16. The code for calculating it is (Python):
def mkcrc(a):
    crc = 0xffffffff
    for x in a:
        v7 = 0
        for j in range(8):
            if (x & 1) != 0:
                v7 |= 1 << (7-j)
            x >>= 1
        crc ^= v7 << 24
        for k in range(8):
            crc = (crc << 1) ^ 0x04c11db7 if crc & 0x80000000 else crc << 1
    out = 0
    for k in range(0x20):
        if (crc & 1) != 0:
            out |= 1 << (31-k)
        crc >>= 1
    return 0xffffffff & ~out
* I haven't been able to get it to run on QEMU yet (VMware refuses to keep the SATA controller on a PCI address of my choice, and I haven't figured out how to edit the AHCI controller location in the .cfg yet), but I've gotten further than on VMware.
E: The controller itself runs on a MIPS emulated CPU apparently. I found a MIPS ELF binary in the memory dump that seems to be the controller OS.
Nael
Post by Nael »
Debug output can be enabled with trace_loader=COM?, trace=COM? (eg COM1) and will be written to serial out.
A full list of whitelisted model names and types. The way it seems to check is: check type. If type (!= 0) is found, use that. Otherwise check name. If you have an IPC127E, you should be able to either modify the ELF or the SMBIOS entry via a UEFI program to show an IPC227E type.
name, type
SIMATIC IPC427C, 0x0
SIMATIC IPC627C, 0x401
SIMATIC IPC647C, 0x402
PSEUDO IPC677C, 0x405
SIMATIC IPC827C, 0x403
PSEUDO IPC847C, 0x404
SIMATIC IPC227D, 0x501
PSEUDO IPC277D, 0x502
SIMATIC IPC427D, 0x701
SIMATIC IPC477D, 0x702
SIMATIC IPC627D, 0x801
PSEUDO IPC647D, 0x802
SIMATIC IPC677D, 0x805
SIMATIC IPC827D, 0x803
SIMATIC IPC847D, 0x804
SIMATIC IPC227E, 0x901
SIMATIC IPC277E, 0x902
SIMATIC IPC547E, 0x203
SIMATIC IPC427E, 0xa01
SIMATIC IPC477E, 0xa02
SIMATIC IPC627E, 0xc01
SIMATIC IPC647E, 0xc02
SIMATIC IPC827E, 0xc03
SIMATIC IPC847E, 0xc04
SIMATIC IPC677E, 0xc05
SIMOTION P350-5, 0x0
NCU730.3B, 0x0
SINUMERIK NCU17X0, 0x0
MC APL1, 0x0
MCU1720, 0x0
SIMATIC 150XD, 0x0
SIMATIC EC457A, 0x0
CPU1517_EC457A_PT1, 0x0
S7+CPU1518, 0x0
CPU15xx, 0x0
CPU 1515SP PC2, 0x602
CELSIUS M470, 0x0
CELSIUS M730power, 0x0
CELSIUS M730 Power, 0x0
CELSIUS M730, 0x0
CELSIUS M740, 0x0
To Be Filled By O.E.M., 0x0
Stargo, 0x0
SandyBridge Platform, 0x0
Shark Bay Client platform, 0x0
To be filled by O.E.M., 0x0
Inagua, 0x0
Persimmon, 0x0
D3313-S5, 0x0
Broxton P, 0x0
JuniperHill, 0x0
Leafhill, 0x0
Grangeville, 0x0
oc_II, 0x602
A few of these (CPU15xx, etc) require an additional parameter to work.
Notably, it's whitelisted on regular desktop PCs and a few FUJITSU CELSIUS models.
spacedev
Post by spacedev »
How activate license for software conroler CPU1507s V21.9 ?
Longhunter
Ramomkosta wrote: Mon May 03, 2021 8:31 pm I have a old Image GHO of IPC277D OS = WinPE 7 x86 V 6.1.7601 . After change to VHD image, can i see de .Reg file.
This is nice, I'll check it later. Maybe I can see something related to the IPC's network adapters. Thank you so much.
Do you have a 15XXs PLC installed in this IPC?
Nael wrote: Mon Dec 26, 2022 6:32 pm Debug output can be enabled with trace_loader=COM?, trace=COM? (eg COM1) and will be written to serial out.
Oh, this is very interesting... I'll give it a try.
crunming
Post by crunming »
Is this thread dead?
Any updates to share?
amarillo
Post by amarillo »
Nael wrote: Mon Dec 26, 2022 1:52 am ...
Regarding the MIPS ELF, this is the firmware that runs on the CP 1625 Profinet controller, which utilizes a Siemens SOC1 MIPS processor. The firmware is downloaded by the x64 CPU OS when the card is installed in a PCIe slot and configured via TIA Portal, then transferred over the internal vNIC.
Additionally, some entry-level S7-1500 firmware runs entirely on the SOC1, while larger CPUs typically require some kind of Intel Atom processors.
Happy hacking!
