[?]: Unprotect Schneider PL7-Pro DFBs
Re: [?]: Unprotect Schneider PL7-Pro DFBs
hello vlad2006gr,i have a same problem with unity pro xl v13
i want to remove project protection password. can you help me?!
vlad2006gr
Project? Upload your project to a file-sharing service, and they'll try to help you.skystar wrote: Sun Sep 21, 2025 8:29 am hello vlad2006gr,i have a same problem with unity pro xl v13
The link won't open.piet_kulula wrote: Sat Sep 20, 2025 5:26 pm Please I need to open DFB program using PL7 pro program thanks
Hi all;
Pls, Can someone help open unlock sections in this program.
thanks in Advance.
https://drive.google.com/drive/folders/ ... drive_link
thanks in Advance.
vlad2006gr
You have Control Expert v16.00, which has a different protection version than older programs. Unfortunately, we can't help you.
funkwerkstatt
есть возможность помочь с паролем от проекта сделанного в somachine 4.3?
sheppard66
Hello, can you help me find the password for the sections of this Unity project please. Thank you all, have a nice day.
https://www.mediafire.com/file/yntuu3f5gti11gh/prog.auto.sta/file
sheppard66
Don't know how to find the sections password
DFB
centritune_v2_15 => 100
Compteurs_débit => des
Compteurs_horaire => des
Entrées_ana => des
Gestion_arrêt_différé => des
Gestion_powerfloc_avec_dosatron => des
Gestion_vanne_gaveuse => des
Modbus_Vacon => des
Traitement_ctrls_couple => des
Traitements_des_discordances => des
DFB
Entrées_ana => des
Modbus_Vacon => des
To access the Centritune section, we need to unlock the "Section & Program Units" password.
Thank you.
Thank you.
marco_valhalla
Hello, can you help me find the password on pl7 pro for this file
https://www.mediafire.com/file/lgyw21i4yrklmej/sassari_15b07.stx/file
Hi everyone,
Please help me to unlock password for this .stx file as link: https://drive.google.com/file/d/1iTpK98 ... sp=sharing
Thanks a lot.
Thanks a lot.
BDominik2001
Hello. Could someone assist me? I have a Control Expert Classic v15.3 PLC project for M580 plc. The password to open the project is: Prog@123321. The issue is that the Section & Program Units password is missing from the project. Could someone please assist me in decrypting this?
The project : https://limewire.com/d/VujlB#cjjMi5kbvM
Thanks in advance!
Thanks in advance!
Hello everyone,
I have trouble with opening a PLC project in Unity Pro XL V11.1.
My grayed code is: 3739.1
Could someone help me open the project?
Project: https://we.tl/t-deL1rAbujo
Thanks much in advance.
turhanotomasyon
@vlad2006gr First of all, thank you all for your help.
As you mentioned, I've been trying everything with the Hex Editor for two days and I've been unsuccessful. Can you explain this issue to us or to me step by step and help me?
And if possible, could you send me a video about it?
The PLC program I'm using is PL7 Pro V4.5. In my project, the blocks in the program section are locked, and no one knows about this lock, and the person who wrote the program is also dead.
I would be grateful if you could help me with this.
Regards,
Enes
Regards,
Enes
Hello everyone,
I’m working on a Schneider Unity Pro project that is password-protected, and I’m having trouble accessing it.
To be clear: this is a project I am authorized to work on, but the original password has unfortunately been lost.
I followed Vlad’s explanation from the previous thread and was able to extract the passwords for the DFBs without any issues.
However, I still can’t locate the password for the main project or for the protected sections, and I’m stuck at that point.
Has anyone experienced this before, or does anyone know if there is a method to recover or reset the project/section passwords when you have legitimate access to the equipment?
LINK: https://www.mediafire.com/file/1bwz6prndhdj2ho/CEG-0037.zip/file
Any guidance would be greatly appreciated.
Thanks in advance!
Thanks in advance!
azeem_javaid
Dear Fellows,
I’m working on a Schneider Unity Pro project that is password-protected, and I’m having trouble accessing it because The "Sections" are
password protected.
Can any one help in this regard please.
Link: https://www.mediafire.com/file/mu8bakg6otqhfwy/W_Program.rar/file
Respects & Best Regards,
password protected.
Can anyone help me in obtaining the password for the DFB, see link below.
https://drive.google.com/file/d/1cICRQu ... drive_link
Thanks in advance.
Thanks in advance.
Password : ed&cRe: [?]: Unprotect Schneider PL7-Pro DFBs
password: des36aRe: [?]: Unprotect Schneider PL7-Pro DFBs
Hello and Happy New Year to everyone. Below is a link to an old M340 with a password on the project, which has read and write access. I can't recover the password, as it's not encrypted. Do you have a procedure for removing it? Thank you all.
https://www.mediafire.com/file/xbz8aq04bztwdqo/Treboulou_M340.rar/file
File : *.sta
Task/section password : ECOAQS0421Re: [?]: Unprotect Schneider PL7-Pro DFBs
Merci, thanks hodor
I had the procedure that I lost, do not hesitate to share it with me. Avec le fichier sta
send a .sta file
password: %ID56500Re: [?]: Unprotect Schneider PL7-Pro DFBs
Can someone tell me how to unprotect dfb on unity pro?
this is the link to the proyect.
section/mast password : b3oQ5jS5eMtf9E
dfb password: 66uFo4g3Re: [?]: Unprotect Schneider PL7-Pro DFBs
This is fantastic Hodor.
How is this done? can you explain???
Hello!!!
I have these 2 files I would like if you possibly can give me the password for the dfb's.
Thanks in advance!!!
It is not accessible. Share it with other file sharing platform.
You are right. Now it works.
send .STA files
Try these for 395-711b-hsb-v4_16:Imanu wrote: Mon Feb 09, 2026 3:02 pm Hello!!!
cZAm25nw
100cbrWA
4R0NTvx69Hf2J5
yes!!!!! these are the passwords
would you be able to explain how this is done?
I have uploaded the other file in exported version. It is an older version of unity and I can not get the STA, But I have the XEF that allows import in newer versions.
https://drive.google.com/drive/folders/ ... sp=sharing
Please, If possible to find the DBF passwords
Imanu wrote: Mon Feb 16, 2026 8:42 am I have uploaded the other file in exported version. It is an older version of unity and I can not get the STA, But I have the XEF that allows import in newer versions.
DFB Block: dfb_ActiveControlSP_v1 - Password: wa6166
DFB Block: dfb_AngleRateWeight_v1 - Password: wa6166
DFB Block: dfb_ArrayMakeReal8_v1 - Password: wa6166
DFB Block: dfb_fdbkScale_v1 - Password: wa6166
DFB Block: dfb_IdentMake_v1 - Password: wa6166
DFB Block: dfb_IdentSine_v1 - Password: wa6166
DFB Block: dfb_IncDecSurface_v1 - Password: wa6166
DFB Block: dfb_infiniteCheck_v1 - Password: wa6166
DFB Block: dfb_IntIncDec_v1 - Password: wa6166
DFB Block: dfb_IntToRealArrayMake8_v1 - Password: wa6166
DFB Block: dfb_LimitationInt_v1 - Password: wa6166
DFB Block: dfb_LimitationReal_v1 - Password: wa6166
DFB Block: dfb_MAFilter_v1 - Password: wa6166
DFB Block: dfb_MlinkDisplayScale_INT_v1 - Password: wa6166
DFB Block: dfb_MlinkDisplayScale_TFOIL_v1 - Password: wa6166
DFB Block: dfb_Mode_Sel_v1 - Password: wa6166
DFB Block: dfb_ModeBools_v1 - Password: wa6166
DFB Block: dfb_MoogVlvControl_v1 - Password: wa6166
DFB Block: dfb_MRUFix_v1 - Password: wa6166
DFB Block: dfb_MRUProtocol_v1 - Password: wa6166
DFB Block: dfb_PitchRollSG_v1 - Password: wa6166
DFB Block: dfb_PitchRollWeighting_v1 - Password: wa6166
DFB Block: dfb_Ploop_v1 - Password: wa6166
DFB Block: dfb_RandSquareWave_v1 - Password: wa6166
DFB Block: dfb_RandTime_v1 - Password: wa6166
DFB Block: dfb_RBTAlgorithm_v1 - Password: wa6166
DFB Block: dfb_RMSRunnning_v1 - Password: wa6166
DFB Block: dfb_ROR_ARBYTE20_v1 - Password: wa6166
DFB Block: dfb_Setpoint_limit_v1 - Password: wa6166
DFB Block: dfb_Speed_Trunc_v1 - Password: wa6166
DFB Block: dfb_SquareWave_v1 - Password: wa6166
DFB Block: dfb_StepGenerator_v1 - Password: wa6166
DFB Block: dfb_TANh_v1 - Password: wa6166
DFB Block: dfb_Tmax_mode_det_v2 - Password: wa6166
DFB Block: dfb_Tmax_v3 - Password: wa6166
DFB Block: dfb_Tmax_Vectoring_v2 - Password: wa6166
DFB Block: dfb_Tracking_error_v1 - Password: wa6166
This is of great help.
Hi. There is a password-protected project. Help me take it off. EXC v15.2
It's not opening in Unity XL pro. Please send .sta file.sdon wrote: Wed Feb 18, 2026 7:40 am Hi. There is a password-protected project. Help me take it off. EXC v15.2
added *.STA
