[?]: Unprotect Schneider PL7-Pro DFBs
Re: [?]: Unprotect Schneider PL7-Pro DFBs
Thank you very much Andreyit. So kind of you.
Thank you very much
Thank you very much
Dear vlad2006gr ,
Please help me to unlock this project
https://drive.google.com/file/d/1Kbpr84 ... drive_link
Thanks in advanced
Thanks in advanced
Try
InTouch9
InTouch9
Thank you melin2000
please i need help
i have two project
i need password for this project
https://mega.nz/file/pdpy0JJZ#Cg36_taM_cNf66f4OT9XHKhRosP1unWowrO0BcWoDaI
https://mega.nz/file/tBJRCBYY#O7hUgLIsBqs6Ovoeq5xc3by9zCTlWngaO3pKMmQLQSw
i have two project
vlad2006gr
See PMmahmoud31 wrote: Fri Nov 08, 2024 5:30 pm please i need help
i have two project
Hello, on a Control Expert project we lost the password. How can we retrieve it ?
Here is the link to my project
https://fromsmash.com/.~6GSGZBLs-ct
vlad2006gr
See PMTintin wrote: Wed Nov 27, 2024 8:53 am Hello, on a Control Expert project we lost the password. How can we retrieve it ?
rqcimperium
rqcimperium
Ok
Finally, I found the passwords in the .stu (PathBase.db)
Good morning, I have this project with read-write protected sections, is it possible that you can help locate the password?
Thanks in advance
https://we.tl/t-JieoeP2vHE
Thanks in advance
@vlad2006grvlad2006gr wrote: Wed Nov 27, 2024 10:53 amSee PMTintin wrote: Wed Nov 27, 2024 8:53 am Hello, on a Control Expert project we lost the password. How can we retrieve it ?
Здравствуйте! Меня зовут Пётр, я пытаюсь активировать WinGP version 4.9.123 на Windows 10 64
в этой ветке viewtopic.php?t=17530
обсуждалась активация WinGP от Pro-face путем замены библиотеки rootframe.dll
Все ссылки состарились, вы можете пожалуйста поделиться библиотекой ?
Telegramm @Peklo87
email Petris@mail.ru
Hello!
I want to ask help with unlock this old project (pl7 4.5 sp5)...
https://1drv.ms/u/c/7295f49f4556e456/EY ... A?e=EEBvT1
Thanks a lot!
Thanks a lot!
20417Bionika wrote: Wed Jan 29, 2025 11:58 am Hello!
Thanks a lot!
PALLDT
palldt
mariolabros
I would need the password for the DFB in this project Control Expert
thank you in advance
Hello again and I am sorry, but...
I want to ask help with one more project (pl7, sp5)
https://1drv.ms/u/c/7295f49f4556e456/ET ... Q?e=6VoGSb
Thank a lot!
Thank a lot!
Hi, I am currently looking into a way to obtained the password for the password protected DFBs. Could anyone be able to share and guide me through this?
Thanks.
Thanks.
Thanks in advance
https://drive.google.com/file/d/14fpBFV ... p=drivesdk
Thanks in advance
Copy of kung kang1-5.stx
Application password:9171756
No password for DFB "Estados_xbt"
Hi!
This is a Unity Pro project, but maybe someone can help me remove the program protection. The DFBs I can find the passwords, but my main goal would be to find the main program password, since the parts that I need to modify are the LD blocks..
If anyone can help me I would be gratefull.
https://drive.google.com/file/d/1HX1G8z ... sp=sharing
Best regards.
Best regards.
YAUYQ7tdoa wrote: Thu Jul 10, 2025 1:39 pm Hi!
Best regards.
Hello All,
I forgot the project password & DFBs password. I need to know the password for the same.
Please check the below link for program backup
https://w-si.link/zZqGBmwwNROaSAxpl
Thanks in advanced.
Thanks in advanced.
Hi all;
can someone help unlocking protected DFB named Modbus_ACS850
https://drive.google.com/drive/folders/ ... sp=sharing
Thanks in Advance!
Thanks in Advance!
desmo2a wrote: Thu Jul 24, 2025 4:27 pm Hi all;
Thanks in Advance!
V@5348Suraj1995 wrote: Fri Jul 25, 2025 12:44 pm Hi all;
can someone help unlocking protected DFB password
thanks for your help, but I thought that it will fix my proplem, can you pls help for providing Program Password,andreyit wrote: Fri Jul 25, 2025 5:54 pmdesmo2a wrote: Thu Jul 24, 2025 4:27 pm Hi all;
Thanks in Advance!
also for DFBs named centrituneV2_15, traitment_des and traitment_ctrls
thanks in advance!
des36a
100
des
Thanks a lot!
I really appreciate your help.
Hello, can you help me find the password for the PLC project in control expert version 15 ?
https://mega.nz/folder/yYVFhbTJ#b_J0pShEE5hxo8fl5QuTGQ
Thanks (Sorry i'm french)
Could someone please unlook this file. It was developed in Control Expert Version 14.
https://drive.google.com/file/d/1rtqdh6 ... drive_link
Thansk in advance.
Thansk in advance.
vlad2006gr
No access........celioric wrote: Tue Aug 19, 2025 12:41 am Could someone please unlook this file. It was developed in Control Expert Version 14.
Thansk in advance.
Hello, I have a CPU Schneider M340 P341000 but password protected. Can I use its memory card for the new CPU? please help me! Thanks a lot
It's possible if you replicate it on a mini SD card.gladiator wrote: Wed Aug 20, 2025 5:05 pm Hello, I have a CPU Schneider M340 P341000 but password protected. Can I use its memory card for the new CPU? please help me! Thanks a lot
vlad2006gr
This is if protection is not installed in the program, binding to the card.It's possible if you replicate it on a mini SD card.
The program can also be linked to the MAC address of the Schneider M340.M340 offers %SW146 and %SW147 to acquire the unique SD card serial number(32bits) tp be used to protect an application against duplication.
Note: The system words %SW146 and %SW147 are available since SV 2.1 of the CPU OS.
Try making an image of the card, writing it to another card and installing it on the backup CPU.The M580 PLC MAC address can be read in Unity Pro using %SW132 to %SW134 system words.
Now with link acess
https://drive.google.com/file/d/1rtqdh6 ... sp=sharing
Developed with Control Expert v14
Thanks in advance
Thanks in advance
vlad2006gr
See PM.celioric wrote: Tue Aug 26, 2025 5:03 pm Now with link acess
Thanks in advance
Worked! Thanks a lot.
vlad2006gr wrote: Tue Aug 26, 2025 6:31 pmSee PM.celioric wrote: Tue Aug 26, 2025 5:03 pm Now with link acess
Thanks in advance
rqcimperium
Greetings!!!
can someone help me unlock protected DFB passwords?
https://w-si.link/IkgYkCzdMBPncXz1a
Thanks in advanced....
Greetings!!!
Greetings!!!
Greetings!!!
vlad2006gr
See PM
See PM
Влад добрый день.
Необходим пароль на секции/блоки проекта Unity Pro. Помогите пожалуйста!
Пробывал сам найти в HexEditor в файле PathBase.db, но к сожалению даже похожего не нашел.
Ссылка на проект: https://drive.google.com/file/d/1kcGbY4DUezwG4n4Bj7AxEOMy5_uXcv7p/view
Заранее спасибо.
Заранее спасибо.
Нифига какой там старьё.
Sweng123
Sweng123
andreyit, Андрей спасибо огромнейшее!!!
piet_kulula
Please I need to open DFB program using PL7 pro program thanks
https://drive.google.com/file/d/1ATQ18p ... drive_link
