HELLO.
I have an HMI connected with Profibus module LAUER PCS 807 but when i commissioning with the original plc programs S400 siemens i found that the device of this module have not the same GSD of LAUER PCS 807 but instead it exists this GSD « LCAPCS31.GSD » that i couldn’t find its GSD which it run normally with the original programme l
Please if you can send me this GSD « LCAPCS31.GSD » i would use it directly because if I use the GSD of LAUER PCS 807 i must know the telegrams used and it is not availaible because i can’t read it
please help
Best regards
Searching for GSD « LCAPCS31.GSD » or alternative
