[?]: Freelance 2000 Controler IP change
другие контроллеры
antihard
Post by antihard »
Hello
i have freelance 2000 Contrôler for ABB an i want change IP adresse 172.16.1.1 to another ,does anyone have a solution.
thanks
Linkinx64
Re: [?]: Freelance 2000 Controler IP change
Post by Linkinx64 »
Hello
You can change IP address directly from CPU module by clicking CFG button and use arrows: "up" and "down".
In case you have an 800F CPU without integrated ethernet and no configuration button there must be a switch on the top of ethernet module. You need eject the module from rack to see it.
