[?]: how to upgrade Freelance 3.3 to 6.2
другие контроллеры
antihard
Post by antihard »
Hello
Es anyone know how to switch to freelance Freelance 200 v3.3 v6.2 windows 2000.
Linkinx64
Re: [?]: how to switch Freelance 3.3 to 6.2
Post by Linkinx64 »
I don't understand your question.
antihard
Post by antihard »
Hello
I have the software Freelance 2000 version 3.3 for Freelancer Controllers under windows NT and I want upgrade this previous version to Freelance 2000 v6.2 under Windows 2000 but i don't know how to do it.it's clear for yoy now ?
Linkinx64
Post by Linkinx64 »
I think such upgrade not possible. Freelance v6.2 you can install for win2k but projects for v3.3 and v6.2 are linked to different hardware definitions (libraries) so you may need make changes in projects after upgrade. Only program logic keeps same.
antihard
Re: [?]: how to upgrade Freelance 3.3 to 6.2
Post by antihard »
Thank you for the answer that you're an idea of how to do
Linkinx64
Post by Linkinx64 »
Actually, this upgrade from one obsolete version to another obsolete version.
Why don't upgrade to Freelance v9.1? viewtopic.php?f=3&t=13305
antihard
Post by antihard »
if I use version 9.1 I have no problems with the hardware configuration? if not, can give me the procedure to be followed
Linkinx64
Post by Linkinx64 »
What kind of 800F hardware you have (PLC, communication boards and IO)?
You can easily check compatibility by installing v9.1, opening old project and trying download program to 800F.
There are maybe limitations for very old hardware, same as in 800M - can operate with existing block but can't insert a new block.
antihard
Post by antihard »
Hello
I tried to send the program and got the following error "Incompatible DMS version"
