HI
I want load program on CPU341 in GE FANUC 9030 PLC ,when i turn off PLC and turn on again program exist on the PLC .
I know need to load program to EPROM /EEPROM but i dont know:
HOW can find inside CPU have EPROM /EEPROM or not?
and also i want to know:
HOW can send program to EPROM /EEPROM?
[?]: Permanent Program on PLC FANUC 9030
hmohamed
Re: [?]: Permanent Program on PLC FANUC 9030
hi naesrkargar
from target-->select hardware configuration --->then double click on cpu the cpu configuration will appear then doubel click on logic/configuration from and select prom then download program and mark check box write all items to flash then the program will be written to flash and every time the program starts it loads from flash
good luck
good luck
