kir9518 wrote: Mon Jan 24, 2022 10:50 am
Good afternoon. There is an SQL database for 450,000 products. We are switching to Eplan pro Panel 2022. When adding SQL, Eplan freezes. Can someone tell me what the problem is?
EPLAN 2022 don't like big databases... the new .alk database is slow too when you import a lot a products.
And EPLAN canceled the "full text search" in SQL database too!
Please contact support if you have a legal version, more support tickets = faster solutions! maybe!
zart wrote: Tue Jan 25, 2022 8:06 am
I face that problem with Data Portal at my new installation after update my computer to Windows 10:
This function is available with EPLAN Data Portal Standard access. Currently you have EPLAN Data Portal Guest access. If you wish to get EPLAN Data Portal Standard access, please contact your EPLAN system consultant.
Do someone have solution for that.
Thank You in advance
It's clear. Just pay Eplan the annual fee, (>1k€), and then your user will become standard user.
Eplan rules.
In the meantime you have guest access, you can see, but you can't download our use.
dibdis wrote: Thu Jan 27, 2022 7:10 am
Hello, how much do yo pay for Eplan in your countries?
Previously, you could buy a software with 1-off cost and then a subscription for service. Now, I believe, they only have an annual subscription option.
For the UK, I have received the following quotation:
In the first year this is priced at £1,729.00 (the subscription price includes the software assurance contract)
The subscription price will increase by 2.5% each year and it is automatically renewed every 12 months
It's really cheap. You can subscribe to 80000 yuan a year in China
One thing I forgot to mention is the type of licence. This is the price for "EPLAN Compact with the Compact+ Elements". Your price might be for Ultimate edition?
If you think too much, it's a stand-alone professional version
EPLAN CPM 2022 & EPLAN View 2022 not .
I added the licenses but when starting the application, the "activate license" dialog is displayed.
Any ideas?
Kind regards!
Goto the folder \Users\Public\Eplan\Common and make a copy of the file lservrc and rename it to lservrc_view for eplan viewer or lservc_cpm for eplan cpm.
Also make sure that the keygen generated the licenses with the viewer and central parts management systems.
It will all work after that...
Where I can find download link of Eplan P8 2022 @chaos363 ?
bloemp wrote: Sun Jan 23, 2022 12:21 pm
During the development of my own patch DLL I've seen that error after protecting it, so maybe your problem also is in that corner
At least I was able to successfully test my unlock on three different devices + 2 virtual machines.
Nevertheless, I'm glad that you provided a working activation, which is why I won't do anything until the next "problem" .
Russian wrote:По крайней мере, я смог успешно протестировать свою разблокировку на трех разных устройствах + 2 виртуальных машинах.
Тем не менее, я рад, что вы предоставили рабочую активацию, поэтому ничего делать не буду до следующей "проблемы".
I created a another version of the vcruntime140.dll.
This one works (well at least for me, with limited testing) for version v2022.0.3.323 AND for v2022.0.3.339.
Therefore you can update to SP1! Hopefully it will work for you too.
Recently upgraded to Windows 11 and decided to update Eplan from 2.9 to 2022 Update 2.
Crack used this: Keygen by chaos363 (1.0.3)+EPLAN_Ultimate.tpl+"No Identity Check"+"Skip Identity Check"+vcruntime140.dll by Bloemp.
As it turned out, some functions do not work correctly. In particular, here are some problems that I was able to find:
1. Periodically freezes the "Project Management" window;
2. The "Project Management Database" server is not replaced by SQL;
3. Unable to rename device designation.
I didn’t check it further, since it’s already impossible to work without point 3.
Maybe the problem is in Win11, maybe in Update 2...
Vasiliy wrote: Sun Jan 30, 2022 3:58 pm
Hello everyone!
I know problem point 3.
I thought it was fixed with newest window 11 Update, but i testet 2022 view minutes ago and the problem still exist.
Maybe a restart from computer will help, i never had this problem with my 2nd pc.
i have a problem with activation of Eplan P8 2.9. I have list with licenses, but only information that: I cant use because of: "A stand-alone license can only be used on one console."
I did everything with ReadMe so I had modified hosts file in Windows, put dll to eplan bin folders, create a licence file with my HWID and cant run my eplan
Hello, Eplan for version 2.9 is no longer available with vcruntime.dll, and created lservrc from "crack"? This vurnability of epan is repaired already? Now my computer shows me that, license is no valid for this comp, but I have correct HWID in generator of license.
Could some one give a help hand?
you need correct vcruntime140.dll for Version 2.9 Licence client, must be patch 1.01 or 1.02, to find here in some posts.
Hi, thanks but for now windows with licenses to choose appears. But i cant turn on any license. Just message under license that: "You can't use this licence" or "A stand-alone license can only be used on one console". I used patch 1_0_2 .
I tried with patch_1_0_3, now I have similar problem: The license 'C: \ Users \ Public \ EPLAN \ Common \ lservrc' is not valid for this computer.
Im trying on windows 10 with newest updates on host and on hyper-v virtual this same.
On VM Ware Player everything is working. Only with Hyper-V problems still :/
Windows 10 Pro 64-bit 21H2 19044.1466
EPLAN 2022 Update2
After a few minutes of use, the input box appears and the data cannot be modified after confirming that the data cannot be modified.
If you have 1st Version from EPLAN 2022 you can download Update 1 and 2 with EPLAN download manager, even if you have a cracked version.
There is no licence check in download manager.
Hi, tY on info. nice to know, but where have you have downloaded initial version from?
Hi, I'm trying the "No Identity Check" and "Skip Identity Check" trick but it's not working for me. I tried already a few variations of it (one in each line, both in the same line, with the quotes, without them, etc) but it's not working.
Would please someone post a screenshot of that part of the file or something so I can understand what I'm doing wrong?
Same config as you: Keygen by chaos363 (1.0.3)+EPLAN_Ultimate.tpl+"No Identity Check"+"Skip Identity Check"+vcruntime140.dll by Bloemp. Clean install on Win10, any solution on point 3?
with update 1 all is working fine, but WMC Addon from weidmuller doesnt integrate in the iterface
Can't load 'Eplan.EplApi.Gui.RibbonIcon' del ensamblado'Eplan.EplApi.Guiu, Version=1.0.0.0, Culture=neutral, PublicKeyToken=57aaa27e22f7b107'.
Hello;
i updated the EPLAN update 2. Use Bloemp vcruntime for cracked. Everthing is ok and work fine. But when i open eplan, its closed a few minutes later then reopen again. it goes on like this all the time. what's wrong.
Sorry Guys,
I still work with Eplan 2.9 but I would to update to 2022.
Honestly I've read everything about it but I didn't understand how to crack eplan 2022.
Someone could to explain the procedure and the necessary files to use Eplan Version 2022 please?
Thanks a lot
