Eplan P8 2.8/2.9 + personal keygen
Тools, Elcad, Eplan, ...
h4rdw4re
Re: Eplan P8 2.8/2.9 + personal keygen
Post by h4rdw4re »
MiRi wrote: Mon Jan 03, 2022 11:46 am I know someone who uses and the version is illegal.
But he did not share the account.
sells
price:375 $
:o :?
If it is possible, then simplicity costs...
For me, using edz files is excellent. Even you can make your own library and work offline.
h4rdw4re
Post by h4rdw4re »
Mate,
In that case, costs of USD375 is not that much.
It is just my opinion regarding edz files. For detailed and professional projects like you described using licensed products has advantages and should be considered, especially if you hand over project files to customers.
Cheers.
Jake1
Post by Jake1 »
375$ might not be the only cost.
It may be that in Russia or China no one cares if you use cracked software, but in Germany or Austria I would not register with an illegal license on the data portal.
That can be really expensive! :D :D
rezamz
Post by rezamz »
Eplan Smart Wiring 2.7 + CRACK
https://veryfiles.com/qopzmfjvexjn
spyrosxp_
Post by spyrosxp_ »
hello
how we can download from this link: https://anonymousfiles.io/k5kK3XVK/ ??
chusebizen
Post by chusebizen »
I will never mind to work without data portal. (Maybe except for 3d model in Pro panel).
Eplan data portal sucks the majority of the times. Parts not correctly created, for example many errors in a plc card in pin type between the symbol and the representation, wrong ordering data.... and many more.
The cost of the yearly data portal fee is a robbery!!! (More than 1k€), for being checking each part downloaded from data portal, because most of the data has errors!!
Jake1
Post by Jake1 »
True!
The idea for a DataPortal is good, but no regulations from EPLAN for the companies to create good macros without errors.
Nobody need macros when you must control any clamp and designations.
Some electrical macros are only in free graphic lines ... (h)
gdbird
Post by gdbird »
You are right, eplan dataportal is only a option, no dataportal we also can use Black box to crated marco.
Some marco when I download from dataportal also need take many time to modified as this is not totally can use in my drawing style.
Even i have toatally EDZ 2.7 offeline but i not usallay to use it. It take me a lot of drive space, i only store it to cloud drive some time to search a xml document. (h)
s1921707
Post by s1921707 »
bloemp
Post by bloemp »
Hi Everyone,
For those people asking if this is the server/client or monitor version. They don't exist anymore...
This package is all in one. The server that provides a web based client and a web based monitor.
Have fun
Jake1
Post by Jake1 »
Thanks for your work, bloemp! (clap)
I never used smart wiring, time to learn how it works :D
Greetings!
zart
Post by zart »
Running only on Windows 8.1 or higher....
freude
Post by freude »
Hi...
I Installed Eplan 2022 3-days ago..
It did not run....
because I run on Remote Desktop Connection..
Check to see if you're running it on a remote desktop connection like me.
leewheel
Post by leewheel »
Eplan doesn't allow to run on remote desktop, you can try using VNC
Jake1
Post by Jake1 »
You can start EPLAN on a remote desktop.
create a .bat file, insert:
@ echo off
tsdiscon
call "C:\Program Files\EPLAN\Electric P8\-EPLAN-Version-folder-\Bin\W3u.exe"
Start the bat file, remote desktop will be closed, Eplan starts, open remote desktop again, you can work with Eplan. (suc)
mareq6666
Post by mareq6666 »
Hi, Thank for everything
but I have a question. How exactly i can run eplan smart wiring... i do everything what readme says but i can not open smart wiring via webbrowser... i run it on wmware...
Can someone give me some advice?
chaos363
Post by chaos363 »
Unfortunately, I had no time due to professional and private reasons, which is why I am only now reporting.
Since this will be the last post for a while, I'll try to describe a solution for update 1.
In update 1 the license client was adapted in such a way that the functions of vcruntime140.dll are contained directly, why the dll is no longer run. Here a new way must be found.
In the following I describe the places, which would have been adapted by the vcruntime140.dll in update 1.
File eplancommoncore.dll has the following address, where the register RAX must always be 0x0! The first pass is usually 0x0, which is not the case with the second.
xxxx
After that the following path is passed, which sets the register EBX to 0x1. With this the check runs through cleanly.
xxxx
Good luck :)
s1921707
Post by s1921707 »
Port settings and windows firewall are required to allow applications to pass through
HooK
Post by HooK »
@chaos363
Thanks for the explanation with how things have changed with Update 1 with regard to vcruntime140.dll & EplanCommonCore.dll.
Did you actually test & get it to work after making the changes to vcruntime140.dll with Update 1?
Just curious if your notes were tested working :wink:
Thanks again for coming back to the forum and responding. We appreciate it!
-HooK
chaos363
Post by chaos363 »
vcruntime140.dll will no longer work, because the source code used in it is no longer called, but has been implemented with its own means by manufacturer.
The lines above show where update 1 must be changed to make the application run again. I have tested it myself and it works.
The best is to start in debugger and patch code live, so you avoid hash check of eplancommoncore.dll.
Unfortunately changing eplancommoncore.dll is not so cool, so the above code has to be changed in a smart way. Here I would think of a hook just before the check, where another system function is abused so that the check can be patched.
I hope you can do something with the info, because I'm currently not working on a solution. The keygen seems to be well prepared for future, so that only hash check must be patched.
bloemp
Post by bloemp »
Good to see you back Chaos363! Very impressed with the keygen
mareq6666
Post by mareq6666 »
Thank you i try it... but still no working what IP address and port i should type to run it?
debugman
Post by debugman »
chaos363 wrote: Sun Jan 16, 2022 2:42 am Unfortunately, I had no time due to professional and private reasons, which is why I am only now reporting.
00007FF8F9B8EAA6 | 85C0 | test eax,eax
00007FF8F9B8EAAD | 74 19 | je eplancommoncore.7FF8F9B8EAC8
00007FF8F9B8EAC8 | BB 0100 | mov ebx,1
The memcmp from vcruntime140.dll would be in the following position in the old version.
00007FF8F9B8EAA1 | E8 CAB2 | call eplancommoncore.7FF8F9B39D70
Good luck :)
We will wait for your new keygen. We can wait as long as possible.
s1921707
Post by s1921707 »
dibdis
Post by dibdis »
delete
nekron
Post by nekron »
Hi all
I've also message 'EplanCommon.lit' and 'EplanCommon.lir' is not actual - can anyone upload correct ones ?
Regards & Thanks for the work
SmokeyNagata
Post by SmokeyNagata »
Hallo,
Is there anyone who is able to share the template files IEC_tpl001.ept, IEC_tpl002.ept and xIEC_tpl003.ept or any of the 3. I can't find them anywhere on my PC. I am using EPlan P8 2.7
chaos363
Post by chaos363 »
bloemp wrote: Mon Jan 17, 2022 5:32 am Good to see you back Chaos363! Very impressed with the keygen, still figuring out how you got that working! If you ever want to share some details about that, feel free to PM me.
As for the proposed code changes to eplancommoncore.dll, it will start Eplan (as you tested), but ..
Yes, that's how it is with time, just not enough :).
Keygen cost a lot of work, but the result is acceptable. Currently I have no plans to send source code.
Ok, this is something new. Out of interest I will look at it, but promise no solution. In best case, several solutions arise.
There is already a very nice approach, let's see if something comes out of it.
leewheel
Post by leewheel »
Waiting for your good news, thank you very much!
MuratKarilci
Post by MuratKarilci »
Hello dear chaos363,
As you know, EPLAN uses Sentinel RMS 9.X for licensing. I used to use the RMS Decoder/Recoder 5.0 tool (by Zhgong007) for lower versions of the RMS. But this tool does not work for newer RMS license. Is it possible to change the keygen you wrote for EPLAN to a way that can be used for other software? I mean, provide a general tool for licensing all software that uses RMS 9.X.
Thank you
mareq6666
Post by mareq6666 »
I know how to disable firewall or i can add port or program to firewall exception but my smartwiring still dont working can someone share some tutorial?
turo1991
Post by turo1991 »
i have a problem with activation of Eplan P8 2.9. I have list with licenses, but only information that: I cant use because of: "A stand-alone license can only be used on one console."
I did everything with ReadMe so I had modified hosts file in Windows, put dll to eplan bin folders, create a licence file with my HWID and cant run my eplan :(
chaos363
Post by chaos363 »
Attached you will find a way to run Update 1, which has worked so far on two machines for base 2022 + Update 1. Since I do not have ProPanel at hand, I can not say how it behaves with other product lines.
Development was done with the knowledge that routines exist to detect modifications. Despite everything, changes are not related to Update 1 and could work with following updates.
To make modification last a few days longer, the files were protected with special software, which makes analysis much more difficult. Here it could come to false positive virus messages.
The readme file gives short information about installation location, which is basically the same as usual, except for an additional dll, which must be placed in the folder "C:\Users\Public\EPL".
Since I have no knowledge of eplan, someone else will have to do the exact functional testing and confirm if changes works.
Download
Comes later due to problems
MuratKarilci wrote: Thu Jan 20, 2022 8:09 am As you know, EPLAN uses Sentinel RMS 9.X for licensing. I used to use the RMS Decoder/Recoder 5.0 tool (by Zhgong007) for lower versions of the RMS. But this tool does not work for newer RMS license. Is it possible to change the keygen you wrote for EPLAN to a way that can be used for other software? I mean, provide a general tool for licensing all software that uses RMS 9.X.
From my point of view, it is not possible with little effort.
The problem with PKCS#1 check will probably exist for all of them, which can only be circumvented by modifying the files.
RMS 9 framework would also have to consist of individual modules, where each customer can define a certain part himself. But since I do not have this in front of me, I can only make assumptions here, which have arisen during debugging.
Maybe I will pass on the source code of the keygen, so more talented developers can work on it :).
MuratKarilci
Thank you chaos363,
According to your description, I installed update 1 and replaced the new files. But the following error is displayed:
The application was unable to start correctly (0xc0000142). Click OK to close the application.
debugman
Post by debugman »
After I installed the New patch, I clicked EPLAN electric P8 2022 and there was no response. No windows pop up. But I'm sure it's EPL Something's wrong with the DLL. Because I deleted the EPL folder, I can open EPLAN electric P8 2022, but I am not authorized to proceed to the next step.
chaos363
Post by chaos363 »
Ok, here I apparently have to put more effort into testing. The download will be suspended until further notice.
gdbird
Post by gdbird »
How to do the administrator settings, i dont't know the Access code. How can i set the access code or setting it?
bloemp
Post by bloemp »
Try "0000" that should work
bloemp
Post by bloemp »
chaos363 wrote: Sun Jan 23, 2022 11:50 am Ok, here I apparently have to put more effort into testing. The download will be suspended until further notice.
During the development of my own patch DLL I've seen that error after protecting it, so maybe your problem also is in that corner
gdbird
Post by gdbird »
Thanks, your are right ,is 0000 (tyou)
Jake1
Post by Jake1 »
thanks for new dll, i will test it too next time.
No messages or errors so far!! (tyou)
debugboy
Post by debugboy »
Thank you very much for your hard work and waiting for your good news.
MuratKarilci
Thank you bloemp,
Your patch does not need the epl.dll file?
I mean just copy the vcruntime140.dll file to the "C: \ Program Files \ EPLAN \ Platform \ 2022.0.3 \ Bin" ?
turo1991
Post by turo1991 »
turo1991 wrote: Thu Jan 20, 2022 11:40 pm Hello,
Hello, Eplan for version 2.9 is no longer available with vcruntime.dll, and created lservrc from "crack"? This vurnability of epan is repaired already? :( Now my computer shows me that, license is no valid for this comp, but I have correct HWID in generator of license.
Could some one give a help hand?
Jake1
Post by Jake1 »
you need correct vcruntime140.dll for Version 2.9 Licence client, must be patch 1.01 or 1.02, to find here in some posts.
dibdis
Post by dibdis »
Hello everybody,
I am reading this forum and I can see here is a lot of download links, some are working some not, some are debugged versions and some not.
Please can you tell me what is final possible Eplan P8 version available for download, and which link should be use?
ty,
br,
kir9518
Post by kir9518 »
Good afternoon. There is an SQL database for 450,000 products. We are switching to Eplan pro Panel 2022. When adding SQL, Eplan freezes. Can someone tell me what the problem is?
HEROS47
Post by HEROS47 »
I'd also like to try the new patch, but I need update 1.
please upload again.
(tyou)
Jake1
Post by Jake1 »
HEROS47 wrote: Mon Jan 24, 2022 1:56 pm I'd also like to try the new patch, but I need update 1.
(tyou)
Start EPLAN and go to Folder > help > support and update > Download manager > install Update1
No problem to get update with illegal licence :)
zart
Post by zart »
I face that problem with Data Portal at my new installation after update my computer to Windows 10:
This function is available with EPLAN Data Portal Standard access. Currently you have EPLAN Data Portal Guest access. If you wish to get EPLAN Data Portal Standard access, please contact your EPLAN system consultant.
Do someone have solution for that.
Thank You in advance
