[?]: Indusoft v7.1 site key
PDLFFALF
Re: InduSoft Web Studio v7.1 SP3 key
Post by PDLFFALF »
Ahmad_k wrote:Site Code:
F4B7 6D46 8DCD BF5D F22A 1318 4BC5 FE76 6E
[HKEY_CLASSES_ROOT\CLSID\{7E81D9FD-3656-4FA8-88EC-2437CE593EAE}\02]
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="DB263F36F8A4CB1C90A5EE753EECAA1E85CD80D76860D639CB8DAB600019ABFD 04"
Ahmad_k
Post by Ahmad_k »
i don't know why it is not working,
i did a fresh install, i have only one network adapter in my PC (not wireless) and the site code is correct.
i have imported the reg file to registry and always i have "License not found"
is there something i missed ?
PDLFFALF
Post by PDLFFALF »
Please download the file to get your PC site code:
http://pan.baidu.com/s/1i39WC8t
Ahmad_k
Post by Ahmad_k »
My registry was messed up, now it is working :D
Thank you
I noticed that the execution mode is Engineering Only, can you create a site code with Engineering + Runtime ?
PDLFFALF
Post by PDLFFALF »
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="999162C47A9815A3958CC273E85BC80F5E9525620D003FFDD02A4DDD7E847FB3 C2"
Runtime Only
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="B5ACE2F9362E70B67604F7025AD89C3D8A6323564FB7931A4A02792EBBCFDC23 79"
install_base123
Re: [?]: indusoft web studio - TCP/IP Server stoped after 48
Post by install_base123 »
Hi PDLFFALF,
My Indusoft v7.1 + SP2 Site Code is:
9C7C 2992 B6DD CADD 561C E385 2A52 A734 8B
Give me Site Key. Thanks in advance.
Ahmad_k
Post by Ahmad_k »
Sorry for being asking a lot but the engineering + Runtime license has only STANDARD execution mode, while Engineering Only has Advanced server Plus which allows alot of tags near 1000000 as i remember
can you produce for same site code an Engineering+Runtime with Advanced Server Plus execution mode ?
Thanks for your effort, i will appreciate your reply
Moggasdog
Post by Moggasdog »
I cant find the file in the link - could upload again, please? (sos)
franklinleron
Post by franklinleron »
i have downloaded the files and installed indusoft web studio 7.1 but dont know what to do to activate and how to see my site code can someone explain it to me please ?
franklinleron
My site code is
64C2 C93B 6AAA 35D8 0C44 9134 BF2D 1945 5D
CAN YOU HELP ME WITH THE CODE TO VALIDATE THE SOFTWARE PLEASE ?
franklinleron
My site code is
PDLFFALF
Post by PDLFFALF »
franklinleron wrote:My site code is
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="5442AE060862623D6F947240336C7A2C4D4AB9F357152D43AD9D83E0C474C1C9 97"
PDLFFALF
Post by PDLFFALF »
install_base123 wrote:Hi PDLFFALF,
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="E40D592A59EF7FB5F73405D69368286E15ED7FF3A01B13F7EABBDD76D08C4995 41"
Mille
Post by Mille »
Please...
My site code:
0CD9 06DD F567 B189 EE1E 9DC4 86A8 15C9 27
franklinleron
Hello, can you help me please i dont know how to enter that code and where to do it, can you explain me please ?
thanks in advance
franklinleron
hello Ahmad how dod you fix the error i have imported the registry file and still se license not found and in the tag count of the program i can see just 371 can you help me with this please
Ahmad_k
Post by Ahmad_k »
franklinleron wrote: hello Ahmad how dod you fix the error i have imported the registry file and still se license not found and in the tag count of the program i can see just 371 can you help me with this please
Do you have a 64bit windows ? I think this is your problem. The license key must be saved in another location for 64 bit.
I will post it to you when I back to home.
PDLFFALF
Post by PDLFFALF »
Mille wrote:Please...
My site code:
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="06E1C1232BC2E6EA52CF7A721074F54782147ABF0E977D8067AD4E3CBAB66688 ED"
hikara0921
Post by hikara0921 »
my Site Code:
340A 591F 1F1B FF37 F620 524E 1DCB 5F75 E6
can you create a site key with Engineering + Runtime ?
Tks
franklinleron
yes its windows 8.1 64 bits, i jus copied the code to a txt fu=ile and changed the extention to .REG and then i double clicked it and it said that the registers where correctly imported, but then i went to windows registry editor and wnet to file > import > and imported the code.
thanks in advance (pgood)
Mille
Post by Mille »
Thank you for the code but I can't get it to work :(
I imported the key with regedit. Imported ok, but it still shows 'License not found.'
I'm running windows64, can that be the issue?
Is the code for Engineering + Runtime?
Thank you in advance!
Ahmad_k
Post by Ahmad_k »
My site code:
A63073DF48FAE011CD73058E5ED0081D7FB3 34
This is a site key for you
Mille
Post by Mille »
To put in the reg-file??
Did try that, still 'License not found'
What am i doing wrong?
Ahmad_k
Post by Ahmad_k »
No this is a site key.
launch Register from start menu located in Indusoft folder
switch the license to Softkey and press check
click on change license
select the netword card that you use when generating site code
paste the site key
Mille
Post by Mille »
Working. Thank you very much!!
PDLFFALF
Post by PDLFFALF »
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="F0F0665F4B3B0D425C78B066D2ED8EE1013C2B39486BB6EC3C8CD047637EECEF 92"
hikara0921
my Site Code:
Tks
Ahmad_k
Post by Ahmad_k »
hikara0921 wrote:my Site Code:
Tks
8BE15023AF61BDA852D260E351FE555A7FB3 F5
franklinleron
hello AHMAD my site code is
can you generate an enginering+runtime site key please ?
Ahmad_k
Post by Ahmad_k »
franklinleron wrote: hello AHMAD my site code is
A113EFCC4A8D9821A55233A1499493BB1201 4E
hikara0921
My Site Code:
F266 4427 F0A9 666B B3A9 AF55 84FE 492E BD
Thank you so much. (tyou)
Ahmad_k
Post by Ahmad_k »
hikara0921 wrote:My Site Code:
9E21734DD7B525E352BF3449778E95231324 AE
sergst
Post by sergst »
Please, please, please...
09E8 C1AF BDEB 1AA0 27CF 226C FDD3 DF4D 7F
Thanks in advance!
install_base123
Hi Ahmad_k,
My Indusoft v7.1 + SP3 + Patch 4 Site Code is:
Network Adapter: Microsoft Visual WiFi Miniport Adapter
Site Code: 9C7C 2992 B6DD CADD 561C E385 2A52 A734 8B
Network Adapter: Atheros AR5B95 Wireless Network Adapter
Site Code: EE6C 1EA5 E3FF B20E BFB0 2F4E 00C2 0712 E9
Network Adapter: Atheros AR8152/8158 PCI-E Fast Ethernet Controller
Site Code: 74E2 2FA9 1385 2224 16EF 6669 9CAF 9F7C 1F
My Laptop is showing different Site Code for every Network Adapter.
Please help & Can you generate an Engineering + Run-time site key please ?
Thanks in advance.
lsmlsm
Post by lsmlsm »
My Site code:
9109 E744 F2A5 DAE0 4A2F D813 B811 0557 67
Someone could create a Site key for Engineering + Rumtime?
Thank you very much.
agentnumber2
Post by agentnumber2 »
Hi Ahmad_k or PDLFFALF,
My site code is 0F14 6749 C022 433C B10A 1EAB A942 AD1B AC
Would you guys be able to generate me a key for the software and runtime.
Thanks very much!
robcioj
Post by robcioj »
24FE 3CC5 1A69 A049 FEA9 F2C0 82EA 2BAC 41
javtell
Post by javtell »
Hello Ahmad_k
my site code is
F0B4 33E3 8436 2868 DC53 0CD4 B49A 57BF A6
can you please generate a runtime + engeneering sitekey.
and also another just for runtime please ?
boss123
Post by boss123 »
My Site Code:
4C75 656C 7CBD AE53 0E69 5D90 8227 8FE3 40
Please send to me the site key, thanks in advance
PDLFFALF
Post by PDLFFALF »
sergst wrote:Please, please, please...
Thanks in advance!
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="192C4FEBFB5EF7C78E405E9A4A4A20A43F1E5D98780AB75FD4BBDAB3BA2A731A B5"
PDLFFALF
Post by PDLFFALF »
install_base123 wrote:Hi Ahmad_k,
Thanks in advance.
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="D509BC9778D361A519E5DFAB05B7C1D93D0AE2799D78AF60286B5358A0D6F831 23"
PDLFFALF
Post by PDLFFALF »
lsmlsm wrote:My Site code:
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="DA7AE14FC4454063677F13429234DBBB98273DD1116564D53CB8987D59736A63 AD"
PDLFFALF
Post by PDLFFALF »
javtell wrote:Hello Ahmad_k
my site code is
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="A102AEFD2A1A0794C86AEDA2A286B354657FA272FB06C5E8A19524353A33C785 6C"
PDLFFALF
Post by PDLFFALF »
boss123 wrote:My Site Code:
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="0D8731E13DD0FADB53E9D03ECC812A2197A904C9E2DBC24FBA933E39C9EFEF10 8A"
walker1990
Post by walker1990 »
hallo!!
that is my site code: C4AD 52DE 20FB 8245 91FF 734A A643 A5E5 A9
could You help me?
boss123
Post by boss123 »
Sorry I was download the software from indusoft.com, its not work.
Now I downloaded it from the site you mentioned.
The Site Code:
10ED D5C3 1A30 5255 A14A 5E69 4E71 544A 42
Would you please send to me the site code? thanks in advance
PDLFFALF
Post by PDLFFALF »
boss123 wrote:Sorry I was download the software from indusoft.com, its not work.
The Site Code:
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\Iesil Famgrro\\PC:"="A472F6DB89B1096B9BE0ED98F12644C0CF0A96ED5366CEA516C3FEDD2A7F0EEF 88"
boss123
Post by boss123 »
Dear Sir,
I m using windows 8 64 bit, it's not working, how I can find the site key?
Thanks in advance
javtell
Post by javtell »
my site code is
can you generate the code for an engineering + runtime please ?
and if possible another code just for runtime
PDLFFALF
Post by PDLFFALF »
IWS 7.1 SP3:
http://pan.baidu.com/s/1eQtNpXw
1:Please download the file to get your PC site code:
2:imported the reg-file with regedit.
3:launch Register from start menu located in Indusoft folder
4:switch the license to Softkey
5:run IWS.OK.
