Eplan P8 2.8/2.9 + personal keygen
Тools, Elcad, Eplan, ...
Vasiliy
Re: Eplan P8 NEW VERSION 2.8
Post by Vasiliy »
Vasiliy wrote: Thu Jan 21, 2021 8:26 am This was a clean install on Windows 8.1 Pro x64 (installed on a VM (VMWare)). I tried to install 2.9.3.14179 and 2.9.4.14642 (after deleting, I thoroughly cleaned the EPLAN traces). License Client (x64) 9.1.17.18800, with the new License Client from 2.9.4.14642 it did not start at all.
Maybe the problem is that all updates are not installed on Windows?
I attach logs from "C: \ Users \ Public \ EPLAN \ Electric P8" https://anonymousfiles.io/hZE55Ekv/
From EplLog.eldb:
License 'EPLAN Electric P8. Professional 'is no longer available. Error [226].
Failed to initialize the EPLAN license system. Unable to start EPLAN (MAX 70.03): License 'EPLAN Electric P8. Professional 'is no longer available. Error [226].
Error starting EPLAN. Failed to initialize the EPLAN license system. Unable to start EPLAN (MAX 70.03): License 'EPLAN Electric P8. Professional 'is no longer available. Error [226].
Could not find setting STATION.SystemError.LogFilePath.
Application closed
juanmemo
Post by juanmemo »
Wow great advance! Awaiting for the final patch! You rule! (oo)
ecadelect
Post by ecadelect »
*1LSACRHJNFWDBEL2004,*1LLQANVKFSRU5C6001C,*1TPTQP4S3TR9SCT2018
Could you please give me general instruction on how to patch it?
I'm downloading the Eplan software from this link; https://fastshare.cz/15529328/eplan-p8- ... pdate4.zip
liu_sg780912
Post by liu_sg780912 »
liu_sg780912 wrote: Thu Jan 21, 2021 12:02 am
chaos363 wrote: Tue Jan 19, 2021 11:08 pm Let's just test it out. I would provide an application with which you can determine your hardware id. Tell me this and you will receive the license and patch. The keygen is released later with which the license can be created flexibly.
I couldn't test any other products but activation could open the entire licensing system. So far, the activation has worked on three different systems.
Unfortunately, the license only works for one user so far. The license cannot be used via a remote desktop and not in a VM. A solution for this should only be a question of time.
Product: EPLAN Electric P8 2.9 / EPLAN Electric P8 2.9 SP1
Application: https://anonymousfiles.io/ffwxs7wQ/
*1HSMRKF4QEZPPNG2004,*1HHE8C7YHBFJSMV001C,*1F35GPETU2QKSDZ2018
OK!!THANK YOU!!
chaos363
Post by chaos363 »
Since i have only tested with windows 10 so far, i would now set it up myself. As written in a previous post, the installation in a vmware is not yet properly supported, but this relates more to the generation of the hardware id. But since the hardware id works, I'll test it in windows 8 and get in touch with you.
chaos363
Post by chaos363 »
chakotay wrote: Thu Jan 21, 2021 7:58 am Cool, thank you. Chapeau.
Eplan 2.7 doesn't work. Eplan 2.9 works. :D
Nice to hear that it works :). If you try to activate with EPLAN 2.7, please note that the crack must also be in the following folder.
A user confirmed to me that the activation for EPLAN 2.6 / 2.7 / 2.9 works.
C:\Program Files\EPLAN\Platform\2.7.x\Bin
EPLSG
Post by EPLSG »
I think that:You are the magician. It would be great a report for installation. I want to ask you: Eplan normally have an online activation,inserting EID directly whwn open P8 for the first time. Is patched too?
With full patch that I hope arriving soon is possible works with Eplan with internet connected or not?
PcFr34K
Post by PcFr34K »
I would also like to test if 2.9 works. Currently using Eplan 2.7 on am Macbook with Parallels with Win10 x64.
My Hardware IDs:
*1AN7PHF7JY8K2MX2004,*1H6WVMNL73SX9F5001C,*1Z3QTESBP93B5Q92018
By the way, GREAT work!
regards
Sprudel1968
Post by Sprudel1968 »
Could someone upload the patch to another site?
Can't download it.
Is there a detailed instruction here?
omronswitcher
Post by omronswitcher »
If you would, please, here's the HW-ID:
*1SVQATZ3L3B3BMH2004,*1RSRCGA9CHYUELA4001C,*1EXXEWU8HZ9GFHA2018
It would aid a lot. Thanks in advance!
Last edited by omronswitcher on Tue Jan 26, 2021 12:20 pm, edited 1 time in total.
chaos363
Post by chaos363 »
EPLSG wrote: Thu Jan 21, 2021 3:07 pm I think that:You are the magician. It would be great a report for installation. I want to ask you: Eplan normally have an online activation,inserting EID directly whwn open P8 for the first time. Is patched too?
The following steps must be carried out to install the activation. This information is also contained in the Readme.txt, which is available in download file.
1. Open C:\Windows\System32\drivers\etc\hosts
	-> insert the following lines
		0.0.0.0 eplan.prod.sentinelcloud.com
		0.0.0.0 licensingservice.epulse.cloud
2. Copy Crack\vcruntime140.dll into install dir
	-> C:\Program Files\EPLAN\Platform\2.9.3\Bin
3. Copy License\lservrc into lic dir
	-> C:\Users\Public\EPLAN\Common
4. Run EPlan
In the end, the online activation only downloads the license that I have made available to you and pushes it into the following folder. When the application starts, it is checked whether this file is there. If not, the popup for entering the license appears. The license itself is an exact replica of the original, where only the PKCS#1 check is not valid. This is what vcruntime140.dll is for.
The change in the hosts file means that EPLAN can no longer correctly resolve the dns addresses for licensing and thus cannot make calls home. Of course, the possible addresses could be expanded by updates from the manufacturer.
The activation that I have sent is in a final state. There could only be problems with an incorrect calculation of the hardware id. Now the possible users must be adjusted or network licenses generated.
At the moment I don't think that the manufacturer expects this activation, which is why everything should work.
omronswitcher
Last edited by omronswitcher on Tue Jan 26, 2021 12:19 pm, edited 1 time in total.
chaos363
Post by chaos363 »
Try this license, it should work.
https://anonymousfiles.io/60bnEyEI/
reedice
Post by reedice »
My Hardware IDs:
*17LZZSWGH9YR2CJ2004,*16RULGUTR4VWJP7001C,*1A5LW5PA29PFSKX2018
mareq6666
Post by mareq6666 »
Helllo
My HW ID *16D8CDLQ5DHGZMC2004,*1NMBH4XQ64VADLU001C,*12RWJRQKL7EEUHJ2018
Thanks a lot . You are god :). Can you please give us exact note how to install and active eplan 2.9.
for example
1. install eplan 9 sp1 update4 ?
2. install eplan license manager ?
3. active eplan via your crack shown in readme.txt ?
chaos363
Post by chaos363 »
omronswitcher wrote: Thu Jan 21, 2021 5:31 pm If you would, please, here's the HW-ID:
*1SVQATZ3LEB3BNH2004,*1RSRCC9GHYUELA4001C,*1EXXEWU8HZ9GFKA2018
https://anonymousfiles.io/AptaXS2b/
chaos363
Post by chaos363 »
PcFr34K wrote: Thu Jan 21, 2021 3:12 pm I would also like to test if 2.9 works. Currently using Eplan 2.7 on am Macbook with Parallels with Win10 x64.
My Hardware IDs:
regards
https://anonymousfiles.io/pvp2ce5j/
Vasiliy
Post by Vasiliy »
chaos363 wrote: Thu Jan 21, 2021 7:29 pm
Thank you!!! Great job! Works under VMWare, Win8.1x64. Eplan version 14179. Professional license. (tyou) (oo)
chakotay
Post by chakotay »
I revise my statement.
If you copy the vcrun140.dll into the Eplan27 Platform binary directory, this hack works, too.
Looking forward to the final crack.
drag1975
Post by drag1975 »
Would like to test it as well. Win10, Mac, Parallels Eplan P2.9 SP1
Great Job!!!
*1WDFYYDMAVDREQU2004,*13NNMALS8EJLEEA001C,*1LBDFAFJRMFTVHK2018
ck1234
Post by ck1234 »
Really good Job!!! Would like to test it as well. Win10, PC, VMWare P2.9 SP1
*1M9VCA934Y5NCDA2004,*1LCTGBBYWXENEA8001C,*1ZENNATNMTD2WGA2018
anoniempje
Post by anoniempje »
Thanx, My ID is *1WYH5L95BFL2GCY2004,*1BRZXSKGJYS9YCX001C,*1C768NYUWDVXRLA2018. Win7 Professional. V2.9 SP1
nyam
Post by nyam »
Cheers for a great job, currently using version 2.7...kindly share for v 2.9
My ID is *128YFG2ZJ59RZQ82004,*1SP7PBVSP8MV6NV001C,*15HX3HJBSYUBUDB2018
Elahe
Post by Elahe »
Hi, Thank you for your help, for windows 7 Professional x64 this is my HW ID :
*1GGR5Y8MDLHDDK52004,*1SKNPY35NT87GPA001C,*1967DLZFA8XBYGL2018
rogerg85
Post by rogerg85 »
Thank you in advance.
Windows 10 Pro x64
HD ID:
*1VRSLYFHXDVH2LM2004,*12LTG8GEHVDNBRJ001C,*15WSLZCJJ6EKCDA2018
PcFr34K
Post by PcFr34K »
(suc) (thnx)
Wow, awesome. Just works perfect. Installed in Parallels V16 on a MacBook Pro.
Just install Eplan 2.9 and copy over the two files. Thats it.
Now I'm excited for the final Patch to make these two files on any machine for yourself.
Thank you!!
HRES
Post by HRES »
Hi chaos363
Please also include me in the group of beta testers.
Thank´s a lot
HRES :wink:
WIN10x64
*1RPSDS27Z5QU4EC2004,*17DHQRVBQ4XGGP4001C,*1WDGDCCLRNYVQLK2018
metl83
Post by metl83 »
Hi, chaos363. could you generate a license for this id *17C9VJ422FFNVJN2004,*1HZUXTDUTP6LFHT001C,*1HHKRSAZXA87XHN2018 please.
metl83
Post by metl83 »
keymak
Post by keymak »
Windows 10 Pro x64
HD ID:
*17ZCYLUYKZ689P42004,*1F86UF9EJEWNQA4001C,*1T6J64EWGVP27HR2018
chaos363
Post by chaos363 »
I would be willing to donate some bitcoin dust.
Send Private message for Private message !!! (pm)
If you want to support me, I would add the address with download.
At the moment I'm in the process of building a GUI for keygen, which is well advanced. This also gives you the opportunity to freely define the content of the license, which makes license smaller than 2mb and significantly
accelerates loading times.
Since the keygen is almost finished, I would no longer evaluate hardware ids and use the time to finish the keygen.
Be patient a little more :)
PcFr34K
Post by PcFr34K »
djto wrote: Fri Jan 22, 2021 3:54 pm Hi chaos363 could you generate a license for this id *1CMARQEDB6J8VCF2004,*1SWZ4AS98SPRBFZ001C,*1B3BVZU8SAA6HPW2018 please.
I currently have Eplan 2.7 and everything works, I can install version 2.9 without uninstalling version 2.7?
thank you for the great work you do
I'm using 2.7 also and do not needed to uninstall 2.7. Only installed 2.9 additionally. No problem.
When the new licence file ist copied, my 2.7 doesn't accept it directly. So I did the same steps for 2.7 and now both ist working. 2.7 and 2.9.
regards
Sprudel1968
Re: Eplan P8 2.8/2.9 + personal keygen
Would like to test too.
Win 10 64bit
*133SF4X759FJME72004,*1HYV3VSEE9XTWLE001C,*1CFEKPRUE9KU3AZ2018
urban99
Post by urban99 »
Vasiliy wrote: Fri Jan 22, 2021 5:32 am
Hi Vasiliy
Could you maybe upload your VMWare image? - it would be exactly this what i need
also would like to share my deepest admiration for chaos363 (oo)
FIL_V
Re: Eplan P8 2.8/2.9 + keygen personale
Post by FIL_V »
Win 10 64bit
*1HSJUGVUAJ3R3LQ2004,*1ZHJTPPREZ6U5GM001C,*1SWBNKFFHTDCYB22018
George_I
Post by George_I »
Hi ,
Win 10 64bit
*1Y4VDZ6Z833Y3KM2004,*1H8P2BMXLMUTXPY001C,*16UARD3FE3CAAP92018
cuervo2k
Post by cuervo2k »
Win 10 64bit
*1PCYW9MXPPJEVRB2004,*1ZYTS84L84E98QG001C,*1RJBQW6XFD9D3BH2018
thanks
amk_
Post by amk_ »
I would like to test it too.
Hope you can help.
Win 10 64bit
*18BACVCJS6FC7GN2004,*1L2R74AHK7YYVK6001C,*1HAVDCFLRQZYKLQ2018
Best regards,
mojtaba
Post by mojtaba »
*1E6XGMZYMG52RRW2004,*1X22BYBRSF949EN001C,*1KX9UXA9HP9D7L42018
Hi. Thanks for the great job you did. This code is for my system.
van8x10
Post by van8x10 »
Detected: Trojan:Script/Wacatac.B!ml
metl83
Post by metl83 »
van8x10 wrote: Tue Jan 26, 2021 6:57 am Detected: Trojan:Script/Wacatac.B!ml
sent to Kaspersky and Dr.Web - did not find viruses
https://vms.drweb.ru/scan_file/
https://opentip.kaspersky.com/
please tell me name programm found the virus in this file? if it is a built-in antivirus WIN10, then it is often mistaken, for example, not allowing you to break the license itself WIN10
noom33
Post by noom33 »
Hi ,
Win 10 64bit
*1YSJFFPUVJC3NB82004,*19F45U2PEE3XWJE001C,*1NQDGASTVV4XVE82018
rumi
Post by rumi »
Hi chaos363
Win10 64bit,
*1DZ8X36YAJ2K3C52004,*1X6LTJKV42LYLFD001C,*1UDHQWSFVQ5P3RU2018
Info
Faq & Info
Faq & Info
Post by Info »
chaos363 wrote: Tue Jan 19, 2021 11:08 pm Product: EPLAN Electric P8 2.9 / EPLAN Electric P8 2.9 SP1
my Kaspersky and Virustotal noting detected see SHA256
https://www.virustotal.com/gui/file/aff ... /detection
chaos363
Post by chaos363 »
My applications do not contain viruses, which is why the .exe is fully visible. If this is too unsure for you, you don't have to run the application :).
chaos363
Post by chaos363 »
And there is the good piece. I hope you can do something with it.
### Crack ###
The file vcruntime140.dll must be in the main directory of the corresponding product. This is automatically loaded into the application process when it is started and ensures that the license you have created yourself is checked successfully.
For eplan eletric 2.7 this is: C:\Program Files\EPLAN\Platform\2.7.3\Bin.
For eplan eletric 2.8 this is: C:\Program Files\EPLAN\Platform\2.8.3\Bin.
For eplan eletric 2.9 this is: C:\Program Files\EPLAN\Platform\2.9.3\Bin.
### Keygen ###
The keygen can generate a license for all current products, but only with the correct license information. There are the following 3 types of license information.
- System
- Module
- Option
To license a product, System_ and Module_ (with the addition "Release:") must be available. Everything else is optional and will only be used if the product is intended to. Option_ cannot currently be saved because I have not yet seen the benefits.
I have implemented a template function so that not everyone has to assemble the license themselves. This consists of a simple text file which contains the id and the text per line. The text and the "=" can be omitted, as only the id (e.g. System_150) is relevant. If the line is invalid, it will not be added.
EplanCommon.lit is read in so that the existing licenses are known. It is checked whether the file is in the current directory. If not, there is a backup in keygen.
The keygen was built in a short time, which is why it is certain that not all problems will be intercepted, but it should work.
### Requirements ###
- Microsoft Visual C++ Redistributable 2019
### Install ###
-> e.g. C:\Program Files\EPLAN\Platform\2.7.3\Bin
-> e.g. C:\Program Files\EPLAN\Platform\2.8.3\Bin
-> e.g. C:\Program Files\EPLAN\Platform\2.9.3\Bin
3. Generate license with Keygen\EPlanKeygen.exe and save it into lic dir
4. Run EPlan
Download: https://anonymousfiles.io/k5kK3XVK/
mareq6666
Post by mareq6666 »
Hello thanks buddy is it working in WMware ?
chaos363
Post by chaos363 »
mareq6666 wrote: Tue Jan 26, 2021 7:25 pm Hello thanks buddy is it working in WMware ?
Yes it works.
tonyjordan
Post by tonyjordan »
Works on both Vmware and Virtualbox. Thank you Chaos for this great work. Please let me know how i can make a donation to you.
metl83
Post by metl83 »
tonyjordan wrote: Tue Jan 26, 2021 7:42 pm Works on both Vmware and Virtualbox. Thank you Chaos for this great work. Please let me know how i can make a donation to you.
COOL!!! Thank you! how donate? ), please send way )
