2016-01-12 EPLAN 2.1 2.3 2.4 2.5 patch x64(Final version)
				abelinux
Re: 2016_01_05 EPLAN P8 1.8- 2.5 patch Windows x32x64.rar
It was there on the zip file uploaded yesterday: '2016_01_05 EPLAN P8 1.8- 2.5 patch  Windows x32x64'.
If you download it today, there's a new version: '2016-01 06 EPLAN P8 1.8- 2.5 patch Windows x32x64', which does not contain any subfolder.
				titus95
Yes, just copy version.dll to C:\Programmes\EPLAN\Platform\2.5.4\BinLuca wrote: What exactly did you do? Only copied the version.dll to C:\Program Files\EPLAN\Platform\2.5.4\Bin ?
I even reinstalled the program, copied the file but still lag occur about every 60 seconds.
I'm doing this on a virtual machine but I doubt that this is the problem.
Edit: the only real difference is that at the start the eplan-eb2.ys168.com opens in the browser..
System : Win 7 Pro 64b Ver. 6.1.7601 Service Pack 1 (mode test)
Eplan 2.5 HF1 Ver. 9451
				Rasputingue
Re: 2016_01_06 EPLAN 2.5.4.9380 patch x64
Can anyone confirm if lag stops with this new patch? I just went to 2.4  two weeks ago and I don't want to risk again now.
				Luca
I can't confirm it. Even with the new patch that is uploaded today i still have freezes. I have tried almost everything - new installation, with HF1, without HF1, with SN-U29627.EGF, with SN-U10066.EGF, the dll file is correctly placed because i have pop-up every time the program is started... but still the freezes occur
Edit: now that I think about it, may be the problem is within HASP runtime version. I'll look for a newer and will tell you how it went
Edit2: Nope. There is no newer version. Nothing changed
				PDLFFALF
I only tested Electric P8 2.5.4.9380 . Are you installing EPLAN not this version?
				Luca
Yes the version is 2.5.4.9380
				van8x10
Same to me (Windows 10 x64 Home Single)!Luca wrote: i have pop-up every time the program is started... but still the freezes occur
.... the only real difference is that at the start the eplan-eb2.ys168.com opens in the browser..
				Luca
There is a new version of the dll file. The pop-up is gone but don't get too excited - the lag stays.
				Perez1985
Are there anyone who doesn`t have lags in eplan 2.5?
				antoan
Does not work (WIN 10 64 bit) ;(
				titus95
				Perez1985
Can you explain detail? Some versions version.dll really reduce the number of lags. For example, without version.dll when you draw a continuous polyline with more segments the interface is frozen for 10 seconds every 60 seconds. With some versions of version.dll lags occur much less frequently. For example, when changing the text box, and so on. It is much easier to tolerate than the original lags. But if you have no lags, we want to understand what the differences in your system.
				dambre77
I confirm that the lag is present with this new file dll.
In this mode is not possibile to work.
Anyone has any other solutions?
Help help help....
Help help help....
				pronto1308
				Luca
No hope. I've tested it
				PDLFFALF
To re download the new crack file.
				Luca
Re: 2016-01-12 EPLAN 2.1 2.3 2.4 2.5 patch x64(Final versi
Yay finally its working!
I've tested it for about 10 minutes and there was no lag whatsoever!
The pop-up is back but this is a minor thing.
Thanks PDLFFALF!
Thanks PDLFFALF!
				Perez1985
Congratulate everyone. Will it work on hotfix1 for Eplan Electric P8?
And more question: Harness proD 2.5(russion version) is not working. Fatal eroor CLT error 80004005 with last crack.
				PDLFFALF
				abelinux
Yeah..!!
It's working..! Thanks a lot PDLFFALF..!
I'm using
OS: Windows 7 Professional 64 Bit
OS Version: 6.1.7601 Service Pack 1
EPlan Electric P8 - Ultimate (64 bits)
Version: 2.5
Build: 9380
Simply copied file 'version.dll' to specified path and worked like charm.
We can get to work, now
Oh! wait ... we can get to work now ...
I'm using
Version: 2.5
Build: 9380
				adaptine
Can't get this to work.
I downloaded new patch. Run the patch-file and copied version.dll to C:\Program Files\EPLAN\Platform\2.5.4\Bin
SN-U29627.EGF is placed in C:\Users\Public\EPLAN\Common, and SN-U29627.reg is applied to register.
When I try to start EPLAN the webpage http://eplan-eb2.ys168.com/ opens (why?) and this message:
http://i.imgur.com/cCqQj8y.png
Then nothing more happens, can't click OK on the button. Just crashes.
What is wrong?
Edit: I had working 2.4 before, but uninstalled that in prior to installing 2.5
http://i.imgur.com/9VdLhaY.png
Edit 2: It works if I delete version.dll from C:\Program Files\EPLAN\Platform\2.5.4\Bin. EPLAN starts up licensed etc, but with lag issue. Why does webpage open and program crash at message box with version.dll?
Windows 10
What is wrong?
Windows 10
				Perez1985
Thanks a lot for link. But there is one more problem: Whisout registration on the Baidu cloud is not alow to dowload the file. For registration need china phone number. Is this file in other place?PDLFFALF wrote:http://pan.baidu.com/s/1i4aRu6p
What about using new version.dll with Eplan Electric P8 HF1?
				dambre77
The lag is still much less than before with version 2.4
Start of the program is very slow
Thanks anyway
Thanks anyway
				coolenatter1
If anybody have lags in 2.4 just copy the version.dll in
\Platform\2.4.4\Bin
that´s the soloution in my case
						\Platform\2.4.4\Bin
				dambre77
I confirm that this settings the lag is not present nad work very well also 2.4 version
Bye Bye
						Bye Bye
				adaptine
Can anyone tell me why crack website opens up when I put version.dll in eplan folder and start eplan!?
Also eplan wont start up, crashes. I'm not even getting the splash screen.
				coolenatter1
Windows 10? I have the same Problem with Win 10, Win 7 works.
Anyone tested the dll it with 2.5 HF1?
				Serge_n
I have a new Windows 7 x64 and want to install Eplan Electric P8 2.5.4.9380
Please, prompt the correct installation procedure and treatment - step by step:
1. Install Eplan Electric P8 2.5.4.9380
2. ...
3. ...
2. ...
3. ...
				antoan
1. NET OFF
2. Install Eplan
3. UAC OFF + (WINDOWS TEST MODE)
4. HASPUserSetup install.
5. Install multikey + copy SN-U29627.EGF C:\Users\Public\EPLAN\Common\ + add reg database: *.reg
6. Copy version.dll C:\Program Files\EPLAN\Platform\2.5.4\Bin\
						2. Install Eplan
				antoan
It works for me (WIN 10 64 bit + EPLAN 2.5 HF1)
				yohimself
supplementary
Show
				EplanUser
Hello antoan,
Can you tell me exactly wich version you have use for Windows 10 please.
I have no problems with windows 7 but it doesn't work with windows 10.
I really need it work's.
Thanks for help and sorry for my english.
				antoan
What is the problem? You could not install the multikey program?
(I use Eplan 2.5 (+HF1) + WIN 10 Pro 1511 64 bit)
				slinky
Has anyone got a Virtual Machine of this running?
Would be easier to share than everyone finding issues and posting questions.
				Burned Electrician
I did this procedure but with file "SN-U38269". I found it when I downloaded the program from viewtopic.php?f=7&t=23112&p=74234#p73945.antoan wrote:1. NET OFF
2. Install Eplan
Finally, when I run the program, it displays this
 and it opens the link  "http://eplan-eb2.ys168.com/". What do I have to do?
 and it opens the link  "http://eplan-eb2.ys168.com/". What do I have to do?-
				antoan
Burned Electrician:
I think this file (SN-U38269+reg) is not good.
Use this:
SN-U29627.EGF + SN-U29627.reg or SN-U10066.EGF + SN-U10066.reg
I think is a bad entry in the windows regisrty.
Look at the difference:
SN-U10066.EGF:
"HlkMemory"=hex:\
00,00,57,55,50,30,55,31,30,30,36,36,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
SN-U29627.EGF:
"HlkMemory"=hex:\
00,00,57,55,50,30,55,32,39,36,32,37,00,00,00,00,\
I hope I did something to help
Use this:
SN-U10066.EGF:
"HlkMemory"=hex:\
SN-U29627.EGF:
"HlkMemory"=hex:\
				Burned Electrician
Antoan:
Where will I find it?
I forgot to say that my system is windows 8.1.
I found somewhere these steps for version 2.3:
"1. Install Eplan P8 2.3
2. Copy the license file (SN-U10066.EGF) C: \ User \ Public \ Eplan \ Common \;
3. SN-U10066.reg run the file and add data to the registry;
4. Run the driver installation Multikey - emulator from your Release \ MultiKey64 \ install.cmd;
5. Run a test mode in Windows 7 x64 dseo13b.exe running the program and the radio button for "Enable Test Mode".
By the way, just note that here also provides the opposite effect "Disable Test Mode", disable the test mode;
6. In one corner will display "Test Mode Windows 7 Rekease 7600;
7. Run the program dseo13b.exe;
8. Add a digital signature for the driver Multikey.
To do this, select "Sign a System File" and enter the filename including the full path "C:\Windows\System32\Drivers\multikey.sys", test mode does not turn off!
9. Reboot your computer;
10. run eplan prof+"
Are these the same approximately with yours?
				antoan
Burned Electrician:
Here is the crack for x64 windows:
(2016-01-15+EPLAN+2.+1+2.3+2.4+2.5+X64+crack.rar)
The exe file will do everything:
- copying license (SN-U29627.EGF)
- add data to the registry
- multikey install...
				Burned Electrician
Antoan:
Sorry, but I was confused.
Therefore, which are the correctly steps?
edit: I did this procedure:
1. Net off
2. Install eplan
3. Install "HASUserSetup.exe"
4. run "EPLAN全系列 2. 1 2.3 2.4 2.5 X64 crack.exe"
5. copy version.dll to C:\Program Files\EPLAN\Platform\2.5.4\Bin
but without result. The problem remains the same.
1. Net off
2. Install eplan
				antoan
Burned Electrician:
Are In Windows Device Manager, between the usb controllers these:
SafeNet Inc. Hardlock Key
SafeNet Inc. USB Key
If yes, then I think you have wrong entries in windows registry.
				diamond
if you have the Wrong SafeNet Inc. Hardlock Key. Then you must deinstall this with remove driver. An install the Hardware Manual.
				Burned Electrician
Antoan and Diamond:
Sorry, but I don't understand you. I have no idea what you said.
				dambre77
New file version.dll work fine with eplan P8 version 2.4 and 2.5 but the lag is present when i work with eplan enhanced version 5.
Anyone have this problem?
It is possibile have a new file version.dll that work also this version?
Thank's a lot for response.
				adaptine
What eplan 2.5 build do you use? 9380?antoan wrote:What is the problem? You could not install the multikey program?
I also Have windows 10 64bit
OS Name: Microsoft Windows 10 Home
OS Version: 10.0.10586 N/A Build 10586
				AmazingTrans
Same issue with burned electricians.
Did the following procedure:
no devices removed
removed failed
devcon failed
Eplan installed on W8.1
EP Version: P8 2.5.4.9380
Thanks!
Command prompt show the following after ran crack.exeedit: I did this procedure:
1. Net off
2. Install eplan
no devices removed
removed failed
devcon failed
Thanks!
				AmazingTrans
Copied all the multikey files to c:\windows\system32
ran install again. this time got a little further. Not sure if i should skip this step and move forward since devcon failed.
I ran the MultiKey64 on a w8.1.
No devices were removed.
Device node created. Install is complete when drivers are installed...
Updating drivers for root\multikey from C:\Windows\system32\multikey.inf.
devcon failed.
Press any key to continue . . .
				Burned Electrician
AmazingTrans:
I read your pm but I didn't manage to do anything about eplan. I don't understand where is the problem about the crack! I was thinking to install previous version of eplan but I didn't. Because I believe that the problem will remain.
				aliuta2000
Could put somebody put complete crack for Eplan 2.4 ? or i should use the crack for 2.5 ?
Eplan 2.5 i manage to make-it run for one trial , after that , i close-it and openit again , and is asking about license.
From all topic about Eplan 2.4-2.5 seems to be better on Eplan 2.4 , but the link that i have use-it is containing just Eplan 2.4 , no crack , and i tried to use this patch from Chinese site, but also this is asking about license.
Like idea i have uninstall 2.5 , and install 2.4 . Should i do something more about REG , or to delete something into the system ?
Thank you a lot for help .
PS... I have succeded to unblock with the Eplan 2.2 crack , but i have some errors when i open . also is the version ulimeted , not the version profesional .
I can use -it .
If you have the crack version for 2.4 please put some lick for download .
Thank you a lot !
I can use -it .
Thank you a lot !
				gyemeira
Done with Eplan Electric P8 2.4.5 9380, windows 10 pro 64bit 1511
1. install Eplan
2. Off OUAC
3. Enter to Windows Test Mode
4. Start EPLAN全系列 2. 1 2.3 2.4 2.5 X64 crack.exe
5. Copy version.dll
6. Done
						1. install Eplan
2. Off OUAC
5. Copy version.dll
6. Done
				John Charles
I have Eplan Electric P8 2.4.4 8366, windows 10 pro 64bit build 10586, but not work, help me.
the problem is the dongle.
