Eplan P8 2.8/2.9 + personal keygen
Тools, Elcad, Eplan, ...
rezamz
Re: Eplan P8 2.8/2.9 + personal keygen
Post by rezamz »
s1921707 wrote: Sat Oct 23, 2021 12:49 pm EPLAN_Smart_Wiring_2022
https://gofile.io/d/WEh7Tv
This can't be cracked
Hi dear friend
This link has expired
Please share SMART WIRING again
I am using version 2.7 but I still have lag problem in every 60S
https://veryfiles.com/o9m7055y306g
zart
Post by zart »
Trying in keygen add an ability to run 2.6(witch is a last that may import 5.7 projects,and I have many).Ho has details steps to do lservrc to add abilities to run 2.6 with same key.
Thank You in advance .
Jake1
Post by Jake1 »
You can work with version 2.6 too when you have licence client from 2022.
Copy the .tpl file from crack folder. Or copy licence file from common folder.
Open keygen.exe, load the copy from .tpl file
click "add" from modules, insert 2.6 in search field on top, add all options.
Safe .tpl and create new key.
I dont know exactly which file you need to run 2.6, if you have all options you have best chances it will work :D
If you have problems load the old .tpl and create new licence or replace licence file in common folder.
It's time to convert all the old 5.70 projects! :wink:
Good luck
bloemp
Post by bloemp »
This one works
Jake1
Post by Jake1 »
bloemp wrote: Fri Dec 10, 2021 5:11 pm Hi guys,
I created a another version of the vcruntime140.dll.
This one works (well at least for me, with limited testing) for version v2022.0.3.323 AND for v2022.0.3.339.
Therefore you can update to SP1! Hopefully it will work for you too.
https://gofile.io/d/qNldQd
Enjoy!
(gpost)
Tested, works great! (tyou)
Thanks for your work!
Best greetings
HooK
Post by HooK »
Excellent @bloemp (pgood)
Works like a charm (so far as my testing goes...)
Others can confirm as well.
(tyou)
-HooK
rezamz
Post by rezamz »
Enjoy!
Hi
Works great without any problems (tyou)
But it does not work for the 32-bit version (smart wiring) 😭
leewheel
Post by leewheel »
Enjoy!
Thank you very much! (tyou)
5156PBK
Post by 5156PBK »
Enjoy!
The tests are as follows: the text cannot be edited, and some instructions are not executed
Jake1
Post by Jake1 »
i tested more...
No problems when i open the program.
When i open a project i can't see frames or title formular. :(
When i convert a project from 2.9 to 2022 Update 1, i can see frames.
When i export the project to .epj and import the .epj project i can see frames and title formular.
When i go back to 2022 without Update1 the projects are ok, all frames to see.
Anybody have same problems?
TheDuke
Post by TheDuke »
@Jake1
Yes, Same here
bloemp
Post by bloemp »
Hi Guys,
Another day, another try... I've modified the patching to include more addresses that seem to be involved.
If it doesn't work for you, it would be helpful to describe what doesn't work based on an example of the included sample project "ESS_Sample_Project".
This way I can check future patches against that functionality.
s1921707
Post by s1921707 »
rezamz wrote: Fri Dec 10, 2021 10:15 am
Hi dear friend
I don't have a complete, only the server side
s1921707
Post by s1921707 »
rezamz wrote: Sat Dec 11, 2021 3:47 am
Enjoy!
Hi
Do you have smart wiring 2022 Monitor and client?
bloemp
Post by bloemp »
Hi
No, the provided vcruntime140.dll is 64 bit version only, also I don't have access to the Smartwiring 2022 software.
If you are in a position to share the software, I could see if we can make it work.
5156PBK
Post by 5156PBK »
bloemp wrote: Sat Dec 11, 2021 10:51 am Hi Guys,
1。Compressing the project card takes n long to complete,
2.The project inspection will take a long time to complete,
Jake1
Post by Jake1 »
- Still no frames in my Projekt with own frames, no title formular
- When i try "compress project > reorganize" it does not work in all projects, in_ESS Sample_project too
Good Luck and and many thanks, bloemp!
bloemp
Post by bloemp »
Hi Guys,
I removed the DLL to prevent to many people downloading it and complaining it doesn't work.
HooK
Post by HooK »
Thanks @bloemp (tyou) (pgood) no worries!!!
We will stay tuned. :D
Jake1
Post by Jake1 »
Take your time!
For now we have 2022 without update1 to test the new software :)
But i will be honest, i always want to have the latest version. 8)
I will stay tuned too :wink:
H123ngoisao
Post by H123ngoisao »
Please someone share me link of Eplan Pro Panel v2022.
Thanks!
artuorik85
Post by artuorik85 »
Hi!
Eplan Pro Panel v.2022:
https://yadi.sk/d/GOB3XAwlpt8utQ
s1921707
Post by s1921707 »
bloemp wrote: Sat Dec 11, 2021 11:27 am
Enjoy!
Hi
I have a way to run it, but there is a lack of client and management installation packages
Daryas
Post by Daryas »
Enjoy!
Hello Bloemp
Thank you for your try, unfortunately that link doesn't work now. Can you again share it ?!
Best regard
zart
Post by zart »
Good luck
[/quote]
Jake1 wrote: Fri Dec 10, 2021 2:52 pm
yolaws
Post by yolaws »
HooK wrote: Mon Dec 06, 2021 9:57 pm Sorry friends. I have been busy with life lately, so not much free time :(
Jake, feel free to share the cracked "Eplan.IdentityClient.Coreu.dll" I have given you with the rest of the people here (pgood) so we don't get an angry mob forming...lol AK47 :P
I spent good amount of time on trying to make a new vcruntime140.dll that will work with Update 1 as well, but I wasn't successful. We need chaos363 to revise it! But for now, just don't apply Update 1 and you will still be able to use EPLAN Electric P8 2022.0.3.17561.
BTW, I have released these on B4A already last month :D :
EPLAN Education 2022.0.3.17561
EPLAN Fluid 2022.0.3.17561
EPLAN Pro Panel 2022.0.3.17561
Cheers! 8)
-HooK
what is B4A?
amoeba
Post by amoeba »
The link https://gofile.io/d/qNldQd is not working.
Can you get a new one?
Daryas
Post by Daryas »
(no)
Daryas wrote: Mon Dec 13, 2021 5:07 am
Enjoy!
Hello Bloemp
Best regard
this link doesn't work. please share it again.
Jake1
Post by Jake1 »
Guys, read the chat!
Patch for Update1 does not work well at this time.
The guys try to fix it, no reason to ask every day for a patch who did not work for now.
Everybody can use first version EPLAN 2022 without ePULSE, read the chat for solution! :wink:
lococb
Post by lococb »
Hi guys,
I can't to start Eplan P8 v2.9 with patch on my PC with WIN10 21H2 (19044.1415). I get a message about license problem (license don't suit to the PC).
At another 4 PCs no problem, but there WIN10 1909.
Does anybody have a solution?
(sos)
Jake1
Post by Jake1 »
Have you changed hardware on this computer?
Start patch 1.02 again and create new licence in "common" folder.
I use 2.9 on Win10 and Win11 without any problems. :wink:
lococb
Post by lococb »
Hardware wasn't change. Problem PC is new DELL latitude laptop, just from box.
I tried to get HWID manualy from EPlanLicenseManager.exe, but HWID the same like in keygen.
Any other ideas? (wow)
Jake1
Post by Jake1 »
lococb wrote: Thu Dec 16, 2021 4:21 am Hardware wasn't change. Problem PC is new DELL latitude laptop, just from box.
vcruntime140.dll is in BIN folder?
Correct version from vcruntime140.dll is in BIN folder? Not newer or older version?
H123ngoisao
artuorik85 wrote: Sun Dec 12, 2021 8:01 pm Hi!
thank you so much!
lococb
Post by lococb »
Jake1 wrote: Thu Dec 16, 2021 10:18 am
I use the correct folder and tried all versions vcruntime140.dll from crack 1.0.0 to 1.0.3.
I started Eplan 2.9 at another 3 PCs and 1 VM. But only one thing different - version of Win10.
Jake1
Post by Jake1 »
Any old licence in common folder, or 2 lservrc files?
Delete all other files from common folder, but not active lservrc file
leewheel
Post by leewheel »
lococb wrote: Thu Dec 16, 2021 6:38 pm
I think only reinstall windows can fix it, i also do this before.
lococb
Post by lococb »
Jake1 wrote: Thu Dec 16, 2021 7:50 pm Any old licence in common folder, or 2 lservrc files?
(no)
No, it's not a my reason. I really done all steps from instruction.
And I was able to do this on other computers successfully.
Problem is only with my new laptop.
lococb
Post by lococb »
leewheel wrote: Fri Dec 17, 2021 1:28 am
It looks like this is the last way.
I'll try system repair before.
(h)
Jake1
Post by Jake1 »
Hmm,
I have no more ideas to fix it, so maybe a new installation is an option.
You can also delete Eplan from laptop, clear registry and install Eplan again, is no so much work as new windows installation.
MuratKarilci
Post by MuratKarilci »
Hi dear bloemp,
Please share again...
Jake1
Post by Jake1 »
MuratKarilci wrote: Fri Dec 24, 2021 7:54 am
Hi dear bloemp,
Update1 still works not fine for now, use EPLAN 2022 without update1
When the guys have a better patch they will share it again.
Greetings
H123ngoisao
Please someone share me link of Eplan electric p8 version 2.9 sp1 update 6 (or 7).
Thanks.
HEROS47
Post by HEROS47 »
Can someone upload Eplan 2022 Update 1 again?
Thank You
rezamz
Post by rezamz »
s1921707 wrote: Mon Dec 13, 2021 3:25 am
Enjoy!
Hi
Please share if you have the server installation packages
rezamz
Post by rezamz »
Enjoy!
Hi
Unfortunately I do not have access to version 2022
I am currently using version 2.7. I think the method of cracking these versions is the same.
MuratKarilci
Please share SmartWiring 2017 with cr***k.
MuratKarilci
Re: EPLAN EPULSE ACCOUNT
MiRi wrote: Sun Jan 02, 2022 7:33 am Hello friends
Please introduce a way to use the 2022 data portal? (tyou)
You can not use the data portal with the cracked version. Because when using epulse, the authenticity of your license is checked by EPLAN. also you must have a ePulse Professional account.
It is better to use edz files that are on the Internet.
MuratKarilci
MiRi wrote: Mon Jan 03, 2022 5:32 am hi thanks
Some friends use the data portal with a valid email, but do not share
In version 2.9 I have access to the data portal.but 2022 is very good
Please help other friends? (tyou)
Your friend is definitely using a ePulse account that has the original license.
Jake1
Post by Jake1 »
No one will give you a legal ePULSU access so you can use it with an illegal EPLAN version! (no)
So give it up!!!
