Fatek Protected File
другие контроллеры
berrter
Re: Fatek Protected File
Post by berrter »
and yet, many passwords are in this thread, the manufacturer from SRPACK or INOVA . may bee others in different countries, he password is the same :)
gssantos
Post by gssantos »
dj1178
Post by dj1178 »
please use other web upload it again
HelpYou
Post by HelpYou »
Drop the file again! (boom)
dj1178
Post by dj1178 »
I cannot download the file from Google
dynak
Post by dynak »
Hi all. Who knows how to open the program data protection?
Thanks in advance.
dipesh1410
Post by dipesh1410 »
Hi..
Share your File..
dj1178
Post by dj1178 »
I can
SHAHZAD AZIZ
Post by SHAHZAD AZIZ »
All plc & Hmi password crack. Contact number.+923464162377. Gmail. shahzadaziz292@gmail.com
matabig1995
Post by matabig1995 »
hello
can you find the password for this file
https://send.cm/d/7FEv
thanks
dj1178
Post by dj1178 »
so easy
it's a Chinese name
matabig1995
What is is!!?
matabig1995
fatekber2020
Fatek ID file (fatek (a) .cif)
Post by fatekber2020 »
Who can tell, the Fatek FBs controller, when trying to connect or look at its status, disconnects the connection with an error - Can not open the customer ID file (fatek (a) .cif).you need to extract the project file, or run after stopping. unable to run because there is protection. who solved this problem?
or switch from Stop to run state, it has to be done through the programmer FP-07C (sos) (sos) (sos)
День добрый!
Кто может подсказать, контроллер Fatek FBs, при попытке соединиться или посмотреть его состояние отключает соединение с ошибкой - Can't open the customer ID file ( fatek(a).cif).нужно извлечь файл проекта или запустить после остановки. запустить не удается потому что есть защита. кто как решал данную проблему?
или переключиться из состояния Stop в состояние run , это необходимо сделать через программатор FP-07C где искать кто знает ? (sos) (sos) (sos)
andreyit
Re: Fatek ID file (fatek (a) .cif)
Post by andreyit »
Про fatek(a).cif и customer ID file писали еще на первый страницах темы, что с этим вы ничего сделать не сможете не получив от изготовителя оборудования этот файл.
С переводом в RUN может быть такая же штука, что в программе плк это заложено (как в мицубишевскийх плк это есть через спец маркера), и ничего не сделаете. Возможно это защита от неоплаты или принудительного техобслуживания через изготовителей оборудования.
fatekber2020
Всем привет , Удалось запустить run на Fatek? осталась проблема как сменить скорость ком порта , он стал по дефолту 9600 , а нужно 38400 ???? или есть метод как сохранить проект ? за любой комент большое спасибо
andreyit
Post by andreyit »
Если в PLC>Setting>Protocol можно что-то менять, то замените первый или второй порт на modbus (нулевой порт не поддерживает). И теперь можете попытаться в регистр R4146 (порт 1) или R4158 (порт 2), записать данные. Сейчас там 5621 в шестрадцетеричке, что значит 9600 bps 7-bit Data, Even、1-bit Stop, вам надо 5663, что 38400 bps 8-bit Data, Even.
Инфо о коммуникации. Инфо о том как высчитать адрес для modbus посылки.
Если нельзя менять, или не сохраняется, то ничего не сделать... Хотя можно еще любой скадой подключится т.к. там используется протокол фатековский которому не надо настройку делать, если через порт 0, и уже через скаду изменить число.
fatekber2020
(welc) (welc) (welc)
Большое спасибо за ответ очень благодарен . У меня нет возможности что-то изменить через Winprolader потому что заблокирован (ev) контролер под файл CIF на которий я не нашел информации , с контролерем чтото случилось что он из RUN вошел в режим STOP режим я включил он запустился , но настройки порта теперь по дефолту 9600 програма не соединяется , можно поподробей о скада , возможно ли изменить настройки на самом контролере кроме winprolader . Большое спасибо что отписал (oo) (oo) (oo) , долго уже вожусь с етим контролером но результата нет , слил би прошивку но как ? (h) (h) (h)
andreyit
Post by andreyit »
Как уже писалось - слить прошивку невозможно, если у вас нет cif файла от производителя оборудования. Обойти невозможно.
А со скадой... Берете тип master scada, создаете подключение, экран, цифровое окно с разрешением менять, подключаетесь и надейтесь. Можно еще подключить панельку тип waintek и через неё попытаться изменить, тоже создав экраны и читать регистр нужный (нужен регистр, типа порта - modbus rtu или ascii, или fatek протокол, и скорость с параметрами).
Ставлю не очень большие шансы на это + может плк забыть эти изменения.
fatekber2020
Всем привет настройку порта я сменил , за ето большое спасибо !!!! от батарейки мог ли повредится проект на контролере ? как убедиться что програма на нем есть , может вичитать регистр ? как убедится что проект там еше есть ?
andreyit
Post by andreyit »
Если батарейка села, то вся программа пропала. Там стоит литиевая перезаряжаемая которой хватает на 6 месяцев, чтобы перезарядится хватает 12 часов
Ну, у вас требует cif, если бы программы не было, то и этого требования не было.
Krisger
Post by Krisger »
Hello guys,
Newbie here, please help me unlock subprogram menu.
https://rapidshare.io/1UZz/1_-1__Belt.pdw
dipesh1410
Password: FM06RU4A
Thanks..
Krisger
Post by Krisger »
Thank you very much! :)
Chuzz
Post by Chuzz »
Hello, could you help me. how can i download the program in plc fatek to upload the file? next i upload it t :shock: o know the password
xavi_zu
Post by xavi_zu »
Hi, i require to connect with fatek FBs-40MCt2-AC.. i tried to cracked with plc key 2.21 but it was impossible cause my PLC's Version is upper 4.52... some one who help for connecting and upload its programm into my pc...
seb_dev
Post by seb_dev »
please can you help me to get password for this file:
https://www.mediafire.com/file/x61togjd ... C.pdw/file
Thanx, Seba
mahmoud31
Post by mahmoud31 »
Please can you sent crack
mahmoudlook1@gmail.com (sos)
mjd-ee
Re: Fatek PLC Password
Post by mjd-ee »
hi all.
i have problem with FBs-20MC..
when i attempt to get online the winproladder gives a message, enter password or ID...
I want to modify the existing code but i don't know the passward...please help me..
thanks advance..
adamalvaro
Post by adamalvaro »
adamalvaro
Please download this file to crack...
https://www.mediafire.com/file/esuukryr ... d.rar/file
berrter
Post by berrter »
5433
ZerocoolMycolit
Post by ZerocoolMycolit »
mjd-ee
Post by mjd-ee »
Main
5249KD
ID
PASS02
Lolq9
Post by Lolq9 »
can You help me with password on this project (PLC ID)?
https://www.mediafire.com/file/jex2b8ka ... B.pdw/file
Thanks ;)
mjd-ee
Post by mjd-ee »
ID
5433
wjmax
Post by wjmax »
Всем доброго времени суток,
ребят не подскажите как разлочить FATEK FBs-20MC (V4.87) os version v4.60 ?
А то турки товарища уже на третий PLC опракидывают.
Каждые пол года станок перестает работать без видимых на то причин,
а турки упирают, что проблемма в PLC и товарищ покупает у них новый ПЛК с запороленной прогой.
Заранее благодарен!
wjmax
Post by wjmax »
Hi Guys,
Will duplicate my question in English.
Can somebody help me please unlock FATEK FBs-20MC (V4.87) os version v4.60 ?
I have no program backup and when trying connect to PLC, it's requests password.
Thank you!
MrArora149
Post by MrArora149 »
Hi, Please Help me to unlock the password for my plc, i have saved earlier backup, thanks in advance.
link to file:-https://ufile.io/2ak2xpia
neobdumanno
Post by neobdumanno »
please give a link to download the software
пожалуйста дайте ссылку на скачивание программы
(oo)
MrArora149
Do you need to retrieve any password?
mjd-ee
Post by mjd-ee »
@ MrArora149
Main AH1210
ID H12101
Ottoman
Post by Ottoman »
Dear all, good day,
could you please help me having passss (main & sub) for following:
https://www.mediafire.com/file/wn8to0qk ... r.pdw/file
(thnx)
mjd-ee
Post by mjd-ee »
Use The Cracked File without password
https://drive.google.com/file/d/1OaWN9s ... sp=sharing
mjd-ee
Post by mjd-ee »
@ Ottoman
Use This File without password
Ottoman
Post by Ottoman »
Thanks put the file STILL HAVING PASSSWORD !!!!!!! :? ??
I need to have the passwords!!?????
nabat
Post by nabat »
Pass GH13OK
Prog ID XY15OK
(boom)
nabat
Post by nabat »
@ Ottoman
Pass GH13OK
Prog ID XY15OK
Ottoman
Post by Ottoman »
Thank you nabat, You are the KING, (thnx)
zk0516
Post by zk0516 »
Dear experts
could you please help me for the password or unlock for following:
https://www.mediafire.com/file/flqiqg7q ... 2.pdw/file
Machine is down and boss is angry..
many thanks!
