Past links are broken
Eplan P8 2.8/2.9 + personal keygen
				dalil
Re: Eplan P8 2.8/2.9 + personal keygen
Can someone re-upload Eplan fluid 2.9?
				UzOdin
@ s1921707
This is Smart Wirng Server. Do you have Smart Wiring Client 2022? And Smart Wiring Monitor 2022?
@ dalil
https://gofile.io/d/8fPWzc
@ dalil
				Linus1
Hello everybody,
I'm new on the forum so this is my first post.
First of all sorry for my english.
I'm searching for Eplan P8 and I've tried to install the Electric P8 2.9.3.14179 version using the 1p02.rar crack but it doesn't work.
The eplanlicensemanager.exe doesn't work, it appears this error: "Error! Redirection from eplan.prod.sentinelcloud.com to local not active" and then "exit"
The keygen doesn't work, it creates a license with the 3 HWID and the eplan systems added, but when I call the program it appears a message that the license is not valid for this computer.
So when I try to activate a license in the next page (trying to activate it online and using the 0000... EID code another error message appears: "impossible to connect to the internet server 'https://eplan.prod.sentinelcloud.com' ERROR [HTTP 12007] Impossible to resolve the name of the server or the address
I don't know if that is the right medicine and if it already works, or if I've made a mistake (very probably...)
If anyone can help me I would appreciate very much.
Thank you all
Thank you all
				EPLSG
I Linus 1
currently I'm using an official license but some weeks ago I installed a license for a friend of mine and worked fine.
I followed the procedure showed in the txt file without online registration.
That's it.
Other forum users will be able to tell you if medicine installation have recently changed.
Keep in touch.
That's it.
Keep in touch.
				Geeklzk
I have a legal serial number and a legal EPLUSE account. The only problem I have now is that the cannot be downloaded from the data portal. Do you have a good solution?
				Jake1
Go to Options > Settings > User > Administration > internet connection
Try connection test, Date Portal must be green.
You are at home or in office?
Maybe a firewall blocks the connection.
				Stefan_TS
Can someone upload Eplan EEC ONE 2022?
				Carlutu
Eplan Fluid 2.9 Links??
				HooK
I was able to patch ePulse login with EPLAN Electric P8 2022.0.3.17561. I tested pushing date many days ahead and it never asks to login to ePulse anymore!
Can anyone share full Setup files for other EPLAN 2022 products? I want to try and crack those too and release soon
Thanks!
-HooK
Thanks!
-HooK
				DesoxyN
Hey everyone,
I'm an Electric & Electronics engineering student. I want to download the latest-stable EPlan Electric. Can anyone link me to correct setup and medicine combo? Thanks!
				tazik
Eplan is free for students. Just download and create a registration and license request during installation.
https://www.eplan-software.com/solution ... -students/
				TheDuke
Hey HooK
This is great news you got to program a crack.
I think that the vast majority of programs are set up on the EPLAN Platform 2022 and all use the same EPULSE ID together, so that your crack then affects the same programs as the chaos363 keygen.
So it would be great for most of them if you would make your crack available to us.
regards
regards
				Jake1
Great news, indeed!
				5156PBK
EPLAN Platform 2022 Update 1 17617,CK
				HooK
Yes, cracked DLL from License Client will bypass ePulse on all EPLAN apps.
They just released Update 1 with new version of License Client so I will patch that one now as well...
-HooK
-HooK
				leewheel
Wait the good news!! & Thanks!!
				leewheel
This Keygen for EPLAN Electric P8 2022.0.3.17561 Still working,but in EPLAN Electric P8 2022.0.3.17617, its not working .chaos363 wrote: Tue Sep 21, 2021 7:55 pm![]()
https://gofile.io/d/CMBfyo
vcruntime140.dll has changed and template has been expanded for the new options.
				Jake1
Update 1 is available since friday 19.11, the guys need little time to modify the new vcruntime140.dll.
ePULSE crack works too (I was allowed to test it), so i think the guys will share ePULSE crack and Update 1 crack together, maybe soon!
				vengai
Re: Eplan P8 2.8/2.9 adding EDZ offline data portal files
Hello All
Could anyone provide information or steps in order to open edz offline data portal files download in eplan p8 electric .Please anyone help me.
Thank you all...
Thank you all...
				Jake1
Hi, when you have articles in edz format go to:
Article management > extras > import > use File type "edz format"
Eplan will create folders for pictures, macros too.
				EPLSG
Hi Vengai,
if you want to use the individual parts you can also open or extract files using 7zip.
edz file is like to a zip,nothing else.
				HooK
Bad news: I tried modifying vcruntime140.dll to make it work with the new license client (v2022.0.3.339) without any luck
We will need @chaos363 help with this as he knows more than me!
Bypassing ePulse with new license client is no problem! The problem is now vcruntime140.dll
For now, just don't update the new license client & don't install update 1!
Keep License Client at version 2022.0.3.323!
				lunakk
HooK, can you please share solution how to bypasse ePULSE.
				zart
Please someone apply link for version 2022.0.3.323,because previous not content English language.
Thanks in advance.
						Thanks in advance.
				lunakk
EPLAN 2022.0.3.323
https://gofile.io/d/MuuUEB
				zart
zart wrote: Tue Nov 23, 2021 6:37 am Please someone apply download link for version 2022.0.3.323,because previous not content English language.
Thanks in advance.
				HEROS47
HooK, can you please share solution how to bypasse ePULSE. Please
				zart
For version 2022.0.3.323.
When I use crack EPLAN_Patch_1_0_3 I have a message "There is not serial in "lservrc",but when I use EPLAN_Patch_1_0_2 not
For E-Pulse it is asking serial,when I try to log with my registration email address same that I use successfully for Eplan 2.9 ,and I get a message that Eplan will stop after 1 week.
Any help will be apreceated .
				willi_TC
anyone has a crack/instruction for licencing?
got it going but have the same issue with epulse message - "will shut down in 1 week"
Anyone a good advise?
				mareq6666
Hello just change date in windows and you can use eplan 2022
				Jake1
Will not work!
@HooK has a solution for EPLAN 2022 without update 1.
We need new crack for update 1, but chaos353 is not available...
				AK47
It doesn't look like @HooK have a solution as so far he didn't publish anything. Chaos353 should be very careful as this could be a trolling trying to find how the license is bypassed so they can fix this in future updates.
				Jake1
HooK has the solution for ePULSE, i have tested it and it still works.
It's his patch, he decides when he will release it.
				AK47
Yeah, yeah. Good for him. He can keep it, no worriesJake1 wrote: Mon Dec 06, 2021 7:44 pm HooK has the solution for ePULSE, i have tested it and it still works.
				HooK
Sorry friends. I have been busy with life lately, so not much free time
Jake, feel free to share the cracked "Eplan.IdentityClient.Coreu.dll" I have given you with the rest of the people here
 so we don't get an angry mob forming...lol AK47
I spent good amount of time on trying to make a new vcruntime140.dll that will work with Update 1 as well, but I wasn't successful. We need chaos363 to revise it! But for now, just don't apply Update 1 and you will still be able to use EPLAN Electric P8 2022.0.3.17561.
BTW, I have released these on B4A already last month
EPLAN Education 2022.0.3.17561
EPLAN Fluid 2022.0.3.17561
EPLAN Pro Panel 2022.0.3.17561
Cheers!
-HooK
Cheers!
-HooK
				AK47
Hi Hook,HooK wrote: Mon Dec 06, 2021 9:57 pm Sorry friends. I have been busy with life lately, so not much free time![]()
Jake, feel free to share the cracked "Eplan.IdentityClient.Coreu.dll" I have given you with the rest of the people hereso we don't get an angry mob forming...lol AK47
I spent good amount of time on trying to make a new vcruntime140.dll that will work with Update 1 as well, but I wasn't successful. We need chaos353 to revise it! But for now, just don't apply Update 1 and you will still be able to use EPLAN Electric P8 2022.0.3.17561.
BTW, I have released these on B4A already last month:
Cheers!![]()
-HooK
Is not an angry post at all, I'm just saying the facts everyone like me reading the forum is seeing. And the facts are, some saying that, he cracked the ePulse but not sharing what he did or at least I can't see it, which is absolutely fine and no one forcing you to share. But the question is, if you don't planing to share it why announcing it on the first place? Please answer.
Second, if you are the ordinator of the ePulse crack, why are you asking someone else to share it. Does it takes that long to upload a file with few kb, but didn't take long to write your post above? Please answer.
And again, no one is angry I just share opinion like everyone else have right to do it.
Thank you
				zart
Cheers!![]()
-HooK
<<<"Eplan.IdentityClient.Coreu.dll" I have given you with the rest of the people here >>>
In EPLAN Electric P8 2022.0.3.17561 set up folder ?
When I install that -> with out E-Pulse not running.
				boroova6523
When creating the "lservc" file in the Keygen (1.03) try adding "No Identity Check" and "Skip Identity Check" in the "Modules" section
				titus95
Thank you boroova6523 it allows to open EPlan.
				TheDuke
Thank you boroova6523 for the tips, thats it.
				Jake1
Cool!boroova6523 wrote: Tue Dec 07, 2021 1:43 pm When creating the "lservc" file in the Keygen (1.03) try adding "No Identity Check" and "Skip Identity Check" in the "Modules" section
Always good when more people have a solution for a problem.
				HooK
Ohh god! Drama queen alert
  I'm ignoring you @AK47... you add no value to this thread whatsoever. Move along...
@boroova6523
Good find mate!
 "No Identity Check" and "Skip Identity Check" eliminates the need to patch "Eplan.IdentityClient.Coreu.dll"!
Now we just need to create a new "vcruntime140.dll" to make it work with update 1.
Chaos353 used cmp RAX & R8 registers with v2.9 & cmp R15 & RBX on v2022 (works up to v2022.0.3.323). I tried debugging/tracing to see what can work for v2022.0.3.339 (update 1) but was unsuccessful (so far). Need Chaos363's help at this time!
Cheers,
-HooK
													@boroova6523
Good find mate!
Cheers,
-HooK
				Tesiro
Hello, can you provide the Elpan fluid 2022 installation package? Thank youHooK wrote: Mon Dec 06, 2021 9:57 pm Sorry friends. I have been busy with life lately, so not much free time![]()
Cheers!![]()
-HooK
				HooK
EPLAN Fluid v2022.0.3.17561:
https://disk.yandex.com/d/geXYuAAmQZgEeg
				brusko
 Thank you so much. This way works perfectly.
And small note. The nickname of Chaos is Chaos363 not Chaos353.
				Tesiro
Thank you so much for sharingHooK wrote: Wed Dec 08, 2021 3:43 pm EPLAN Fluid v2022.0.3.17561:
				EPLSG
I am using version 2.9 but I would like to upgrade to the new one. Anyone have an installation guide point to point?.
Thanks all
						Thanks all
				Jake1
Patching 2022 is same as patching 1.9
Use patch 1.03
- Copy vcruntime140.dll in bin folder from 2022
- When creating the "lservc" file in the Keygen (1.03) try adding "No Identity Check" and "Skip Identity Check" in the "Modules" section
						Use patch 1.03
				EPLSG
OK thanks I'll try to follow your indication
				timido
I have installed and patched succesfully Eplan 2022, but if I try to open Propanel 2.9 that was installed and working it says that there isn't a valid license. I have tried to add in the patch all the modules of the version 2.9 and create the lservrc, but it says the same. Is it possible to have at the same time both versions? Thanks!
