May I ask, how You find codes for domino a200? I really need codes for my new job. But I can't find. please help
[?]: Quality codes Domino A series non-impact printers
DamonLuos
Re: [?]: Quality codes Domino A series non-impact printers
Hi everyone!!
marciceee
hello i need code for ir 369bk.
Fotak1234
Hello....im new and i need help.Does anybody have ink cartridge code for IC ink - Domino 420i?!
jcamb
At this time I need some codes for MC 2BK009 - make up
thanks,
jcamb
thanks,
jcamb
jcamb
I need to change the language of a domino A100.
Can someone help me, please?
rolandas
Good day. You cant change easy
. You need rewrite program...
rolandas
Good day,jcamb wrote: Mon Jul 08, 2024 8:34 am Hello,
thanks,
jcamb
7D00-2452D 12/2024
1D4D-0225A 12/2024
Fotak1234
Hi....is anybody using IC ink for Domino?!
dannio
270BK
Hello, why my Domini A-Series plus write "Wrong ink type", after i enter new ink q code from new ink tank? We buy same inks BK270 all times?
080-750-2297 10/24
670-409-7405 02/25
152-198-2734 02/25
049-275-2803 02/25
080-750-2297 10/24
670-409-7405 02/25
152-198-2734 02/25
049-275-2803 02/25
dannio
270BK
02/25 500-670-5449
02/25 500-670-5449
Valiants
.... what codes do you need for A_Series and GP ?? Just name it !
Valiants
Remarks above you have 1 wrong inkdannio wrote: Fri Sep 06, 2024 6:36 am 270BK
080-750-2297 10/24 .... 10/24 270 BK .... OK
670-409-7405 02/25 .....05/24 291 BK .... NOT OK
152-198-2734 02/25 ..... 02/25 270 BK .... ok
049-275-2803 02/25 ..... 02/25 270 BK .... ok
Valiants
Fluid Type :270BKA
Expiry Date :Feb2025
Assigned Batch :Batch No.
Customer Name :Customer details ... HAPPY CHRISTMAS 2024
Number of Generated Code(s) :n/a
The Following Code(s) Apply ...
367-584-9725
172-846-9285
836-495-9732
247-748-7258
952-707-2484
953-987-2483
883-243-5779
473-812-5495
671-856-8524
424-407-6597
235-889-6742
325-421-7967
747-159-2982
150-186-2784
652-847-9876
212-248-7495
892-772-4755
942-415-7529
151-989-2764
367-584-9725
172-846-9285
836-495-9732
247-748-7258
952-707-2484
953-987-2483
883-243-5779
473-812-5495
671-856-8524
424-407-6597
235-889-6742
325-421-7967
747-159-2982
150-186-2784
652-847-9876
212-248-7495
892-772-4755
942-415-7529
151-989-2764
Franc88
Hello CIJs!
We decrypted those codes. I work with CIJs for 20 years.
I can generate any Quality Code QC for Domino A Series, A120 A220 and A+
Also I can generate Linx CJ400 5900 7900 Surefill codes and Maintenance / Service Passwords , send me the PRC code then I generate the password.
Linx 8900 8920 8940 Linx 10 , Linx 8820 8840 codes and Rfid Tags also, like 1240 1512 1505 ..
please email me inkjetprinter@protonmail.com (I look this email each 10 days )
For Domino Ax Series ax150i also I have a solution using original RFID tags (no chinese clones).
Domino A320i A420I A520i I also can generate 2BK009 2BK006 351694-0021 344497-0021 351694-0022 344497-0022. Tetra Pak Domino 520i 320i 420i also.
For Videojet 1000 series I can provide the chips generator
Regards!!
Regards!!
ali9999
Hi everyone;
Looking fresh codes for 299 Bk and 445 or 446 Rd
ali9999
Franc88 wrote: Thu Nov 07, 2024 7:28 pm Hello CIJs!
Regards!!
ali9999
Friends can share with me and exchange Quality Codes of only Domimo Printers on this WhatsApp number please also can discuss faults , i try my best to help you out …….
+92-322 6860820
Sajid Ansari From Pakistan
shtlkj
Domino A200+Opaque printer IR-253WTSPB ink. I need quality codes
. Thanks in advance.
dannio
Здравствуйте, Ax150i Domino, есть две коробки просроченых баков с разбавителем и чернилами. Работать дает, хотя и пишет что баки просрочены, но спустя примерно 4 часа, блокирует чип бачка разбавителя и просит поставить другой, ставлю, опять 4 часа и блок. Можно как то это недоразумение обойти или две коробки с расходниками в мусор?
Eng:
Eng:
Hello, Ax150i Domino, I have two boxes of expired tanks with make-up and ink. It works, although it says that the tanks are expired, but after about 4 hours, it blocks the chip of the make-up tank and asks to install another one, I install it, again 4 hours and a block. Is there any way to bypass this misunderstanding or two boxes of consumables in the trash?
m4r10
Hello everyone, please I need codes for MC-2MC009 and IC2BK009,
thank you very much everyone, excellent forum.
Johnny Jordan
Hi CIJ,
I want makeup codes for domino A320 ink type is 2bk034
ali9999
299 and 291 bk quality codes need
the1cale
Is it possible to use a code or change the RFID tag for the ITM module in the Ax150i ?
elektrihar
Please send me a quality code for 270 BK
sofa09
hello, i need code for 2BK006 domino 320i
rolandas
Hi, yes if you would use twice same ITM you need re-stick new RFID tag instead old. You need buy same means ITM02, ITM06 or ITM03...the1cale wrote: Tue Apr 29, 2025 7:53 pm Is it possible to use a code or change the RFID tag for the ITM module in the Ax150i ?
rolandas
106-690-0000 299BK
119-699-9990 299BK
lmartins
olá, preciso do código para 2BK009 domino 320i
PapaInk
Hello to all troubled Domino's
I was once again faced with the problem that I still had plenty of ink left, but the 600 hours had expired.
I'd like to try developing a code generator, but I still have a lot to learn about the codes. I've already deciphered some of the code and successfully tested the first one I created today. However, to separate luck from skill, I need more information about the codes, or rather, testers.
I already have a small database based on the codes mentioned here and those collected elsewhere. Unfortunately, it doesn't contain complete information and some of it is incorrect. Nevertheless, I was able to figure out a few connections, but not everything I need to reliably create a code.
Please,
if anyone needs to renew their code, please write to me and send me your old code, ink type, batch number, and expiration date.
I will return a working code if possible; if not, I'll get more information that way.
Best regards, all over the world
JOA
Please,
JOA
Bashaib0
I need Mc 2BK006
Teng
Hello everyone,
Please share new IR270BK codes.
Thanks.
Thanks.
esprimo
270BK
527-072-0395
672-925-1370
527-072-0395
672-925-1370
esprimo
Hello. Need code for 252WT Domino
Root84
Need quality code for IC-1BK001, MC-1BK001 and the I-tech for domino A430i
shtlkj
Hi all. Domino A200+Opaque printer IR-253WTSPB ink. I need quality codes
. I'm having trouble finding it.
setool3
IC-253WT 06/26
230-281-9027
545-499-8907
350-907-0859
090-700-9825
893-988-0975
230-281-9027
545-499-8907
350-907-0859
090-700-9825
893-988-0975
setool3
IC-1BK001 12/27
3E1D-8D26-7ABE
8AE1-AE16-2F78
F1CA-8774-6E82
MC-1BK001 12/27
5079-19290
A260-9B950
1900-2208C
itech
6DDB0B28C
5013EDEDB
DDAE0D3DB
3E1D-8D26-7ABE
8AE1-AE16-2F78
F1CA-8774-6E82
MC-1BK001 12/27
5079-19290
A260-9B950
1900-2208C
itech
6DDB0B28C
5013EDEDB
DDAE0D3DB
setool3
IC-252WT 06/26
574-752-0000
630-755-4444
747-402-5555
150-547-5555
274-650-5555
327-040-5555
330-354-7777
950-574-7777
070-645-7777
002-457-8888
574-752-0000
630-755-4444
747-402-5555
150-547-5555
274-650-5555
327-040-5555
330-354-7777
950-574-7777
070-645-7777
002-457-8888
