Eplan P8 2.8/2.9 + personal keygen
Тools, Elcad, Eplan, ...
rogerg85
Re: Eplan P8 2.8/2.9 + personal keygen
Post by rogerg85 »
Hi chaos363,
maybe you have the module / relase for
Eplan Pro Panel Production AutomationML Export
Eplan Pro Panel Production Rittal Assembly
Eplan Pro Panel Production Rittal Cutting
Eplan Pro Panel Production Rittal Machining
Eplan Pro Panel Production Rittal Wire Processing
Eplan Pro Panel Production Wiring Rittal - Averex
Eplan Pro Panel Production Wiring WuS-Tec
Thank you in advance
mayers21
Post by mayers21 »
TOP!
Perfect work!
Evan ePlan Data Portal is working
redline147
Post by redline147 »
Hello chaos363 congratulations on your work.
The post I put in was wrong. It was a bug in my code, there was a throw not contemplated. Sorry.
The API works perfect.
If you need support in programming, maybe I could help you, I would be honored.
mayers21
Post by mayers21 »
Doe's someone have Fluid working and download link?
Thanks!
FIL_V
Re: Eplan P8 2.8/2.9 + keygen personale
Post by FIL_V »
can someone share the installation of eec one 2.9
Thanks in advance
oleksandr_ua
Post by oleksandr_ua »
EPLAN 2.9 Sp1 Update4
where is the healthy link?
(dlink)
debugman
Post by debugman »
chaos363 wrote: Fri Feb 05, 2021 11:21 am As information for everyone, I'm currently trying to optimize the activation and actively looking for errors. The keygen does not load template properly. Here he has problems with very long names, which has now been fixed. The license term is now also set to unlimited.
I have built a new template which should start the application directly (only 1 valid license), so no selection anymore. Modules are also all activated.
Next I try to find errors in calculation of hardware id.
Thank you for your work. We are looking forward to your updated version. When will it be available for download.
deividasn
Post by deividasn »
Hello, Thanks For Eplan, but i have a problem
I have installed Eplan 2.9 on Windows 7 cracked its working.
But my primary PC have installed Windows 10. Installed Eplan 2.9 on Windows 10 cracked , but Eplan won't start i get error see picture.
https://i114.fastpic.ru/big/2021/0207/f ... 950bf7.png
chaos363
Post by chaos363 »
Here would be an update from the keygen, which contains following changes:
- systems and modules can be sorted by clicking on column
- adding systems and modules now has a live search which is not case sensitive
- templates are now imported correctly
- a new template was built, which should contain everything relevant for 2.7 / 2.8 / 2.9
- the licenses are now valid indefinitely
A few additional words about the template and the activation of features.
As written above, the template contains all modules, which can lead to an error message in older versions of EPLAN. The reason for this is the EplanCommon.lit and EplanCommon.lir files, which contain the currently valid features. With older versions it now loads module_xxxx, which is not available in the old version. An error is displayed when starting that the two files are not up to date.
There are two ways to fix this.
1. Update EPLAN :).
2.1 [Only 2.9] Copies EplanCommon.lit and EplanCommon.lir from keygen directory into eplan directory (C:\ProgramData\EPLAN\Common).
2.2. [2.7/2.8] The non-existent module must be removed. The module that was not recognized is visible in the license information window at start-up, as the text is missing and just the ID (e.g. module_xxx) is shown.
If the window with license information does not appear, e.g. If only one valid license is available, you would now have to add another valid license (system_ / module_) in keygen. This brings the information and missing module can be removed.
Version: 1.0.1
Download: https://anonymousfiles.io/k5kK3XVK/
deividasn
Post by deividasn »
Thanks! working now!
becareful123
Post by becareful123 »
Thanks a lot, chaos363!!!
However, the mandatory scan of several virus scanners reported a hit (Win32/Wacatac.B!ml and VCObfuscator.gen!C). Please check. (sos)
becareful123 Please post link to virustotal
my Kaspersky and Virustotal noting detected see SHA256
https://www.virustotal.com/gui/file/aff ... /detection
https://www.virustotal.com/gui/file/afff6a52324ad34bce59a08a2956ab24e36314d93b078fb8e7c1e377c8126a52/detection
becareful123
anoniempje
Post by anoniempje »
I have installed eplan 2.9.4 under hyper V. I am trying to activate it now but I get the following message: 70:56. Not suitable for the current version. what could this be?ImageImage
The lines are added to the hosts file and the dll file is copied.
DanH
Post by DanH »
Turn off enhanced session.
chaos363
Post by chaos363 »
I can understand your concern, but I am absolutely not ready to look for the code, which is why isolated anti-virus programs report cryptic names. If other programs were to work without a digital signature, many anti-virus programs would also sound alarm.
The keygen contains a number of general functionalities which I can quickly code in if necessary. Otherwise there is a good amount of dead code. Since it's not about performance or memory size, I don't care.
It also contains the routines for calculating the license. For an anti-virus program this is a whole lot of code that shows cryptic behavior.
anoniempje
Thanks it works now!
His_Shadow
Post by His_Shadow »
Absolutely great !! (pgood)
It even works on an ESXI if you start EPlan beforehand via the console and then take it over via remote desktop.
The new Update 5 on VM without any problems!
Great thank you !!
mastercheto
Post by mastercheto »
I installed EPLAN 2.8.3 (Win 10) and used your last instruction and keygen.
After copied two files EplanCommon.lit and EplanCommon.lir in directory C:\ProgramData\EPLAN\Common I tried to start EPLAN, but follow message appears:
Maybe I have to use another template valid for 2.8.3. I don't know. Can you help me about this error message?
Thank you in advance !
chaos363
Post by chaos363 »
Since I haven't tested it with 2.8, it probably won't work. It is best to replace the two files with original and reinstall them if necessary (sry).
To solve the real problem, the non-existent module must be removed. The module that was not recognized is visible in the license information window at start-up, as the text is missing and just the ID (e.g. module_xxx) is shown.
Brodie1201
Post by Brodie1201 »
Is there a risk of using a legit Epulse login for home use?
mastercheto
Thank you chaos363. I removed non-existent modules and systems and created key again. After that the message disappear and EPLAN 2.8.3 started normally.Good job. (clap)
Donjore
Post by Donjore »
(close) link eplan fluid 2.9?
siraguiar
Post by siraguiar »
Hello chaos363.
If you don't mind, I would like to use the new version of eplan:
*1UA6YCHM3GECAH72004,*1T4ELRLJ4MXPFN9001C,*15CYNYW49WSA5FR2018.
Win 10 Home, 64 bits.
Thanks for the great job.
Best regards.
oleksandr_ua
EPLAN Data Portal - ??? (not_allow)
How to activate EPLAN Data Portal ?
I just need to register under any email?
wconan100
Post by wconan100 »
perfect ... thanks for sharing...running the versions perfectly.
TheoPap
Post by TheoPap »
Hi guys, can somebody describe in details the process and the step to follow with the Keygen. Also when start Eplan , a pop up window with the following information appear:
"'''The license files
C:\ProgramData\EPLAN\Common\EplanCommon.lit
C:\ProgramData\EPLAN\Common\EplanCommon.lir
are not up to date
For the activation, these files must be up to date in the current version''''
Any suggestion ??? Although after that, eplan load and seems to work fine
in keygen version 1.01, i have found these 2 files, replace it and works!
hier you find the keygen 1.01 https://anonymousfiles.io/k5kK3XVK/
chusebizen
Post by chusebizen »
I'm really surprised, how some people do not understand how this whole thing works.
The Eplan people make money from the legitimate licenses that they sell. They are expensive, yes, but the software is masterclass in his area.
Nowadays all systems are internet connected, so they moved their license system to a network one, in which, you can get te best of the software due to its network tools.
Now, thanks to chaos (huge work man, btw) it is possible to use (again) the software but in an offline basis with very few network tools available.
Sure you can connect to internet, but they can detect you (as chaos stated, the are many processes running in background, and more than one can check online with servers) immediately having your IP, Mac address, host name, hardware fingerprint of your computer, (they will defend their interests) and possibly claiming you any fine for using their software without license. Likewise other companies like Aut* d*sk or D*ass*ult.
So think a little bit, all network functions, may not work without a legit license.
And that includes Data Portal, because even with a legit license, if you don't pay the annual maintenance fee, you have no access to Data Portal, which is located in their servers.
So please, think about it before asking how to access to data Portal or any other network feature.
elektron0x90 wrote: Sat Feb 06, 2021 9:15 am
cobra919 wrote: Fri Feb 05, 2021 11:49 am Hello,
Chaos I want to thank you that worked straight away, thank you.
I have a few general security questions.
Can Eplan find out somehow that I have worked with a cracked version if I continue to send the Eplan files?
Does anyone know by chance whether Eplan does anything to detect cracked licenses when I send the Eplan P8 files?
I only need the version because I want to work from home. We have an original license at work.
As far as i know they check the serial. So you should enter the serial of your office-licence in the keygen and (*sorry @chaos363) replace the serial: chaos363 in the keygen with it
regards
And yes, in every page of an Eplan project is stored the serial number of the dongle, (they do this from the very beginning, in the page tree, right click on a page, properties, scroll down, you will see the dongle, and you can't change it). And maybe there are other ways to mark the serial number of the dongle not so "visible". Therefore, when you handover a zw1 file to someone, at least the serial number of the dongle is stored in every page.
Cheers,
ficatdi
Post by ficatdi »
I have installed Eplan V2.9 on several PC with Win10 64-bit and Win7 64-bit. On some PC there was already installed V2.7, on some there wasn't. Some machine was on VM, and other regular OS. On PC with Win10 everything went OK.
But on every Win7, i have some problem.
Eplan start, but there is some error and some funtionalti is missing.
Error message is:
Eror initializing the module 'EplanEplApiModule'.
Method for patching was same for both Win10 and Win7.
It wasn't significant if it was VM, or regular OS, or there was already installed V2.7 or not.
I tried importing all modules, but that didn't help.
Here is picture with error.
Does anybody have idea what i was doing wrong, or what shell a do?
https://ibb.co/djNMxkL
bernards6
Post by bernards6 »
Hi, Thanks for all your input. I Still cant understand how to generate the HW-ID and active/download the crack. can some one help please
Luisinho
Post by Luisinho »
My activation doesnt work, i tryied many times and always get this error https://imgur.com/a/78sW3yJ "license file is not suitable for the current version, but the license manager recognize the CHAOS363 generated from KeyGen but dont show me versions to select to open the software. How i solve this?
erwin_claus
Post by erwin_claus »
Works like a charm, perfect!!!
W10 x64, using Eplan 2.9 SP1
Thanks a lot!!!
chaos363
Post by chaos363 »
ficatdi wrote: Tue Feb 16, 2021 12:13 am Eplan start, but there is some error and some funtionalti is missing.
Error message is:
The faulty function calls are not based on unlicensed modules, there seem to be fundamental problems with operating system / EPLAN installation. To get a better overview, I have a windows 7 x64 vm, which is provided with latest security updates. Here the license is loaded cleanly and there are no incorrect entries in the eplan log.
Of course, I can't say exactly why, because windows 7 is end of life and normal update function does not provide everything you need to install eplan. There can be clear differences here, which is why functions cannot be loaded properly. It's not impossible with windows 7, but I would recommend windows 10. If someone has a solution for this, he is welcome to share this.
Luisinho wrote: Tue Feb 16, 2021 1:51 pm My activation doesnt work, i tryied many times and always get this error https://imgur.com/a/78sW3yJ "license file is not suitable for the current version, but the license manager recognize the CHAOS363 generated from KeyGen but dont show me versions to select to open the software. How i solve this?
First, please use newer version (1.0.1) :).
Secondly. To me it looks like you haven't used a template. Your screenshot shows three modules, which are permanently added by the keygen. Please click on TPL Load in the keygen, select EPLAN_Ultimate.tpl file and then click on create.
The problem is simply that the license you created does not have any meaningful entries for EPLAN, which is why you get an error message.
bernards6 wrote: Tue Feb 16, 2021 1:45 pm Hi, Thanks for all your input. I Still cant understand how to generate the HW-ID and active/download the crack. can some one help please
PM is out.
onurbfatsoc
Post by onurbfatsoc »
Good evening everybody.
Anyone have a detailed "step by step" about this process? I tried in my PC but doesn't work, may I did anything wrong.
If possible, with images about the complete process (editing HOST file, generating the license file, etc).
I tried in 2.9.3 version.
Thanks for your time.
See ya.
wconan100
Post by wconan100 »
tufan20
Post by tufan20 »
Here is my hw id
*14F7RX9967M2LKP2004,*1ED62E5DZEUZ2HA001C,*1VR5TY2F3N9L4KE2018
I sent with pm but no answer.
winloud
Post by winloud »
Could I use this keygen to active v2.7?
OSCARFL
Post by OSCARFL »
hi all
the "HOST" file must be with .txt extension ???
thanks
OSCARFL
Post by OSCARFL »
the archive into the PATCH carpet
is EPLAN_Ultimate.tpl
not EPLAN_Ultimate_P8.tpl
xdoit
Post by xdoit »
emm.. the file have no any extension name. Just edit it with any text editor then put it to the original folder.
OSCARFL
Post by OSCARFL »
now works
u need the
EPLAN_Electric_P8_Pro.tpl
not EPLAN_Electric_P8.tpl
OSCARFL
Post by OSCARFL »
many thanks to CHAOS ...
y muito obrigado a CONAN..
(thnx)
leewheel
Post by leewheel »
deividasn wrote: Mon Feb 08, 2021 4:02 pm Hello, Thanks For Eplan, but i have a problem
Same as you......
leewheel
Post by leewheel »
I think it may be because of multiple network cards, the HWID is incorrect , So it shows "License is invalid for this computer"
ficatdi
Post by ficatdi »
Many thanks for your instruction.
All it was needed is to update Windows 7.
After Windows update there was no problem.
Now everything work great.
One more time many thanks for pach.
wconan100
Post by wconan100 »
use esse tutorial que eu criei...todos créditos a CHAOS363 .
https://1drv.ms/u/s!Asfmibl2vx_4oqBOgV2q1rvg8DiS2g?e=E0MaXR
Ringo_tml
Post by Ringo_tml »
Could someone upload EPLAN Harness proD 2.9? I can't find links on the forum.
Thank you very much!
s1921707
Post by s1921707 »
https://pan.baidu.com/s/1-zVKJ9ieB7Sp2De4p0aIbA ,keyword:hf8b
Ringo_tml
Post by Ringo_tml »
Veeeeeeeeeeery Goooooooooooood,Thanks o lot!
snowman
Post by snowman »
You need to install BaiduNetdisk client software and regist a account to get those resouces shared by others through BaiduNetdisk.
