Eplan P8 2.8/2.9 + personal keygen
Тools, Elcad, Eplan, ...
s1921707
Re: Eplan P8 2.8/2.9 + personal keygen
Post by s1921707 »
It has been released, but only with a genuine license can it be downloaded.
ssz66
Post by ssz66 »
EPLAN 2026 Virtual Machine Edition:https://my.world.taobao.com/item/867172585104.htm
For2024
Post by For2024 »
On the EPLAN web /client side, the new 2026 version can only be downloaded if you first exchange your 2025 license. I think this is something new! Attached is the 2026 License Client — I don’t think it will work with the VMware setup, but if anyone feels like experimenting with it, go ahead.
In directory 3 you wil find EPLAN License Client 2026!
https://www.filemail.com/d/jmqibtouebjavbc
4arald
Post by 4arald »
Tested with VMware win10 eplan2025, License client and platform updated. It worked fine. Waiting for the new version 2026 avaible, to test it.
sandy_22
Post by sandy_22 »
@520arrow Thanks a lot. I downloaded the pan baidu archive with https://baidu.erranium.com/ and the crack is still available.
520arrow
Post by 520arrow »
sandy_22 wrote: Thu Oct 09, 2025 10:21 pm @520arrow Thanks a lot. I downloaded the pan baidu archive with https://baidu.erranium.com/ and the crack is still available.
You're welcome
For2024
Post by For2024 »
EPLAN Education 2026, try it
https://www.filemail.com/d/qqpnaikzjfgqinj
PZO_Automation
Post by PZO_Automation »
could you please update the link for Eplan 2026
4arald
Post by 4arald »
For2024 wrote: Mon Oct 20, 2025 12:36 pm EPLAN Education 2026, try it
Tested. It works fine with the chinese license server.
For2024
Post by For2024 »
4arald wrote: Thu Oct 30, 2025 6:55 am
Could you please explain how you did it? I can’t seem to get the program to start through VMware.
Thanks!
4arald
Post by 4arald »
For2024 wrote: Fri Oct 31, 2025 7:08 am
Thanks!
Link to the explanation of license server https://rutracker.org/forum/viewtopic.php?t=6656751.
You need find out the IP address of server and put yours on same range. Then, run eplan2026
using the license manager option, putting the IP of your server. Finaly, login with the user EPLAN and pass 5379
Carlutu
Post by Carlutu »
Hello
My IP address isn't showing up on my VMware machine.
4arald wrote: Fri Oct 31, 2025 5:49 pm
Thanks!
twatson
Post by twatson »
4arald
Post by 4arald »
Carlutu wrote: Mon Nov 03, 2025 6:14 pm Hello
You just need to have the eplan host and the license server on the same network.
Make sure by pinging the IP server from the host.
Klamsi
Post by Klamsi »
Does anyone know how many clients the VM license server can support?
yakuzaturk
Post by yakuzaturk »
twatson wrote: Wed Nov 05, 2025 3:19 pm Eplan electric P8 2026
https://rutracker.net/forum/viewtopic.php?t=6764023
Where are you chaos363? We need the crack for this version. I'm sure this is very simple for you.
twatson
Post by twatson »
yakuzaturk wrote: Sun Dec 28, 2025 6:49 pm
The virtual system licensing method for EPLAN 2025 enables the normal use of EPLAN 2026.
jark1990
Post by jark1990 »
Can anybody share a link with Eplan 2025 or 2026 on Virtual machine?
jark1990 wrote: Thu Jan 22, 2026 3:30 pm Hello,
(mirr) https://disk.yandex.ru/d/ruYZAnnzOggaOw
ebnf
Post by ebnf »
(tyou)
YDC001
Post by YDC001 »
No stand-alone crack available anymore for E2025/E2026?
Or someone who has the info to create my own VM with patched ELM?
Kind regards
polkar
Post by polkar »
could someone share a link for eplan p8 2.7 or 2.8 or 2.9 + crack keygen
thanks
zheng1205
Post by zheng1205 »
https://100-ac.com/ ❌️
I haven't tried it, but if you're interested, you can give it a look
sorry
This is a scam website
polkar
Post by polkar »
zheng1205 wrote: Tue Feb 03, 2026 1:53 am https://100-ac.com/
thanks for your reply, but they wants to pay 93$ ...
nuhrop
Post by nuhrop »
basukesu wrote: Wed Jun 25, 2025 6:00 pm
gino_007 wrote: Mon May 26, 2025 5:43 am
I can't download it (EPLAN_LPM), it's on a Chinese website and that's not so easy if you're from Europe.
I've uploaded both LPM files to google drive to make it easier for others to get them.
:D
https://drive.google.com/drive/folders/ ... sp=sharing
Hello, could you add LPM 2026 if possible, pls
pawel_1980
Post by pawel_1980 »
Looking for a crack or keygen for version P8 2.2 or 2.3. Does anyone have it? Could they share?
monty_burns_007
Post by monty_burns_007 »
has anyone got that VMWARE license server running ?
It's running on my VM, but when trying to connect to it from a 2026 EPLAN license client (running on other PC: Host or other VM) I get
error : Error [Dcom]: [0x800706BA] The RPC server is unavailable. (MAX 10.26 is popup header)
I tried following user in the connect popup:
user: EPLAN2025-20241\EPLAN
password: 5379
in the txt files they talk about:
User licence manager: xx\EPLAN
Pass: 5379
is it user EPLAN ? because there's also a user EPLAN2025
Strange thing when i install EPLAN 2026 inside of the VM, I don't get a license activation window after installation.
It fully works, can even make changes and save. Only Product info says: "EPLAN DEMO SYSTEM".
edit 1: i've tweaked the license VM a bit (settings of DCOM) and now my EPLAN client can also connect to the license server in the VM.
But still it also shows product: "EPLAN DEMO SYSTEM" inside the license screen. (fully functional)
edit 2: strange, I now make a second VM with a EPLAN 2025 installed in it and let it look at the license VM server. Now it looks fully licensed normally. Product now shows: "EPLAN Component Manufacturer".
So the same license is working for 2025, but for 2026 it shows a EPLAN DEMO SYSTEM (but is fully functional), anyone same experience for 2026 ?
monty 8)
elmum
Post by elmum »
I'm having an issue where the "lservrc" file seems to be missing from the virtual machine on the VM License Server.
Can anyone help me with this?
I downloaded the License Server here:
https://rutracker.net/forum/viewtopic.php?t=6656751
monty_burns_007
elmum wrote: Fri Mar 20, 2026 11:20 pm Hello,
i also have that same error message, but you can ignore it, license server works.
elmum
Post by elmum »
I can ping the server, so I know the correct network address.
When I start EPLAN and am prompted for the license server, I enter the corresponding IP address.
Is there anything else I need to do on the VM where the server is running? Start something?
Then I’m asked for a username and password.
I’m not sure what to enter for the username.
I tried “EPLAN2025” as the username. Password: 5379
Then the following error message appeared:
The License Manager ‘192.168.5.128’ is not available over the network.
User: EPLAN2025
Error [DCOM 0x800706BA]: The RPC server is not available.
monty_burns_007
elmum wrote: Fri Mar 27, 2026 7:04 pm Hello,
User: EPLAN2025
I opened up more DCOM settings on the license VM server, otherwise my other PC with EPLAN installed would not be able to connect to the license VM server. Just change with dcomcfg (componet services) and add user "everyone" the the dcom config op eplan processes.
