Did you manage to find a solution to this? Trying to run 2023 P8 on M4 Max with Windows 11 enterprise and get the error about the license being invalid. Any other fixes available?gdbird wrote: Wed Oct 30, 2024 12:05 pm I recently try to using MacBook Air m3 to running EPLAN. As EPLAN only can running in windows system, so my solution is use Parallels Desktop for Mac to install windows. I find in the virtual machine, not all the version of eplan can fully carck like in windows system, I only can crack 2022. using EPLAN_Patch_1_0_3. The reason why 2023 and 2024 also 2024 couldn't crack successful is the vcruntime140.dll . on Mac system , m1-m3 cpu is ARM structure, so the win11 also only can install arm version, may be there are some different to x86 structure systems , then the vcruntime140.dll couldn't work.
Back to your question, usually we use EPLAN_Patch_1_0_5. to crack the eplan. make sure you have add the 2024 module to the license file.
When you update the eplan, the best way is download the update file do not update the client .
Eplan P8 2.8/2.9 + personal keygen
				bombaclot
Re: Eplan P8 2.8/2.9 + personal keygen
				djto
You need to check that the version of windows 11 is lower than "24H2".
I went crazy, because whatever version of Eplan "2022, 2023, 2024 I installed, always the same license error. I installed windows 10 22H2 and everything worked.
Give it a try
Give it a try
				denden
Could you please share the EPLAN_Patch_1_0_3 somewhere?
				520arrow
				denden
Thank you for sending the link, but I can't download it from this server. It requires registration, but it seems registration outside of China isn’t possible, as it doesn’t accept my phone number.
				520arrow
https://drive.google.com/file/d/1ppJAEH ... drive_linkdenden wrote: Fri Nov 15, 2024 8:15 am Thank you for sending the link, but I can't download it from this server. It requires registration, but it seems registration outside of China isn’t possible, as it doesn’t accept my phone number.
				denden
Thanks a lot!
				Esmigol
Please could you send the eplan 2025 installer again to test the crack
				His_Shadow
has anyone managed to get the 2025 version to work? If so, how?
Thanks for your answers!
				Klamsi
downloadlink for P8 2025: https://www.filemail.com/d/eeabsaytougyxdu  available for one week
				His_Shadow
Let me ask another question.
Is there already a vcruntime140.dll for EPlan 2025?
I think that's the only thing missing.
Unfortunately, 2025 requires a new license client. This is probably what causes the error:
"An error occurred while reading the licenses. Error [2100092) The given license code is invalid. Hence, it could not be added to the "no-net" license server."
My 2023 version works great, but unfortunately 2025 doesn't!
The 2025 version doesn't work with the 2023 license client.
Has anyone managed to get the 2025 version to work with medicine?
If so, please describe exactly how!
Thanks!
 Thanks!
				guty97+
Привет друзья, есть ли у кого-нибудь установщик eplan 2025 в utorren или другом носителе, который не является baidui и кряком? Они хотят попробовать несколько файлов tpl и посмотреть, как работает eplan 2025?
				For2024
				basukesu
Hey,
I am having an issue with Eplan P8 2023.
I've seen the issue described here one or two times but never really found a real solution or reasoning to what is causing it.
The issue is, that when I am working on a project after a few minutes it doesn't let me edit texts or object properties.
I can still add and delete any object, just not edit any properties properly.
Sometimes it doesn't happen for up to 30 minutes, sometimes it stops working within a few minutes.
I have Eplan installed on a Windows 11 Virtual Machine.
I've had it installed on various machines, also on Windows 10 it happened.
I hope someone may have a clue for me to what goes wrong here, whether it is an error in the install process or a weird setting I've enabled.
I'd appreciate any help, thanks in advance.
				pinkzwinkz
Does anyone have link for 2025 download? Please, all links are dead
				wconan100
Technically explanation behind this:
EPLAN still passively check his license routine even the application is successfully cracked/patched! And you have altered the Windows HOSTS file correctly to block the EPLAN License servers
The first passively commonly check routine is after between 5-20 minutes after EPLAN has been started.
Then every 3-5 (between) minutes the application “freezing” or “Hanging” for a few seconds
Basically the application is turning into a “viewer” mode! You can’t alter settings or do changed
Why? Because EPLAN thinks it’s 2025! But the current state of the operating system is 2024
This also happens with other features like for example the copy & paste functionality
All credit to...T.R
Open the “Date & time” settings window and keep that settings window open/standby. Drag it out of the middle of your screen but enough to set the time back immediately!
Change date to one year ahead: this is true!
Then open the EPLAN application and the EPLAN splash screen (box) will appear (show)
Now keep an eye out
When you see it’s start loading (bottom of the splash screen) and the first blue box shows up [
Then immediately set “Date & Time” back or click the two buttons: Automatic!!!
Then EPLAN & Crack works %
All credit to...T.R
All credit to...T.R
Now keep an eye out
All credit to...T.R
				JeffZhang
Hello Which Virtual machine you are runing in? I find the crack in VMware can work but when crack at HyperV not success.zerocooolx wrote: Thu Oct 31, 2024 8:33 am Unfortunately not yet. I use Eplan 2024 with virtual machine 23H2. Most likely we will have to wait for Eplan 2025 for use on 24H2
				solid9009
Hi, I'm trying to get the EPLAN Harness working, but I'm getting always a license error 210092 the given license code is invalide. Hence it could not be added to the "no-net" license server
I have generated the license with the keygen which was included. I have tried V23 and V24, but always same error.
What do I wrong?
What do I wrong?
				Dimchek
Folks, few questions.
1. I run EPlan 2024 via script for set date 1 year ahead, okay. But Eplan works so slowly, interface lagging mainly. Eplan start-up time is quite long, but okay - it because of crack I believe. Is it because of crack or may be some libraries/runtimes/packages/framewoks/cookies/bananas is missing
I have no super workstation, but not Pentium II either - Core i7 9750H with 16Gb and SSD. 3D cabinets spin in 60fps. At work we work via rdp, somewhere in cloud and these VMs running fast - but in ProPanel my old laptop looks much better.
2. Is here a way to work with ePulse DataPortal via same hole as been in old DataPortal? You should remember - you needed just create locally part with same name as in DataPortal and the press "update data" - and even with guest account you could get macros.
3. What do you think what could happen if I log in in ePulse with my corporate account? Except of answer "do it! do it!"
				guty97+
Здравствуйте, удалось ли вам получить ссылку на eplan 2025 Я тоже хочу попробовать кряки, которые у меня есть с eplan 2025
				For2024
				Shein
Dear All,
Happy new year!!!
Hope eplan 2025 crack version can get soon!
						Happy new year!!!
				lin2m3
Happy New Year!
Guys, I run into a problem: Worked fine in a Eplan 2022 project but if I wanted to share the project with someone with same version valid licence, the Eplan gives a message: eplan p8 can not open project due to licence differences. Any Idea? BTW, From 2.8 works to convert it to 2022.
				dogpoopdog
Is there a way to crack Eplan Education? I need it for school
				Shein
Dear all,
Eplan 2025 crack is not possible?
				For2024
A solution is needed that works with Autodesk programs, such as the ADSFlex Net Server or the NLM Server, but it needs to be adapted to the EPLAN version. This is why the "no-net server" error message appears. The EPLAN template (TPL) and license are available for version 2025, but the communication with the EPLAN server is missing.Maybe some software guru could figure out how it works.
				alafandy
RIGHTNOW NO SOLUTION  FOR  EPLAN 2025
Connect to License Manager (MAX 13.39)
The License Client was not installed completely.
Please install the program again.
Check license (MAX 73.04)
Error 210092
"no-net" license Server.
Error 210092
				OMkar
is it possible to run previous version if the 2025 version is not able to run right now. i tried installing Eplan 2024 but it showed the same no-net error. I an not able to find setup files for previous versions of e plan. is it not possible to use previous version ? i thought it might work because the .tpl files i have right now are for version 2023 and 2022.
				Klamsi
In the meantime we have 2025, does the problem still exist that you have to introduce the date 1 year ahead?
				Shein
Dear all,
So Eplan 2025 hopless?
				gale99
"Is this a cracked version or?"
				Shein
Hello dear,
If 2025 crack version, kindly share to us...
				fighter_36
Hello Can you share with me eplan p2.9 2025 with crack keygen file . Best RegardsFor2024 wrote: Mon Dec 30, 2024 9:01 am https://www.filemail.com/d/vscugvswrtbjhon
just for 1 week!! V2025
				For2024
				For2024
Please hide the user name in the right corner above!!!
				For2024
				alafandy
NO CRACK 4 VERSION  2025
				For2024
How did you manage to start the program?
With a legal license?
				Shein
				Patrikrou
Hello, I am new on this forum.
I use Eplan 2022 and 2023. But I don’t have access to Eplan data portal.
Is there any free solution for connecting to the data portal?
Please help me with a concrete answer.
Thanks, best regards.
				eddiedon
the man use a VMware to be a license server and push the license . then he can use eplan2025
https://www.bilibili.com/video/BV1rBCNY ... f1a4a98591
				SJJT
 wconan100 ты тута?
 wconan100 ты тута?-
				Patrikrou
I installed eplan 2025 vmware, but I still don't have access to eplan cloud, epulse, data portal.eddiedon wrote: Tue Feb 11, 2025 2:13 pm the man use a VMware to be a license server and push the license . then he can use eplan2025
Please if you can help.
thank you very much.
				pinkzwinkz
Were you able to crack and open the EPLAN 2025 ? Can you share if you were able to make crack work?
				Patrikrou
yes I got it working, but without access to the portal data.pinkzwinkz wrote: Fri Feb 14, 2025 2:10 am Were you able to crack and open the EPLAN 2025 ? Can you share if you were able to make crack work?
 Do you want me to share the download link or something?
				gale99
Hello,Patrikrou wrote: Fri Feb 14, 2025 6:36 amyes I got it working, but without access to the portal data.pinkzwinkz wrote: Fri Feb 14, 2025 2:10 am Were you able to crack and open the EPLAN 2025 ? Can you share if you were able to make crack work?
Please if you can share it it would be great.
Thx
				Patrikrou
				Shein
Hello Dear,
I am not ok to download above link.
Because i can not register with our singapore phone number.
Do you have other way to download?
Thanks.
				Patrikrou
ok I understand, then try downloading through this site https://baidudownloader.com/product/tra ... rive-link/Shein wrote: Fri Feb 14, 2025 2:41 pm
Hello Dear,
Thanks.
I checked and it costs almost 12 usd and you get it in google drive.
				wconan100
hello...friend would it be possible for you to make this virtual machine available on another hosting...I can't download it because I'm not from your region (Country)
