Hi friends,
I need GSD file of CQM1-PTR21, Profibus of PLC Omron.
Its name: 0C_054D.GSD
Many thanks,
[?+]: GSD file of CQM1-PTR21
copy-paste in notepad,save with 0C_054D.GSDобычно находится по адресу:
C:\Program Files\OMRON\CX-One\CX-Profibus\GSD
;** Omron Europe B.V. **
;** European Headquarters **
;** Wegalaan 67-69 **
;** NL-2132 JD Hoofddorp **
;** The Netherlands **
;** European Technical Centre **
;** Zilverenberg 2 **
;** NL-5234 GM 's-Hertogenbosch **
;** Device DataBase File for CQM1-PRT21 PLC I/O Slave **
;** Filename: OC_054D.GSD **
;** Version : 1.0 **
;** Date : February 23, 2000 **
;** (C) Copyright OMRON Corporation 1998, 1999 **
;** All Right Reserved **
;** Important notice: **
;** - Any modification of parameters in this file may lead to undefined **
;** behavior of the Profibus-DP system. **
; General information *********************************************************/
#Profibus_DP ;
GSD_Revision = 1 ; GSD file revision 1.0.
Vendor_Name = "OMRON Corporation" ; Vendor name string.
Model_Name = "CQM1-PRT21" ; Model type string.
Ident_Number = 0x054D ; PNO Identification number.
FMS_supp = 0 ; Profibus-FMS not supported.
Protocol_Ident = 0 ; Profibus-DP supported.
Station_Type = 0 ; Station = DP-Slave.
Slave_Family = 10 ; Slave family = 10 (PLC).
Revision = "V1.0" ; Device revision 1.0.
Hardware_Release = "V1.0" ; Hardware revision 1.0.
Software_Release = "V1.0" ; Software revision 1.0.
Bitmap_Device = "OC054D_R" ; Bitmap RUNNING
Bitmap_Diag = "OC054D_D" ; Bitmap DIAGNOSTIC
Bitmap_SF = "OC054D_S" ; Bitmap SPECIAL
; Specific implementation information *****************************************/
Implementation_type = "SPC3" ; Siemens SPC3 ASIC used.
Redundancy = 0 ; Redundancy NOT supported.
Repeater_Ctrl_Sig = 2 ; Supported, TTL level
24V_Pins = 0 ; No external 24 Volt input.
Set_Slave_Add_supp = 0 ; Station address is set
; through hardware address
; selectors.
; Media access information ****************************************************/
; Automatic baud rate select
Auto_Baud_supp = 1 ; (SPC3 specific feature).
; Supported baud rates:
9.6_supp = 1 ; 9600 Baud
19.2_supp = 1 ; 19.2 kBaud
45.45_supp = 1 ; 45.45 kBaud
93.75_supp = 1 ; 93.75 kBaud
187.5_supp = 1 ; 187.5 kBaud
500_supp = 1 ; 500 kBaud
1.5M_supp = 1 ; 1.5 MBaud
3M_supp = 1 ; 3 MBaud
6M_supp = 1 ; 6 MBaud
12M_supp = 1 ; 12 MBaud
; Max. response times:
MaxTsdr_9.6 = 60 ; 60 Tbit = 6.25 msec.
MaxTsdr_19.2 = 60 ; 60 Tbit = 3.125 msec.
MaxTsdr_45.45 = 250 ; 250 Tbit = 5.50 msec.
MaxTsdr_93.75 = 60 ; 60 Tbit = 640 usec.
MaxTsdr_187.5 = 60 ; 60 Tbit = 320 usec.
MaxTsdr_500 = 100 ; 100 Tbit = 200 usec.
MaxTsdr_1.5M = 150 ; 150 Tbit = 100 usec.
MaxTsdr_3M = 250 ; 250 Tbit = 83 usec.
MaxTsdr_6M = 450 ; 450 Tbit = 75 usec.
MaxTsdr_12M = 800 ; 800 Tbit = 67 usec.
Min_Slave_Intervall = 5 ; Minimum slave interval =
; 0.5 msec.
; DP-slave information ********************************************************/
Freeze_Mode_supp = 1 ; Freeze mode supported.
Sync_Mode_supp = 1 ; Sync mode supported.
Fail_Safe = 1 ; Fail safe supported.
Modular_Station = 1 ; Modular station.
Max_Module = 1 ; Maximum # of modules: 1.
Max_Input_Len = 16 ; Maximum # of input bytes.
Max_Output_Len = 16 ; Maximum # of output bytes.
Max_Data_Len = 32 ; Maximum # of data bytes.
Max_Diag_Data_Len = 6 ; Maximum diagnostic length.
; User parameter message definition *******************************************/
; Preset parameterization
User_Prm_Data_Len = 3 ; message length and default
; message.
User_Prm_Data = 0x40,\ ; Mandatory additional user
0x00,\ ; parameters.
0x00 ;
; Module definition list ******************************************************/
; I/O definitions:
Module = " 2 words In/Out" 0x71 ; 2 words I/O.
EndModule ;
Module = " 4 words In/Out" 0x73 ; 4 words I/O.
EndModule ;
Module = " 6 words In/Out" 0x75 ; 6 words I/O.
EndModule ;
Module = " 8 words In/Out" 0x77 ; 8 words I/O.
EndModule ;
; End of GSD file *************************************************************/
