see v1.8.6 http://plc.net.ru/viewtopic.php?t=7009
EPLAN PPE v1.8.4With our EPLAN Electric P8 we are initiating the new dimension in engineering. A unique range of diverse functions makes interdisciplinary work worldwide a reality. With a free choice between graphical and object orientation the software provides that cutting edge of technology for your success, aligning itself without restriction to the needs of the user. This ensures reliability in handling the software and fast results.
Expect the unique
EPLAN Electric P8 knows what you need. Variant technology, diverse interfaces, and extensive automation options provide for the perfect integration and efficient workflows. In short, EPLAN Electric P8 offers you opportunities you've never had before for your interdisciplinary engineering.
The next dimension in electrical engineering
EPLAN Electric P8 – the new dimension in electrical engineering facilitates both graphically and object-oriented work at all times. With ingenious platform technology, full data support from EPLAN 5 and EPLAN 21, variant technology, internationality, and extensive automation options EPLAN Electric P8 delivers productivity from the outset.
Thanks to the unique Engineering platform this innovative solution can be configuredflexibly to your needs. Many and varied interfaces facilitate the perfect integrationfor efficient workflows. In short, EPLAN Electric P8 is the solution for unlimitedpossibilities in interdisciplinary electrical engineering.
4*44.444.444 + 21.530.204
http://rapidshare.com/files/194541504/E ... _1_8_1.ZIP
http://rapidshare.com/files/194541722/E ... _1_8_2.ZIP
EPLAN Fluid 1.8.4EPLAN PPE is the optimal tool for successful international collaboration in theplanning and realization of electrical, measuring, and control system projects. Besides the maximum data and service compatibility, also the wide range of powerful interfaces, utilizing the full capacity of modern communication channels,supports collaboration by the whole project team over all the planning stages. This mobility and flexibility is particularly effective in the internal environment. For example, EPLAN PPE can also simplify and automatically advance adaptation andmodernization processes at your own company. The new EPLAN technology provides a platform where fluid, electrical, measuring, and control engineering caninteract directly in interdisciplinary collaboration.
The overall concept behind EPLAN PPE is aligned to the present demands ofmeasuring, control, and automation technologies. If work is to conform to thestandards, a process control group concept based on NAMUR recommendationsmust be integrated. These NAMUR specifications for process control engineeringare fully supported by EPLAN PPE. Its practical orientation and ease of use make EPLAN PPE an efficient tool formodern process plant engineering. Established methods and innovative developments have been combined into an extremely powerful and efficient solution.
The new modular Engineering platform technology is your key to the future, providing core functions for fluid, electrical, measuring, and control engineering as well as CAE for electrical systems. Based on a unified platform all systems are supplied from the same database. From now on multiple data entries and inconsistencies are history.
Besides a unified database the platform also includes basic functions like the graphical editor (for circuit diagrams, fluid plans, process control group plans), a unified rights management, the viewer, online/offline foreign language translations, and the comprehensive audit system. The unique framework concept delivers impressively fast results – not least of all owing to the unified look & feel throughout all applications.
4 *44.444.444 + 24.200.257
http://rapidshare.com/files/357065854/E ... d1.8_1.zip
http://rapidshare.com/files/357065883/E ... d1.8_2.zip
http://rapidshare.com/files/357066012/E ... d1.8_3.zip
http://rapidshare.com/files/357065952/E ... d1.8_4.zip
http://rapidshare.com/files/357065447/E ... d1.8_5.zip
EPLAN Fluid supports fluid engineering with automated documentation. Simple handling, numerous test functions, and standard support make your design efficient – from now on the system assumes time-consuming standard tasks.
Compared with conventional, mostly CAD-based systems EPLAN Fluid comes with unique logic functions and automatisms that accelerate your fluid planning. The modern user interface with extensive drawing functions helps you familiarize yourself with its full potential – of course with the complete data stock from the predecessor system fluidPLAN. The autoconnect function applies to all connections that can be provided and analyzed with logical properties. This means you have an overview of all components, including the small parts like connectors, hoses, and pipes – and therefore a firm grip on the costs!
The new Engineering platform is your key to the future, providing core functions for fluid, electrical, measuring, and control engineering as well as CAE for electrical systems. Based on a unified platform all systems are suppliedfrom the same database. From now on multiple data entries and inconsistencies are history.
Besides a unified database the platform also includes basic functions like thegraphical editor (for circuit diagrams, fluid plans, process control group plans), a unified rights management, the viewer, online/offline foreign language transla-tions, and the comprehensive audit system. The unique framework concept deliversimpressively fast results – not least of all owing to the unified look & feel throughout all applications.
ECabinet v1.8
7*44.444.444 + 24.365.105
(rar inside zip)
http://rapidshare.com/files/194540986/E ... _1_8_1.zip
http://rapidshare.com/files/194541083/E ... _1_8_2.zip
http://rapidshare.com/files/194541239/E ... _1_8_3.zip
http://rapidshare.com/files/194541043/E ... _1_8_4.zip
http://www.eplan.deEPLAN Cabinet is a comfortable facility helping you layout your enclosures. You receive high-quality documentation including the full manufacturing data for wire assembly machines and automatic NC drilling machines. This helps you cut your production costs and raise your productivity and quality at the same time.
EPLAN Cabinet Basic
The basic module contains all the functions for equipping mounting panels and whole enclosures quickly and reliably with componentry. The look & feel interface and the engineering tools like the Project Wizard make sure that all users are introduced quickly and easily to project planning.
Modularisation
The modular concept behind EPLAN Cabinet means that it can be adapted to your workflow. Decide your own functionality. Optional modules for routing, NC, and graphical editorround off the strengths of EPLAN Cabinet Basic – for professional enclosure project planningand manufacture.
For you!
