[LINK]: PROFIBUS Scope (Diagnosis/Analysis/Qualification)
ppp
Post by ppp » Thu Jul 05, 2007 6:05 am
"PROFIBUS Scope" фирмы Trebing + Himstedt Prozessautomation GmbH & Co. ( http://www.t-h.de/index/english/99427 )
Work with CP5512 and CP5611
"PROFIBUS Scope" :
distributive+crack
https://www89.zippyshare.com/v/5ZkA59ia/file.html
reupload 20/02/2020
http://www.t-h.de wrote:The PROFIBUS Scope is an indispensible tool for commissioning, FAT/SAT, acute troubleshooting as well as during operation of PROFIBUS installations. Regular or permanent network monitoring allows identification of any failures at a very early stage, and enables you to take measures for preventive maintenance. This in turn minimizes downtime and increases plant and equipment availability.
Plants that have to meet special qualification requirements, such as in the field of pharmaceutical industry (FDA, EU), can be monitored and documented throughout the entire life cycle. Quality assurance is provided manufacturer-independent for all critical network parameters (cycle times, device diagnosis, error telegrams …). This ensures immediate identification of possible configuration failures upon device replacements or extensions. The PROFIBUS Scope is recommended as an ideal tool for validation of FDA-regulated plants in the PNO guideline »Validation of PROFIBUS Systems«.
Extensive trigger functions and record filters allow complex troubleshooting. Typical failures such as double station addresses, short circuits, twisted wires or wrong bus terminating resistors are identified due to their characteristic telegram content or sequences. An extensive online help with practical examples and tips provides valuable support for the user.
Standard CP5512/CP5611 Siemens PC cards as well as PGs with integrated CP5611 serve as respective hardware platforms for direct access in the field. The xEPI is available for central access via Ethernet.
The PROFIBUS Scope has already proved its worth in thousands of installations. By continuously updating the tool, latest requirements and enhancements are directly implemented.
ppp in Russian wrote:Никому надеюсь не надо объяснять для чего нужен снифер профибаса.
Всем хороша программа Amprolyzer (лечилку ранее уже выкладывал на этом форуме).
Но у нее есть существенный недостаток.
Работает она только с картами CP5611 (встроеной в программатор или PCI-исполнения).
А программаторы есть не у всех (у меня например уже нет). Комп с PCI-картой не удобно таскать на производство.
Все-таки снифер это вспомогательная функция карты.
После долгого поиска альтернативная программа была найдена.
Это "PROFIBUS Scope" фирмы Trebing + Himstedt Prozessautomation GmbH & Co. ( http://www.t-h.de )
ppp in Russian wrote:Она работает не только с CP5611, но и с PCMCI-картами CP5512, которые обычно и используют в ноутбуках.
Программа по функциям имеет некоторые отличия от amprolyzer.
Создается впечатление, что она предназначена в основном для специалистов, впрочем режим diagnosis подойдет и для начинающих.
Что сразу понравилось:
- интерфейс программы более продуман чем в Amprolyzer.
- программа разделена на четыре режима для разных целей анализа
- есть лог реального времени в режиме telegrams(в amprolyzer лог создается только после остановки сниферения)
- режиме Signals можно мониторить входа/выхода в виде графиков !!! (правда сам еще не пробовал)
ppp in Russian wrote:- есть богатые настройки фильтрации по DP, DPV1, DPV2, FMS, FDL
- автоопределение типа устройств на линии. Возможность добавления своих gsd файлов устройств.
- сообщения программы можно отправлять по электронной почте
- возможность печати логов прямо из программы.
А так программы во многом схожи.
Также устанавливается свой драйвер на карточку. Правда не из программы, а bat-файлами, что наверно более удобно.
Также можно сохранять сообщения в файл, но ограничения на 1000 сообщений уже нет.
Также есть функция автоопределения скорости на линии.
Сравните логи этой программы с Amprolyzer (так фонит процессор по MPI ):
Compare Amprolyzer and Profibus Scope
Amprolyzer
Profibus Scope
В общем крутая реально полезная программа.
исходник:
http://www.t-h.de/media/content/Downloa ... .5.1.9.zip
For work without HASP key
ppp in Russian wrote:SP для работы без Hasp:
http://rapidshare.com/files/41097987/so ... 9.exe.html
mirrors:
http://www.megaupload.com/?d=2WXYQ6E7
http://slil.ru/24594710
Может понабиться также DAO3.5 (на XP сам не ставил - и так работает):
http://www.t-h.de/media/content/Downloa ... AO/DAO.zip
Поставить его можно только остановив службу лицензий симатика.
bond
Post by bond » Thu Aug 23, 2007 7:31 am
Уважаемый ppp!
Нужная программа, но у меня к сожалению не захотела работать :(
Пишет:
Invalid license!
Software works in Offline mode!
Сначала поставил программу, потом сервис пак (crack).
В чем может быть проблема
centipede
Post by centipede » Thu Aug 23, 2007 10:23 am
I think we need an INF-File to switch the driver to TH Driver.
Does anybody have the driver with inf?
ppp
Post by ppp » Thu Aug 23, 2007 11:38 am
New version: add support CP5511
http://www.t-h.de/media/content/Downloa ... 4.0_en.zip
or mirror http://rapidshare.com/files/50769797/PB ... th_key.zip
antikey patch
http://rapidshare.com/files/50758340/so ... 0.exe.html
Mirror: http://www.megaupload.com/?d=UVCDRFP8
ppp in Russian wrote:Проверьте пути куда ставится программа и лечилка. Для дистрибутива и SP они должны быть одинаковы.
Проверял на трех компах с картами - все работало.
А вообще уже вышла новая версия программы:
Ну и лечилка:
Может эта версия вам больше подойдет.
Добавили поддержку карты CP5511. Некоторые изменения не понравились. Так в режиме Telegrams значения в колонке Data отображаются только при правильно выбранной интерпритации в Setting. По-умолчанию всегда берется DPV2, что не удобно если мониторишь например MPI. Но это не критично.
В предыдущей версии MPI-данные отображались и так.
Проверил еще не все режимы (diagnosis для полного функционала требует временно отключать мастера, что пока для меня не возможно)
А вообще очень странно. Как только я выложил кряк, так спустя неделю программу обновили (до этого не обновляли более года)
Однако радует, что проект развивается...
Пробуйте и пишите результаты.
P.S. Надумал купить их карты xEPI. По описанию вроде удобная вещица. Подсоединяешь к профибасу контроллера и используешь уже в сетке.
У сименса коммуникационники в контроллер надо вставлять, что не всегда удобно.
Написал письмо с целью узнать цены. Оказывается это такой большой секрет...(?) Отказались дать прайс на Profibus Scope и карту xEPI. А я на полном серьезе хотел купить пяток карт (если цена в пределах 500 евро за штуку) и программу заодно. Ну и пусть работают тогда на нас даром. Совесть наша будет чиста.
centipede
Post by centipede » Thu Aug 23, 2007 12:00 pm
GREAT STUFF !!!!
The V4 runs well
THANK YOU
bond
Post by bond » Thu Aug 23, 2007 1:40 pm
Thanks, it's work
А четвертая версия заработала без проблем.
Спасибо ppp за отличные программы.
cemara
Post by cemara » Tue Jan 06, 2009 8:04 am
I have install profibus scope successfully. but when i open it, i have a message:
channel to card could not be open! check your setting and card installation! software works in off line mode.
my system:
- windows XP sp3
- cp 5511
when i use simatic manager, using this cp5511 i could connect to 315 PLC. anyone had any idea what went wrong??
ppp
Post by ppp » Thu Jan 08, 2009 6:38 am
Before start of program Scope it is necessary to establish the driver:
Run/Program/Profibus Scope/Activate TH Driver.
To use Simatic it is necessary to return the driver:
Run/Program/Profibus Scope/Activate Siemens Driver.
ppp
Post by ppp » Mon Jun 29, 2009 5:21 am
bond
Post by bond » Mon Jun 29, 2009 5:40 pm
спасибо, проверим
PLC_ITA
No connection with cp 5512
Post by PLC_ITA » Thu Jul 16, 2009 8:29 pm
Hello friend's i have try this package, but i don't connect whit the network.
Any time i try to connect the follow alarm is displayed :
i have activated Siemens Driver. Into Control Panel--> setting PG interface , i have setting 5512 profibus ...
The step 7 working correctly but profibus scope not working.
Anyone had any idea what went wrong or have a suggest for me ?
thank you in advance
ppp
Post by ppp » Fri Jul 17, 2009 3:43 am
Befor start program "Profibus Scope" run "Activate TH Driver".
Please study documentation!!!
Ksn76
Re: [LINK]: PROFIBUS Scope (Diagnosis/Analysis/Qualificatio
Post by Ksn76 » Fri May 21, 2010 9:58 am
Hello!
Have you SP for latest version 4.2.0.0?
Link
Post by Link » Sat May 22, 2010 7:12 am
graf_STEP7
Post by graf_STEP7 » Sat May 22, 2010 5:04 pm
>PROFIBUS Scope v4.2
>http://www.t-h.de/en/support-and-servic ... ation.html
Here you must be registration.
No direct download. !
Ksn76
Post by Ksn76 » Sun May 23, 2010 9:09 am
Thanks for links! (tyou)
Link
Post by Link » Mon May 24, 2010 3:22 am
graf_STEP7 wrote:Hi
>PROFIBUS Scope v4.2
You use any data for registration (no check)
link distributive :
http://www.t-h.de/fileadmin/inhalt/IC/d ... .2.0.0.zip
Link
Post by Link » Mon May 24, 2010 6:42 pm
Here is the german link.
setup_de_4.2.0.0.zip
http://rapidshare.com/files/391167278/s ... .2.0.0.zip
9081luca
Post by 9081luca » Wed Jun 23, 2010 2:27 pm
I installed the software, I activated the driver for the interface but when launching the program I released the following message
Invalid License ! Software works in Offline mode !
thanks for the help (wow)
mario_ingen
Post by mario_ingen » Mon Sep 22, 2014 12:06 pm
Any have the key and sharing for Profibus scope (boom)
stephan
Post by stephan » Sat Nov 01, 2014 1:59 pm
(sos) Could somebody re-link the software and patch please
benio
Post by benio » Mon Nov 23, 2015 2:40 pm
Please reupload software and key eanglish version.
Best regards.
ppp
Post by ppp » Tue Nov 24, 2015 5:54 am
benio
Post by benio » Tue Nov 24, 2015 6:03 am
Thanks for reupload.
Best regards.
voha888
Post by voha888 » Tue Sep 12, 2017 3:43 pm
links not work
JC LOBATO
Re: [LINK]: PROFIBUS Scope (Diagnosis/Analysis/Qualification)
Post by JC LOBATO » Sat Nov 09, 2019 1:33 am
Please, Could someone provide a download link for PB SCOPE 3.5 or 4.0?
Thanks!
benio
Post by benio » Sun Nov 10, 2019 11:25 am
I wait for version 4 and above because i need to use it with CP5611 on PG. Can someone have version works with CP ?
