[?]: Import Siemens Step7 files (*.awl) into Codesys ?
amet
Post by amet » Thu Apr 19, 2007 8:26 am
Is it possible to import Siemens Step7 files (*.awl) into Codesys ?
:oops:
thanks.
graf_STEP7
Post by graf_STEP7 » Mon Apr 23, 2007 5:37 pm
Hi
It is posible with "Copy and Paste" - from Windows system funktion.
The *.awl code ist not the thame Code as CoDeSys.
The Syntax is an other.
You must find the replacement-Code for CoDeSys.
For Information: Step7-SCL (Siemens)
and ST-Code (CoDeSys) they are works with only litle changes :wink:
