Dear friends
I us OPC Server for s7-200 to connect it with WinCC v6.0.
It work ok as monitor but i can't use opc server as control.
I can monitor all of tags but i can't make acontrol.
Can opc used as control?
If yes how?
thanks alot
[?]: OPC Server for s7-200 to connect it with WinCC v6.0
hi...
would u like to tell me more about your working project???
i mean: what kind of server u use, is there are any problem in adjustment procedure of this server and so on....
soon i will have the same job: i must connect 6 s7-200 PLC in active ethernet or other network and then connect them to active WinCC station.
