[LINK]: Unlocking protected C-/VB-functions in WinCC
Utilites for Simatic HMI
zbr82
Re: [LINK]: unPassword STEP7/WinCC -projects
Post by zbr82 » Thu Feb 18, 2016 11:35 am
РРР, you are planning to implement the removal of the password to the F- Program?
hardprogger
Post by hardprogger » Mon Mar 07, 2016 3:26 pm
Does anybody know how to remove or get password (know how protection) from Sinamics Starter scripts?
robertetc
Post by robertetc » Wed Jun 01, 2016 5:46 am
hello, has anybody tried to access a full password protected (for writing and also for reading) mmc card? i do not have access to the project folder situated only on the mmc in order for the pss7 1.82 to read the password that is setup on the project itself.
i tried with a card reader inside a siemens computer and it didn't work, it wouldn't let me acces the mmc, evens if i saw the structure of the project itself.
a friend of mine suggested to buy an usb prommer; the prommer connected to a pc offers the possibility for the pss7 to conect to the device and read the password.
can anybody help me with this?
kind regards,
gkaim
Post by gkaim » Mon Jun 06, 2016 10:37 am
PPP and guys please,
I downloaded WinccNoProtect.exe and use it in Windows XP Pro to remove the passwords from C-scripts but is not working.
I have closed all the projects. How this patch should be used ?
Thank you.
HLAM
Post by HLAM » Wed Jun 22, 2016 1:17 am
Hi everyone,
Can this software discover the CPU password?
I have a Siemens 222 CN and I cant upload the project.
Thanks a lot.
Contact:
Post by CoMod » Wed Jul 06, 2016 11:09 am
https://virustotal.com/ru/file/62767ffb ... 467803280/
(h) 3/52 DrWeb, McAfee-GW-Edition, Qihoo-360
xflash
Post by xflash » Thu Jul 07, 2016 3:23 am
ppp wrote:updata to v1.83
Great thanks!
It just works like magic.
Please consider unPassword wincc picture password. It is new for wincc 7.2/7.3/7.3SE/7.4
Good luck.
duongvuquy
Post by duongvuquy » Tue Jul 26, 2016 5:54 pm
http://www.mediafire.com/download/157c0 ... 1510cm.zip
I have a project as above link, But I can't find password of safety FC.
Please help me to find it.
Thanks and best regards,
markento
Post by markento » Fri Dec 02, 2016 10:03 am
Are there Soft for unPassword TIA Portal 13; 14 (s7-1200; S7-1500) and S7-Distributed Safety?
https://www.slideshare.net/AlexanderTim ... lideshow=1
https://github.com/atimorin/scada-tools ... tractor.py
https://github.com/atimorin/scada-tools/blob/master/s7_password_hashes_extractor.py
mikelyu
Post by mikelyu » Tue Jan 09, 2018 2:43 am
(tyou) (gpost)
If PPP could add TIA-12/1500 CPU, it will be much more great!!
Also as mentioned by others, WINCC-V7.3 picture password is needed in future.
PPP up!
ppp
Post by ppp » Fri Jun 14, 2019 11:23 am
pss7_v1.84a
fix bug passwords for wincc vb-script
Thanks to cuihl
https://www90.zippyshare.com/v/XTUzhDs1/file.html
Contact:
Post by CoMod » Fri Jun 14, 2019 12:46 pm
My Avast blocked to download updated version of pss7.exe too
PPP uses bad Crypt packer for decrease size and for anti reverse analyzing (boom)
Russian wrote: PPP использует плохие упаковщики для уменьшения размера файла и чтобы никто не смог разобрать и понять логику его программы
=========== if you're afraid of threats - Use in Virtual Machine ==================
=========== если боитесь угрозы - используйте на Виртуальной Машине ==================
passworded ZIP - password for unpack 1
https://mega.nz/#!SOxy1SZQ!RPJTyCrQBxHC ... tqAOTHrAXM
(mirr) https://disk.yandex.ru/d/10fLlqQsVX1Q9w
ppp
Post by ppp » Fri Jun 14, 2019 1:10 pm
Эта утилита изначально ХАКЕРСКАЯ!
Она ищет пароли в проектах!
Через некоторое время ее в свои базы и другие антивирусы включат, а не эти 5 никому не известных
coslad
Post by coslad » Mon Jul 15, 2019 4:38 pm
Hi ,
i'am tryng to unlock a *.Bmo file(wincc 7.2) , but unPassword software doesn''t reconize it as password protected .
Any advice ?
Terere_Py
Post by Terere_Py » Thu Oct 10, 2019 11:20 am
it is safe to use virtual box for this kind of softwares?
fanteral
Re: [LINK]: Unlocking protected C-/VB-functions in WinCC
Post by fanteral » Wed Dec 11, 2019 8:50 am
is the software can get the picture password?
joozzer
Post by joozzer » Thu Jan 09, 2020 2:37 am
Hi ,
Any advice ?
I get the same result when trying to unpassword vb-script. The software did recognize password for c-script.
I used the 1.84 version
Dear ppp,
Do you have update for pss7?
I use this version for unlocking winCC v7.4 sp1. it can be used to unlock c-script, but it cannot find vb-script password.
dj1178
Post by dj1178 » Mon Aug 24, 2020 1:00 am
please upload your project, maybe i can help you
joozzer
Post by joozzer » Mon Aug 24, 2020 6:54 am
Here is the project. And please also get the picture password.
Thanks.
https://mega.nz/folder/VqgklSjC#e69j54S1qqzxAabR-4-aZg
dj1178
Post by dj1178 » Mon Aug 24, 2020 7:54 am
sorry I cannot download it
joozzer
Post by joozzer » Mon Aug 24, 2020 9:23 am
I can download the file without login to mega.
But here is the alternative link
https://drive.google.com/file/d/1T4e4sw ... sp=sharing
joozzer
Post by joozzer » Thu Oct 22, 2020 5:51 am
Can you download the project from the link I share?
Toms
Post by Toms » Sat Oct 24, 2020 9:53 am
Thanks.
You can try to ignore the screen password, and then directly press the confirm key to open the screen
Peter76
Post by Peter76 » Wed Mar 24, 2021 10:29 am
Could you tell me please how to unlock the C Script?
I've used the pss7_v1.84a, but it doesn't work.
I would like to know if someone of you know a way to unlock a WinCC C script.
Basically they are a file with a .fct exention, i've been able to open it in a binary mode, but nothing else.
Any suggest?
Thanks Peter.
Thanks!
artemarchi
Post by artemarchi » Wed May 05, 2021 10:24 am
Hi, I have the same problem with the C Script, did you manage to open it?
joozzer
Post by joozzer » Tue May 11, 2021 6:00 am
In my case, pss7_v1.84a gave me the C script password. But cannot detect the vb script password.
Prasad
Post by Prasad » Sun Aug 15, 2021 11:51 am
Pss7_v1.840a not supported for wincc 7.5 vbscript
pcd_13
Post by pcd_13 » Sat Jun 25, 2022 1:09 pm
I have also tried to get C Script password . But It didn't detect C Script. It showing empty folder. i.e it is not going into files.
PLC_ITA
Post by PLC_ITA » Wed Sep 14, 2022 5:25 pm
Anyone please may upload pass.exe ?
Any link are died !
Thank you
Plc_ITA
Link
Forum Community
Forum Community
Contact:
Post by Link » Wed Sep 14, 2022 8:54 pm
Any link are died !
Mega live ...
PLC_ITA
Post by PLC_ITA » Thu Sep 15, 2022 9:24 am
Thank you !!!!
Anilk0633
Post by Anilk0633 » Sat Mar 18, 2023 6:21 am
Please remove the password. Thank a lot.
https://mega.nz/folder/FUcDHbhZ#ype9mjVc3lUikeU-5PlhFQ
