[LINK]: Unlocking protected C-/VB-functions in WinCC
How it possible - to unlocked Know_how_protected functions in winCC?
The program for removal of the password from C-scripts Wincc (version 5 and 6).
script_WinCC_without_password
See new version 1.6 Jun 30, 2014
viewtopic.php?f=1&t=17844
Всем удачи!
http://s2kkpp.narod.ru/ppp in Russian wrote:Программа снятия парольной защиты с ВыньСС скрипта
![Link Dead [dead]](./images/smilies/Link_dead.gif)
Всем удачи!
Manual remove password from VB-script
1. Open file in WinHex http://winhex.com/winhex/index-m.html
2. In the end the file has such appearance:
Passworded
00 00 00 01 00 00 00 00 00 00 06 00 00 00 73 5E 52 57 5E 16
UnPassworded
00 00 00 00 00 00 00 00 00 00 06 00 00 00 73 5E 52 57 5E 16
01 - Attribute of presence of the password
06 - Number of symbols in the password
735E52575E16 - The coded password
We change 01 on 00 and the script can be opened
Passworded
UnPassworded
in Russian wrote:Снять пароль с VB-скрипта еще проще.
Открываем файл скрипта любым 16-ричным редактором (например Winhex).
В конце файл имеет примерно такой вид:
где 735E52575E16 - закодированный пароль
06 - число символов в пароле
01 - признак наличия пароля
Меняем 01 на 00 и скрипт можно будет открыть.
Писать оболочку для указанных действий что-то лень.
I open file .bmo in Winhex, but it don't look like this. Any advance?ppp wrote:Manual remove password from VB-script
Re:
Yes you are correct it doenot look li this any other method???
Re: [LINK]: Unlocking protected C-/VB-functions in WinCC
New patcher for un/protection password c-scripts, support WinCC v4.2, 5, 6, 7
program need MS Framework >=1.1
WinccNoProtect
See new version
WinccNoProtect
See new version
- Forum Community
- Location: We are anonymous users. We do not read your private messages :( Ask questions in the forum !
- Contact:
Update
as not all produced by hand using WinHEX unprotect VB-scripts and added the removal of this protection in the patch.
I recall a program patches only WinCC, the project is no manipulation is not
Support C-script WinCC v4.2, 5, 6, 7
Support VB-Script WinCC v6, 7
https://mega.co.nz/#!GMUXSSKD!5pO7o_OAQ ... qmJp2ZPeDc
т.к. не у всех получается вручную с помощью WinHEX снять защиту с VB- скриптов добавил снятие и этой защиты в патч.
Напоминаю программой патчуется только WinCC, с проектом никаких манипуляций не производится.
Hi, I try it,s, but I not open protect script, always ask me the password. I try with wincc 7 sp1. I think it´s possible that the file have into folder,etc...Can anyone help me.
Thank you very much
Thank you very much
You use C-script or VB-script?
Please give me your script in personal messages.
I try help.
I try help.
I check program.
Support only Windows 2000, WindowsXP.
NOT SUPPORT Windows 7
- Forum Community
- Contact:
New version. Add support Windows7.
need MS Framework >=2.0
WinccNoProtect1.2.exe
Thank you very much, now run ok.
I try in my project, and magic open script. thank again..........
aguere
aguere
[LINK]: unPassword STEP7/WinCC -projects
Only for old password - not for Block Privacy
After all, the programmers who wrote the STEP7 used a standard method from the Microsoft Visual Studio:
It was enough to remove the asterisk in the property textBox.PasswordChar and password are displayed.
It could have been done a bunch of programs (asterwin, iws from Isqsoft ...)
However, starting with version 5.5 of this hole covered. Under the stars have no password.
But now you can see passwords in the STEP7 project using pss7
Requirements:
MS Framework 2.0 or higher.
tested on WinXP and Windows7.
virustotal.com check showed that the virus does not.
Using simple. Select the project folder and if it is the processors have the passwords, they will appear in the right part of the program.
Projects supported by any version of STEP7.
========= Others tools ==================
Unlock password for S7 200 and S7 300 MMC viewtopic.php?t=2005
UnPassword for S7 300 and S7 400 viewtopic.php?f=1&t=17844
Unlock password for S7 300 and S7 400 by dictionary (tested with PC adapters, CP5512, CP5611)
viewtopic.php?t=7029
Unlocking protected C-/VB-functions in WinCC viewtopic.php?f=37&t=4748
Decoder ProSave viewtopic.php?f=37&t=8598
Earlier in STEP7 CPU passwords hidden under asterisks could see easily enough.Только для старого метода паролирования - не для Block Privacy
Раньше в STEP7 пароли процессоров под звездочками можно было посмотреть достаточно легко.
Ведь программисты, написавшие STEP7 использовали стандартный прием от Microsoft Visual Studio:
Достаточно было убрать звездочку в свойстве textBox.PasswordChar и пароль отображался.
Это можно было сделать кучей программ (asterwin, iws от Isqsoft и др.)
Однако начиная с версии 5.5 эту дыру прикрыли. Под звездочками уже нет никакого пароля.
Однако теперь можно посмотреть пароли в проекте STEP7 с помощью программы pss7
Requirements:
Требования:
MS Framework 2.0 и выше.
проверено на WinXP и Windows7.
проверка на virustotal.com показала, что вирусов нет.
Пользоваться просто. Выбираем папку проекта и если в нем процессоры имеют пароли, то они отобразятся в правой части программы.
Поддерживаются проекты созданные в ЛЮБОЙ версии STEP7.
Re: [LINK]: unPassword CPU under star in STEP7-projects
thank you very mush
Its helpful
Its helpful
Updata.
add password MicroWin
add password TIA Portal Step7 (CPU S7-300/S7-400)
save passwords in file (button "floppy")
p.s.
TIA Portal как оказалось хранит ВСЕ пароли, которые вы когда либо вводили.
И их легко можно посмотреть.
p.s.
PPP uses bad Crypt packer for decrease size and for anti reverse analyzinghttps://www.virustotal.com/file/925bd96 ... 349290882/
My Avast blocked to download updated version of pss7.exe too
Kaspersky find nothing
Russian wrote:PPP использует плохие упаковщики для уменьшения размера файла и чтобы никто не смог разобрать и понять логику его программы
Касперский пока молчит
Excellent. Worked perfectly.
Updata to v1.3
add password WinCC C-script from *.pas
see v1.6
see v1.6
Updata to v1.4
add password WinCC VB-script
fix bugs
see v1.6
fix bugs
see v1.6
check Universal UnProtector for Step7 and WinCC
viewtopic.php?f=1&t=17844&p=57434#p57434
PPP wrote:add password WinCC VB-script
Hello ppp,
do you have solution for s7-1200? On all others workes fine but on 1200 not at all...
THX
THX
Updata to v1.5
add password LOGO!
fix bugs
see v1.6
add password LOGO!
fix bugs
see v1.6
New version 1.5.1
Fix bugs.
see v1.6
Fix bugs.
see v1.6
Hello PPP,
GREAT JOB!!
Are you looking some solution for s7-1200?
THX
GREAT JOB!!
THX
Thank you verry much! Tool is good!
New version 1.6
+ fix bugs
+ add panel Pro-face
+ fix bugs
Не планируется ли для серии s7-1200 подобное сделать? мне бы сейчас очень помогло
Thanks again for the update.
Now we are waiting for the 7.3 unPassword
thanks again
thanks again
Waiting for S7 - 1200 CPUs
Оживите ссылки пожалуйста
WinCCnoprotect
Как программой Passwords Simatic определяются пароли на скрипты WinCC?
Есть проект WinCC, интегрированный в Step7, указываю путь к проекту Step7, пароли на скрипты WinCC не появляются в окне Passwords Simatic?
Что делаю не так?
P.S. Хотел скачать еще WinCCnoprotect.exe, но все ссылки не рабочие....
all the links are not working...
give a working link
give a working link
Re: [LINK]: unPassword STEP7/WinCC -projects
New version 1.7
>= MS Framework 4.0 (For Windows 7,8,10)
add pass project PLC Delta
add pass project Elau EPAS-4
fix bugs
http://www37.zippyshare.com/v/v3s8LhyS/file.html
http://rghost.ru/6pRFByyML
https://1fichier.com/?f2cvw9nse5
http://ge.tt/6J6nKlA2/v/0?c
new upload
no detect "virus"
fix bugs
new upload
no detect "virus"
use VirtualBox - no problem
new upload
no detect "virus"
no detect "virus"
1/57ppp wrote:new upload
no detect "virus"
Qihoo-360 HEUR/QVM03.0.Malware.Gen 20150219
New version 1.8a
add pass project TwidoSuite from Schneider Electric
http://www79.zippyshare.com/v/cXfJJJQ6/file.html
http://rghost.ru/6QkKjhh8G
https://1fichier.com/?7p48qa78vw
http://ge.tt/2F0sVtG2/v/0
Is it also possible to see Password for safety program (S7 F-Systems, based on CFC - not Distributed Safety)???
Is there what to follow with Elau EPAS-4 projects?
No password is indicated(signalised).
A vintage and a writing password presumably exists here.
Thank you very much! v1.7 is working very well, but on v1.8 - virus 11 / 56:
https://www.virustotal.com/ru/file/d7e9 ... /analysis/
TIA Portal V13 SP1 not work
pss cannot make it in all time. Any updates ?
Great thanks~
Great thanks~
Thank you very much! 1.8A working very well. CPU & safety hacked.
Can you add passwords for AS-i monitor 3?
updata to v1.82
fix bugs
http://www42.zippyshare.com/v/jzMYnxZP/file.html
http://rghost.ru/8t5LhY27Q
https://1fichier.com/?2919yzluvn
http://ge.tt/3WkmdKO2/v/0
http://multiupload.biz/czhe2vb6i5ea/pss ... z.exe.html
ADMIN add
=========== if you're afraid of threats - Use in Virtual Machine ==================
=========== если боитесь угрозы - используйте на Виртуальной Машине ==================
https://www.virustotal.com/ru/file/7006 ... 442933620/
2015-09-22 14:53:40 UTC 4/56 (DrWeb Trojan.DownLoader11.18272 )
2015-12-21 17:58:28 UTC 2/55 (DrWeb Trojan.DownLoader11.18272 )
fix bugs
ADMIN add
Great thanks.
1.82 works like a charm.
Will ppp try to reveal the wincc 7.2/7.3SE picture password? It is needed in future.
