It is alpha version.
Tested on decompilation of STL (AWL) files created by SCL compiler v5.3-5.6.
i'm sorry, but.. what ?? Supported operating system - Linux and MacOS ?? Since witch time SIMATIC Manager and Siemens programming tools support Linux or MacOS ?? I will never believe that you have developed a fully working recompiler for operating systems, in witch such products normally never will be used."supported operation systems: Windows (XP and newer), MacOS, Linux. Contact us to get desktop version with contact@stl2scl.com."
FUNCTION_BLOCK FB 1
TITLE =
VERSION : 0.0
VAR
s : STRUCT
x1 : INT ;
x2 : INT ;
END_STRUCT ;
END_VAR
BEGIN
NETWORK
TITLE =SCL network
//compiled by SCL compiler version: SCLCOMP K05.03.06.00_01.03.00.01 release
SET ;
SAVE ;
= L 0.1;
L B#16#2;
T DIB [AR2,P#0.0];
SAVE ;
BE ;
END_FUNCTION_BLOCK
FUNCTION_BLOCK FB1
TITLE = ''
VERSION : '0.0'
VAR
s : STRUCT
x1 : INT ;
x2 : INT ;
END_STRUCT ;
s_BYTE AT s : ARRAY[0 ..3] OF BYTE;
END_VAR
BEGIN
s_BYTE[0]:=B#16#2;
END_FUNCTION_BLOCK
FUNCTION_BLOCK FB 10
TITLE =
VERSION : 0.0
VAR_INPUT
x : STRUCT
x1 : INT ;
x2 : INT ;
x3 : INT ;
x4 : INT ;
x5 : INT ;
END_STRUCT ;
END_VAR
VAR_OUTPUT
y : STRUCT
x1 : INT ;
x2 : INT ;
x3 : INT ;
x4 : INT ;
x5 : INT ;
END_STRUCT ;
err : INT ;
END_VAR
BEGIN
NETWORK
TITLE =SCL network
SET ;
SAVE ;
= L 0.1;
L DW#16#1002000A;
T LD 2;
L DINO;
T LW 6;
TAR2 ;
+ L#0;
T LD 8;
L DW#16#1002000A;
T LD 12;
L DINO;
T LW 16;
TAR2 ;
+ L#80;
T LD 18;
TAR2 LD 22;
UC SFC 20 {
P#L 2.0,
P#L 26.0,
P#L 12.0};
LAR2 LD 22;
L LW 26;
T #err;
A L 0.1;
SAVE ;
BE ;
END_FUNCTION_BLOCK
FUNCTION_BLOCK FB10
TITLE = ''
VERSION : '0.0'
VAR_INPUT
x : STRUCT
x1 : INT ;
x2 : INT ;
x3 : INT ;
x4 : INT ;
x5 : INT ;
END_STRUCT ;
END_VAR
VAR_OUTPUT
y : STRUCT
x1 : INT ;
x2 : INT ;
x3 : INT ;
x4 : INT ;
x5 : INT ;
END_STRUCT ;
err : INT ;
END_VAR
BEGIN
err:=SFC20(SRCBLK:=x,DSTBLK:=y);
END_FUNCTION_BLOCK
It doesn make sense for me. No one living man use Siemens Automation on Linux or MacOS, all the Siemens Software Solutions working exclusively on Windows systems.stl2sclSupport wrote: The converter is cross-platform so you can use it on any of mentioned operation systems.
FUNCTION_BLOCK FB 7
TITLE =
VERSION : 0.0
VAR
x : REAL ;
i : INT ;
END_VAR
BEGIN
NETWORK
TITLE =SCL network
SET ;
SAVE ;
= L 0.1;
A7d0: L #i;
L 10;
<I ;
JCN A7d1;
L #x;
L 3.000000e+000;
+R ;
JO I007;
JU I008;
I007: CLR ;
= L 0.1;
I008: T #x;
L #i;
L 1;
+I ;
JO I009;
JU I00a;
I009: CLR ;
= L 0.1;
I00a: T #i;
JU A7d0;
A7d1: CLR ;
A L 0.1;
SAVE ;
BE ;
END_FUNCTION_BLOCK
FUNCTION_BLOCK FB7
TITLE = ''
VERSION : '0.0'
VAR
x : REAL ;
i : INT ;
END_VAR
BEGIN
WHILE i<10 DO
x:=x + 3.000000e+000;
i:=i + 1;
END_WHILE;
END_FUNCTION_BLOCK
FUNCTION_BLOCK FB4
TITLE = ''
VERSION : '0.0'
VAR
x : REAL ;
y : REAL ;
i : INT ;
b1 : BOOL ;
b : BOOL ;
END_VAR
BEGIN
IF b THEN
IF NOT b THEN
y:=1.000000e+000;
IF NOT b1 THEN
y:=2.000000e+000;
ELSE
y:=3.000000e+000;
END_IF;
IF NOT b1 THEN
y:=4.000000e+000;
ELSE
IF NOT b1 THEN
y:=5.000000e+000;
ELSE
y:=6.000000e+000;
END_IF;
y:=7.000000e+000;
END_IF;
ELSE
IF NOT b1 THEN
y:=8.000000e+000;
ELSE
y:=9.000000e+000;
END_IF;
y:=1.000000e+001;
END_IF;
IF NOT b1 THEN
y:=1.100000e+001;
ELSE
y:=1.200000e+001;
END_IF;
END_IF;
END_FUNCTION_BLOCK
FUNCTION_BLOCK FB1
TITLE = ''
VERSION : '0.0'
VAR
x : REAL ;
y : REAL ;
i : INT ;
END_VAR
BEGIN
CASE i OF
1:
IF x<0.000000e+000 THEN
y:=1.000000e+001;
END_IF;
2:
IF x>0.000000e+000 THEN
y:=2.000000e+001;
END_IF;
3:
IF x=0.000000e+000 THEN
y:=3.000000e+001;
END_IF;
ELSE:
y:=5.000000e+002;
END_CASE;
END_FUNCTION_BLOCK
FUNCTION_BLOCK "FbDrive"
TITLE =Channel Block for Motor Drives Telegramm1/20
{ S7_driver := 'chn'; S7_tasklist := 'OB100' }
AUTHOR : AdvLib90
FAMILY : Channel
VERSION : 9.0
VAR_INPUT
END_VAR
VAR_OUTPUT
END_VAR
VAR_IN_OUT
Mode : DWORD := DW#16#10; //Quality and mode
DataXchg : DWORD ; //Data exchange
DataXchg1 : DWORD ; //Data exchange
MS_Xchg : DWORD ; //Maintenance State exchange
END_VAR
VAR
sbRestart : BOOL := TRUE;
sdwRESERVE : DWORD ; //Reserve für zukünftige Änderungen
sCLSFailCounter : INT ;
sCLSCounter : INT ;
BytStatus : BYTE ; //Statusbyte für Ausgänge
LastByQuality : BYTE ;
END_VAR
VAR_TEMP
TOP_SI : STRUCT
EV_CLASS : BYTE ;
EV_NUM : BYTE ;
PRIORITY : BYTE ;
NUM : BYTE ;
TYP2_3 : BYTE ;
TYP1 : BYTE ;
ZI1 : WORD ;
ZI2_3 : DWORD ;
END_STRUCT ;
START_UP_SI : STRUCT
EV_CLASS : BYTE ;
EV_NUM : BYTE ;
PRIORITY : BYTE ;
NUM : BYTE ;
TYP2_3 : BYTE ;
TYP1 : BYTE ;
ZI1 : WORD ;
ZI2_3 : DWORD ;
END_STRUCT ;
pi_RET_VAL : INT ;
Status : BOOL ; //Status
FlutTm_t : DWORD ; //Flatterunterdrückungszeit
bTmpDXCHG : BOOL ; //BOOL für verrundung der DXCHG_xx 0 bit
BtMS07 : BOOL ; //Bool for MS State 07
BtMS06 : BOOL ; //Bool for MS State 06
tDXCHG : DWORD ;
tbCtrlSimStatus : BOOL ;
tFbDriveIn : ARRAY [0 .. 5 ] OF WORD ;
tIn0By : BYTE ;
tFbDriveOut : ARRAY [0 .. 1 ] OF WORD ;
RETURN_CODE : INT ; //Hilfsparameter (Wechselnde Bedeutung)!
by_dummy : BYTE ; //Hilfsparameter
w_dummy : WORD ; //Hilfsparameter
r_dummy : REAL ;
grad : REAL ;
MS_AS : DWORD ; //Maintenance State AS
xConditionMonitoring : BOOL ; //1=ConditionMonitoring
END_VAR
BEGIN
NETWORK
TITLE =SCL Netzwerk
//generiert vom SCL Übersetzer Version: SCLCOMP K05.03.08.03_04.01.00.01 release
SET ;
SAVE ;
= L 76.2;
L W#16#0;
T LW 78;
L DW#16#87000000;
T LD 80;
L W#16#0;
T LW 84;
L DW#16#87000060;
T LD 86;
TAR2 LD 90;
UC "RD_SINFO" {
P#L 24.0,
P#L 78.0,
P#L 84.0};
LAR2 LD 90;
L #TOP_SI.NUM;
L B#16#64;
==I ;
L #Mode;
L DW#16#10000;
UD ;
L DW#16#10000;
TAK ;
= L 76.3;
==D ;
O L 76.3;
SPBN A7d0;
SET ;
= #sbRestart;
A7d0: CLR ;
U L 76.2;
SAVE ;
BE ;
END_FUNCTION_BLOCK
FUNCTION_BLOCK "MOD_D8_PN"
TITLE =PN Diagnostic Module Check (0 - 7 Channel)
{ S7_hardware := 'sm'; S7_alarm_ui := '1'; S7_tasklist := 'OB1,OB82,OB83,OB85,OB100,OB86'; S7_tag := 'false' }
AUTHOR : DRIVER90
FAMILY : '@SYSTEM'
VERSION : 9.0
VAR_INPUT
[b][color=#FF0000]<... DETAILS SEE ATTACH ...>[/color][/b]
END_VAR
BEGIN
NETWORK
TITLE =SCL Netzwerk
//generiert vom SCL Übersetzer Version: SCLCOMP K05.06.00.00_06.01.00.01 release
SET ;
SAVE ;
= L 140.1;
CLR ;
= #EN_OUTP;
= #EN_ALRM;
= #sbRACKF;
L W#16#0;
T #OB_START;
L 0;
T #RETURN_CODE;
T #CHANNELS;
T #CHANNELS_OFFSET;
T #X;
T #y;
T #Z;
TAK ;
T #SZL_HEADER.LENTHDR;
T #SZL_HEADER.N_DR;
L B#16#0;
T #GEO_PN.SUBNET;
T #GEO_PN.RACK;
TAK ;
T #GEO_PN.SLOT;
T #GEO_PN.SUBSL_NO;
T #ZI1;
TAK ;
T #byQHL;
T #byQLL;
= #bMBSM;
= #bMBFM;
L DW#16#0;
T #ZI2_3;
T #CH_O;
T #CH_E;
T #CH_A;
T #EXT_S;
TAK ;
T #TOP_SI.EV_CLASS;
T #TOP_SI.EV_NUM;
T #TOP_SI.PRIORITY;
T #TOP_SI.NUM;
T #TOP_SI.TYP2_3;
T #TOP_SI.TYP1;
L W#16#0;
T #TOP_SI.ZI1;
L DW#16#0;
T #TOP_SI.ZI2_3;
T #tdwMS_AS;
T #tMS_XCHG;
= #bTmpDXCHG;
= #bTmpFlutter;
T #tDXCHG;
TAK ;
T #MOD_INF_TEMP.SUBN_ID_RACK_NO;
T #MOD_INF_TEMP.SLOT_NO_SUBSL_NO;
T #MOD_INF_TEMP.BASADR;
T #MOD_INF_TEMP.EXPECTYP;
T #MOD_INF_TEMP.ACTTYP;
T #MOD_INF_TEMP.RESERVE;
L B#16#0;
T #MOD_INF_TEMP.IOSTAT;
= #MOD_INF_TEMP.IOSTAT_0;
= #MOD_INF_TEMP.IOSTAT_1;
= #MOD_INF_TEMP.IOSTAT_2;
= #MOD_INF_TEMP.IOSTAT_3;
= #MOD_INF_TEMP.IOSTAT_4;
= #MOD_INF_TEMP.IOSTAT_5;
= #MOD_INF_TEMP.IOSTAT_6;
= #MOD_INF_TEMP.IOSTAT_7;
TAK ;
T #MOD_INF_TEMP.AREA_ID;
L DW#16#0;
T #tMODE;
= #tModfBg;
L 0;
T #intINDEX;
T #tiLen;
L W#16#0;
T #twHART_OB82;
T #twHART_OB1;
= #tbHART;
TAK ;
T #iRET_VAL;
TAK ;
T #wINFO1;
L DW#16#0;
T #dwINFO2;
= #MODF_BG_GONE;
= #tbCondMon;
T #tdwDXCHG1;
= #tbMaintAlarm;
= #tbMaintWarn;
= #tbMaintReqst;
L B#16#0;
T #-spam-;
L W#16#0;
T #twTextRef;
T #twChnNum_OB82;
T #twErrStat_OB82;
T #twErrTyp_OB82;
T #twChnNum_OB1;
T #twErrStat_OB1;
T #twErrTyp_OB1;
L DIW [AR2,P#1714.0];
T LW 142;
TAK ;
AUF DB [LW 142];
L DID [AR2,P#1716.0];
LAR1 ;
TAK ;
L W [AR1,P#6.0];
T LW 142;
L 1;
TAK ;
==I ;
SPB A7d1;
SPA A7d2;
A7d1: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#8.0];
T #TOP_SI.NUM;
SPA A7d0;
A7d2: L 2;
L LW 142;
==I ;
SPB A7d3;
SPA A7d4;
A7d3: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#9.0];
T #TOP_SI.NUM;
SPA A7d0;
A7d4: L 3;
L LW 142;
==I ;
SPB A7d5;
SPA A7d6;
A7d5: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#10.0];
T #TOP_SI.NUM;
SPA A7d0;
A7d6: L 4;
L LW 142;
==I ;
SPB A7d7;
SPA A7d8;
A7d7: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#11.0];
T #TOP_SI.NUM;
SPA A7d0;
A7d8: L 5;
L LW 142;
==I ;
SPB A7d9;
SPA A7da;
A7d9: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#12.0];
T #TOP_SI.NUM;
SPA A7d0;
A7da: L 6;
L LW 142;
==I ;
SPB A7db;
SPA A7dc;
A7db: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#13.0];
T #TOP_SI.NUM;
SPA A7d0;
A7dc: L 7;
L LW 142;
==I ;
SPB A7dd;
SPA A7de;
A7dd: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#14.0];
T #TOP_SI.NUM;
SPA A7d0;
A7de: L 8;
L LW 142;
==I ;
SPB A7df;
SPA A7e0;
A7df: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#15.0];
T #TOP_SI.NUM;
SPA A7d0;
A7e0: L 9;
L LW 142;
==I ;
SPB A7e1;
SPA A7e2;
A7e1: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#16.0];
T #TOP_SI.NUM;
SPA A7d0;
A7e2: L 10;
L LW 142;
==I ;
SPB A7e3;
SPA A7e4;
A7e3: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#17.0];
T #TOP_SI.NUM;
SPA A7d0;
A7e4: L 11;
L LW 142;
==I ;
SPB A7e5;
SPA A7e6;
A7e5: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#18.0];
T #TOP_SI.NUM;
SPA A7d0;
A7e6: L 12;
L LW 142;
==I ;
SPB A7e7;
SPA A7e8;
A7e7: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#19.0];
T #TOP_SI.NUM;
SPA A7d0;
A7e8: L 13;
L LW 142;
==I ;
SPB A7e9;
SPA A7ea;
A7e9: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#20.0];
T #TOP_SI.NUM;
SPA A7d0;
A7ea: L 14;
L LW 142;
==I ;
SPB A7eb;
SPA A7ec;
A7eb: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#21.0];
T #TOP_SI.NUM;
SPA A7d0;
A7ec: L 15;
L LW 142;
==I ;
SPB A7ed;
SPA A7ee;
A7ed: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#22.0];
T #TOP_SI.NUM;
SPA A7d0;
A7ee: L 16;
L LW 142;
==I ;
SPB A7ef;
SPA A7d0;
A7ef: L DIW [AR2,P#1714.0];
T LW 144;
TAK ;
AUF DB [LW 144];
LAR1 ;
TAK ;
L B [AR1,P#23.0];
T #TOP_SI.NUM;
SPA A7d0;
A7d0: L #TOP_SI.NUM;
L B#16#1;
==I ;
SPBN A7f1;
SET ;
= L 2.6;
L DIW [AR2,P#1720.0];
T LW 142;
TAK ;
AUF DB [LW 142];
L DID [AR2,P#1722.0];
LAR1 ;
TAK ;
U [AR1,P#3.5];
= #sbRACKF;
CLR ;
O( ;
U #sbRACKF;
UN #QRACKF;
O ;
UN #sbRACKF;
U #QRACKF;
SPBN A7f4;
L #SUBN1_ID;
L B#16#FF;
==I ;
SPBN A7f3;
U #sbRACKF;
NOT ;
= #ACC_MODE;
A7f3: CLR ;
U #sbRACKF;
= #QRACKF;
SPA A7f4;
A7f1: L #TOP_SI.NUM;
L B#16#55;
==I ;
SPBN A7f5;
SET ;
= L 2.4;
T LW 142;
TAK ;
AUF DB [LW 142];
LAR1 ;
TAK ;
L W [AR1,P#1550.0];
UW W#16#FF;
T #GEO_PN.SUBNET;
L W [AR1,P#1552.0];
UW W#16#FF;
T #GEO_PN.RACK;
L W [AR1,P#1554.0];
T #GEO_PN.SLOT;
L W [AR1,P#1556.0];
T #GEO_PN.SUBSL_NO;
L B [AR1,P#1538.0];
T #TOP_SI.EV_CLASS;
L D [AR1,P#1546.0];
T #ZI2_3;
SPA A7f4;
A7f5: L #TOP_SI.NUM;
L B#16#52;
==I ;
SPBN A7f6;
SET ;
= L 2.2;
T LW 142;
TAK ;
AUF DB [LW 142];
LAR1 ;
TAK ;
L W [AR1,P#68.0];
UW W#16#FF;
T #GEO_PN.SUBNET;
L W [AR1,P#70.0];
UW W#16#FF;
T #GEO_PN.RACK;
L D [AR1,P#90.0];
L DW#16#FFFF0000;
UD ;
SRD 16;
T #GEO_PN.SLOT;
L D [AR1,P#90.0];
L DW#16#FFFF;
UD ;
SLD 16;
T #GEO_PN.SUBSL_NO;
L D [AR1,P#56.0];
T LD 52;
L D [AR1,P#60.0];
T LD 56;
L D [AR1,P#64.0];
T #TOP_SI.ZI2_3;
SPA A7f4;
A7f6: L #TOP_SI.NUM;
L B#16#56;
==I ;
SPBN A7f7;
SET ;
= L 2.5;
T LW 142;
TAK ;
AUF DB [LW 142];
LAR1 ;
TAK ;
L W [AR1,P#1574.0];
UW W#16#FF;
T #GEO_PN.SUBNET;
L W [AR1,P#1576.0];
UW W#16#FF;
T #GEO_PN.RACK;
L D [AR1,P#1562.0];
T LD 52;
L D [AR1,P#1566.0];
T LD 56;
L D [AR1,P#1570.0];
T #TOP_SI.ZI2_3;
SPA A7f4;
A7f7: L #TOP_SI.NUM;
L B#16#53;
==I ;
SPBN A7f8;
SET ;
= L 2.3;
T LW 142;
TAK ;
AUF DB [LW 142];
LAR1 ;
TAK ;
L W [AR1,P#1526.0];
UW W#16#FF;
T #GEO_PN.SUBNET;
L W [AR1,P#1528.0];
UW W#16#FF;
T #GEO_PN.RACK;
L W [AR1,P#1530.0];
T #GEO_PN.SLOT;
L W [AR1,P#1532.0];
T #GEO_PN.SUBSL_NO;
L D [AR1,P#1514.0];
T LD 52;
L D [AR1,P#1518.0];
T LD 56;
L D [AR1,P#1522.0];
T #TOP_SI.ZI2_3;
SPA A7f4;
A7f8: L #TOP_SI.NUM;
L B#16#64;
==I ;
SPBN A7f9;
SET ;
= L 2.7;
SPA A7f4;
A7f9: L #TOP_SI.NUM;
L B#16#46;
==I ;
SPBN A7fa;
SET ;
= L 2.0;
T LW 142;
TAK ;
AUF DB [LW 142];
LAR1 ;
TAK ;
L W [AR1,P#48.0];
UW W#16#FF;
T #GEO_PN.SUBNET;
L W [AR1,P#50.0];
UW W#16#FF;
T #GEO_PN.RACK;
L D [AR1,P#36.0];
T LD 52;
L D [AR1,P#40.0];
T LD 56;
L D [AR1,P#44.0];
T #TOP_SI.ZI2_3;
SPA A7f4;
A7fa: L #TOP_SI.NUM;
L B#16#48;
==I ;
SPBN A7f4;
SET ;
= L 2.1;
SPA A7f4;
A7f4: CLR ;
U L 140.1;
SAVE ;
BE ;
END_FUNCTION_BLOCK
Scl_ResetOptions ;
Scl_OverwriteBlocks := 'y' ;
Scl_GenerateReferenceData := 'y' ;
Scl_S7ServerActive := 'y' ;
Scl_CreateObjectCode := 'y' ;
Scl_OptimizeObjectCode := 'y' ;
Scl_MonitorArrayLimits := 'n' ;
Scl_CreateDebugInfo := 'n' ;
Scl_SetOKFlag := 'n' ;
Scl_SetMaximumStringLength := '254'
// project name:
// file name : FB 1869
// library : Advanced Prozess Library V7.1
// system : PCS7
// version : 06.00.00
// application : @System
// restrictions:
// requirements: Mit der CFC-Funktion "Baugruppentreiber erzeugen" wird Folgendes automatisch ausgefuhrt:
// - Der Baustein wird in der Ablaufreihenfolge hinter dem RACK-Baustein eingebaut.
// - Der Eingang SLOT_NO (Steckplatznummer der Stromversorgung) wird parametriert.
// - Der Eingang EN wird mit dem Ausgang eines AND-Bausteins verschaltet.
// Dessen Eingange werden mit dem Ausgang EN_SUBx des OB_BEGIN-Bausteins, dem
// Ausgang EN_Rxxx des SUBNET-Bausteins und dem Ausgang EN_Mxx des RACKBausteins
// verschaltet.
// - Die OUT-Strukturen CPU_DIAG des OB_BEGIN-Bausteins und RAC_DIAG des RACKBausteins
// werden mit den gleichnamigen IN_OUT-Strukturen des PS-Bausteins verschaltet.
// search items:
// functionality: Der Baustein PS überwacht den Zustand einer Stromversorgung eines Baugruppenträgers
// und meldet die zugehörigen Fehlerereignisse.
// change log table:
// version date expert in charge changes applied
// 8.7 17.07.2017 comatic - created -
// 8.7 24.07.2017 DLM - commented -
FUNCTION_BLOCK "A_MOD_D8_PN"
TITLE = 'PN Diagnostic Module Check (0 - 7 Channel)'
AUTHOR : DRIVER90
FAMILY : '@SYSTEM'
VERSION : '9.0'
VAR_INPUT
LADDR { S7_link := 'false' }: INT ; //Logical Address of Module
LADDR1 { S7_link := 'false' }: INT ; //Logical Address of Module
SUBN_TYP { S7_link := 'false' }: BOOL ; //1=External PN-Interface
SUBN1_ID { S7_link := 'false' }: BYTE := B#16#FF; //ID of Primary Subnet
SUBN2_ID { S7_link := 'false' }: BYTE := B#16#FF; //ID of Redundant Subnet
RACK_NO { S7_link := 'false' }: BYTE ; //Rack Number
SLOT_NO { S7_link := 'false' }: BYTE ; //Slot Number
SUBSL_NO { S7_link := 'false' }: BYTE ; //Subslot Number
CHAN_NUM { S7_link := 'false' }: INT ; //Highest Channel Address
MODE_00 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Mode Channel 0
MODE_01 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Mode Channel 1
MODE_02 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Mode Channel 2
MODE_03 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Mode Channel 3
MODE_04 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Mode Channel 4
MODE_05 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Mode Channel 5
MODE_06 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Mode Channel 6
MODE_07 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Mode Channel 7
DELAY1 { S7_visible := 'false'; S7_link := 'false' }: INT := 2; //Alarm Delay 1 (s)
DELAY2 { S7_visible := 'false'; S7_link := 'false' }: INT := 2; //Alarm Delay 2 (s)
FEATURE_01 { S7_visible := 'false'; S7_link := 'false' }: WORD ; //Features of Hardware Paramter 01
FEATURE_02 { S7_visible := 'false'; S7_link := 'false' }: WORD ; //Features of Hardware Paramter 02
FEATURE_03 { S7_visible := 'false'; S7_link := 'false' }: WORD ; //Features of Hardware Paramter 03
FEATURE_04 { S7_visible := 'false'; S7_link := 'false' }: WORD ; //Features of Hardware Paramter 04
FEATURE_05 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Features of Hardware Paramter 05
FEATURE_06 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Features of Hardware Paramter 06
FEATURE_07 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Features of Hardware Paramter 07
FEATURE_08 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Features of Hardware Paramter 08
FEATURE_09 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Features of Hardware Paramter 09
FEATURE_10 { S7_visible := 'false'; S7_link := 'false' }: DWORD ; //Features of Hardware Paramter 10
EV_ID1 { S7_visible := 'false'; S7_link := 'false'; S7_param := 'false'; S7_server := 'alarm_archiv'; S7_a_type := 'alarm_8p' }: DWORD ; //Event ID 1
EV_ID2 { S7_visible := 'false'; S7_link := 'false'; S7_param := 'false'; S7_server := 'alarm_archiv'; S7_a_type := 'alarm_8p' }: DWORD ; //Event ID 2
EN_MSG { S7_visible := 'false'; S7_link := 'false' }: BOOL := TRUE; //1=Enable Alarm
MS { S7_link := 'false'; S7_m_c := 'true' }: DWORD ; //Maintenance State
MS_REQ { S7_link := 'false'; S7_m_c := 'true' }: BOOL ; //Maintenance Release Request
DIAG_BUF { S7_visible := 'false' }: BOOL ; //1= CPU Diagnostic Buffer entry on (relevant for service personnel)
END_VAR
VAR_OUTPUT
QERR { S7_visible := 'false'; S7_dynamic := 'true' }: BOOL := TRUE; //1=Runtime Error
QRACKF { S7_dynamic := 'true' }: BOOL ; //1 = higher-level error
QMODF { S7_dynamic := 'true' }: BOOL ; //1=Module Removed / Out of Order
QPERAF { S7_dynamic := 'true' }: BOOL ; //1=Module I/O Access Failure
O_MS { S7_visible := 'false' }: DWORD ; //Maintenance State
CH_EXIST { S7_visible := 'false';
S7_m_c := 'true' } : DWORD; // Channel exist
CH_EXIST_byte AT CH_EXIST : ARRAY[0..3] OF BYTE;
CH_ACTIVE { S7_visible := 'false';
S7_m_c := 'true' } : DWORD; // Channel active
CH_ACTIVE_byte AT CH_ACTIVE : ARRAY[0..3] OF BYTE;
CH_OK { S7_visible := 'false';
S7_m_c := 'true' } : DWORD; // Channel OK
CH_OK_byte AT CH_OK : ARRAY[0..3] OF BYTE;
EXT_STAT { S7_visible := 'true';
S7_m_c := 'true' } : DWORD; // Maintenance Release - Extended Status
EXT_STAT_byte AT EXT_STAT : ARRAY[0..3] OF BYTE;
EXT_STAT_A { S7_visible := 'true'; S7_m_c := 'true' }: DWORD ; //Extended Status - Application
FS_ACTIVE { S7_visible := 'false'; S7_m_c := 'true' }: DWORD ; //Flatter supress active
DM_ACTIVE { S7_visible := 'false'; S7_m_c := 'true' }: DWORD ; //Delayed messaging active
OMODE_00 { S7_visible := 'false' }: DWORD ; //Mode Channel 0
OMODE_01 { S7_visible := 'false' }: DWORD ; //Mode Channel 1
OMODE_02 { S7_visible := 'false' }: DWORD ; //Mode Channel 2
OMODE_03 { S7_visible := 'false' }: DWORD ; //Mode Channel 3
OMODE_04 { S7_visible := 'false' }: DWORD ; //Mode Channel 4
OMODE_05 { S7_visible := 'false' }: DWORD ; //Mode Channel 5
OMODE_06 { S7_visible := 'false' }: DWORD ; //Mode Channel 6
OMODE_07 { S7_visible := 'false' }: DWORD ; //Mode Channel 7
DXCHG_00 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 0
DXCHG_01 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 1
DXCHG_02 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 2
DXCHG_03 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 3
DXCHG_04 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 4
DXCHG_05 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 5
DXCHG_06 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 6
DXCHG_07 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 7
DXCHG1_00 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 0
DXCHG1_01 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 1
DXCHG1_02 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 2
DXCHG1_03 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 3
DXCHG1_04 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 4
DXCHG1_05 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 5
DXCHG1_06 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 6
DXCHG1_07 { S7_visible := 'false' }: DWORD ; //Bidirectional data exchange Channel 7
MS_XCHG_00 { S7_visible := 'false' }: DWORD ; //MS exchange Channel 0
MS_XCHG_01 { S7_visible := 'false' }: DWORD ; //MS exchange Channel 1
MS_XCHG_02 { S7_visible := 'false' }: DWORD ; //MS exchange Channel 2
MS_XCHG_03 { S7_visible := 'false' }: DWORD ; //MS exchange Channel 3
MS_XCHG_04 { S7_visible := 'false' }: DWORD ; //MS exchange Channel 4
MS_XCHG_05 { S7_visible := 'false' }: DWORD ; //MS exchange Channel 5
MS_XCHG_06 { S7_visible := 'false' }: DWORD ; //MS exchange Channel 6
MS_XCHG_07 { S7_visible := 'false' }: DWORD ; //MS exchange Channel 7
MSGSTAT1 { S7_visible := 'false' }: WORD ; //Message Failure 1
MSGSTAT2 { S7_visible := 'false' }: WORD ; //Message Failure 2
MSG_ACK1 { S7_visible := 'false' }: WORD ; //Message Acknowledged 1
MSG_ACK2 { S7_visible := 'false' }: WORD ; //Message Acknowledged 2
MOD_INF { S7_visible := 'false' }: STRUCT
SUBN_ID : BYTE ; //Subnet Number
RACK_NO : BYTE ; //Rack Number
SLOT_NO : BYTE ; //Slot Number
SUBSL_NO : BYTE ; //Subslot Number
BASADR : WORD ; //Base Address
EXPECTYP : WORD ; //Expected Module Type
ACTTYP : WORD ; //Actual Module Type
RESERVE : WORD ; //Reserved
IOSTAT : BYTE ; //Data ID of Logical Address
IOSTAT_0 : BOOL ; //1=Module Fault
IOSTAT_1 : BOOL ; //1=Module Exists
IOSTAT_2 : BOOL ; //1=Module Removed
IOSTAT_3 : BOOL ; //Reserved
IOSTAT_4 : BOOL ; //Reserved
IOSTAT_5 : BOOL ; //1=Module can be Host for Submodule
IOSTAT_6 : BOOL ; //Reserved for S7-400
IOSTAT_7 : BOOL ; //1=Module on Local Bus Segment
AREA_ID : WORD ; //Area ID
END_STRUCT ;
DIAG_INF { S7_visible := 'false' } : "DIAG_INF" ;
DIAG_INF_AR AT DIAG_INF : ARRAY[0..1431] OF BYTE;
GET_DIAG_AR AT DIAG_INF : STRUCT
HEADER_INFO : ARRAY[0..12] OF WORD;
ALARM_INFO : ARRAY[0..702] OF WORD;
END_STRUCT;
END_VAR
VAR_IN_OUT
CPU_DIAG_PN : "CPU_DIAG_PN" ;
RAC_DIAG : "RAC_DIAG" ;
CPU_DIAG_PN_AR AT CPU_DIAG_PN : ARRAY[0..1423] OF BYTE;
ACC_MODE { S7_link := 'false' } : BOOL ; //1=Accept New Mode Settings
END_VAR
VAR
sdwRESERVE1 : DWORD ; //Reserve für zukünftige Änderungen
sdwRESERVE2 : DWORD ; //Reserve für zukünftige Änderungen
sdwRESERVE3 : DWORD ; //Reserve für zukünftige Änderungen
sdwRESERVE4 : DWORD ; //Reserve für zukünftige Änderungen
sdwRESERVE5 : DWORD ; //Reserve für zukünftige Änderungen
sdwRESERVE6 : DWORD ; //Reserve für zukünftige Änderungen
sdwRESERVE7 : DWORD ; //Reserve für zukünftige Änderungen
sdwRESERVE8 : DWORD ; //Reserve für zukünftige Änderungen
sdwRESERVE9 : DWORD ; //Reserve für zukünftige Änderungen
sdwRESERVE10 : DWORD ; //Reserve für zukünftige Änderungen
swHART_DIAG_RALRM : WORD ;
swHART_DIAG_RDREC : WORD ;
LADDR_BASIS : INT ; //Basisadresse der Baugruppe wird aus LADDR und LADDR1 bestimmt
siBeginChannelType : INT ; //wird benötigt für weitere Kanaltypen
siBeginChannelDiag : INT ; //wird benötigt für weitere Kanaltypen
sbFurtherChannelType : BOOL ; //wird benötigt für weitere Kanaltypen
sbFurtherChannelTypeSC : BOOL ; //weiterer Kanaltyp aber gleiche Kanäle wie der vorhergehende Kanaltyp
sbOB83CheckFWUpdate : BOOL ; //Bei spez. Hart Baugruppen muß wegen mögl.FW Update bei gehendem OB83 Dignose im
sbyChannelType : BYTE ; //wird benötigt für weitere Kanaltypen
sbyDiagnosticBitsPerChn : BYTE ; //wird benötigt für weitere Kanaltypen
sbyNumberOfChn : BYTE ; //wird benötigt für weitere Kanaltypen
sbyChnVector1 : BYTE ; //wird benötigt für weitere Kanaltypen
sbyChnVector2 : BYTE ; //wird benötigt für weitere Kanaltypen
sbyChnVector3 : BYTE ; //wird benötigt für weitere Kanaltypen
OB82_CNT : INT ; //OB82 Aufrufzähler
LOCK_82_TM : DINT ; //Wartezeit OB82
IOTYP : BYTE := B#16#FF; //Ein- oder Ausgabemodul
BG300 : BOOL ; //1: S7-300 - Modul 16 Bit
HART : BOOL ; //1: HART - Modul
CHECK : BOOL ; //Konfiguration OK?
END_STRUCT ;
RQ : STRUCT
PARA : BOOL ; //Parametrierung angefordert / läuft
DIAG : BOOL ; //Diagnose angefordert / läuft
CHRS : BOOL ; //Kanalfehler löschen
OB1PARA : BOOL ; //OB1 liest Parametrierung
OB1DIAG : BOOL ; //OB1 liest Diagnosedaten
PRIO28 : BOOL ; //Unterbrechung mit PRIO 28
OB1INT : BOOL ; //OB1 während Parametrierung oder Diagnose unterbrochen?
END_STRUCT ;
MODF : STRUCT
BG : BOOL ; //Baugruppenfehler
ZS : BOOL ; //Baugruppe gezogen
ZSMEL : BOOL ; //Baugruppe gezogen melden // 2.8.2001 SCH
FBG : BOOL ; //Falsche Bauruppe //2.8.2001 SCH
ACC : BOOL ; //Peripheriezugriffsfehler
X1 : BOOL ; //Maintenance Demand/ uncertain
X2 : BOOL ; //reserve Alarm8p Signal 8
END_STRUCT ;
MODF_MESG : STRUCT
END_STRUCT ;
sMODF_MESG : STRUCT
END_STRUCT ;
T_CH2 : ARRAY [0 .. 7 ] OF //Kanalfehlertext alarm8p 2
INT ; //Kanalfehlertext alarm8p 2
TX_NR : ARRAY [0 .. 31 ] OF //Fehlertext_Nummer
INT := 1, 2, 3, 4, 5, 6, 7, 8; //Fehlertext_Nummer
siDiagBit : INT := 7; //Anzahl der ausgewerteten Diagnose Bits
sdwDiagBitAllocation : DWORD ; //Diagnosebits des Kanals in einem DWORD
T_BG_ZS : INT ; //Ziehen Stecken Fehlertextnummer 4.5 Schultz
T_BG_F : INT ; //Baugruppenfehler Fehlertextnummer 4.5 Schultz
CH_VECT : BYTE ; //Kanalfehlervektor 1 und 2
CH_VECT_MESG : BYTE ; //Kanalfehlervektor 1
sCH_VECT : BYTE ;
sbCH_VECT_MESG1 : BYTE ; //letztes Kanalfehlervektor 1
sbCH_VECT_MESG2 : BYTE ; //letztes Kanalfehlervektor 2
DEL_CNT_MESG : ARRAY [0 .. 7 ] OF //Verzögerung (ms)
DINT ; //Verzögerung (ms)
DEL_TIM_MESG : ARRAY [0 .. 7 ] OF //Verzögerung (ms)
DEL_ACT_MESG : ARRAY [0 .. 7 ] OF BOOL ;
DEL_CNT_MESG_MODF_ZSMEL : DINT ;
DEL_CNT_MESG_MODF_BG : DINT ;
DEL_CNT_MESG_MODF_FBG : DINT ;
DEL_CNT_MESG_MODF_X1 : DINT ;
DEL_TIM_MESG_MODF_ZSMEL : DINT ;
DEL_TIM_MESG_MODF_BG : DINT ;
DEL_TIM_MESG_MODF_FBG : DINT ;
DEL_TIM_MESG_MODF_X1 : DINT ;
DEL_ACT_MESG_MODF_ZSMEL : BOOL ;
DEL_ACT_MESG_MODF_BG : BOOL ;
DEL_ACT_MESG_MODF_FBG : BOOL ;
DEL_ACT_MESG_MODF_X1 : BOOL ;
DEL_CNT_MESG_MaintAlarm : DINT ;
DEL_CNT_MESG_MaintWarn : DINT ;
DEL_CNT_MESG_MaintReqst : DINT ;
DEL_TIM_MESG_MaintAlarm : DINT ;
DEL_TIM_MESG_MaintWarn : DINT ;
DEL_TIM_MESG_MaintReqst : DINT ;
DEL_ACT_MESG_MaintAlarm : BOOL ;
DEL_ACT_MESG_MaintWarn : BOOL ;
DEL_ACT_MESG_MaintReqst : BOOL ;
sbCH_VECT1 : BYTE ; //Kanalfehlervektor 1
sbMODFZS : BOOL ; //Letztes gemeldetes ZS-Ereignis
sbMODFBG : BOOL ; //Letztes gemeldetes BG-Ereignis
sbMODFFBG : BOOL ;
sbMODFX1 : BOOL ; //Maintenance Demand/ uncertain
sbMODFX2 : BOOL ; //reserve Alarm8p Signal 8
sbPERAF : BOOL ; //Letztes gemeldetes PERAF-Ereignis
OB82_SP : BOOL ; //Meldung OB82 gesperrt
sbOB82_SP : BOOL ; //Zustand Meldung OB82 gesperrt
INI_ALRM1 : BOOL := TRUE; //1=ALARM_8P_1 muß initialisiert werden
INI_ALRM2 : BOOL := TRUE; //1=ALARM_8P_2 muß initialisiert werden
KIR : BOOL ; //Konfiguration im Run
KIR_OLD : BOOL ; //Hilfsmerker Konfiguration im Run
sbRESTART : BOOL := TRUE;
DEL_ACT : BOOL ; //PERAF wird für übergeordneten Fehler verzögert
DEL_CNT : DINT ; //Verzögerung (ms)
DEL_TIM : DINT ; //Start der Verzögerung
DELAY : DINT ; //Eingestellte Verzögerung
bFlutterNotSet : BOOL := TRUE;
ALARM_8P_1 : "ALARM_8P"; //Multiinstanzierte ALARM_8P
ALARM_8P_2 : "ALARM_8P"; //Multiinstanzierte ALARM_8P
RDREC_1 : "RDREC"; //Multiinstanz SFB 52
sChNummer : INT ;
sbOB82BeforeOB83 : BOOL ;
-spam- : BOOL ;
sbUpdOMODEAftrRckRet : BOOL ;
sbMaintAlarm : BOOL ;
sbMaintWarn : BOOL ;
sbMaintReqst : BOOL ;
sbMaintAlarm_old : BOOL ;
sbMaintWarn_old : BOOL ;
sbMaintReqst_old : BOOL ;
sbMaintAlarm_MESG : BOOL ;
sbMaintWarn_MESG : BOOL ;
sbMaintReqst_MESG : BOOL ;
sbMaintAlarm_MESG_old : BOOL ;
sbMaintWarn_MESG_old : BOOL ;
sbMaintReqst_MESG_old : BOOL ;
sbIoModNotRed : BOOL ;
sbHwFwDiff : BOOL ;
sbIoModNotRed_old : BOOL ;
sbHwFwDiff_old : BOOL ;
END_VAR
VAR_TEMP
EN_OUTP : BOOL ; //Ausgänge freigeben
EN_ALRM : BOOL ; //Alarm_8P freigeben
sbRACKF : BOOL ; //Rackfehler
OB_START : WORD;
OBSTART AT OB_START : STRUCT
OB_70 : BOOL; // Ablauf im OB70 Peripherie-Redundanzfehler
OB_72 : BOOL; // Ablauf im OB72 CPU-Redundanzfehler
OB_82 : BOOL; // Ablauf im OB82 Dianose-Interrupt
OB_83 : BOOL; // Ablauf im OB83 Ziehen- Stecken Alarm
OB_85 : BOOL; // Ablauf im OB85 Zeitablauf Fehler
OB_86 : BOOL; // Ablauf im OB86 PN-IO Stationsausfall
OB_1 : BOOL; // Ablauf im OB1 Cyclical Prog
OB_100 : BOOL; // Ablauf im OB100 Restart
OB_3x : BOOL; // Ablauf im OB30 bis OB38
OB_NP : BOOL; // Ablauf im NP - Organization Block not provided
OB_80 : BOOL; // Ablauf im OB80 Zykluszeitüberschreitung
OB_81 : BOOL; // Ablauf im OB81
END_STRUCT;
CHANNELS : INT ; //Kanalanzahl der Baugruppe
CHANNELS_OFFSET : INT ; //Kanal Offset bei mehreren Kanaltypen mit weiteren Kanälen
X : INT ; //schleifenzähler für Texte für Begleitwerte
y : INT ; //temp Integer
Z : INT ; //temp Integer
SZL_HEADER : STRUCT
LENTHDR : WORD ;
N_DR : WORD ;
END_STRUCT ;
GEO_PN : STRUCT
SUBNET : BYTE ; //SUBNET belegt 1 WORD im Speicher!
RACK : BYTE ;
SLOT : WORD ;
SUBSL_NO : WORD ;
END_STRUCT ;
ZI1 : WORD ;
byQHL : BYTE ;
byQLL : BYTE ;
bMBSM : BOOL ;
bMBFM : BOOL ;
ZI2_3 : DWORD ;
ZI2_3_AR AT ZI2_3 : ARRAY[0..1] OF WORD;
CH_O : DWORD;
CH_O_bool AT CH_O : ARRAY[0..31] OF BOOL;
CH_O_byte AT CH_O : ARRAY[0..3] OF BYTE;
CH_E : DWORD ;
CH_E_bool AT CH_E : ARRAY[0..31] OF BOOL;
CH_E_byte AT CH_E : ARRAY[0..3] OF BYTE;
CH_A : DWORD;
CH_A_bool AT CH_A : ARRAY[0..31] OF BOOL;
CH_A_byte AT CH_A : ARRAY[0..3] OF BYTE;
EXT_S : DWORD ;
EXT_S_bool AT EXT_S : ARRAY[0..31] OF BOOL;
EXT_S_byte AT EXT_S : ARRAY[0..3] OF BYTE;
TOP_SI : STRUCT
EV_CLASS : BYTE ;
EV_NUM : BYTE ;
PRIORITY : BYTE ;
NUM : BYTE ;
TYP2_3 : BYTE ;
TYP1 : BYTE ;
ZI1 : WORD ;
ZI2_3 : DWORD ;
END_STRUCT ;
tdwMS_AS : DWORD ; //Maintenance State AS
tMS_XCHG : DWORD ; //Maintenance State AS
bTmpFlutter : BOOL ; //BOOL für verrundung der DXCHG_xx 0 bit
tDXCHG : DWORD ;
MOD_INF_TEMP : STRUCT
SUBN_ID_RACK_NO : WORD ; //bei dezentralem Aufbau mit PROFINET IO: Bit 15 = 1 (PROFINET IO-Kennung), die l
SLOT_NO_SUBSL_NO : WORD ; //bei dezentralem Aufbau mit PROFINET IO: Steckplatznummer
END_STRUCT ;
tMODE : DWORD ;
tModfBg : BOOL ;
intINDEX : INT ;
tiLen : INT ;
twHART_OB82 : WORD ;
twHART_OB1 : WORD ;
tbHART : BOOL ;
iRET_VAL : INT ;
wINFO1 : WORD ;
dwINFO2 : DWORD ;
MODF_BG_GONE : BOOL ;
tbCondMon : BOOL ;
tdwDXCHG1 : DWORD ;
tbMaintAlarm : BOOL ;
tbMaintWarn : BOOL ;
tbMaintReqst : BOOL ;
-spam- : BYTE ;
twTextRef : WORD ;
twChnNum_OB82 : WORD ;
twErrStat_OB82 : WORD ;
twErrTyp_OB82 : WORD ;
twChnNum_OB1 : WORD ;
twErrStat_OB1 : WORD ;
twErrTyp_OB1 : WORD ;
END_VAR
BEGIN
EN_OUTP := FALSE;
EN_ALRM := FALSE;
sbRACKF := FALSE;
// NUM := B#16#0;
OB_START := W#16#0;
RETURN_CODE := 0;
CHANNELS := 0;
CHANNELS_OFFSET := 0;
X := 0;
y := 0;
Z := 0;
SZL_HEADER.LENTHDR := W#16#0;
SZL_HEADER.N_DR := W#16#0;
GEO_PN.SUBNET := B#16#0;
GEO_PN.RACK := B#16#0;
GEO_PN.SLOT := B#16#0;
GEO_PN.SUBSL_NO := B#16#0;
ZI1 := W#16#0;
byQHL := B#16#0;
byQLL := B#16#0;
bMBSM := 0;
bMBFM := 0;
ZI2_3 := DW#16#0;
CH_O := DW#16#0;
CH_E := DW#16#0;
CH_A := DW#16#0;
EXT_S := DW#16#0;
TOP_SI.EV_CLASS := B#16#0;
TOP_SI.EV_NUM := B#16#0;
TOP_SI.PRIORITY := B#16#0;
TOP_SI.NUM := B#16#0;
TOP_SI.TYP2_3 := B#16#0;
TOP_SI.TYP1 := B#16#0;
TOP_SI.ZI1 := W#16#0;
TOP_SI.ZI2_3 := DW#16#0;
//wQHL := W#16#0;
//wQLL := W#16#0;
tdwMS_AS := W#16#0;
tMS_XCHG := W#16#0;
bTmpDXCHG := FALSE;
bTmpFlutter := FALSE;
tDXCHG := FALSE;
MOD_INF_TEMP.SUBN_ID_RACK_NO := W#16#0;
MOD_INF_TEMP.SLOT_NO_SUBSL_NO := W#16#0;
MOD_INF_TEMP.BASADR := W#16#0;
MOD_INF_TEMP.EXPECTYP := W#16#0;
MOD_INF_TEMP.ACTTYP := W#16#0;
MOD_INF_TEMP.RESERVE := W#16#0;
MOD_INF_TEMP.IOSTAT := B#16#0;
MOD_INF_TEMP.IOSTAT_0 := FALSE;
MOD_INF_TEMP.IOSTAT_1 := FALSE;
MOD_INF_TEMP.IOSTAT_2 := FALSE;
MOD_INF_TEMP.IOSTAT_3 := FALSE;
MOD_INF_TEMP.IOSTAT_4 := FALSE;
MOD_INF_TEMP.IOSTAT_5 := FALSE;
MOD_INF_TEMP.IOSTAT_6 := FALSE;
MOD_INF_TEMP.IOSTAT_7 := FALSE;
MOD_INF_TEMP.AREA_ID := W#16#0;
tMODE := FALSE;
tModfBg := FALSE;
intINDEX := 0;
tiLen := 0;
twHART_OB82 := W#16#0;
twHART_OB1 := W#16#0;
tbHART := FALSE;
iRET_VAL := 0;
wINFO1 := W#16#0;
dwINFO2 := DW#16#0;
MODF_BG_GONE := FALSE;
//tbCentralOneSideFail := FALSE;
tbCondMon := FALSE;
tdwDXCHG1 := FALSE;
tbMaintAlarm := FALSE;
tbMaintWarn := FALSE;
tbMaintReqst := FALSE;
-spam- := B#16#0;
twTextRef := W#16#0;
twChnNum_OB82 := W#16#0;
twErrStat_OB82 := W#16#0;
twErrTyp_OB82 := W#16#0;
twChnNum_OB1 := W#16#0;
twErrStat_OB1 := W#16#0;
twErrTyp_OB1 := W#16#0;
CASE CPU_DIAG_PN.OB_S.NUM_CNT OF
1 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_01;
2 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_02;
3 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_03;
4 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_04;
5 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_05;
6 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_06;
7 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_07;
8 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_08;
9 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_09;
10 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_10;
11 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_11;
12 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_12;
13 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_13;
14 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_14;
15 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_15;
16 :
TOP_SI.NUM := CPU_DIAG_PN.OB_S.NUM_16;
ELSE;
END_CASE;
(** Ablauf-OB bestimmen **)
IF TOP_SI.NUM = B#16#1 THEN
(* Bit im Status besetzen *)
OBSTART.OB_1 := TRUE; //
(* Sonderbehandlung beim Ablauf im OB1 *)
sbRACKF := RAC_DIAG.RACK_ERR;
IF sbRACKF <> QRACKF THEN
IF SUBN1_ID = B#16#FF THEN
ACC_MODE := NOT sbRACKF;
END_IF;
QRACKF := sbRACKF;
END_IF;
ELSIF TOP_SI.NUM = B#16#55 THEN
OBSTART.OB_85 := TRUE;
(* Ablauf im OB85 Programmablauffehler *)
GEO_PN.SUBNET := WORD_TO_BYTE(CPU_DIAG_PN.OB_85.SUBNET);
GEO_PN.RACK := WORD_TO_BYTE(CPU_DIAG_PN.OB_85.RACK);
GEO_PN.SLOT := CPU_DIAG_PN.OB_85.SLOT;
GEO_PN.SUBSL_NO := CPU_DIAG_PN.OB_85.SUBSL_NO;
TOP_SI.EV_CLASS := CPU_DIAG_PN.OB_85.TOP_SI.EV_CLASS;
ZI2_3 := CPU_DIAG_PN.OB_85.TOP_SI.ZI2_3;
ELSIF TOP_SI.NUM = B#16#52 THEN
OBSTART.OB_82 := TRUE;
(* Ablauf im OB82 Diagnose-Alarm *)
GEO_PN.SUBNET := WORD_TO_BYTE(CPU_DIAG_PN.OB_82.SUBNET);
GEO_PN.RACK := WORD_TO_BYTE(CPU_DIAG_PN.OB_82.RACK);
GEO_PN.SLOT := DWORD_TO_WORD(SHR(IN:=(CPU_DIAG_PN.OB_82.AINFO.SLOT_SUBSLOT_NO AND DW#16#FFFF0000),N:=16));
GEO_PN.SUBSL_NO := DWORD_TO_WORD(SHL(IN:=(CPU_DIAG_PN.OB_82.AINFO.SLOT_SUBSLOT_NO AND DW#16#FFFF),N:=16));
TOP_SI := CPU_DIAG_PN.OB_82.TOP_SI;
//TOP_SI.ZI2_3 := CPU_DIAG_PN.OB_82.TOP_SI.ZI2_3;
ELSIF TOP_SI.NUM = B#16#56 THEN
OBSTART.OB_86 := TRUE;
(* Ablauf im OB86 Baugruppenträgerausfall *)
GEO_PN.SUBNET := WORD_TO_BYTE(CPU_DIAG_PN.OB_86.SUBNET);
GEO_PN.RACK := WORD_TO_BYTE(CPU_DIAG_PN.OB_86.RACK);
TOP_SI := CPU_DIAG_PN.OB_86.TOP_SI;
//TOP_SI.ZI2_3 := CPU_DIAG_PN.OB_86.TOP_SI.ZI2_3;
ELSIF TOP_SI.NUM = B#16#53 THEN
OBSTART.OB_83 := TRUE;
(* Ablauf im OB83 Ziehen / Stecken Alarm *)
GEO_PN.SUBNET := WORD_TO_BYTE(CPU_DIAG_PN.OB_83.SUBNET);
GEO_PN.RACK := WORD_TO_BYTE(CPU_DIAG_PN.OB_83.RACK);
GEO_PN.SLOT := CPU_DIAG_PN.OB_83.SLOT;
GEO_PN.SUBSL_NO := CPU_DIAG_PN.OB_83.SUBSL_NO;
TOP_SI := CPU_DIAG_PN.OB_83.TOP_SI;
//TOP_SI.ZI2_3 := CPU_DIAG_PN.OB_83.TOP_SI.ZI2_3;
ELSIF TOP_SI.NUM = B#16#64 THEN
OBSTART.OB_100 := TRUE;
(* Ablauf im OB100 *)
ELSIF TOP_SI.NUM = B#16#46 THEN
OBSTART.OB_70 := TRUE;
(* Ablauf im OB70 Peripherie-Redundanzfehler *)
GEO_PN.SUBNET := WORD_TO_BYTE(CPU_DIAG_PN.OB_70.SUBNET);
GEO_PN.RACK := WORD_TO_BYTE(CPU_DIAG_PN.OB_70.RACK);
TOP_SI := CPU_DIAG_PN.OB_70.TOP_SI;
ELSIF TOP_SI.NUM = B#16#48 THEN
OBSTART.OB_72 := TRUE;
(* Ablauf im OB72 CPU-Redundanzfehler *)
ELSE
END_IF;
SFB00_CTU
SFB01_CTD
SFB02_CTUD
SFB03_TP
SFB04_TON
SFB05_TOF
SFB08_USEND
SFB09_URCV
SFB12_BSEND
SFB13_BRCV
SFB14_GET
SFB15_PUT
SFB16_PRINT
SFB19_START
SFB20_STOP
SFB21_RESUME
SFB22_STATUS
SFB23_USTATUS
SFB29_HS_COUNT
SFB30_FREQ_MES
SFB31_SEND_PTP
SFB33_ALARM
SFB34_ALARM_8
SFB35_ALARM_8P
SFB36_NOTIFY
SFB37_AR_SEND
SFB38_HSC_A_B
SFB39_POS
SFB41_CONT_C
SFB42_CONT_S
SFB52_RDREC
SFB53_WRREC
SFB54_RALRM
SFB73_RCVREC
SFB74_PRVREC
SFC1
SFC13
SFC14
SFC15
SFC17
SFC18
SFC20
SFC21
SFC22
SFC23
SFC24
SFC27
SFC28
SFC29
SFC30
SFC31
SFC5
SFC52
SFC6
SFC64
FUNCTION_BLOCK FB 3
AUTHOR : DRIVER90
FAMILY : '@SYSTEM'
VERSION : 9.0
VAR_INPUT
... SEE ATTACH ...
END_VAR
BEGIN
NETWORK
TITLE =SCL Netzwerk
//generiert vom SCL Übersetzer Version: SCLCOMP K05.06.00.00_11.01.00.01 release
SET ;
SAVE ;
= L 140.1;
CLR ;
L #TOP_SI.EV_CLASS;
L B#16#39;
==I ;
U L 2.2;
L #twChnNum_OB82;
L W#16#8000;
UW ;
L W#16#8000;
= L 140.2;
==I ;
L #twErrTyp_OB82;
L W#16#121;
= L 140.3;
==I ;
= L 140.4;
U L 2.2;
NOT ;
L #twErrTyp_OB1;
L W#16#121;
= L 140.5;
==I ;
U L 140.5;
O L 140.4;
NOT ;
U L 140.3;
L DIW [AR2,P#308.0];
L W#16#3;
UW ;
L W#16#3;
= L 140.3;
==I ;
L #FEATURE_05;
L DW#16#241670;
= L 140.4;
==D ;
U L 140.4;
O L 140.3;
U L 140.2;
SPBN A7d1;
SET ;
= #MODF.BG;
A7d1 : CLR;
U L 140.1;
SAVE ;
BE ;
END_FUNCTION_BLOCK
END_VAR
BEGIN
MODF.BG:=TRUE;
END_FUNCTION_BLOCK
MODF_BG_GONE :=
((TOP_SI.EV_CLASS = B#16#39 AND OBSTART.OB_82 AND ((twChnNum_OB82 AND W#16#8000) = W#16#8000))
AND
((twErrStat_OB82 AND W#16#1800) = W#16#1800)
AND NOT
(FEATURE_01 = W#16#1) OR MODF_BG_GONE) OR (
((TOP_SI.EV_CLASS = B#16#39) AND OBSTART.OB_82) AND ((twChnNum_OB82 AND W#16#8000) = W#16#8000)
AND
((twErrStat_OB82 AND W#16#1800) = W#16#1000) AND ((CPU_DIAG_PN.OB_82.TOP_SI.ZI2_3 AND DW#16#1000000) = DW#16#1000000));
So, whats the true ? Supported or not supported ?stl2sclSupport wrote: ↑Fri Jan 17, 2020 12:56 amIN_OUT variables (including structure type variables) are supported.
Tryed now witch different code sequences and many options, in the english mnemonics. Your shit still does not work. I have no idea, how to use your programm, in order to help me by reversing of Blocks. I see actually no one single benefit from it.2. For correct operation of the converter, use English mnemonics.
А что вам именно не понравилось ? Предприимчивые ребята решили капусты срубить на "тупых пиндосах", видимо. Здесь однако люди тоже не лыком шиты. Какой ещё смысл вот так юродствовать, чтобы потом признаться, что продукт дерьмо (я извиняюсь, ограниченно функционален !) и типо давай денюжку, цыганочка погадает ?
