STL to SCL conversion
Utilites for Simatic Automation
stl2sclSupport
Contact:
Post by stl2sclSupport » Thu Jan 09, 2020 3:17 pm
We bring to your attention free online service
https://stl2scl.com
This service allows to convert/decompile your STL code made in Simatic Step 7 to readable SCL code.
It is alpha version.
Tested on decompilation of STL (AWL) files created by SCL compiler v5.3-5.6.
The source file is an awl file created with:
Show
Waiting for your feedback and suggestions!
Draco Malfoy
Re: STL to SCL conversion
Post by Draco Malfoy » Thu Jan 16, 2020 12:31 pm
Very interesting. How can i purchase the product with fully support ? I have actually allways the "internal server error" if i try to recompile blocks from sources inside of your demo version.
I have also many questions, how it should work. Maybe you can answer to it, and make clear, that your product is a reliably solution in different usecases.
1. How your programm will treat the lost Views on a Variable, build by usind the Operator "AT" ? Will generate possible views, or generate an error, or ask the operator ?
2. Whats happen, if your programm recover an acces to a system function, or acces to a third party funktion block in the code ? How it will be reconstructed ?
3.Its a citation from your page:
"supported operation systems: Windows (XP and newer), MacOS, Linux. Contact us to get desktop version with contact@stl2scl.com."
i'm sorry, but.. what ?? Supported operating system - Linux and MacOS ?? Since witch time SIMATIC Manager and Siemens programming tools support Linux or MacOS ?? I will never believe that you have developed a fully working recompiler for operating systems, in witch such products normally never will be used.
It seems like the web-demo were only a web interface for this one tool:
http://plc4good.org.ua/view_post.php?id=100
stl2sclSupport
Contact:
Post by stl2sclSupport » Thu Jan 16, 2020 4:44 pm
Thank your for your response!
The converter is cross-platform so you can use it on any of mentioned operation systems.
We have some limitations for the online version in error messages. Sometimes it may not be clear from the messages what is going wrong. Thus, you can follow these steps:
1. Check that you did not change original AWL code. Sometimes it can happen that minimal changes can cause errors.
2. Verify your compiler version. We have tested our code on SCL compiler v5.3-5.6. Other compiler versions support is in development.
3. It could be a bug in code, so if your still get an error, than your can send us an example of code that does not work on contact@stl2scl.com. Our engineers will do their best to solve an issue.
1. AT variables are created automatically in the necessary sections of the VAR areas, if necessary.
You can try with a simple example:
Show
FUNCTION_BLOCK FB 1
TITLE =
VERSION : 0.0
VAR
  s : STRUCT
   x1 : INT ;
   x2 : INT ;
  END_STRUCT ;
END_VAR
BEGIN
NETWORK
TITLE =SCL network
//compiled by SCL compiler version:  SCLCOMP K05.03.06.00_01.03.00.01 release
      SET   ;
      SAVE  ;
      =     L      0.1;
      L     B#16#2;
      T     DIB [AR2,P#0.0];
      SAVE  ;
      BE    ;
END_FUNCTION_BLOCK
It will be converted to:
Show
FUNCTION_BLOCK FB1
TITLE = ''
VERSION : '0.0'
VAR
  s : STRUCT
   x1 : INT ;
   x2 : INT ;
  END_STRUCT ;
	s_BYTE AT s : ARRAY[0 ..3] OF BYTE;
END_VAR
BEGIN
s_BYTE[0]:=B#16#2;
END_FUNCTION_BLOCK
2. SFB and SFC are supported (in the current version, not all, but in the near future we will add the remaining ones).
You can try an example:
Show
FUNCTION_BLOCK FB 10
TITLE =
VERSION : 0.0
VAR_INPUT
  x : STRUCT
   x1 : INT ;
   x2 : INT ;
   x3 : INT ;
   x4 : INT ;
   x5 : INT ;
  END_STRUCT ;
END_VAR
VAR_OUTPUT
  y : STRUCT
   x1 : INT ;
   x2 : INT ;
   x3 : INT ;
   x4 : INT ;
   x5 : INT ;
  END_STRUCT ;
  err : INT ;
END_VAR
BEGIN
NETWORK
TITLE =SCL network
      SET   ;
      SAVE  ;
      =     L      0.1;
      L     DW#16#1002000A;
      T     LD     2;
      L     DINO;
      T     LW     6;
      TAR2  ;
      +     L#0;
      T     LD     8;
      L     DW#16#1002000A;
      T     LD    12;
      L     DINO;
      T     LW    16;
      TAR2  ;
      +     L#80;
      T     LD    18;
      TAR2  LD    22;
      UC    SFC   20 {
            P#L 2.0,
            P#L 26.0,
            P#L 12.0};
      LAR2  LD    22;
      L     LW    26;
      T     #err;
      A     L      0.1;
      SAVE  ;
      BE    ;
END_FUNCTION_BLOCK
Show
FUNCTION_BLOCK FB10
TITLE = ''
VERSION : '0.0'
VAR_INPUT
  x : STRUCT
   x1 : INT ;
   x2 : INT ;
   x3 : INT ;
   x4 : INT ;
   x5 : INT ;
  END_STRUCT ;
END_VAR
VAR_OUTPUT
  y : STRUCT
   x1 : INT ;
   x2 : INT ;
   x3 : INT ;
   x4 : INT ;
   x5 : INT ;
  END_STRUCT ;
  err : INT ;
END_VAR
BEGIN
err:=SFC20(SRCBLK:=x,DSTBLK:=y);
END_FUNCTION_BLOCK
No, we don't use http://plc4good.org.ua project.
Draco Malfoy
Post by Draco Malfoy » Thu Jan 16, 2020 4:59 pm
I've tested your online recompiler with different code-samples and i have the following fixing now:
- Your software ist not able to recognize simple loops like FOR, WHILE etc.
- Your software simply ignore parts of original code
- Your software does not recompile the IF...THEN...ELSE statements
However, i've send you an Email with a code example witch i need to recompile. If you can show me that your solution works in this case, i may be interested to buy the programm.
stl2sclSupport wrote: The converter is cross-platform so you can use it on any of mentioned operation systems.
It doesn make sense for me. No one living man use Siemens Automation on Linux or MacOS, all the Siemens Software Solutions working exclusively on Windows systems.
stl2sclSupport
Contact:
Post by stl2sclSupport » Thu Jan 16, 2020 5:19 pm
1. Loops are supported. Code created with FOR and WHILE statements decompiled as WHILE statement. Code, created with REPEAT statement decompiled as REPEAT statement.
Example with WHILE:
Show
FUNCTION_BLOCK FB 7
TITLE =
VERSION : 0.0
VAR
  x : REAL ;
  i : INT ;
END_VAR
BEGIN
NETWORK
TITLE =SCL network
      SET   ;
      SAVE  ;
      =     L      0.1;
A7d0: L     #i;
      L     10;
      <I    ;
      JCN   A7d1;
      L     #x;
      L     3.000000e+000;
      +R    ;
      JO    I007;
      JU    I008;
I007: CLR   ;
      =     L      0.1;
I008: T     #x;
      L     #i;
      L     1;
      +I    ;
      JO    I009;
      JU    I00a;
I009: CLR   ;
      =     L      0.1;
I00a: T     #i;
      JU    A7d0;
A7d1: CLR   ;
      A     L      0.1;
      SAVE  ;
      BE    ;
END_FUNCTION_BLOCK
Show
FUNCTION_BLOCK FB7
TITLE = ''
VERSION : '0.0'
VAR
  x : REAL ;
  i : INT ;
END_VAR
BEGIN
WHILE i<10 DO
	x:=x + 3.000000e+000;
	i:=i + 1;
END_WHILE;
END_FUNCTION_BLOCK
IF, ELSE, CASE are suppored.
Here is an example of SСL code (we do not give STL because it will be long) that you can try to compile and then try to decompile.
Example with IF ELSE :
Show
FUNCTION_BLOCK FB4
TITLE = ''
VERSION : '0.0'
VAR
  x : REAL ;
  y : REAL ;
  i : INT ;
  b1 : BOOL ;
  b : BOOL ;
END_VAR
BEGIN
IF b THEN
	IF NOT b THEN
		y:=1.000000e+000;
		IF NOT b1 THEN
			y:=2.000000e+000;
		ELSE
			y:=3.000000e+000;
		END_IF;
		IF NOT b1 THEN
			y:=4.000000e+000;
		ELSE
			IF NOT b1 THEN
				y:=5.000000e+000;
			ELSE
				y:=6.000000e+000;
			END_IF;
			y:=7.000000e+000;
		END_IF;
	ELSE
		IF NOT b1 THEN
			y:=8.000000e+000;
		ELSE
			y:=9.000000e+000;
		END_IF;
		y:=1.000000e+001;
	END_IF;
	IF NOT b1 THEN
		y:=1.100000e+001;
	ELSE
		y:=1.200000e+001;
	END_IF;
END_IF;
END_FUNCTION_BLOCK
Example with CASE:
Show
FUNCTION_BLOCK FB1
TITLE = ''
VERSION : '0.0'
VAR
  x : REAL ;
  y : REAL ;
  i : INT ;
END_VAR
BEGIN
CASE i OF
	1:
		IF x<0.000000e+000 THEN
			y:=1.000000e+001;
		END_IF;
	2:
		IF x>0.000000e+000 THEN
			y:=2.000000e+001;
		END_IF;
	3:
		IF x=0.000000e+000 THEN
			y:=3.000000e+001;
		END_IF;
ELSE:
	y:=5.000000e+002;
END_CASE;
END_FUNCTION_BLOCK
Try to complicate these examples, everything should work)
Draco Malfoy
Post by Draco Malfoy » Thu Jan 16, 2020 5:41 pm
Ok, very well. Please look at my Email and give me feedback. My Trials with different Blocks from real librarys was'nt succesvull until now. Additionaly, i dont know with witch compiler options they was compilated in the original. But the version of SCL compiler should be correct.
Something let me suggest, that i will never receive a reply on my email.
here is my Sample-FB with witch i've tryed:
https://mega.nz/#!hY82wAKQ!nmtZCTq4I3fM ... UAnv1YawZA
Are you able to recompile it with your program ? Thanks
What i do not understand, for example, this simple code
part is alredy enough to get a total server error:
Show
FUNCTION_BLOCK "FbDrive"
TITLE =Channel Block for Motor Drives Telegramm1/20
{ S7_driver := 'chn'; S7_tasklist := 'OB100' }
AUTHOR : AdvLib90
FAMILY : Channel
VERSION : 9.0
VAR_INPUT
END_VAR
VAR_OUTPUT
END_VAR
VAR_IN_OUT
  Mode : DWORD  := DW#16#10;	//Quality and mode
  DataXchg : DWORD ;	//Data exchange
  DataXchg1 : DWORD ;	//Data exchange
  MS_Xchg : DWORD ;	//Maintenance State exchange
END_VAR
VAR
  sbRestart : BOOL  := TRUE;
  sdwRESERVE : DWORD ;	//Reserve für zukünftige Änderungen
  sCLSFailCounter : INT ;
  sCLSCounter : INT ;
  BytStatus : BYTE ;	//Statusbyte für Ausgänge
  LastByQuality : BYTE ;
END_VAR
VAR_TEMP
  TOP_SI : STRUCT
   EV_CLASS : BYTE ;
   EV_NUM : BYTE ;
   PRIORITY : BYTE ;
   NUM : BYTE ;
   TYP2_3 : BYTE ;
   TYP1 : BYTE ;
   ZI1 : WORD ;
   ZI2_3 : DWORD ;
  END_STRUCT ;
  START_UP_SI : STRUCT
   EV_CLASS : BYTE ;
   EV_NUM : BYTE ;
   PRIORITY : BYTE ;
   NUM : BYTE ;
   TYP2_3 : BYTE ;
   TYP1 : BYTE ;
   ZI1 : WORD ;
   ZI2_3 : DWORD ;
  END_STRUCT ;
  pi_RET_VAL : INT ;
  Status : BOOL ;	//Status
  FlutTm_t : DWORD ;	//Flatterunterdrückungszeit
  bTmpDXCHG : BOOL ;	//BOOL für verrundung der DXCHG_xx 0 bit
  BtMS07 : BOOL ;	//Bool for MS State 07
  BtMS06 : BOOL ;	//Bool for MS State 06
  tDXCHG : DWORD ;
  tbCtrlSimStatus : BOOL ;
  tFbDriveIn : ARRAY  [0 .. 5 ] OF WORD ;
  tIn0By : BYTE ;
  tFbDriveOut : ARRAY  [0 .. 1 ] OF WORD ;
  RETURN_CODE : INT ;	//Hilfsparameter (Wechselnde Bedeutung)!
  by_dummy : BYTE ;	//Hilfsparameter
  w_dummy : WORD ;	//Hilfsparameter
  r_dummy : REAL ;
  grad : REAL ;
  MS_AS : DWORD ;	//Maintenance State AS
  xConditionMonitoring : BOOL ;	//1=ConditionMonitoring
END_VAR
BEGIN
NETWORK
TITLE =SCL Netzwerk
//generiert vom SCL Übersetzer Version:  SCLCOMP K05.03.08.03_04.01.00.01 release
      SET   ;
      SAVE  ;
      =     L     76.2;
      L     W#16#0;
      T     LW    78;
      L     DW#16#87000000;
      T     LD    80;
      L     W#16#0;
      T     LW    84;
      L     DW#16#87000060;
      T     LD    86;
      TAR2  LD    90;
      UC    "RD_SINFO" {
            P#L 24.0,
            P#L 78.0,
            P#L 84.0};
      LAR2  LD    90;
      L     #TOP_SI.NUM;
      L     B#16#64;
      ==I   ;
      L     #Mode;
      L     DW#16#10000;
      UD    ;
      L     DW#16#10000;
      TAK   ;
      =     L     76.3;
      ==D   ;
      O     L     76.3;
      SPBN  A7d0;
      SET   ;
      =     #sbRestart;
A7d0: CLR   ;
      U     L     76.2;
      SAVE  ;
      BE    ;
END_FUNCTION_BLOCK
It is the SFC6 "RD_SINFO" System function Call, witch is not supported by your programm ?
Here, for example:
This AWL Code :
Show
FUNCTION_BLOCK "MOD_D8_PN"
TITLE =PN Diagnostic Module Check (0 - 7 Channel)
{ S7_hardware := 'sm'; S7_alarm_ui := '1'; S7_tasklist := 'OB1,OB82,OB83,OB85,OB100,OB86'; S7_tag := 'false' }
AUTHOR : DRIVER90
FAMILY : '@SYSTEM'
VERSION : 9.0
VAR_INPUT
[b][color=#FF0000]<... DETAILS SEE ATTACH ...>[/color][/b]
END_VAR
BEGIN
NETWORK
TITLE =SCL Netzwerk
//generiert vom SCL Übersetzer Version:  SCLCOMP K05.06.00.00_06.01.00.01 release
      SET   ;
      SAVE  ;
      =     L    140.1;
      CLR   ;
      =     #EN_OUTP;
      =     #EN_ALRM;
      =     #sbRACKF;
      L     W#16#0;
      T     #OB_START;
      L     0;
      T     #RETURN_CODE;
      T     #CHANNELS;
      T     #CHANNELS_OFFSET;
      T     #X;
      T     #y;
      T     #Z;
      TAK   ;
      T     #SZL_HEADER.LENTHDR;
      T     #SZL_HEADER.N_DR;
      L     B#16#0;
      T     #GEO_PN.SUBNET;
      T     #GEO_PN.RACK;
      TAK   ;
      T     #GEO_PN.SLOT;
      T     #GEO_PN.SUBSL_NO;
      T     #ZI1;
      TAK   ;
      T     #byQHL;
      T     #byQLL;
      =     #bMBSM;
      =     #bMBFM;
      L     DW#16#0;
      T     #ZI2_3;
      T     #CH_O;
      T     #CH_E;
      T     #CH_A;
      T     #EXT_S;
      TAK   ;
      T     #TOP_SI.EV_CLASS;
      T     #TOP_SI.EV_NUM;
      T     #TOP_SI.PRIORITY;
      T     #TOP_SI.NUM;
      T     #TOP_SI.TYP2_3;
      T     #TOP_SI.TYP1;
      L     W#16#0;
      T     #TOP_SI.ZI1;
      L     DW#16#0;
      T     #TOP_SI.ZI2_3;
      T     #tdwMS_AS;
      T     #tMS_XCHG;
      =     #bTmpDXCHG;
      =     #bTmpFlutter;
      T     #tDXCHG;
      TAK   ;
      T     #MOD_INF_TEMP.SUBN_ID_RACK_NO;
      T     #MOD_INF_TEMP.SLOT_NO_SUBSL_NO;
      T     #MOD_INF_TEMP.BASADR;
      T     #MOD_INF_TEMP.EXPECTYP;
      T     #MOD_INF_TEMP.ACTTYP;
      T     #MOD_INF_TEMP.RESERVE;
      L     B#16#0;
      T     #MOD_INF_TEMP.IOSTAT;
      =     #MOD_INF_TEMP.IOSTAT_0;
      =     #MOD_INF_TEMP.IOSTAT_1;
      =     #MOD_INF_TEMP.IOSTAT_2;
      =     #MOD_INF_TEMP.IOSTAT_3;
      =     #MOD_INF_TEMP.IOSTAT_4;
      =     #MOD_INF_TEMP.IOSTAT_5;
      =     #MOD_INF_TEMP.IOSTAT_6;
      =     #MOD_INF_TEMP.IOSTAT_7;
      TAK   ;
      T     #MOD_INF_TEMP.AREA_ID;
      L     DW#16#0;
      T     #tMODE;
      =     #tModfBg;
      L     0;
      T     #intINDEX;
      T     #tiLen;
      L     W#16#0;
      T     #twHART_OB82;
      T     #twHART_OB1;
      =     #tbHART;
      TAK   ;
      T     #iRET_VAL;
      TAK   ;
      T     #wINFO1;
      L     DW#16#0;
      T     #dwINFO2;
      =     #MODF_BG_GONE;
      =     #tbCondMon;
      T     #tdwDXCHG1;
      =     #tbMaintAlarm;
      =     #tbMaintWarn;
      =     #tbMaintReqst;
      L     B#16#0;
      T     #-spam-;
      L     W#16#0;
      T     #twTextRef;
      T     #twChnNum_OB82;
      T     #twErrStat_OB82;
      T     #twErrTyp_OB82;
      T     #twChnNum_OB1;
      T     #twErrStat_OB1;
      T     #twErrTyp_OB1;
      L     DIW [AR2,P#1714.0];
      T     LW   142;
      TAK   ;
      AUF   DB [LW 142];
      L     DID [AR2,P#1716.0];
      LAR1  ;
      TAK   ;
      L     W [AR1,P#6.0];
      T     LW   142;
      L     1;
      TAK   ;
      ==I   ;
      SPB   A7d1;
      SPA   A7d2;
A7d1: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#8.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7d2: L     2;
      L     LW   142;
      ==I   ;
      SPB   A7d3;
      SPA   A7d4;
A7d3: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#9.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7d4: L     3;
      L     LW   142;
      ==I   ;
      SPB   A7d5;
      SPA   A7d6;
A7d5: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#10.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7d6: L     4;
      L     LW   142;
      ==I   ;
      SPB   A7d7;
      SPA   A7d8;
A7d7: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#11.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7d8: L     5;
      L     LW   142;
      ==I   ;
      SPB   A7d9;
      SPA   A7da;
A7d9: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#12.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7da: L     6;
      L     LW   142;
      ==I   ;
      SPB   A7db;
      SPA   A7dc;
A7db: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#13.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7dc: L     7;
      L     LW   142;
      ==I   ;
      SPB   A7dd;
      SPA   A7de;
A7dd: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#14.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7de: L     8;
      L     LW   142;
      ==I   ;
      SPB   A7df;
      SPA   A7e0;
A7df: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#15.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7e0: L     9;
      L     LW   142;
      ==I   ;
      SPB   A7e1;
      SPA   A7e2;
A7e1: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#16.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7e2: L     10;
      L     LW   142;
      ==I   ;
      SPB   A7e3;
      SPA   A7e4;
A7e3: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#17.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7e4: L     11;
      L     LW   142;
      ==I   ;
      SPB   A7e5;
      SPA   A7e6;
A7e5: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#18.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7e6: L     12;
      L     LW   142;
      ==I   ;
      SPB   A7e7;
      SPA   A7e8;
A7e7: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#19.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7e8: L     13;
      L     LW   142;
      ==I   ;
      SPB   A7e9;
      SPA   A7ea;
A7e9: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#20.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7ea: L     14;
      L     LW   142;
      ==I   ;
      SPB   A7eb;
      SPA   A7ec;
A7eb: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#21.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7ec: L     15;
      L     LW   142;
      ==I   ;
      SPB   A7ed;
      SPA   A7ee;
A7ed: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#22.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7ee: L     16;
      L     LW   142;
      ==I   ;
      SPB   A7ef;
      SPA   A7d0;
A7ef: L     DIW [AR2,P#1714.0];
      T     LW   144;
      TAK   ;
      AUF   DB [LW 144];
      LAR1  ;
      TAK   ;
      L     B [AR1,P#23.0];
      T     #TOP_SI.NUM;
      SPA   A7d0;
A7d0: L     #TOP_SI.NUM;
      L     B#16#1;
      ==I   ;
      SPBN  A7f1;
      SET   ;
      =     L      2.6;
      L     DIW [AR2,P#1720.0];
      T     LW   142;
      TAK   ;
      AUF   DB [LW 142];
      L     DID [AR2,P#1722.0];
      LAR1  ;
      TAK   ;
      U      [AR1,P#3.5];
      =     #sbRACKF;
      CLR   ;
      O(    ;
      U     #sbRACKF;
      UN    #QRACKF;
      O     ;
      UN    #sbRACKF;
      U     #QRACKF;
      SPBN  A7f4;
      L     #SUBN1_ID;
      L     B#16#FF;
      ==I   ;
      SPBN  A7f3;
      U     #sbRACKF;
      NOT   ;
      =     #ACC_MODE;
A7f3: CLR   ;
      U     #sbRACKF;
      =     #QRACKF;
      SPA   A7f4;
A7f1: L     #TOP_SI.NUM;
      L     B#16#55;
      ==I   ;
      SPBN  A7f5;
      SET   ;
      =     L      2.4;
      T     LW   142;
      TAK   ;
      AUF   DB [LW 142];
      LAR1  ;
      TAK   ;
      L     W [AR1,P#1550.0];
      UW    W#16#FF;
      T     #GEO_PN.SUBNET;
      L     W [AR1,P#1552.0];
      UW    W#16#FF;
      T     #GEO_PN.RACK;
      L     W [AR1,P#1554.0];
      T     #GEO_PN.SLOT;
      L     W [AR1,P#1556.0];
      T     #GEO_PN.SUBSL_NO;
      L     B [AR1,P#1538.0];
      T     #TOP_SI.EV_CLASS;
      L     D [AR1,P#1546.0];
      T     #ZI2_3;
      SPA   A7f4;
A7f5: L     #TOP_SI.NUM;
      L     B#16#52;
      ==I   ;
      SPBN  A7f6;
      SET   ;
      =     L      2.2;
      T     LW   142;
      TAK   ;
      AUF   DB [LW 142];
      LAR1  ;
      TAK   ;
      L     W [AR1,P#68.0];
      UW    W#16#FF;
      T     #GEO_PN.SUBNET;
      L     W [AR1,P#70.0];
      UW    W#16#FF;
      T     #GEO_PN.RACK;
      L     D [AR1,P#90.0];
      L     DW#16#FFFF0000;
      UD    ;
      SRD   16;
      T     #GEO_PN.SLOT;
      L     D [AR1,P#90.0];
      L     DW#16#FFFF;
      UD    ;
      SLD   16;
      T     #GEO_PN.SUBSL_NO;
      L     D [AR1,P#56.0];
      T     LD    52;
      L     D [AR1,P#60.0];
      T     LD    56;
      L     D [AR1,P#64.0];
      T     #TOP_SI.ZI2_3;
      SPA   A7f4;
A7f6: L     #TOP_SI.NUM;
      L     B#16#56;
      ==I   ;
      SPBN  A7f7;
      SET   ;
      =     L      2.5;
      T     LW   142;
      TAK   ;
      AUF   DB [LW 142];
      LAR1  ;
      TAK   ;
      L     W [AR1,P#1574.0];
      UW    W#16#FF;
      T     #GEO_PN.SUBNET;
      L     W [AR1,P#1576.0];
      UW    W#16#FF;
      T     #GEO_PN.RACK;
      L     D [AR1,P#1562.0];
      T     LD    52;
      L     D [AR1,P#1566.0];
      T     LD    56;
      L     D [AR1,P#1570.0];
      T     #TOP_SI.ZI2_3;
      SPA   A7f4;
A7f7: L     #TOP_SI.NUM;
      L     B#16#53;
      ==I   ;
      SPBN  A7f8;
      SET   ;
      =     L      2.3;
      T     LW   142;
      TAK   ;
      AUF   DB [LW 142];
      LAR1  ;
      TAK   ;
      L     W [AR1,P#1526.0];
      UW    W#16#FF;
      T     #GEO_PN.SUBNET;
      L     W [AR1,P#1528.0];
      UW    W#16#FF;
      T     #GEO_PN.RACK;
      L     W [AR1,P#1530.0];
      T     #GEO_PN.SLOT;
      L     W [AR1,P#1532.0];
      T     #GEO_PN.SUBSL_NO;
      L     D [AR1,P#1514.0];
      T     LD    52;
      L     D [AR1,P#1518.0];
      T     LD    56;
      L     D [AR1,P#1522.0];
      T     #TOP_SI.ZI2_3;
      SPA   A7f4;
A7f8: L     #TOP_SI.NUM;
      L     B#16#64;
      ==I   ;
      SPBN  A7f9;
      SET   ;
      =     L      2.7;
      SPA   A7f4;
A7f9: L     #TOP_SI.NUM;
      L     B#16#46;
      ==I   ;
      SPBN  A7fa;
      SET   ;
      =     L      2.0;
      T     LW   142;
      TAK   ;
      AUF   DB [LW 142];
      LAR1  ;
      TAK   ;
      L     W [AR1,P#48.0];
      UW    W#16#FF;
      T     #GEO_PN.SUBNET;
      L     W [AR1,P#50.0];
      UW    W#16#FF;
      T     #GEO_PN.RACK;
      L     D [AR1,P#36.0];
      T     LD    52;
      L     D [AR1,P#40.0];
      T     LD    56;
      L     D [AR1,P#44.0];
      T     #TOP_SI.ZI2_3;
      SPA   A7f4;
A7fa: L     #TOP_SI.NUM;
      L     B#16#48;
      ==I   ;
      SPBN  A7f4;
      SET   ;
      =     L      2.1;
      SPA   A7f4;
A7f4: CLR   ;
U     L    140.1;
      SAVE  ;
      BE    ;
END_FUNCTION_BLOCK
refer to this original code:
Show
Scl_ResetOptions ;
Scl_OverwriteBlocks         :=  'y' ;
Scl_GenerateReferenceData   :=  'y' ;
Scl_S7ServerActive          :=  'y' ;
Scl_CreateObjectCode        :=  'y' ;
Scl_OptimizeObjectCode      :=  'y' ;
Scl_MonitorArrayLimits      :=  'n' ;
Scl_CreateDebugInfo         :=  'n' ;
Scl_SetOKFlag               :=  'n' ;
Scl_SetMaximumStringLength  :=  '254'
//  project name:
//  file name   :   FB 1869
//  library     :   Advanced Prozess Library    V7.1
//  system      :   PCS7
//  version     :   06.00.00
//  application :   @System
//  restrictions:
//  requirements:   Mit der CFC-Funktion "Baugruppentreiber erzeugen" wird Folgendes automatisch ausgefuhrt:
//                  -   Der Baustein wird in der Ablaufreihenfolge hinter dem RACK-Baustein eingebaut.
//                  -   Der Eingang SLOT_NO (Steckplatznummer der Stromversorgung) wird parametriert.
//                  -   Der Eingang EN wird mit dem Ausgang eines AND-Bausteins verschaltet.
//                      Dessen Eingange werden mit dem Ausgang EN_SUBx des OB_BEGIN-Bausteins, dem
//                      Ausgang EN_Rxxx des SUBNET-Bausteins und dem Ausgang EN_Mxx des RACKBausteins
//                      verschaltet.
//                  -   Die OUT-Strukturen CPU_DIAG des OB_BEGIN-Bausteins und RAC_DIAG des RACKBausteins
//                      werden mit den gleichnamigen IN_OUT-Strukturen des PS-Bausteins verschaltet.
//  search items:
//  functionality:  Der Baustein PS überwacht den Zustand einer Stromversorgung eines Baugruppenträgers
//                  und meldet die zugehörigen Fehlerereignisse.
//  change log table:
//  version   date          expert in charge        changes applied
//  8.7       17.07.2017    comatic                 - created -
//  8.7       24.07.2017    DLM                     - commented -
FUNCTION_BLOCK "A_MOD_D8_PN"
TITLE = 'PN Diagnostic Module Check (0 - 7 Channel)'
AUTHOR : DRIVER90
FAMILY : '@SYSTEM'
VERSION : '9.0'
VAR_INPUT
    LADDR { S7_link := 'false' }: INT ;    //Logical Address of Module
    LADDR1 { S7_link := 'false' }: INT ;    //Logical Address of Module
    SUBN_TYP { S7_link := 'false' }: BOOL ;    //1=External PN-Interface
    SUBN1_ID { S7_link := 'false' }: BYTE  := B#16#FF;    //ID of Primary Subnet
    SUBN2_ID { S7_link := 'false' }: BYTE  := B#16#FF;    //ID of Redundant Subnet
    RACK_NO { S7_link := 'false' }: BYTE ;    //Rack Number
    SLOT_NO { S7_link := 'false' }: BYTE ;    //Slot Number
    SUBSL_NO { S7_link := 'false' }: BYTE ;    //Subslot Number
    CHAN_NUM { S7_link := 'false' }: INT ;    //Highest Channel Address
    MODE_00 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Mode Channel 0
    MODE_01 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Mode Channel 1
    MODE_02 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Mode Channel 2
    MODE_03 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Mode Channel 3
    MODE_04 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Mode Channel 4
    MODE_05 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Mode Channel 5
    MODE_06 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Mode Channel 6
    MODE_07 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Mode Channel 7
    DELAY1 { S7_visible := 'false'; S7_link := 'false' }: INT  := 2;    //Alarm Delay 1 (s)
    DELAY2 { S7_visible := 'false'; S7_link := 'false' }: INT  := 2;    //Alarm Delay 2 (s)
    FEATURE_01 { S7_visible := 'false'; S7_link := 'false' }: WORD ;    //Features of Hardware Paramter 01
    FEATURE_02 { S7_visible := 'false'; S7_link := 'false' }: WORD ;    //Features of Hardware Paramter 02
    FEATURE_03 { S7_visible := 'false'; S7_link := 'false' }: WORD ;    //Features of Hardware Paramter 03
    FEATURE_04 { S7_visible := 'false'; S7_link := 'false' }: WORD ;    //Features of Hardware Paramter 04
    FEATURE_05 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Features of Hardware Paramter 05
    FEATURE_06 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Features of Hardware Paramter 06
    FEATURE_07 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Features of Hardware Paramter 07
    FEATURE_08 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Features of Hardware Paramter 08
    FEATURE_09 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Features of Hardware Paramter 09
    FEATURE_10 { S7_visible := 'false'; S7_link := 'false' }: DWORD ;    //Features of Hardware Paramter 10
    EV_ID1 { S7_visible := 'false'; S7_link := 'false'; S7_param := 'false'; S7_server := 'alarm_archiv'; S7_a_type := 'alarm_8p' }: DWORD ;    //Event ID 1
    EV_ID2 { S7_visible := 'false'; S7_link := 'false'; S7_param := 'false'; S7_server := 'alarm_archiv'; S7_a_type := 'alarm_8p' }: DWORD ;    //Event ID 2
    EN_MSG { S7_visible := 'false'; S7_link := 'false' }: BOOL  := TRUE;    //1=Enable Alarm
    MS { S7_link := 'false'; S7_m_c := 'true' }: DWORD ;    //Maintenance State
    MS_REQ { S7_link := 'false'; S7_m_c := 'true' }: BOOL ;    //Maintenance Release Request
    DIAG_BUF { S7_visible := 'false' }: BOOL ;    //1= CPU Diagnostic Buffer entry on  (relevant for service personnel)
END_VAR
VAR_OUTPUT
    QERR { S7_visible := 'false'; S7_dynamic := 'true' }: BOOL  := TRUE;    //1=Runtime Error
    QRACKF { S7_dynamic := 'true' }: BOOL ;    //1 = higher-level error
    QMODF { S7_dynamic := 'true' }: BOOL ;    //1=Module Removed / Out of Order
    QPERAF { S7_dynamic := 'true' }: BOOL ;    //1=Module I/O Access Failure
    O_MS { S7_visible := 'false' }: DWORD ;    //Maintenance State
    CH_EXIST    {   S7_visible  := 'false';
                    S7_m_c      := 'true'                       }   :   DWORD;                  // Channel exist
    CH_EXIST_byte     AT CH_EXIST                                   :   ARRAY[0..3] OF BYTE;
    CH_ACTIVE   {   S7_visible  := 'false';
                    S7_m_c      := 'true'                       }   :   DWORD;                  // Channel active
    CH_ACTIVE_byte    AT CH_ACTIVE                                  :   ARRAY[0..3] OF BYTE;
    CH_OK       {   S7_visible  := 'false';
                    S7_m_c      := 'true'                       }   :   DWORD;                  // Channel OK
    CH_OK_byte        AT CH_OK                                      :   ARRAY[0..3] OF BYTE;
    EXT_STAT    {   S7_visible  := 'true';
                    S7_m_c      := 'true'                       }   :   DWORD;                  // Maintenance Release - Extended Status
    EXT_STAT_byte     AT EXT_STAT                                   :   ARRAY[0..3] OF BYTE;
  EXT_STAT_A { S7_visible := 'true'; S7_m_c := 'true' }: DWORD ;    //Extended Status - Application
  FS_ACTIVE { S7_visible := 'false'; S7_m_c := 'true' }: DWORD ;    //Flatter supress active
  DM_ACTIVE { S7_visible := 'false'; S7_m_c := 'true' }: DWORD ;    //Delayed messaging active
  OMODE_00 { S7_visible := 'false' }: DWORD ;    //Mode Channel 0
  OMODE_01 { S7_visible := 'false' }: DWORD ;    //Mode Channel 1
  OMODE_02 { S7_visible := 'false' }: DWORD ;    //Mode Channel 2
  OMODE_03 { S7_visible := 'false' }: DWORD ;    //Mode Channel 3
  OMODE_04 { S7_visible := 'false' }: DWORD ;    //Mode Channel 4
  OMODE_05 { S7_visible := 'false' }: DWORD ;    //Mode Channel 5
  OMODE_06 { S7_visible := 'false' }: DWORD ;    //Mode Channel 6
  OMODE_07 { S7_visible := 'false' }: DWORD ;    //Mode Channel 7
  DXCHG_00 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 0
  DXCHG_01 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 1
  DXCHG_02 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 2
  DXCHG_03 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 3
  DXCHG_04 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 4
  DXCHG_05 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 5
  DXCHG_06 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 6
  DXCHG_07 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 7
  DXCHG1_00 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 0
  DXCHG1_01 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 1
  DXCHG1_02 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 2
  DXCHG1_03 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 3
  DXCHG1_04 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 4
  DXCHG1_05 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 5
  DXCHG1_06 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 6
  DXCHG1_07 { S7_visible := 'false' }: DWORD ;    //Bidirectional data exchange Channel 7
  MS_XCHG_00 { S7_visible := 'false' }: DWORD ;    //MS exchange Channel 0
  MS_XCHG_01 { S7_visible := 'false' }: DWORD ;    //MS exchange Channel 1
  MS_XCHG_02 { S7_visible := 'false' }: DWORD ;    //MS exchange Channel 2
  MS_XCHG_03 { S7_visible := 'false' }: DWORD ;    //MS exchange Channel 3
  MS_XCHG_04 { S7_visible := 'false' }: DWORD ;    //MS exchange Channel 4
  MS_XCHG_05 { S7_visible := 'false' }: DWORD ;    //MS exchange Channel 5
  MS_XCHG_06 { S7_visible := 'false' }: DWORD ;    //MS exchange Channel 6
  MS_XCHG_07 { S7_visible := 'false' }: DWORD ;    //MS exchange Channel 7
  MSGSTAT1 { S7_visible := 'false' }: WORD ;    //Message Failure 1
  MSGSTAT2 { S7_visible := 'false' }: WORD ;    //Message Failure 2
  MSG_ACK1 { S7_visible := 'false' }: WORD ;    //Message Acknowledged 1
  MSG_ACK2 { S7_visible := 'false' }: WORD ;    //Message Acknowledged 2
  MOD_INF { S7_visible := 'false' }: STRUCT
   SUBN_ID : BYTE ;    //Subnet Number
   RACK_NO : BYTE ;    //Rack Number
   SLOT_NO : BYTE ;    //Slot Number
   SUBSL_NO : BYTE ;    //Subslot Number
   BASADR : WORD ;    //Base Address
   EXPECTYP : WORD ;    //Expected Module Type
   ACTTYP : WORD ;    //Actual Module Type
   RESERVE : WORD ;    //Reserved
   IOSTAT : BYTE ;    //Data ID of Logical Address
   IOSTAT_0 : BOOL ;    //1=Module Fault
   IOSTAT_1 : BOOL ;    //1=Module Exists
   IOSTAT_2 : BOOL ;    //1=Module Removed
   IOSTAT_3 : BOOL ;    //Reserved
   IOSTAT_4 : BOOL ;    //Reserved
   IOSTAT_5 : BOOL ;    //1=Module can be  Host for Submodule
   IOSTAT_6 : BOOL ;    //Reserved for S7-400
   IOSTAT_7 : BOOL ;    //1=Module on Local  Bus Segment
   AREA_ID : WORD ;    //Area ID
  END_STRUCT ;
  DIAG_INF { S7_visible := 'false' }    : "DIAG_INF" ;
  DIAG_INF_AR AT DIAG_INF   :   ARRAY[0..1431] OF BYTE;
  GET_DIAG_AR AT DIAG_INF   :   STRUCT
    HEADER_INFO     :   ARRAY[0..12] OF WORD;
    ALARM_INFO      :   ARRAY[0..702] OF WORD;
END_STRUCT;
END_VAR
VAR_IN_OUT
    CPU_DIAG_PN                     :   "CPU_DIAG_PN" ;
    RAC_DIAG                        :   "RAC_DIAG" ;
    CPU_DIAG_PN_AR AT CPU_DIAG_PN   :   ARRAY[0..1423] OF BYTE;
    ACC_MODE { S7_link := 'false' } :   BOOL ;    //1=Accept New Mode Settings
END_VAR
VAR
  sdwRESERVE1 : DWORD ;    //Reserve für zukünftige Änderungen
  sdwRESERVE2 : DWORD ;    //Reserve für zukünftige Änderungen
  sdwRESERVE3 : DWORD ;    //Reserve für zukünftige Änderungen
  sdwRESERVE4 : DWORD ;    //Reserve für zukünftige Änderungen
  sdwRESERVE5 : DWORD ;    //Reserve für zukünftige Änderungen
  sdwRESERVE6 : DWORD ;    //Reserve für zukünftige Änderungen
  sdwRESERVE7 : DWORD ;    //Reserve für zukünftige Änderungen
  sdwRESERVE8 : DWORD ;    //Reserve für zukünftige Änderungen
  sdwRESERVE9 : DWORD ;    //Reserve für zukünftige Änderungen
  sdwRESERVE10 : DWORD ;    //Reserve für zukünftige Änderungen
  swHART_DIAG_RALRM : WORD ;
  swHART_DIAG_RDREC : WORD ;
  LADDR_BASIS : INT ;    //Basisadresse der Baugruppe wird aus LADDR und LADDR1 bestimmt
  siBeginChannelType : INT ;    //wird benötigt für weitere Kanaltypen
  siBeginChannelDiag : INT ;    //wird benötigt für weitere Kanaltypen
  sbFurtherChannelType : BOOL ;    //wird benötigt für weitere Kanaltypen
  sbFurtherChannelTypeSC : BOOL ;    //weiterer Kanaltyp aber gleiche Kanäle wie der vorhergehende Kanaltyp
  sbOB83CheckFWUpdate : BOOL ;    //Bei spez. Hart Baugruppen muß wegen mögl.FW Update bei gehendem OB83 Dignose im
  sbyChannelType : BYTE ;    //wird benötigt für weitere Kanaltypen
  sbyDiagnosticBitsPerChn : BYTE ;    //wird benötigt für weitere Kanaltypen
  sbyNumberOfChn : BYTE ;    //wird benötigt für weitere Kanaltypen
  sbyChnVector1 : BYTE ;    //wird benötigt für weitere Kanaltypen
  sbyChnVector2 : BYTE ;    //wird benötigt für weitere Kanaltypen
  sbyChnVector3 : BYTE ;    //wird benötigt für weitere Kanaltypen
  OB82_CNT : INT ;    //OB82 Aufrufzähler
  LOCK_82_TM : DINT ;    //Wartezeit OB82
   IOTYP : BYTE  := B#16#FF;    //Ein- oder Ausgabemodul
   BG300 : BOOL ;    //1: S7-300 - Modul 16 Bit
   HART : BOOL ;    //1: HART - Modul
   CHECK : BOOL ;    //Konfiguration OK?
  END_STRUCT ;
  RQ : STRUCT
   PARA : BOOL ;    //Parametrierung angefordert / läuft
   DIAG : BOOL ;    //Diagnose angefordert / läuft
   CHRS : BOOL ;    //Kanalfehler löschen
   OB1PARA : BOOL ;    //OB1 liest Parametrierung
   OB1DIAG : BOOL ;    //OB1 liest Diagnosedaten
   PRIO28 : BOOL ;    //Unterbrechung mit PRIO 28
   OB1INT : BOOL ;    //OB1 während Parametrierung oder Diagnose unterbrochen?
  END_STRUCT ;
  MODF : STRUCT
   BG : BOOL ;    //Baugruppenfehler
   ZS : BOOL ;    //Baugruppe gezogen
   ZSMEL : BOOL ;    //Baugruppe gezogen melden // 2.8.2001 SCH
   FBG : BOOL ;    //Falsche Bauruppe         //2.8.2001 SCH
   ACC : BOOL ;    //Peripheriezugriffsfehler
   X1 : BOOL ;    //Maintenance Demand/ uncertain
   X2 : BOOL ;    //reserve Alarm8p Signal 8
  END_STRUCT ;
  MODF_MESG : STRUCT
  END_STRUCT ;
  sMODF_MESG : STRUCT
  END_STRUCT ;
  T_CH2 : ARRAY  [0 .. 7 ] OF //Kanalfehlertext alarm8p 2
  INT ;    //Kanalfehlertext alarm8p 2
  TX_NR : ARRAY  [0 .. 31 ] OF //Fehlertext_Nummer
  INT  := 1, 2, 3, 4, 5, 6, 7, 8;    //Fehlertext_Nummer
  siDiagBit : INT  := 7;    //Anzahl der ausgewerteten Diagnose Bits
  sdwDiagBitAllocation : DWORD ;    //Diagnosebits des Kanals in einem DWORD
  T_BG_ZS : INT ;    //Ziehen Stecken Fehlertextnummer  4.5 Schultz
  T_BG_F : INT ;    //Baugruppenfehler Fehlertextnummer  4.5 Schultz
  CH_VECT : BYTE ;    //Kanalfehlervektor 1 und 2
  CH_VECT_MESG : BYTE ;    //Kanalfehlervektor 1
  sCH_VECT : BYTE ;
  sbCH_VECT_MESG1 : BYTE ;    //letztes Kanalfehlervektor 1
  sbCH_VECT_MESG2 : BYTE ;    //letztes Kanalfehlervektor 2
  DEL_CNT_MESG : ARRAY  [0 .. 7 ] OF //Verzögerung (ms)
  DINT ;    //Verzögerung (ms)
  DEL_TIM_MESG : ARRAY  [0 .. 7 ] OF //Verzögerung (ms)
  DEL_ACT_MESG : ARRAY  [0 .. 7 ] OF BOOL ;
  DEL_CNT_MESG_MODF_ZSMEL : DINT ;
  DEL_CNT_MESG_MODF_BG : DINT ;
  DEL_CNT_MESG_MODF_FBG : DINT ;
  DEL_CNT_MESG_MODF_X1 : DINT ;
  DEL_TIM_MESG_MODF_ZSMEL : DINT ;
  DEL_TIM_MESG_MODF_BG : DINT ;
  DEL_TIM_MESG_MODF_FBG : DINT ;
  DEL_TIM_MESG_MODF_X1 : DINT ;
  DEL_ACT_MESG_MODF_ZSMEL : BOOL ;
  DEL_ACT_MESG_MODF_BG : BOOL ;
  DEL_ACT_MESG_MODF_FBG : BOOL ;
  DEL_ACT_MESG_MODF_X1 : BOOL ;
  DEL_CNT_MESG_MaintAlarm : DINT ;
  DEL_CNT_MESG_MaintWarn : DINT ;
  DEL_CNT_MESG_MaintReqst : DINT ;
  DEL_TIM_MESG_MaintAlarm : DINT ;
  DEL_TIM_MESG_MaintWarn : DINT ;
  DEL_TIM_MESG_MaintReqst : DINT ;
  DEL_ACT_MESG_MaintAlarm : BOOL ;
  DEL_ACT_MESG_MaintWarn : BOOL ;
  DEL_ACT_MESG_MaintReqst : BOOL ;
  sbCH_VECT1 : BYTE ;    //Kanalfehlervektor 1
  sbMODFZS : BOOL ;    //Letztes gemeldetes ZS-Ereignis
  sbMODFBG : BOOL ;    //Letztes gemeldetes BG-Ereignis
  sbMODFFBG : BOOL ;
  sbMODFX1 : BOOL ;    //Maintenance Demand/ uncertain
  sbMODFX2 : BOOL ;    //reserve Alarm8p Signal 8
  sbPERAF : BOOL ;    //Letztes gemeldetes PERAF-Ereignis
  OB82_SP : BOOL ;    //Meldung OB82 gesperrt
  sbOB82_SP : BOOL ;    //Zustand Meldung OB82 gesperrt
  INI_ALRM1 : BOOL  := TRUE;    //1=ALARM_8P_1 muß initialisiert werden
  INI_ALRM2 : BOOL  := TRUE;    //1=ALARM_8P_2 muß initialisiert werden
  KIR : BOOL ;    //Konfiguration im Run
  KIR_OLD : BOOL ;    //Hilfsmerker Konfiguration im Run
  sbRESTART : BOOL  := TRUE;
  DEL_ACT : BOOL ;    //PERAF wird für übergeordneten Fehler verzögert
  DEL_CNT : DINT ;    //Verzögerung (ms)
  DEL_TIM : DINT ;    //Start der Verzögerung
  DELAY : DINT ;    //Eingestellte Verzögerung
  bFlutterNotSet : BOOL  := TRUE;
  ALARM_8P_1 : "ALARM_8P";    //Multiinstanzierte ALARM_8P
  ALARM_8P_2 : "ALARM_8P";    //Multiinstanzierte ALARM_8P
  RDREC_1 : "RDREC";    //Multiinstanz SFB 52
  sChNummer : INT ;
    sbOB82BeforeOB83 : BOOL ;
    -spam- : BOOL ;
    sbUpdOMODEAftrRckRet : BOOL ;
    sbMaintAlarm : BOOL ;
    sbMaintWarn : BOOL ;
    sbMaintReqst : BOOL ;
    sbMaintAlarm_old : BOOL ;
    sbMaintWarn_old : BOOL ;
    sbMaintReqst_old : BOOL ;
    sbMaintAlarm_MESG : BOOL ;
    sbMaintWarn_MESG : BOOL ;
    sbMaintReqst_MESG : BOOL ;
    sbMaintAlarm_MESG_old : BOOL ;
    sbMaintWarn_MESG_old : BOOL ;
    sbMaintReqst_MESG_old : BOOL ;
    sbIoModNotRed : BOOL ;
    sbHwFwDiff : BOOL ;
    sbIoModNotRed_old : BOOL ;
    sbHwFwDiff_old : BOOL ;
END_VAR
VAR_TEMP
  EN_OUTP : BOOL ;    //Ausgänge freigeben
  EN_ALRM : BOOL ;    //Alarm_8P freigeben
  sbRACKF : BOOL ;    //Rackfehler
    OB_START                                                            :   WORD;
    OBSTART    AT      OB_START                                         :   STRUCT
        OB_70                                                               :   BOOL;       // Ablauf im OB70 Peripherie-Redundanzfehler
        OB_72                                                               :   BOOL;       // Ablauf im OB72 CPU-Redundanzfehler
        OB_82                                                               :   BOOL;       // Ablauf im OB82 Dianose-Interrupt
        OB_83                                                               :   BOOL;       // Ablauf im OB83 Ziehen- Stecken Alarm
        OB_85                                                               :   BOOL;       // Ablauf im OB85 Zeitablauf Fehler
        OB_86                                                               :   BOOL;       // Ablauf im OB86 PN-IO Stationsausfall
        OB_1        :   BOOL;       // Ablauf im OB1 Cyclical Prog
        OB_100                                                              :   BOOL;       // Ablauf im OB100 Restart
        OB_3x                                                               :   BOOL;       // Ablauf im OB30 bis OB38
        OB_NP                                                               :   BOOL;       // Ablauf im NP - Organization Block not provided
        OB_80                                                               :   BOOL;       // Ablauf im OB80 Zykluszeitüberschreitung
        OB_81                                                               :   BOOL;       // Ablauf im OB81
    END_STRUCT;
  CHANNELS : INT ;    //Kanalanzahl der Baugruppe
  CHANNELS_OFFSET : INT ;    //Kanal Offset bei mehreren Kanaltypen mit weiteren Kanälen
  X : INT ;    //schleifenzähler für Texte für Begleitwerte
  y : INT ;    //temp Integer
  Z : INT ;    //temp Integer
  SZL_HEADER : STRUCT
   LENTHDR : WORD ;
   N_DR : WORD ;
  END_STRUCT ;
  GEO_PN : STRUCT
   SUBNET : BYTE ;    //SUBNET belegt 1 WORD im Speicher!
   RACK : BYTE ;
   SLOT : WORD ;
   SUBSL_NO : WORD ;
  END_STRUCT ;
  ZI1 : WORD ;
  byQHL : BYTE ;
  byQLL : BYTE ;
  bMBSM : BOOL ;
  bMBFM : BOOL ;
  ZI2_3 : DWORD ;
    ZI2_3_AR AT ZI2_3                                                       :  ARRAY[0..1] OF WORD;
    CH_O        :   DWORD;
    CH_O_bool AT CH_O                                                       :  ARRAY[0..31] OF BOOL;
    CH_O_byte AT CH_O                                                       :  ARRAY[0..3] OF BYTE;
    CH_E        :   DWORD ;
    CH_E_bool AT CH_E                                                       :   ARRAY[0..31] OF BOOL;
    CH_E_byte AT CH_E                                                       :   ARRAY[0..3] OF BYTE;
    CH_A        :   DWORD;
    CH_A_bool AT CH_A                                                       :   ARRAY[0..31] OF BOOL;
    CH_A_byte AT CH_A                                                       :   ARRAY[0..3] OF BYTE;
    EXT_S                                                               :   DWORD ;
    EXT_S_bool AT EXT_S                                                     :   ARRAY[0..31] OF BOOL;
    EXT_S_byte AT EXT_S                                                     :   ARRAY[0..3] OF BYTE;
  TOP_SI : STRUCT
   EV_CLASS : BYTE ;
   EV_NUM : BYTE ;
   PRIORITY : BYTE ;
   NUM : BYTE ;
   TYP2_3 : BYTE ;
   TYP1 : BYTE ;
   ZI1 : WORD ;
   ZI2_3 : DWORD ;
  END_STRUCT ;
  tdwMS_AS : DWORD ;    //Maintenance State AS
  tMS_XCHG : DWORD ;    //Maintenance State AS
  bTmpFlutter : BOOL ;    //BOOL für verrundung der DXCHG_xx 0 bit
  tDXCHG : DWORD ;
  MOD_INF_TEMP : STRUCT
   SUBN_ID_RACK_NO : WORD ;    //bei dezentralem Aufbau mit PROFINET IO: Bit 15 = 1 (PROFINET IO-Kennung), die l
   SLOT_NO_SUBSL_NO : WORD ;    //bei dezentralem Aufbau mit PROFINET IO: Steckplatznummer
  END_STRUCT ;
    tMODE : DWORD ;
    tModfBg : BOOL ;
    intINDEX : INT ;
    tiLen : INT ;
    twHART_OB82 : WORD ;
    twHART_OB1 : WORD ;
    tbHART : BOOL ;
    iRET_VAL : INT ;
    wINFO1 : WORD ;
    dwINFO2 : DWORD ;
    MODF_BG_GONE : BOOL ;
    tbCondMon : BOOL ;
    tdwDXCHG1 : DWORD ;
    tbMaintAlarm : BOOL ;
    tbMaintWarn : BOOL ;
    tbMaintReqst : BOOL ;
    -spam- : BYTE ;
    twTextRef : WORD ;
    twChnNum_OB82 : WORD ;
    twErrStat_OB82 : WORD ;
    twErrTyp_OB82 : WORD ;
    twChnNum_OB1 : WORD ;
    twErrStat_OB1 : WORD ;
    twErrTyp_OB1 : WORD ;
END_VAR
BEGIN
EN_OUTP             := FALSE;
EN_ALRM             := FALSE;
sbRACKF             := FALSE;
// NUM                 := B#16#0;
OB_START            := W#16#0;
RETURN_CODE         := 0;
CHANNELS            := 0;
CHANNELS_OFFSET     := 0;
X                   := 0;
y                   := 0;
Z                   := 0;
SZL_HEADER.LENTHDR  := W#16#0;
SZL_HEADER.N_DR     := W#16#0;
GEO_PN.SUBNET          := B#16#0;
GEO_PN.RACK            := B#16#0;
GEO_PN.SLOT            := B#16#0;
GEO_PN.SUBSL_NO         := B#16#0;
ZI1                 := W#16#0;
byQHL               := B#16#0;
byQLL               := B#16#0;
bMBSM               := 0;
bMBFM               := 0;
ZI2_3               := DW#16#0;
CH_O                := DW#16#0;
CH_E                := DW#16#0;
CH_A                := DW#16#0;
EXT_S               := DW#16#0;
TOP_SI.EV_CLASS     := B#16#0;
TOP_SI.EV_NUM       := B#16#0;
TOP_SI.PRIORITY     := B#16#0;
TOP_SI.NUM          := B#16#0;
TOP_SI.TYP2_3       := B#16#0;
TOP_SI.TYP1         := B#16#0;
TOP_SI.ZI1          := W#16#0;
TOP_SI.ZI2_3        := DW#16#0;
//wQHL                := W#16#0;
//wQLL                := W#16#0;
tdwMS_AS                        := W#16#0;
tMS_XCHG                        := W#16#0;
bTmpDXCHG                       := FALSE;
bTmpFlutter                     := FALSE;
tDXCHG                          := FALSE;
MOD_INF_TEMP.SUBN_ID_RACK_NO    :=  W#16#0;
MOD_INF_TEMP.SLOT_NO_SUBSL_NO   :=  W#16#0;
MOD_INF_TEMP.BASADR             :=  W#16#0;
MOD_INF_TEMP.EXPECTYP           :=  W#16#0;
MOD_INF_TEMP.ACTTYP             :=  W#16#0;
MOD_INF_TEMP.RESERVE            :=  W#16#0;
MOD_INF_TEMP.IOSTAT             :=  B#16#0;
MOD_INF_TEMP.IOSTAT_0           :=  FALSE;
MOD_INF_TEMP.IOSTAT_1           :=  FALSE;
MOD_INF_TEMP.IOSTAT_2           :=  FALSE;
MOD_INF_TEMP.IOSTAT_3           :=  FALSE;
MOD_INF_TEMP.IOSTAT_4           :=  FALSE;
MOD_INF_TEMP.IOSTAT_5           :=  FALSE;
MOD_INF_TEMP.IOSTAT_6           :=  FALSE;
MOD_INF_TEMP.IOSTAT_7           :=  FALSE;
MOD_INF_TEMP.AREA_ID            :=  W#16#0;
tMODE                           :=  FALSE;
tModfBg                         :=  FALSE;
intINDEX                        :=  0;
tiLen                           :=  0;
twHART_OB82                     :=  W#16#0;
twHART_OB1                      :=  W#16#0;
tbHART                          :=  FALSE;
iRET_VAL                        :=  0;
wINFO1              :=  W#16#0;
dwINFO2             :=  DW#16#0;
MODF_BG_GONE        :=  FALSE;
//tbCentralOneSideFail    := FALSE;
tbCondMon                   := FALSE;
tdwDXCHG1                   := FALSE;
tbMaintAlarm                := FALSE;
tbMaintWarn                 := FALSE;
tbMaintReqst                := FALSE;
-spam-               := B#16#0;
twTextRef                   := W#16#0;
twChnNum_OB82               := W#16#0;
twErrStat_OB82           := W#16#0;
twErrTyp_OB82           := W#16#0;
twChnNum_OB1            := W#16#0;
twErrStat_OB1           := W#16#0;
twErrTyp_OB1            := W#16#0;
CASE CPU_DIAG_PN.OB_S.NUM_CNT OF
    1 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_01;
    2 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_02;
    3 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_03;
    4 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_04;
    5 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_05;
    6 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_06;
    7 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_07;
    8 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_08;
    9 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_09;
    10 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_10;
    11 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_11;
    12 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_12;
    13 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_13;
    14 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_14;
    15 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_15;
    16 :
        TOP_SI.NUM  :=  CPU_DIAG_PN.OB_S.NUM_16;
ELSE;
END_CASE;
(** Ablauf-OB bestimmen **)
IF TOP_SI.NUM   =   B#16#1 THEN
    (* Bit im Status besetzen *)
    OBSTART.OB_1    :=  TRUE;               //
    (* Sonderbehandlung beim Ablauf im OB1 *)
    sbRACKF             :=  RAC_DIAG.RACK_ERR;
    IF sbRACKF <> QRACKF THEN
        IF SUBN1_ID =   B#16#FF THEN
            ACC_MODE    :=  NOT sbRACKF;
        END_IF;
        QRACKF  :=  sbRACKF;
    END_IF;
ELSIF TOP_SI.NUM    =   B#16#55 THEN
    OBSTART.OB_85    :=  TRUE;
    (* Ablauf im OB85 Programmablauffehler *)
    GEO_PN.SUBNET          :=  WORD_TO_BYTE(CPU_DIAG_PN.OB_85.SUBNET);
    GEO_PN.RACK            :=  WORD_TO_BYTE(CPU_DIAG_PN.OB_85.RACK);
    GEO_PN.SLOT            :=  CPU_DIAG_PN.OB_85.SLOT;
    GEO_PN.SUBSL_NO         := CPU_DIAG_PN.OB_85.SUBSL_NO;
    TOP_SI.EV_CLASS         :=  CPU_DIAG_PN.OB_85.TOP_SI.EV_CLASS;
    ZI2_3                   :=  CPU_DIAG_PN.OB_85.TOP_SI.ZI2_3;
ELSIF TOP_SI.NUM    =   B#16#52 THEN
    OBSTART.OB_82    :=  TRUE;
    (* Ablauf im OB82 Diagnose-Alarm *)
    GEO_PN.SUBNET           :=  WORD_TO_BYTE(CPU_DIAG_PN.OB_82.SUBNET);
    GEO_PN.RACK             :=  WORD_TO_BYTE(CPU_DIAG_PN.OB_82.RACK);
    GEO_PN.SLOT             :=  DWORD_TO_WORD(SHR(IN:=(CPU_DIAG_PN.OB_82.AINFO.SLOT_SUBSLOT_NO AND DW#16#FFFF0000),N:=16));
    GEO_PN.SUBSL_NO         :=  DWORD_TO_WORD(SHL(IN:=(CPU_DIAG_PN.OB_82.AINFO.SLOT_SUBSLOT_NO AND DW#16#FFFF),N:=16));
    TOP_SI                  :=  CPU_DIAG_PN.OB_82.TOP_SI;
    //TOP_SI.ZI2_3            :=  CPU_DIAG_PN.OB_82.TOP_SI.ZI2_3;
ELSIF TOP_SI.NUM    =   B#16#56 THEN
    OBSTART.OB_86    :=  TRUE;
    (* Ablauf im OB86 Baugruppenträgerausfall *)
    GEO_PN.SUBNET          :=  WORD_TO_BYTE(CPU_DIAG_PN.OB_86.SUBNET);
    GEO_PN.RACK            :=  WORD_TO_BYTE(CPU_DIAG_PN.OB_86.RACK);
    TOP_SI                  :=  CPU_DIAG_PN.OB_86.TOP_SI;
    //TOP_SI.ZI2_3            :=  CPU_DIAG_PN.OB_86.TOP_SI.ZI2_3;
ELSIF TOP_SI.NUM    =   B#16#53 THEN
    OBSTART.OB_83    :=  TRUE;
    (* Ablauf im OB83 Ziehen / Stecken Alarm *)
    GEO_PN.SUBNET          :=  WORD_TO_BYTE(CPU_DIAG_PN.OB_83.SUBNET);
    GEO_PN.RACK            :=  WORD_TO_BYTE(CPU_DIAG_PN.OB_83.RACK);
    GEO_PN.SLOT            :=  CPU_DIAG_PN.OB_83.SLOT;
    GEO_PN.SUBSL_NO         :=  CPU_DIAG_PN.OB_83.SUBSL_NO;
    TOP_SI                  :=  CPU_DIAG_PN.OB_83.TOP_SI;
    //TOP_SI.ZI2_3            :=  CPU_DIAG_PN.OB_83.TOP_SI.ZI2_3;
ELSIF TOP_SI.NUM    =   B#16#64 THEN
    OBSTART.OB_100    :=  TRUE;
    (* Ablauf im OB100 *)
ELSIF TOP_SI.NUM    =   B#16#46 THEN
    OBSTART.OB_70    :=  TRUE;
    (* Ablauf im OB70 Peripherie-Redundanzfehler *)
    GEO_PN.SUBNET          :=  WORD_TO_BYTE(CPU_DIAG_PN.OB_70.SUBNET);
    GEO_PN.RACK            :=  WORD_TO_BYTE(CPU_DIAG_PN.OB_70.RACK);
    TOP_SI                  :=  CPU_DIAG_PN.OB_70.TOP_SI;
ELSIF TOP_SI.NUM    =   B#16#48 THEN
    OBSTART.OB_72    :=  TRUE;
    (* Ablauf im OB72 CPU-Redundanzfehler *)
ELSE
END_IF;
There is no system functions calls, no other function calls, no loops, nothing. Only Acces to some call-by-reference values, given by an IN_OUT_VAR. Your programm fail alredy there.
stl2sclSupport
Contact:
Post by stl2sclSupport » Fri Jan 17, 2020 12:56 am
At a minimum, you should create your STL code taking into account the options described by us at the beginning of the topic. This needs to be done because the converter expects absolute addressing. If you do this, "ALARM_8P" will be converted to SFB 35, and will be correctly interpreted by the converter. The same applies to the large file provided here and sent to us by mail. If the recognition is still not correct, write)
SFC6 is supported.
As mentioned above, try to create STL code taking into account the options described by us at the beginning of the topic.
Full list of currently supported SFB and SFC:
Show
SFB00_CTU
SFB01_CTD
SFB02_CTUD
SFB03_TP
SFB04_TON
SFB05_TOF
SFB08_USEND
SFB09_URCV
SFB12_BSEND
SFB13_BRCV
SFB14_GET
SFB15_PUT
SFB16_PRINT
SFB19_START
SFB20_STOP
SFB21_RESUME
SFB22_STATUS
SFB23_USTATUS
SFB29_HS_COUNT
SFB30_FREQ_MES
SFB31_SEND_PTP
SFB33_ALARM
SFB34_ALARM_8
SFB35_ALARM_8P
SFB36_NOTIFY
SFB37_AR_SEND
SFB38_HSC_A_B
SFB39_POS
SFB41_CONT_C
SFB42_CONT_S
SFB52_RDREC
SFB53_WRREC
SFB54_RALRM
SFB73_RCVREC
SFB74_PRVREC
SFC1
SFC13
SFC14
SFC15
SFC17
SFC18
SFC20
SFC21
SFC22
SFC23
SFC24
SFC27
SFC28
SFC29
SFC30
SFC31
SFC5
SFC52
SFC6
SFC64
IN_OUT variables (including structure type variables) are supported. Try to create STL code taking into account the options described by us at the beginning of the topic.
Last edited by stl2sclSupport on Fri Jan 17, 2020 1:29 am, edited 1 time in total.
Draco Malfoy
Post by Draco Malfoy » Fri Jan 17, 2020 6:29 am
You may not understand the sense of a recompiler. I cannot create a STL Code, because the STL Code is generated by the Origin of a closed library, or, for example, the original source file ist lost. I need a recompiler to restore the Source File, or, at least, something similar i.e. nearly identical, but without comments in the file.
Therefore, you recompiler should be able to recognize the options, with witch the original code was created, and then reverse it correctly.
Nevertheless, you was able to recompile the Sample Code i send to you, or not ? Can you post the result here or give me Feedback by Email ? I would like to compare you result with my origin.
I mean, the SFC51 is one of the most important system functions, witch is explicit not supported by yours. It has considerably more relevance in the praxis, than an SFC31, or SFB38, or SFB30.
stl2sclSupport
Contact:
Post by stl2sclSupport » Fri Jan 17, 2020 12:18 pm
Ok, let's say you have an SCL block whose source has been lost. From this block, using the Simatic Manager tools, you can make several different AWL sources using the various settings of Simatic Manager. You can use absolute or symbolic addressing to generate an AWL file. For the converter to work properly, absolute addressing is required. Such a required AWL file can be generated from any previously compiled SCL block.
The above files, including your large file, cannot be converted correctly until you recreate the AWL file using the required settings.
Please check the procedure preparing the file for decompilation.
1. Open the SIMATIC Manager, open your project,
find the block which you want to decompile:
Show
2. Open the block using the STL editor, select Options-> Customize in the upper pane of the editor window. In the window that opens, go to the Sources tab, and check the boxes as in the picture. Then click OK.
settings:
Show
3. Save the open file using the key combination Ctrl + S (or via the menu File-> Save). Warning will appear that the language of the block will be changed. Click Yes.
Spoiler
Show
4. Go to the Sources folder of your project. There you should see the source code generated by you in STL, with the necessary type of addressing.
Spoiler
Show
Well, we plan to expand the list of supported SFB and SFC in the near future
Draco Malfoy
Post by Draco Malfoy » Fri Jan 17, 2020 1:43 pm
Ok, now I know, what you mean. This Option will only change the symbolical names of the called SFCs/SFBs to the absolute names. Lets try again:
https://mega.nz/#!RcNAmIjZ!8dCVX5kKmZS- ... URQRaOqSrI
Can you recompile it with your tool ? Still does not work automatically, may be because of using SFC51 inside of the code.
I have now eliminated the SFC51 Calls from the STL Source, its still not successful. Tried now with different samples, with absolute SFB/SFC Names and without SFC51 Calls. Still no result. Internal Server Error.
One Question:
Such a simple code sequence:
Show
FUNCTION_BLOCK FB 3
AUTHOR : DRIVER90
FAMILY : '@SYSTEM'
VERSION : 9.0
VAR_INPUT
	... SEE ATTACH ...
END_VAR
BEGIN
NETWORK
TITLE =SCL Netzwerk
//generiert vom SCL Übersetzer Version:  SCLCOMP K05.06.00.00_11.01.00.01 release
      SET   ;
      SAVE  ;
      =     L    140.1;
      CLR   ;
      L     #TOP_SI.EV_CLASS;
      L     B#16#39;
      ==I   ;
      U     L      2.2;
      L     #twChnNum_OB82;
      L     W#16#8000;
      UW    ;
      L     W#16#8000;
      =     L    140.2;
      ==I   ;
      L     #twErrTyp_OB82;
      L     W#16#121;
      =     L    140.3;
      ==I   ;
      =     L    140.4;
      U     L      2.2;
      NOT   ;
      L     #twErrTyp_OB1;
      L     W#16#121;
      =     L    140.5;
      ==I   ;
      U     L    140.5;
      O     L    140.4;
      NOT   ;
      U     L    140.3;
      L     DIW [AR2,P#308.0];
      L     W#16#3;
      UW    ;
      L     W#16#3;
      =     L    140.3;
      ==I   ;
      L     #FEATURE_05;
      L     DW#16#241670;
      =     L    140.4;
      ==D   ;
      U     L    140.4;
      O     L    140.3;
      U     L    140.2;
      SPBN  A7d1;
      SET   ;
      =     #MODF.BG;
A7d1 : CLR;
      U     L    140.1;
      SAVE  ;
      BE    ;
END_FUNCTION_BLOCK
your web-demo convert into the following statement:
Show
END_VAR
BEGIN
MODF.BG:=TRUE;
END_FUNCTION_BLOCK
Sorry, but you mean not, there is "something rotten in the state of denmark" ?
Draco Malfoy
Post by Draco Malfoy » Mon Jan 20, 2020 12:44 pm
Dear Sirs,
Should i expect any response from you, or not ?
stl2sclSupport
Contact:
Post by stl2sclSupport » Mon Jan 20, 2020 4:25 pm
1. We updated the online demo version, now all SFB and SFC are supported.
2. For correct operation of the converter, use English mnemonics.
It is set as follows:
Show
3. Our converter translates files of limited complexity. So, for example, only simple indirect addressing options are supported.
The file you are trying to translate contains currently unsupported indirect addressing options.
Draco Malfoy
Post by Draco Malfoy » Mon Jan 20, 2020 6:09 pm
Im Sorry, but what exacley are you mean with "indirect addressing options" ?? Please an Example in the SCL Source.
The File, witch i'm trying to translate ist working only with structured operands, witch are represented by IN_OUT_VAR as a structure / UDT. There is nothing like "DBX.DBDYY" or so.
Its seems in the source in the following manner:
Show
       MODF_BG_GONE    :=
                ((TOP_SI.EV_CLASS = B#16#39 AND OBSTART.OB_82 AND ((twChnNum_OB82 AND W#16#8000) = W#16#8000))
                 AND
                ((twErrStat_OB82 AND W#16#1800) = W#16#1800)
                AND NOT
                (FEATURE_01 = W#16#1) OR MODF_BG_GONE) OR (
                ((TOP_SI.EV_CLASS = B#16#39) AND OBSTART.OB_82) AND ((twChnNum_OB82 AND W#16#8000) = W#16#8000)
                AND
                ((twErrStat_OB82 AND W#16#1800) = W#16#1000) AND ((CPU_DIAG_PN.OB_82.TOP_SI.ZI2_3 AND DW#16#1000000) = DW#16#1000000));
Witch kind of operations from the example above is not supported by your programm ? Anyway, how i should use your programm, if i dont have the exact information aboout witch adressing options was used in the original source ??
So, whats the true ? Supported or not supported ?
Tryed now witch different code sequences and many options, in the english mnemonics. Your shit still does not work. I have no idea, how to use your programm, in order to help me by reversing of Blocks. I see actually no one single benefit from it.
stl2sclSupport
Contact:
Post by stl2sclSupport » Wed Jan 22, 2020 3:49 pm
Surely you have several files for conversion. Send us a few of them that are minimal in terms of the amount of clean code (here, by clean code we mean code without a var section).
Draco Malfoy
Post by Draco Malfoy » Wed Jan 22, 2020 6:31 pm
Yes, i have. Should i send it by Email or upload here on mega ?
stl2sclSupport
Contact:
Post by stl2sclSupport » Thu Jan 23, 2020 1:47 am
Regarding your files, we suggest continuing the dialogue by e-mail.
Draco Malfoy
Post by Draco Malfoy » Thu Jan 23, 2020 4:50 pm
Is there any relationship to this chinese project ?
https://github.com/bssthu/stl2scl/blob/ ... convert.py
stl2sclSupport
Contact:
Post by stl2sclSupport » Thu Jan 23, 2020 5:47 pm
No, we are in no way associated with the mentioned project.
