[?]: Cable PG631 AS501 for S5 130K / CPU921
robj
Post by robj » Thu Aug 22, 2019 8:31 pm
I'm working on a machine tool with a 130K / CPU921 setup and need to get a programmer connected in for faultfinding and maintenance.
Does anyone have a pinout for the cable to use with these, or is it just straight through pin-to-pin?
I have bought a PG631 and an AS501 card and would like to have the 50 way cable made up ready to test things when they arrive - but I cannot find any information whatsoever on the pinouts of the connectors on the PG or 6ES5501 card.
I *think* the cable would be a 6ES5734-0BD20, but searching that on google shows everything from USB to 9 pin or 25 pin cables...
Any info greatly appreciated!
Rob.
Re: [?]: Cable PG631 AS501 for S5 130K / CPU921
Post by CoMod » Fri Aug 23, 2019 8:17 am
centipede
Post by centipede » Fri Aug 23, 2019 11:25 am
Sorry Admin, but the AS501 is a parallel Interface
Your scheme is the newer TTY Interface
Post by CoMod » Fri Aug 23, 2019 12:12 pm
(sfaq) How do you connect a PG 6xx and a PG 7xx?
https://support.industry.siemens.com/cs/document/217845
(boom) (h)
(boom) (h) [dead] https://support.industry.siemens.com/cs ... 5921-3UA12
:anon: (sfaq) Migration Guide: SIMATIC S5 to SIMATIC S7-1500
https://support.industry.siemens.com/cs ... /105106251
robj
Post by robj » Fri Aug 23, 2019 4:30 pm
thanks for the replies.
Unfortunately this one is the interface that is seems Siemens would rather forget existed... It was only used on the S5-110 and early 130, as far as I can see, then they moved on to a serial interface for diagnostics and monitoring, via the AS511 or built-in PG interfaces.
For this particular PLC, with the programmer connected, the PLC executes directly from the RAM in the programmer rather than the program being loaded in to the PLCs own RAM; the full address and data bus are connected via the cable...
It's from the centre connector on here:
https://i.ebayimg.com/images/g/ZDoAAOSw ... -l1600.jpg
To one of these:
https://www.ebay.co.uk/itm/SIMATIC-S5-P ... 3370255253
I'm guessing it is most likely just pin-to-pin; that's logical but you never know with Siemens gear. If I cannot get any info I'll have to wait until the PG and board arrive and start cross checking power and signal connections.
robj
Post by robj » Fri Aug 23, 2019 6:13 pm
For clarification, this is the newer CPU921 used in the 135 series, a 6ES5921-3xxxx - similar to the one in the Siemens page link, with a built-in PG interface:
https://i.ebayimg.com/images/g/oUIAAOSw ... -l1600.jpg
But this is the type I'm working with, one which was used in the basic 130 series, a 6ES5921-1AA21
https://www.ebay.co.uk/itm/Simatic-S5-C ... 2714062189
It's not compatible with an AS511 card, having that in just completely locks up the PLC and it does nothing; it has to be the oddball 501 interface.
centipede
Post by centipede » Sun Aug 25, 2019 6:58 am
Yes you are right. AS511 and the Serial Interfaces are different to the AS501.
The AS501 are very old und was used very seldom.
6ES5734-0BD20 is the right cable. But unfortunately i found nothing of information about it.
I have documentation about the 130A and W, but there is no pinout.
Sorry
robj
Post by robj » Wed Aug 28, 2019 7:46 pm
thanks for trying.
I've received the PG630*** Correction, PG631 today; it is complete in its transport case and has the user manuals included, but no 50 way cable unfortunately.
The screen just shows random, junk cycling every so often - as someone has taken the RAM ICs out.
I've found some on ebay, £7 for a set of four (2116 / 6116 type 2K x 8 ).
Luckily all the system EPROMs are still in place.
The user manual does include the pin connections for the ports, including the 50 way link. Once I have the 501 card it should be easy to see if it is a 1:1 cable, I just hope it is, otherwise there is a lot of signal tracing to do!
Does anyone know if Siemens ever released a service manual for the PG631?
RJ.
Edit - PG 631 not 630
I've got the RAM ICs and fitted those, but still not working. Time to get the oscilloscope out!
