Тools, Elcad, Eplan, ...
Alex Pro
Post by Alex Pro » Thu Sep 28, 2023 8:16 pm
Системные требования смотри здесь https://eplan.help/en-us/Infoportal/Con ... s_k_os.htm (h)
Alex Pro
Post by Alex Pro » Thu Sep 28, 2023 8:17 pm
roguebear
Post by roguebear » Fri Sep 29, 2023 1:15 pm
Hi , This URL cannot get....
Alex Pro
Post by Alex Pro » Fri Sep 29, 2023 7:30 pm
Используй VPN, и будет тебе счастье!
leewheel
Post by leewheel » Sat Sep 30, 2023 4:58 am
Thanks!!!
redline147
Post by redline147 » Sat Sep 30, 2023 6:21 am
Hi, I'm also looking for Eplan Fluid 2024. I downloaded it from: https://rutracker.org/forum/viewtopic.php?t=6403899
EPLAN Platform 2024.0.3.21408 (Electric P8+ProPanel ADD-on) 2024.0.3 21408 x64 [22.08.2023, Multi + RUS]
They announced in the post that the folder includes: EPLAN FieldSys, EPLAN Preplanning, EPLAN Fluid, EPLAN Cogineer.
But after I downloaded the folder, the only content I found is:
!CRACK
Download Manager
Electric P8
Electric P8 Add-on
ELM
EPLAN_Harness_proD_2024
License Client
License Client (Win32)
Platform
Platform Add-on
Platform GUI
Pro Panel
Pro Panel Add-on
Services
Setup
Setup Manager
setup.exe
I've tried all the .exe files located in the root folder, but I can't install the desired software: EPLAN FieldSys, EPLAN Preplanning, EPLAN Fluid, EPLAN Cogineer.
If anyone can help us, I would appreciate it.
Thanks, community.
roguebear
Post by roguebear » Sat Sep 30, 2023 12:52 pm
Yes, There hasn't the fuild
roguebear
Post by roguebear » Sat Sep 30, 2023 12:54 pm
download it and install. but there hasn't fuild....Pls help...
Alex Pro
Post by Alex Pro » Mon Oct 02, 2023 4:29 pm
(h) смотри скриншоты лицензий в torente https://rutracker.org/forum/viewtopic.php?t=6403899. Лицензией определяется ПАКЕТ программ работающих в единой оболочке ePlan Platform (он же Eplan Electric Prof), зачем устанавливать для каждой из них свою оболочку? Эти дистрибутивы нужны только если пользователям нужно работать только к одном из них.
Mohamadhdeab
Post by Mohamadhdeab » Sun Oct 08, 2023 6:45 am
So, Does the 2024 version work now? without the need for another software like runasdate
EPLAN2022
Post by EPLAN2022 » Mon Oct 16, 2023 5:51 am
Hello to all friends
Hello Alex Pro
EPLAN 2023 or EPLAN 2024 software does not work properly in the form and Plot frame design part!
Because it cannot perpetuate its history!!!
RUN AS DATE is no perfect!
(sbutton)
YDC001
Post by YDC001 » Wed Oct 18, 2023 1:23 pm
I'm an EPLAN API developer and when I like to debug my API from Visual Studio, I'm getting the error with as message box name "Thermida" and as message "A debugger has been found running in your system. Please, unload it from memory and restart your program".
This error is linked to the EPLAN Patch. When I don't patch the dll and start the Visual Studio debug, the EPLAN license client is starting but says there is a license problem.
When I patch the dll, the "Thermida" message box is show when the EPLAN license client starts.
Starting EPLAN 2024 normally with the patch works fine :)
Please someone who have the knowledge to take a look at this error and can provide a solution? I really would like to debug my created EPLAN APIs.
Kind regards!
Alex Pro
Post by Alex Pro » Thu Oct 19, 2023 3:47 pm
launching an eplan without RunAsDate to see https://rutracker.org/forum/viewtopic.php?t=6403899
6. Before launching the ePlan 2024(23) program, set the system time, or rather the date, forward by 1 year.
7. launch ePlan 2024 (23)
8. after starting eplan, but before opening the project(s), restore the system time.
agnostic
Post by agnostic » Sun Oct 22, 2023 9:42 am
Hi dear friends,
I have made a loader to solve the problem of EPLAN 2024. (pgood) It is enough to use this file to run the EPLAN instead of running the software through the shortcut on the desktop.
This tool first advances the system date by one year. Then it runs the EPLAN 2024.
After EPLAN 2024 is fully executed, it rolls back the year again and calls the time synchronization function in Windows to set the clock precisely.
Note that this tool requires administrator access to run.
I hope chaos363 will solve this problem by editing the "vcruntime140.dll" file fundamentally. Unfortunately, I am a beginner and cannot edit this file.
https://mega.nz/file/hWZnBYAJ#yeNOPnjgh ... 917sbK86QY
***If the antivirus detects it as a virus, put it in the antivirus exception list.***
P.S.
I forgot one thing! First of all, activate the software according to the method that has been mentioned many times in this thread.
Mohamadhdeab
Post by Mohamadhdeab » Sun Oct 22, 2023 7:59 pm
Hello Users,
I have a problem in Eplan 2022
for some reason, the software keeps pasting the same object, even though I have reinstalled it
However, it's totally fine on the same PC but on another User Account
Any Solutions?
Alex Pro
Post by Alex Pro » Sun Oct 22, 2023 8:23 pm
This happens when using one clipboard, it looks like it's "jammed", to clear it, try this:
Go to ePlan Settings/User/Display/General/Clipboard - uncheck all the settings, then when you try to copy and paste something again, delete all the lists in the window that appears. After that, all the buffer settings need to be returned, unless you want to use multiple buffers, sometimes this is also necessary.
Такое бывает при использовании одного буфера обмена, похоже что его "заклинило", для его очистки попробуй так:
Заходишь в Настройки еплана /Пользователь/Отображение/Общие/Буфер обмена - снять все галочки настроек, затем при очередной попытке что либо скопировать и вставить удали все списки в появившемся окне. После чего все настройки буфера нужно вернуть, если только не захочешь использовать несколько буферов обмена, иногда это тоже необходимо.
Mohamadhdeab
Post by Mohamadhdeab » Sun Oct 22, 2023 8:59 pm
Thanks for the answer,
But were I can find this setting Settings/User/General/Clipboard - ?
I Use Windows 11
Alex Pro
Post by Alex Pro » Mon Oct 23, 2023 2:03 pm
No these are ePlan settings
EPLAN2022
Post by EPLAN2022 » Tue Oct 24, 2023 4:55 am
Hello
Thank you very much for sharing the file, but this file does not work properly!
There is a problem with copy and paste mode.
Mohamadhdeab
Post by Mohamadhdeab » Tue Oct 24, 2023 10:44 am
I have reinstalled windows, and it worked, Thanks man!
lucasp016
Post by lucasp016 » Wed Nov 08, 2023 11:12 pm
I have the same problem, I couldn't solve it, after using eplan for a while it causes this problem when pasting the same object forever, it can only be resolved by formatting, however, after formatting when using the program for a few weeks it will cause the same problem again, I'm using Windows 10 and EPLAN 2024.
I also couldn't find these options that the friend mentioned in the comments above, that is, Settings/User/General/Clipboard doesn't exist.
Guys, I just solved the problem without having to format the computer, just follow this tutorial.
https://www.youtube.com/watch?v=E-kGf9aREe4
Alex Pro
Post by Alex Pro » Sun Nov 12, 2023 5:57 pm
Еще раз для (h) непонятливых.
Заходишь в EPLAN Настройки/Пользователь/Отображение/Общие/Буфер обмена
Вот скрин и гугл в помощь.
https://disk.yandex.ru/i/5hc_mmDTRFQXpA
Или флаг в руки и вечная переустановка ОС. (boom)
Juba
Post by Juba » Wed Dec 06, 2023 12:48 pm
Maybe someone could help. I use eplan 2.9 SP1 update14, everything works, but when I connect to epulse I want to import a macro, it says that I don't have a license
roguebear
Post by roguebear » Fri Dec 08, 2023 1:26 pm
Anybody can provide fuild 2024 ???
igbt
Post by igbt » Thu Dec 14, 2023 6:46 pm
Хорошо. Т.е. при установке проги просто так ради забавы мы ставим отдельно electric и panel? :)
Описание: EPLAN Platform x64 2024 0.3.21408
EPLAN_Platform_2024 в составе:
EPLAN Electric P8
EPLAN ProPanel
EPLAN FieldSys
EPLAN Preplanning
EPLAN Fluid
EPLAN Cogineer
...... и т.д. определяется файлом лицензии. Полный перечень, смотри скриншоты.
Как в таком случае имея лицензию скажем на Cogineer с ним работать если его панель не активна?
При этом на оф сайте cogineer - отдельная надстройка.
В е2023 от вас же Cogineer, Fluid и пр - это тоже отдельные установки из setup.
Полагаю в этой ветке нет пользователя, который не был бы вам благодарен за раздачу и я в их числе.
Просто есть непонимание ситуации с е2024 и хочется её прояснить.
Если вам известен алгоритм активации надстроек кроме файла лицензии - прошу его озвучить.
С уважением и признательностью за труды.
Mohamadhdeab
Post by Mohamadhdeab » Mon Jan 01, 2024 7:30 pm
I have this problem with Eplan, it opens but stuck on this screen, though, it opens in another windows User Account
Please help
https://ibb.co/0VfPv3B
s1921707
Post by s1921707 » Sun Jan 21, 2024 8:01 am
EPLAN_FLUID_2024
https://pan.baidu.com/s/16CX69BRleefAAOXugh9uqA
Extracted code:ka33
Also, who can crack EPLAN_ Smart_ Production_ Collection_2024?
EPLAN_Smart_Production_Collection_2024
https://pan.baidu.com/s/1EAyGuTPuUTjy5ze1bhhIxQ
Extracted code:xn5u
gergo58
Post by gergo58 » Sun Jan 21, 2024 9:49 am
Hello guys!
What is the correct way to use the cracked Eplan (2.9/2023) Epulse/Data Portal function?
Create a fake account or use legal? How can you use acces data portal?? Many thanks (pgood)
s1921707
Post by s1921707 » Sat Jan 27, 2024 12:41 am
1. Cracking fehlgeschlagen
2. Ungeeignete Windows-Systemversion
wonderer
Eplan P8 2.7
Post by wonderer » Mon Jan 29, 2024 5:15 pm
On Windows 10 PRO desktop computer, the EPLAN 2.7 works for someone...?!!! HOW????
I have tried to install Eplan 2.7.3.11418 and with ALL the steps in ALL the forums, and I keep receive the message "The License Client was not installed completeley. Please install the program again"!
I've tried with the latest HASPUserSetup (9.15), with HASPUserSetup 8.31.. No success!
1 day ago, the software worked perfectly on my desktop... I've installed on another laptop - worked perfectly...
BUT on my desktop, stop working!
I could found was that the "devcon" doesn't work... I've manually installed multikey... Etc... Etc...
The digital signing drivers - I've disabled... No problem, I can install them...
What is wrong with the procedure?! There is a Windows update messing the install procedure of the Eplan...?!
I don't understand anymore anything regarding...
peewee
Post by peewee » Tue Feb 20, 2024 1:21 pm
Extracted code:xn5u
Unfortunately, I can't download it to check if the vitamin works
If only you could upload it to another platform, e.g. https://wetransfer.com/
s1921707
Post by s1921707 » Thu Feb 22, 2024 12:11 am
https://we.tl/t-qE4p1LqOHM
peewee
Post by peewee » Thu Feb 22, 2024 11:25 am
thanks, I will check and let you know
redline147
Post by redline147 » Thu Feb 22, 2024 12:29 pm
I think Eplan_smart_production_collection doesn't work with the Chaos crack, at least I haven't managed to get it working. The reason is that this software needs to connect with Eplan License Manager on a network, not a single license. Therefore, I haven't been able to make it work. If anyone knows of a method, please comment. Thank you.
peewee
Post by peewee » Fri Feb 23, 2024 2:15 pm
Chaos crack is only for the eplan electric package with the accessories that are included in it (they are integrated with it) such as propanel, fluid, topology etc
elements that are separate products, such as Eplan Smart Production or Harness proD require a different approach
I don't know how Harnes but Smart wiring could be quite easily bypassed
roguebear
Post by roguebear » Mon Mar 04, 2024 10:31 am
how to use smart wiring 2024 ???
peewee
Post by peewee » Thu Mar 07, 2024 8:25 am
smart wiring is a separate (server) program for cabinet installers
it allows the project to be imported from eplan export to facilitate assembly and track progress
roguebear
Post by roguebear » Thu Mar 07, 2024 10:37 am
Tks, I mean. how to pass license verification....
peewee
Post by peewee » Tue Mar 12, 2024 10:46 am
Unfortunately, the Company has changed the licensing system for Smart Production Collectios regarding smarwire
The old methods do not work, Unfortunately, another solution must be found
Zeshan5999
Post by Zeshan5999 » Sun Mar 31, 2024 7:02 pm
I have installed eplan 2023 and data portal tab is not showing up. I am a new user kindly help
heiyeyulanhai
Post by heiyeyulanhai » Fri Apr 05, 2024 3:40 am
HI,can help me to crack the epulse ?
My gmail:heiyeyulanhai@gmail.com
smargana
Post by smargana » Sun Apr 07, 2024 2:50 pm
I think this problem occurs when you change the date (sytem time) into 2025.
Then copy something to Eplan clipbord.
After you switch back to 2024 date then it doesn't do the copy anymore.
Esmigol
Post by Esmigol » Thu Apr 18, 2024 12:08 am
Hello, I get a problem when trying to activate Eplan 2024 with error 210092, does anyone know how I can solve it, I use Windows 11 Insider Pro
dset
Post by dset » Tue Apr 30, 2024 5:57 am
goodmorning where I can find the link for last eplanfluid egain?
many thanks
ork1990
Post by ork1990 » Sat May 04, 2024 1:13 pm
Hey,
Does anyone have the Eplan P8 Electric 2.9 Ultimate license available? I'm a developer, and I'm trying to debug an application with Eplan's Api and I'm receiving a license message.
I can open the normal program, and it is loading the professional license.
Has anyone been through this and know how to solve it?
The_Voice
Post by The_Voice » Sat May 04, 2024 2:21 pm
Hello everyone,
Could you help me with Crack for EPLAN_Electric_P8_2022. I have already downloaded on my PC, but I would like to use also a Crack.
Details for my PC are: Win 10 PRO x64
I'll appreciate for any help from other enthusiasts people here!
P.C.
Link for download EPLAN_Electric_P8_2022 (of course it's getting from the Forum :) )
https://disk.yandex.ru/d/XWXJfL4niLbi-g
Thank you in advance!
The_Voice
The_Voice
Post by The_Voice » Sat May 04, 2024 4:24 pm
Hello again,
I already installed EPLAN_Electric_P8_2022 with Included Patch folder (in my previous topic). The installation finished without any problems.
The problem that I found is connecting with the Language.
After the installation finished and during start up the program the following message appear: "The language resources for en_US have not been installed or licensed. Please install a licensed language."
My question about is: Can somebody can help me - how to install EN language.
I found that during the instillation has a lot of option for different languages, but EN was not possible to choice.
q790198803
Post by q790198803 » Fri May 10, 2024 6:40 am
Can you leave your email and contact information? I have already cracked the data portal
