It is currently Tue Nov 20, 2018 6:52 pm
 Post subject: PLC VIPA problem
PostPosted: Sat Sep 08, 2018 6:16 pm
Im using a VIPA 313SC (313-5BF03) with 2 externals cards:
- 331-1KF01 (AI 8 X 13 bit)
- 332-5HB01 (AO 2 x 12 bit)
and simatic 5.5.
but I cant regonize the cards:
-I already change the bus connectors,
- tried just 1 card per time,
-facotory reset
 Post subject: Re: PLC VIPA problem
PostPosted: Sat Sep 08, 2018 6:29 pm
Right click over modules -> Module Information
Make and put here 2 screenshots.
PostPosted: Sat Sep 08, 2018 8:37 pm
If the system is not working yet , you need to update the firmware of the processor. If the system worked, you need replace busconnection.
PostPosted: Thu Sep 13, 2018 8:03 pm
PostPosted: Thu Sep 13, 2018 8:10 pm
the plc is update, and its work, but dont recongnize the cards, I already change the bus conector, and I tested each busconnector contact, and its ok.
PostPosted: Sat Sep 15, 2018 9:46 pm
1. The processor does not recognize the modules. Try inserting a different version of the module.
2. The processor does not "see" the modules. Try inserting a different type of module.
Users browsing this forum: No registered users and 12 guests
