PLC VIPA problem
другие контроллеры
andregk
PLC VIPA problem
Post by andregk » Sat Sep 08, 2018 3:16 pm
Im using a VIPA 313SC (313-5BF03) with 2 externals cards:
- 331-1KF01 (AI 8 X 13 bit)
- 332-5HB01 (AO 2 x 12 bit)
and simatic 5.5.
but I cant regonize the cards:
-I already change the bus connectors,
- tried just 1 card per time,
-facotory reset
Rex2701
Re: PLC VIPA problem
Post by Rex2701 » Sat Sep 08, 2018 3:29 pm
Right click over modules -> Module Information
Make and put here 2 screenshots.
Post by Dfcz » Sat Sep 08, 2018 5:37 pm
If the system is not working yet , you need to update the firmware of the processor. If the system worked, you need replace busconnection.
andregk
Post by andregk » Thu Sep 13, 2018 5:03 pm
Rex2701 wrote:Right click over modules -> Module Information
andregk
Post by andregk » Thu Sep 13, 2018 5:10 pm
Dfcz wrote:If the system is not working yet , you need to update the firmware of the processor. If the system worked, you need replace busconnection.
the plc is update, and its work, but dont recongnize the cards, I already change the bus conector, and I tested each busconnector contact, and its ok.
Post by Dfcz » Sat Sep 15, 2018 6:46 pm
1. The processor does not recognize the modules. Try inserting a different version of the module.
2. The processor does not "see" the modules. Try inserting a different type of module.
